        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "9tripod-x3568-v4",
                "BOARD_CORE_OR_USERPATCHED": "core",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3568 quad core 2GB-8GB RAM SoC 2 x GBE eMMC USB3 WiFi/BT PCIe SATA NVMe",
                "BOARD_HAS_VIDEO": true,
                "BOARD_MAINTAINERS": [
                    "rbqvq"
                "BOARD_POSSIBLE_BRANCHES": [
                    "current",
                    "edge"
                "BOARD_SUPPORT_LEVEL": "csc",
                "BOARD_TOP_LEVEL_VARS": {
                    "BOARDFAMILY": "rockchip64",
                    "BOARD_MAINTAINER": "rbqvq",
                        "rbqvq"
                    "BOARD_NAME": "9Tripod X3568 v4",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "9tripod-x3568-v4/current",
                    "BOARD_VENDOR": "rockchip",
                    "BOOT_FDT_FILE": "rockchip/rk3568-9tripod-x3568-v4.dtb",
                    "BOOT_LOGO": "desktop",
                    "BOOT_SOC": "rk3568",
                    "FULL_DESKTOP": "yes",
                    "IMAGE_PARTITION_TABLE": "gpt",
                    "INTRODUCED": "2024",
                    "KERNEL_TARGET": "current,edge",
                    "KERNEL_TEST_TARGET": "current",
                    "MODULES": "ledtrig_netdev",
                    "OVERLAY_PREFIX": "rk3568-9tripod-x3568-v4"
            "pipeline": {},
            "target_id": "00000000010000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "current",
                "BUILD_DESKTOP": "yes",
                "BUILD_MINIMAL": "no",
                "DESKTOP_ENVIRONMENT": "xfce",
                "DESKTOP_ENVIRONMENT_CONFIG_NAME": "config_base",
                "RELEASE": "sid",
                "REVISION": "26.05.0-trunk"
        "logs": [
            "warn: Not-installing software-properties-common For distro 'Debian' release 'sid'\\n"
        "out": {
            "APT_MIRROR": "deb.debian.org/debian",
            "ARCH": "arm64",
            "ARCHITECTURE": "arm64",
            "ARMBIAN_ARTIFACTS_TO_HANDLERS_DICT": [
                "@TODO",
                "bash associative arrays aka dictionaries are not supported yet",
                "[armbian-base-files]=\"armbian-base-files\" [armbian-desktop]=\"armbian-desktop\" [armbian-bsp-desktop]=\"armbian-bsp-desktop\" [full_firmware]=\"full_firmware\" [armbian-zsh]=\"armbian-zsh\" [armbian-plymouth-theme]=\"armbian-plymouth-theme\" [fake_ubuntu_advantage_tools]=\"fake_ubuntu_advantage_tools\" [rootfs]=\"rootfs\" [armbian-bsp-cli]=\"armbian-bsp-cli\" [u-boot]=\"uboot\" [uboot]=\"uboot\" [kernel]=\"kernel\" [firmware]=\"firmware\" "
            "ARMBIAN_WILL_BUILD_UBOOT": "yes",
            "ATFPATCHDIR": "atf-rockchip64",
            "ATFSOURCE": "",
            "ATF_COMPILE": "no",
            "ATF_COMPILER": "aarch64-linux-gnu-",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3568_bl31_v1.44.elf",
            "BOARD_TYPE": "csc",
            "BOOTBRANCH": "tag:v2025.10",
            "BOOTCONFIG": "9tripod-x3568-v4-rk3568_defconfig",
            "BOOTDELAY": "0",
            "BOOTDIR": "u-boot",
            "BOOTENV_FILE": "rk35xx.txt",
            "BOOTPATCHDIR": "v2025.10/board_9tripod-x3568-v4",
            "BOOTSCRIPT": "boot-rockchip64.cmd:boot.cmd",
            "BOOTSOURCE": "https://github.com/u-boot/u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2025.10",
            "BOOT_SCENARIO": "spl-blobs",
            "BOOT_SOC_MKIMAGE": "rk3568",
            "CHROOT_CACHE_VERSION": "7",
            "COMPRESS_OUTPUTIMAGE": "sha,img",
            "CONSOLE_AUTOLOGIN": "yes",
            "CONSOLE_CHAR": "UTF-8",
            "CPUMAX": "1992000",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3568_ddr_1560MHz_v1.21.bin",
            "DEBIAN_MIRROR": "deb.debian.org/debian",
            "DEBIAN_SECURITY": "security.debian.org/",
            "DEB_COMPRESS": "none",
            "DEST_LANG": "en_US.UTF-8",
            "DISABLE_IPV6": "true",
            "DISTRIBUTION": "Debian",
            "EXIT_PATCHING_ERROR": "",
            "EXTRAWIFI": "yes",
            "EXTRA_BSP_NAME": "",
            "EXTRA_IMAGE_SUFFIX": "",
            "EXTRA_PACKAGES_IMAGE": [
                "@TODO",
                "bash simple-arrays are not supported yet",
                "[0]=\"chrony\" [1]=\"network-manager\" [2]=\"network-manager-openvpn\" [3]=\"netplan.io\" [4]=\"network-manager-gnome\" [5]=\"network-manager-ssh\" [6]=\"network-manager-vpnc\""
            "EXTRA_PACKAGES_IMAGE_REFS": [
                "@TODO",
                "[0]=\"extension_prepare_config__install_chrony:/armbian/extensions/network/net-chrony.sh:6\" [1]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [2]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [3]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [4]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [5]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [6]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\""
            "EXTRA_ROOTFS_MIB_SIZE": "0",
            "FAST_CREATE_IMAGE": "yes",
            "GHCR_SOURCE": "ghcr.io",
            "GITHUB_SOURCE": "https://github.com",
            "GOVERNOR": "ondemand",
            "HOST": "9tripod-x3568-v4",
            "IMAGE_FILE_ID": "9tripod-x3568-v4_sid_current_6.18.y_xfce_desktop",
            "IMAGE_TYPE": "user-built",
            "INITRD_ARCH": "arm64",
            "KERNELBRANCH": "branch:linux-6.18.y",
            "KERNELPATCHDIR": "archive/rockchip64-6.18",
            "KERNELSOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "KERNEL_COMPILER": "aarch64-linux-gnu-",
            "KERNEL_DRIVERS_SKIP": [
                "@TODO",
            "KERNEL_HAS_WORKING_HEADERS": "yes",
            "KERNEL_IMAGE_TYPE": "Image",
            "KERNEL_INSTALL_TYPE": "install",
            "KERNEL_MAJOR": "6",
            "KERNEL_MAJOR_MINOR": "6.18",
            "KERNEL_PATCH_ARCHIVE_BASE": "rockchip64",
            "KERNEL_SRC_ARCH": "arm64",
            "LANGUAGE": "en_US:en",
            "LINUXCONFIG": "linux-rockchip64-current",
            "LINUXFAMILY": "rockchip64",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__rockchip64__arm64",
            "LOADER_UBOOT_OFFSET": "0x200000",
            "MAINLINE_FIRMWARE_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git",
            "MAINLINE_KERNEL_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "MAINLINE_UBOOT_DIR": "u-boot",
            "MAINLINE_UBOOT_SOURCE": "https://github.com/u-boot/u-boot",
            "MAINTAINER": "John Doe",
            "MAINTAINERMAIL": "john.doe@somewhere.on.planet",
            "MAIN_CMDLINE": "rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles",
            "NAMESERVER": "1.0.0.1",
            "NAME_INITRD": "uInitrd",
            "NAME_KERNEL": "Image",
            "NETWORKING_STACK": "network-manager",
            "OFFSET": "16",
            "OVERLAY_DIR": "/boot/dtb/rockchip/overlay",
            "OVERLAY_PREFIX": "rk3568-9tripod-x3568-v4",
            "PACKAGES_HASHED_STORAGE": "/armbian/output/packages-hashed",
            "PACKAGE_LIST_BOARD": [],
            "PACKAGE_LIST_BOARD_REMOVE": [],
            "PACKAGE_LIST_FAMILY": [
                "ethtool"
            "PACKAGE_LIST_FAMILY_REMOVE": [],
            "PARTITION_TYPE_UUID_ROOT": "B921B045-1DF0-41C3-AF44-4C6F280D3FAE",
            "PLYMOUTH": "yes",
            "QEMU_BINARY": "qemu-aarch64-static",
            "QEMU_CPU": "cortex-a53",
            "REMOVE_PACKAGES": [
                "@TODO",
                "[0]=\"software-properties-common\" [1]=\"software-properties-gtk\" [2]=\"software-properties-common\""
            "REMOVE_PACKAGES_REFS": [
                "@TODO",
                "[0]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [1]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [2]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\""
            "RKBIN_DIR": "/armbian/cache/sources/rkbin-tools",
            "ROCKUSB_BLOB": "rk35/rk356x_spl_loader_v1.21.113.bin",
            "ROOTFS_CACHE_MAX": "200",
            "ROOTFS_TYPE": "ext4",
            "SELECTED_CONFIGURATION": "desktop",
            "SERIALCON": "ttyS2",
            "SHOW_WARNING": "yes",
            "SOURCED_BOARD_CONFIGS_FILENAME_LIST": [
                "/armbian/config/boards/9tripod-x3568-v4.csc"
            "TZDATA": "Etc/UTC",
            "UBOOT_COMPILER": "aarch64-linux-gnu-",
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3568_bl31_v1.44.elf ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3568_ddr_1560MHz_v1.21.bin;;u-boot-rockchip.bin",
            "UBUNTU_MIRROR": "ports.ubuntu.com/",
            "USE_CCACHE": "no",
            "VENDOR": "Armbian-unofficial",
            "VENDORBUGS": "https://armbian.atlassian.net/",
            "VENDORCOLOR": "247;16;0",
            "VENDORDOCS": "https://docs.armbian.com/",
            "VENDORLOGO": "armbian-logo",
            "VENDORPRIVACY": "https://duckduckgo.com/",
            "VENDORSUPPORT": "https://community.armbian.com/",
            "VENDORURL": "https://duckduckgo.com/",
            "WANT_ARTIFACT_ALL_ARRAY": [
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_BASE_FILES",
                "ARMBIAN_ZSH",
                "ARMBIAN_PLYMOUTH_THEME",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ARMBIAN_BSP_DESKTOP",
                "ROOTFS"
            "WANT_ARTIFACT_ALL_NAMES_ARRAY": [
                "uboot",
                "kernel",
                "firmware",
                "armbian-base-files",
                "armbian-zsh",
                "armbian-plymouth-theme",
                "armbian-bsp-cli",
                "armbian-desktop",
                "armbian-bsp-desktop",
                "rootfs"
            "WANT_ARTIFACT_ARMBIAN_BASE_FILES_INPUTS_ARRAY": [
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_BSP_CLI_INPUTS_ARRAY": [
                "'EXTRA_BSP_NAME='",
                "'BRANCH=current'",
                "'BOARD=9tripod-x3568-v4'"
            "WANT_ARTIFACT_ARMBIAN_BSP_DESKTOP_INPUTS_ARRAY": [
                "'BRANCH=current'",
                "'DESKTOP_ENVIRONMENT=xfce'",
                "'DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base'",
                "'BOARD=9tripod-x3568-v4'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_DESKTOP_INPUTS_ARRAY": [
                "'DESKTOP_AGGREGATION_RESULTS=8855c6119660c614d285554e51769066e94fcb75ff215ccc2fa6b4838b18756b'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_PLYMOUTH_THEME_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_ARMBIAN_ZSH_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_FIRMWARE_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_KERNEL_INPUTS_ARRAY": [
                "'LINUXCONFIG=linux-rockchip64-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=rockchip64-current'",
                "'KERNELBRANCH=branch:linux-6.18.y'",
                "'KERNEL_MAJOR_MINOR=6.18'",
                "'KERNELSOURCE=https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rockchip64'",
                "'KERNELPATCHDIR=archive/rockchip64-6.18'"
            "WANT_ARTIFACT_ROOTFS_INPUTS_ARRAY": [
                "'BUILD_MINIMAL=no'",
                "'SELECTED_CONFIGURATION=desktop'",
                "'DESKTOP_APPGROUPS_SELECTED=no_DESKTOP_APPGROUPS_SELECTED_set'",
                "'EXTRA_PKG_ADD_REMOVE_HASH=9484d87e17c18694c6beeb148595dde16586e36948cc22225c4564e1b0cee6fd'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_UBOOT_INPUTS_ARRAY": [
                "'BOOTPATCHDIR=v2025.10/board_9tripod-x3568-v4'",
                "'BOOTSOURCE=https://github.com/u-boot/u-boot.git'",
                "'BOOTBRANCH=tag:v2025.10'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "rbqvq"
                    "current",
                    "edge"
                        "rbqvq"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "9tripod-x3568-v4/edge",
            "pipeline": {},
            "target_id": "00000000020000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "9tripod-x3568-v4_sid_edge_7.0.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-7.0.y",
            "KERNELPATCHDIR": "archive/rockchip64-7.0",
                "@TODO",
            "KERNEL_MAJOR": "7",
            "KERNEL_MAJOR_MINOR": "7.0",
            "LINUXCONFIG": "linux-rockchip64-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__rockchip64__arm64",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rockchip64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=rockchip64-edge'",
                "'KERNELBRANCH=branch:linux-7.0.y'",
                "'KERNEL_MAJOR_MINOR=7.0'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/rockchip64-7.0'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "aml-a311d-cc",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic A311D 2/4GB RAM eMMC GBE USB3",
                    "Tonymac32"
                    "current",
                    "edge"
                "BOARD_SUPPORT_LEVEL": "conf",
                    "BOARDFAMILY": "meson-g12b",
                    "BOARD_MAINTAINER": "Tonymac32",
                        "Tonymac32"
                    "BOARD_NAME": "Alta",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "aml-a311d-cc/current",
                    "BOARD_VENDOR": "libre-computer",
                    "BOOT_FDT_FILE": "amlogic/meson-g12b-a311d-libretech-cc.dtb",
                    "INTRODUCED": "2022",
                    "KERNEL_TEST_TARGET": "edge",
                    "MODULES_BLACKLIST": "simpledrm",
                    "SERIALCON": "ttyAML0"
            "pipeline": {},
            "target_id": "00000000030000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ARMBIAN_WILL_BUILD_UBOOT": "no",
            "ASOUND_STATE": "asound.state.meson64",
            "ATFPATCHDIR": "atf-meson64",
            "AUFS": "yes",
            "BOARD_TYPE": "conf",
            "BOOTBRANCH": "tag:v2022.07",
            "BOOTCONFIG": "none",
            "BOOTENV_FILE": "meson.txt",
            "BOOTPATCHDIR": "v2022.07",
            "BOOTSCRIPT": "boot-meson64.cmd:boot.cmd",
            "BOOTSIZE": "0",
            "BOOTSOURCE": "https://github.com/u-boot/u-boot",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2022.07",
            "CPUMAX": "1536000",
            "CPUMIN": "500000",
            "DISTRO_FIRMWARE_PACKAGES": "",
            "DISTRO_GENERIC_KERNEL": "no",
            "DISTRO_KERNEL_PACKAGES": "",
            "DISTRO_KERNEL_VER": "arm64",
            "EXTRAWIFI": "yes",
            "EXTRA_BSP_NAME": "-grub",
                "@TODO",
                "[0]=\"chrony\" [1]=\"network-manager\" [2]=\"network-manager-openvpn\" [3]=\"netplan.io\" [4]=\"network-manager-gnome\" [5]=\"network-manager-ssh\" [6]=\"network-manager-vpnc\" [7]=\"efibootmgr\" [8]=\"efivar\" [9]=\"cloud-initramfs-growroot\" [10]=\"busybox\" [11]=\"os-prober\" [12]=\"grub-efi-arm64-bin\" [13]=\"grub-efi-arm64\""
                "@TODO",
                "[0]=\"extension_prepare_config__install_chrony:/armbian/extensions/network/net-chrony.sh:6\" [1]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [2]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [3]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [4]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [5]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [6]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [7]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [8]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [9]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [10]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [11]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [12]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [13]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\""
            "GRUB_CMDLINE_LINUX_DEFAULT": "",
            "HOST": "aml-a311d-cc",
            "IMAGE_FILE_ID": "Aml-a311d-cc_sid_current_6.18.y_xfce_desktop",
            "KERNELDIR": "linux-uefi-meson64",
            "KERNELPATCHDIR": "archive/meson64-6.18",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "meson64",
            "LINUXCONFIG": "linux-meson64-current",
            "LINUXFAMILY": "meson64",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__meson64__arm64",
            "OFFSET": "4",
            "OVERLAY_DIR": "/boot/dtb/amlogic/overlay",
            "OVERLAY_PREFIX": "meson",
            "PACKAGE_LIST_FAMILY": [],
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "SERIALCON": "ttyAML0",
                "/armbian/config/boards/aml-a311d-cc.conf"
            "SRC_LOADADDR": "LOADADDR=0x1080000",
            "UBOOT_TARGET_MAP": "u-boot-dtb.img;;u-boot.bin.sd.bin:u-boot.bin u-boot-dtb.img",
            "UEFISIZE": "260",
            "UEFI_ENABLE_BIOS_AMD64": "yes",
            "UEFI_EXPORT_KERNEL_INITRD": "no",
            "UEFI_GRUB_DISABLE_OS_PROBER": "",
            "UEFI_GRUB_DISTRO_NAME": "Armbian",
            "UEFI_GRUB_TARGET": "arm64-efi",
            "UEFI_GRUB_TARGET_BIOS": "",
            "UEFI_GRUB_TERMINAL": "serial console",
            "UEFI_GRUB_TIMEOUT": "0",
            "USE_CCACHE": "no",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'EXTRA_BSP_NAME=-grub'",
                "'BRANCH=current'",
                "'BOARD=aml-a311d-cc'"
                "'BRANCH=current'",
                "'BOARD=aml-a311d-cc'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-meson64-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=meson64-current'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=meson64'",
                "'KERNELPATCHDIR=archive/meson64-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "Tonymac32"
                    "current",
                    "edge"
                        "Tonymac32"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "aml-a311d-cc/edge",
            "pipeline": {},
            "target_id": "00000000040000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTSIZE": "0",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Aml-a311d-cc_sid_edge_7.0.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/meson64-7.0",
                "@TODO",
            "LINUXCONFIG": "linux-meson64-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__meson64__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "UEFISIZE": "260",
            "USE_CCACHE": "no",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-meson64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=meson64-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/meson64-7.0'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "aml-c400-plus",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic S912 octa core 3Gb RAM SoC eMMC",
                    "jomadeto"
                    "current",
                    "edge"
                    "ASOUND_STATE": "asound.state.mesongx",
                    "BOARDFAMILY": "meson-gxl",
                    "BOARD_MAINTAINER": "jomadeto",
                        "jomadeto"
                    "BOARD_NAME": "Magicsee C400 Plus",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "aml-c400-plus/current",
                    "BOARD_VENDOR": "amlogic",
                    "BOOTFS_TYPE": "fat",
                    "BOOTSIZE": "512",
                    "BOOT_FDT_FILE": "amlogic/meson-gxm-c400-plus.dtb",
                    "SRC_CMDLINE": "rootflags=data=writeback console=ttyAML0,115200n8 console=tty0",
                    "SRC_EXTLINUX": "no"
            "pipeline": {},
            "target_id": "00000000050000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTSIZE": "512",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "aml-c400-plus",
            "IMAGE_FILE_ID": "Aml-c400-plus_sid_current_6.18.y_xfce_desktop",
            "IMAGE_PARTITION_TABLE": "msdos",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/aml-c400-plus.conf"
            "SRC_EXTLINUX": "no",
            "USE_CCACHE": "no",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=aml-c400-plus'"
                "'BRANCH=current'",
                "'BOARD=aml-c400-plus'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "jomadeto"
                    "current",
                    "edge"
                        "jomadeto"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "aml-c400-plus/edge",
                    "BOOTSIZE": "512",
            "pipeline": {},
            "target_id": "00000000060000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTSIZE": "512",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Aml-c400-plus_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "aml-s805-mxq",
                "BOARD_FILE_HARDWARE_DESC": "MXQ TV box based on Amlogic S805 quad core 1GB RAM SoC GBE",
                "BOARD_MAINTAINERS": [],
                    "current"
                "BOARD_SUPPORT_LEVEL": "tvb",
                    "BOARDFAMILY": "meson8b",
                    "BOARD_MAINTAINER": "",
                    "BOARD_NAME": "MXQ",
                        "current"
                    "BOARD_SLASH_BRANCH": "aml-s805-mxq/current",
                    "BOOTENV_FILE": "aml-s805-mxq.txt",
                    "BOOTSCRIPT": "boot-aml-s805-mxq.cmd:boot.cmd",
                    "BOOTSCRIPT_OUTPUT": "s805_autoscript",
                    "BOOTSIZE": "200",
                    "INTRODUCED": "2015",
                    "KERNEL_TARGET": "current",
            "pipeline": {},
            "target_id": "00000000070000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
            "ARCHITECTURE": "arm",
                "@TODO",
            "ATFPATCHDIR": "atf-meson",
            "ATF_COMPILE": "yes",
            "AUFS": "yes",
            "BOARD_TYPE": "tvb",
            "BOOTPATCHDIR": "u-boot-meson",
            "BOOTSIZE": "200",
            "CPUMAX": "1632000",
            "CPUMIN": "504000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "aml-s805-mxq",
            "IMAGE_FILE_ID": "Aml-s805-mxq_sid_current_6.12.y_xfce_desktop",
            "INITRD_ARCH": "arm",
            "KERNELBRANCH": "tag:v6.12.28",
            "KERNELPATCHDIR": "archive/meson-6.12",
            "KERNEL_COMPILER": "arm-linux-gnueabihf-",
                "@TODO",
            "KERNEL_IMAGE_TYPE": "uImage",
            "KERNEL_INSTALL_TYPE": "uinstall",
            "KERNEL_MAJOR_MINOR": "6.12",
            "KERNEL_PATCH_ARCHIVE_BASE": "meson",
            "KERNEL_SRC_ARCH": "arm",
            "LINUXCONFIG": "linux-meson-current",
            "LINUXFAMILY": "meson",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.12__meson__armhf",
            "NAME_KERNEL": "uImage",
            "OFFSET": "4",
            "PARTITION_TYPE_UUID_ROOT": "69DAD710-2CE4-4E3C-B16C-21A1D49ABED3",
            "PLYMOUTH": "yes",
            "QEMU_BINARY": "qemu-arm-static",
                "@TODO",
                "@TODO",
            "SKIP_BOOTSPLASH": "yes",
                "/armbian/config/boards/aml-s805-mxq.tvb"
            "SRC_LOADADDR": "LOADADDR=0x00208000",
            "UBOOT_COMPILER": "arm-linux-gnueabihf-",
            "USE_CCACHE": "no",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=aml-s805-mxq'"
                "'BRANCH=current'",
                "'BOARD=aml-s805-mxq'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-meson-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=meson-current'",
                "'KERNELBRANCH=tag:v6.12.28'",
                "'KERNEL_MAJOR_MINOR=6.12'",
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=meson'",
                "'KERNELPATCHDIR=archive/meson-6.12'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "aml-s905d3-cc",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic s905d3 2/4GB RAM eMMC GBE USB3",
                    "Tonymac32"
                    "current",
                    "edge"
                "BOARD_SUPPORT_LEVEL": "wip",
                    "BOARDFAMILY": "meson-sm1",
                        "Tonymac32"
                    "BOARD_NAME": "Libre Computer Solitude",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "aml-s905d3-cc/current",
                    "BOOT_FDT_FILE": "amlogic/meson-sm1-s905d3-libretech-cc.dtb",
                    "INTRODUCED": "2023",
            "pipeline": {},
            "target_id": "00000000080000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOARD_TYPE": "wip",
            "BOOTSIZE": "0",
            "CPUMAX": "2100000",
            "CPUMIN": "667000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "aml-s905d3-cc",
            "IMAGE_FILE_ID": "Aml-s905d3-cc_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/aml-s905d3-cc.wip"
            "UEFISIZE": "260",
            "USE_CCACHE": "no",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=aml-s905d3-cc'"
                "'BRANCH=current'",
                "'BOARD=aml-s905d3-cc'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "Tonymac32"
                    "current",
                    "edge"
                        "Tonymac32"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "aml-s905d3-cc/edge",
            "pipeline": {},
            "target_id": "00000000090000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTSIZE": "0",
            "CPUMIN": "667000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Aml-s905d3-cc_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "UEFISIZE": "260",
            "USE_CCACHE": "no",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "aml-s9xx-box",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic S9xx based TVBox",
                    "SteeManMI"
                    "current",
                    "edge"
                    "BOARD_MAINTAINER": "SteeManMI",
                        "SteeManMI"
                    "BOARD_NAME": "aml-s9xx-box",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "aml-s9xx-box/current",
                    "BOOTSIZE": "512",
                    "BOOT_FDT_FILE": "amlogic/meson-gxl-s905x-p212.dtb",
                    "INTRODUCED": "2016",
                    "SRC_EXTLINUX": "yes"
            "pipeline": {},
            "target_id": "00000000100000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTSIZE": "512",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "aml-s9xx-box",
            "IMAGE_FILE_ID": "Aml-s9xx-box_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/aml-s9xx-box.tvb"
            "SRC_EXTLINUX": "yes",
            "USE_CCACHE": "no",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=aml-s9xx-box'"
                "'BRANCH=current'",
                "'BOARD=aml-s9xx-box'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "SteeManMI"
                    "current",
                    "edge"
                        "SteeManMI"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "aml-s9xx-box/edge",
                    "BOOTSIZE": "512",
            "pipeline": {},
            "target_id": "00000000110000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTSIZE": "512",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Aml-s9xx-box_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "aml-t95z-plus",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic S912 octa core 3Gb RAM SoC eMMC chinese clone",
                    "edge"
                    "BOARDFAMILY": "meson-gxl\"                         # s912",
                    "BOARD_NAME": "T95Z Plus",
                        "edge"
                    "BOARD_SLASH_BRANCH": "aml-t95z-plus/edge",
                    "BOARD_VENDOR": "generic",
                    "BOOTBRANCH_BOARD": "tag:v2024.04",
                    "BOOTCONFIG": "meson-gxm-t95z-plus_defconfig",
                    "BOOTPATCHDIR": "v2024.04/board_t95z\" # This has a 000.patching_config.yaml inside, to avoid null-patching, as only new files are added (defconfig/dts",
                    "BOOT_FDT_FILE": "amlogic/meson-gxm-t95z-plus.dtb\" # From chewitt",
                    "KERNEL_TARGET": "edge",
                    "SRC_CMDLINE": "loglevel=7 splash=verbose console=ttyAML0,115200\" # Those boards are serial-debug only; 'root=LABEL=armbi_root",
            "pipeline": {},
            "target_id": "00000000120000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2024.04",
            "BOOTPATCHDIR": "v2024.04/board_t95z",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2024.04",
            "BOOT_FDT_FILE": "amlogic/meson-gxm-t95z-plus.dtb",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "[0]=\"u-boot-menu\" [1]=\"chrony\" [2]=\"network-manager\" [3]=\"network-manager-openvpn\" [4]=\"netplan.io\" [5]=\"network-manager-gnome\" [6]=\"network-manager-ssh\" [7]=\"network-manager-vpnc\""
                "@TODO",
                "[0]=\"extension_prepare_config__add_uboot_menu_pkg:/armbian/extensions/u-boot-menu.sh:9\" [1]=\"extension_prepare_config__install_chrony:/armbian/extensions/network/net-chrony.sh:6\" [2]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [3]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [4]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [5]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [6]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [7]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\""
            "HOST": "aml-t95z-plus",
            "IMAGE_FILE_ID": "Aml-t95z-plus_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/aml-t95z-plus.tvb"
            "SRC_CMDLINE": "loglevel=7 splash=verbose console=ttyAML0,115200",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=aml-t95z-plus'"
                "'BRANCH=edge'",
                "'BOARD=aml-t95z-plus'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2024.04/board_t95z'",
                "'BOOTSOURCE=https://github.com/u-boot/u-boot'",
                "'BOOTBRANCH=tag:v2024.04'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "arduino-uno-q",
                "BOARD_FILE_HARDWARE_DESC": "Qualcomm QRB2210 4 core 2/4GB RAM SoC USB-C",
                    "edge"
                    "BOARDFAMILY": "qrb2210",
                    "BOARD_NAME": "Arduino UNO Q",
                        "edge"
                    "BOARD_SLASH_BRANCH": "arduino-uno-q/edge",
                    "BOARD_VENDOR": "arduino",
                    "BOOTCONFIG": "qcom_defconfig",
                    "BOOTSIZE": "512",
                    "BOOT_FDT_FILE": "qcom/qrb2210-arduino-imola.dtb",
                    "SERIALCON": "ttyMSM0"
            "pipeline": {},
            "target_id": "00000000130000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
            "ARDUINO_ROOTFS_LOOP": "",
            "ARDUINO_ROOTFS_MOUNT": "",
                "@TODO",
            "ATFPATCHDIR": "atf-qrb2210",
            "AUFS": "yes",
            "BOOTBRANCH": "branch:qcom-mainline",
            "BOOTDELAY": "1",
            "BOOTENV_FILE": "qrb2210.txt",
            "BOOTPATCHDIR": "u-boot-qrb2210",
            "BOOTSCRIPT": "boot-qrb2210.cmd:boot.cmd",
            "BOOTSIZE": "512",
            "BOOTSOURCE": "https://github.com/arduino/u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/qcom-mainline",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "HOST": "arduino-uno-q",
            "IMAGE_FILE_ID": "Arduino-uno-q_sid_edge_7.0.y_xfce_desktop",
            "KERNELBRANCH": "branch:qcom-v7.0.0-unoq",
            "KERNELPATCHDIR": "qrb2210-edge",
            "KERNELSOURCE": "https://github.com/arduino/linux-qcom.git",
            "KERNEL_BTF": "no",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "qrb2210",
            "LINUXCONFIG": "linux-qrb2210-edge",
            "LINUXFAMILY": "qrb2210",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__qrb2210__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
            "QCOMBIN_DIR": "/armbian/cache/sources/qcombin",
                "@TODO",
                "@TODO",
            "SERIALCON": "ttyMSM0",
                "/armbian/config/boards/arduino-uno-q.csc"
            "UBOOT_TARGET_MAP": "DEVICE_TREE=qcom/qrb2210-arduino-imola;;u-boot.bin boot.img",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=arduino-uno-q'"
                "'BRANCH=edge'",
                "'BOARD=arduino-uno-q'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-qrb2210-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=qrb2210-edge'",
                "'KERNELBRANCH=branch:qcom-v7.0.0-unoq'",
                "'KERNELSOURCE=https://github.com/arduino/linux-qcom.git'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=qrb2210'",
                "'KERNELPATCHDIR=qrb2210-edge'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-qrb2210'",
                "'BOOTSOURCE=https://github.com/arduino/u-boot.git'",
                "'BOOTBRANCH=branch:qcom-mainline'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "armsom-aim7-io",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588 SoC octa core 8-32GB SoC 2.5GBe eMMC USB3 NvME",
                    "vendor"
                    "BOARDFAMILY": "rockchip-rk3588",
                    "BOARD_NAME": "ArmSoM AIM7 IO",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-aim7-io/vendor",
                    "BOARD_VENDOR": "armsom",
                    "BOOTCONFIG": "armsom-aim7-io-rk3588_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3588-armsom-aim7-io.dtb",
                    "KERNEL_TARGET": "vendor"
            "pipeline": {},
            "target_id": "00000000140000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
            "warn: Not-installing software-properties-common For distro 'Debian' release 'sid'\\n",
            "[LEAKED]:** No matches found for Bash declare regex (origin: unknown), line ==>declare -i KERNEL_GIT_CACHE_TTL=\"120\"<=="
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-rk35xx",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3588_bl31_v1.48.elf",
            "BOOTBRANCH": "branch:next-dev-v2024.10",
            "BOOTDELAY": "0",
            "BOOTDIR": "u-boot-rockchip64",
            "BOOTPATCHDIR": "legacy/u-boot-radxa-rk35xx",
            "BOOTSCRIPT": "boot-rk35xx.cmd:boot.cmd",
            "BOOTSOURCE": "https://github.com/radxa/u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-rockchip64/next-dev-v2024.10",
            "BOOT_SOC": "rk3588",
            "BOOT_SOC_MKIMAGE": "rk3588",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.18.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "armsom-aim7-io",
            "IMAGE_FILE_ID": "Armsom-aim7-io_sid_vendor_6.1.y_xfce_desktop",
            "KERNELBRANCH": "branch:rk-6.1-rkr5.1",
            "KERNELPATCHDIR": "rk35xx-vendor-6.1",
            "KERNELSOURCE": "https://github.com/armbian/linux-rockchip.git",
                "@TODO",
            "KERNEL_MAJOR_MINOR": "6.1",
            "KERNEL_PATCH_ARCHIVE_BASE": "rk35xx",
            "KERNEL_TARGET": "vendor",
            "LINUXCONFIG": "linux-rk35xx-vendor",
            "LINUXFAMILY": "rk35xx",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.1__rk35xx__arm64",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rockchip-rk3588",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "ROCKUSB_BLOB": "rk35/rk3588_spl_loader_v1.16.113.bin",
            "SERIALCON": "ttyFIQ0",
                "/armbian/config/boards/armsom-aim7-io.csc"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3588_bl31_v1.48.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-aim7-io'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-aim7-io'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rk35xx-vendor'",
                "'ARMBIAN_KERNEL_DEB_NAME=rk35xx-vendor'",
                "'KERNELBRANCH=branch:rk-6.1-rkr5.1'",
                "'KERNEL_MAJOR_MINOR=6.1'",
                "'KERNELSOURCE=https://github.com/armbian/linux-rockchip.git'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rk35xx'",
                "'KERNELPATCHDIR=rk35xx-vendor-6.1'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=legacy/u-boot-radxa-rk35xx'",
                "'BOOTSOURCE=https://github.com/radxa/u-boot.git'",
                "'BOOTBRANCH=branch:next-dev-v2024.10'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "armsom-cm5-io",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3576 SoC octa core 8-64GB SoC GBe eMMC USB3 NvME WIFI",
                    "vendor"
                    "BOARDFAMILY": "rk35xx",
                    "BOARD_NAME": "ArmSoM CM5 IO",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-cm5-io/vendor",
                    "BOOTCONFIG": "armsom-cm5-io-rk3576_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3576-armsom-cm5-io.dtb",
            "pipeline": {},
            "target_id": "00000000150000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3576_bl31_v1.20.elf",
            "BOOTDELAY": "0",
            "BOOTENV_FILE": "rockchip64.txt",
            "BOOTSCRIPT": "boot-rk3576.cmd:boot.cmd",
            "BOOT_SOC": "rk3576",
            "BOOT_SOC_MKIMAGE": "rk3576",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3576_ddr_lp4_2112MHz_lp5_2736MHz_v1.08.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "armsom-cm5-io",
            "IMAGE_FILE_ID": "Armsom-cm5-io_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rk35xx",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/armsom-cm5-io.csc"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3576_bl31_v1.20.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-cm5-io'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-cm5-io'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "armsom-cm5-rpi-cm4-io",
                    "vendor"
                    "BOARD_NAME": "ArmSoM CM5 CM4 IO",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-cm5-rpi-cm4-io/vendor",
                    "BOOTCONFIG": "armsom-cm5-rpi-cm4-io-rk3576_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3576-armsom-cm5-rpi-cm4-io.dtb",
            "pipeline": {},
            "target_id": "00000000160000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "armsom-cm5-rpi-cm4-io",
            "IMAGE_FILE_ID": "Armsom-cm5-rpi-cm4-io_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/armsom-cm5-rpi-cm4-io.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-cm5-rpi-cm4-io'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-cm5-rpi-cm4-io'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "armsom-forge1",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3506J triple core 512MB SoC 2x100MBe NAND USB2",
                    "amazingfate"
                    "vendor"
                    "BOARDFAMILY": "rockchip",
                    "BOARD_MAINTAINER": "amazingfate",
                        "amazingfate"
                    "BOARD_NAME": "ArmSoM Forge1",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-forge1/vendor",
                    "BOOTCONFIG": "forge1-rk3506b_defconfig",
                    "BOOT_FDT_FILE": "rk3506b-armsom-forge1.dtb",
                    "BOOT_SOC": "rk3506",
                    "DDR_BLOB": "rk35/rk3506b_ddr_750MHz_v1.06.bin",
                    "INTRODUCED": "2025",
            "pipeline": {},
            "target_id": "00000000170000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "ATFPATCHDIR": "atf-rockchip",
            "AUFS": "yes",
            "BOOTBRANCH": "commit:0b8e25bd9e16e8043b600e8f49b926b95572dc47",
            "BOOTDELAY": "1",
            "BOOTDIR": "u-boot-rk3506",
            "BOOTENV_FILE": "rk3506.txt",
            "BOOTPATCHDIR": "u-boot-rk3506",
            "BOOTSCRIPT": "boot-rk3506.cmd:boot.cmd",
            "BOOTSOURCE": "https://source.denx.de/u-boot/contributors/kwiboo/u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-rk3506/0b8e25bd9e16e8043b600e8f49b926b95572dc47",
            "CPUMAX": "1900000",
            "CPUMIN": "600000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "armsom-forge1",
            "IMAGE_FILE_ID": "Armsom-forge1_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "KERNEL_IMAGE_TYPE": "zImage",
            "KERNEL_INSTALL_TYPE": "zinstall",
            "KERNEL_PATCH_ARCHIVE_BASE": "rockchip",
            "LINUXCONFIG": "linux-rockchip-vendor",
            "LINUXFAMILY": "rockchip",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.1__rockchip__armhf",
            "NAME_KERNEL": "zImage",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rockchip",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/armsom-forge1.csc"
            "TEE_BLOB": "rk35/rk3506_tee_v2.10.bin",
            "UBOOT_TARGET_MAP": "ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3506b_ddr_750MHz_v1.06.bin TEE=/armbian/cache/sources/rkbin-tools/rk35/rk3506_tee_v2.10.bin;;u-boot-rockchip.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-forge1'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-forge1'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rockchip-vendor'",
                "'ARMBIAN_KERNEL_DEB_NAME=rockchip-vendor'",
                "'BRANCH=vendor'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rockchip'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-rk3506'",
                "'BOOTSOURCE=https://source.denx.de/u-boot/contributors/kwiboo/u-boot.git'",
                "'BOOTBRANCH=commit:0b8e25bd9e16e8043b600e8f49b926b95572dc47'",
                "'BRANCH=vendor'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "armsom-sige1",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3528 quad core 1-8GB SoC GBe eMMC USB3 Wifi Bt",
                    "amazingfate"
                    "vendor"
                        "amazingfate"
                    "BOARD_NAME": "ArmSoM Sige1",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-sige1/vendor",
                    "BOOTCONFIG": "hinlink_rk3528_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3528-armsom-sige1.dtb",
            "pipeline": {},
            "target_id": "00000000180000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3528_bl31_v1.17.elf",
            "BOOTDELAY": "0",
            "BOOT_SOC": "rk3528",
            "BOOT_SOC_MKIMAGE": "rk3528",
            "CPUMAX": "2016000",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3528_ddr_1056MHz_v1.09.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "armsom-sige1",
            "IMAGE_FILE_ID": "Armsom-sige1_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "ROCKUSB_BLOB": "rk35/rk3528_spl_loader_v1.07.104.bin",
                "/armbian/config/boards/armsom-sige1.csc"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3528_bl31_v1.17.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-sige1'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-sige1'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "armsom-sige3",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3568 quad core 1-8GB SoC GBe eMMC USB3",
                    "amazingfate"
                    "vendor"
                        "amazingfate"
                    "BOARD_NAME": "ArmSom Sige3",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-sige3/vendor",
                    "BOOTCONFIG": "armsom-sige3-rk3568_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3568-armsom-sige3.dtb",
            "pipeline": {},
            "target_id": "00000000190000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "armsom-sige3",
            "IMAGE_FILE_ID": "Armsom-sige3_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/armsom-sige3.csc"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3568_bl31_v1.44.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-sige3'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-sige3'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "armsom-sige5",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3576 SoC octa core 8-64GB SoC 2*GBe eMMC USB3 NvME WIFI",
                    "vendor",
                    "edge"
                    "BOARD_NAME": "ArmSoM Sige5",
                        "vendor",
                        "edge"
                    "BOARD_SLASH_BRANCH": "armsom-sige5/vendor",
                    "BOOTCONFIG": "armsom-sige5-rk3576_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3576-armsom-sige5.dtb",
                    "KERNEL_TARGET": "vendor,edge"
            "pipeline": {},
            "target_id": "00000000200000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "armsom-sige5",
            "IMAGE_FILE_ID": "Armsom-sige5_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "KERNEL_TARGET": "vendor,edge",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/armsom-sige5.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-sige5'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-sige5'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "vendor",
                    "edge"
                        "vendor",
                        "edge"
                    "BOARD_SLASH_BRANCH": "armsom-sige5/edge",
            "pipeline": {},
            "target_id": "00000000210000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/next-dev-v2024.10",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Armsom-sige5_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "SERIALCON": "ttyS0",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "armsom-sige7",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588 SoC octa core 8-64GB SoC 2*2.5GBe eMMC USB3 NvME WIFI",
                    "current",
                    "edge",
                    "vendor"
                    "BL31_BLOB": "rk35/rk3588_bl31_v1.38.elf",
                    "BOARD_NAME": "ArmSoM Sige7",
                        "current",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-sige7/current",
                    "BOOTCONFIG": "armsom-sige7-rk3588_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3588-armsom-sige7.dtb",
                    "BOOT_SPI_RKSPI_LOADER": "yes",
                    "BOOT_SUPPORT_SPI": "yes",
                    "DDR_BLOB": "rk35/rk3588_ddr_lp4_2112MHz_lp5_2736MHz_v1.11.bin",
                    "KERNEL_TARGET": "current,edge,vendor"
            "pipeline": {},
            "target_id": "00000000220000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "armsom-sige7",
            "IMAGE_FILE_ID": "Armsom-sige7_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "KERNEL_TARGET": "current,edge,vendor",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/armsom-sige7.csc"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3588_bl31_v1.38.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb rkspi_loader.img",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=armsom-sige7'"
                "'BRANCH=current'",
                "'BOARD=armsom-sige7'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "vendor"
                        "current",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-sige7/edge",
            "pipeline": {},
            "target_id": "00000000230000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Armsom-sige7_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "vendor"
                        "current",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-sige7/vendor",
            "pipeline": {},
            "target_id": "00000000240000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Armsom-sige7_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BRANCH=vendor'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "armsom-w3",
                    "vendor"
                    "BOARD_NAME": "ArmSoM W3",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "armsom-w3/vendor",
                    "BOOTCONFIG": "armsom-w3-rk3588_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3588-armsom-w3.dtb",
            "pipeline": {},
            "target_id": "00000000250000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "armsom-w3",
            "IMAGE_FILE_ID": "Armsom-w3_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/armsom-w3.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-w3'"
                "'BRANCH=vendor'",
                "'BOARD=armsom-w3'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'BOARD=armsom-w3'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "avaota-a1",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner Cortex-A55 octa core 2/4GB RAM SoC USB3 USB-C 2x GbE LCD",
                    "chainsx"
                    "legacy"
                    "BOARDFAMILY": "sun55iw3-syterkit",
                    "BOARD_MAINTAINER": "chainsx",
                        "chainsx"
                    "BOARD_NAME": "Avaota A1",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "avaota-a1/legacy",
                    "BOARD_VENDOR": "allwinner",
                    "BOOTSIZE": "256",
                    "BOOT_FDT_FILE": "allwinner/sun55i-t527-avaota-a1.dtb",
                    "KERNEL_TARGET": "legacy",
                    "SERIALCON": "ttyAS0",
                    "SRC_CMDLINE": "earlycon=uart8250,mmio32,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyAS0,115200 loglevel=8 cma=64M init=/sbin/init",
                    "SYTERKIT_BOARD_ID": "avaota-a1"
            "pipeline": {},
            "target_id": "00000000260000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFBRANCH": "commit:af220ebbe467aa580e6b9ba554676f78ffec930f",
            "ATFDIR": "arm-trusted-firmware",
            "ATFPATCHDIR": "atf-sun55iw3-syterkit",
            "ATFSOURCE": "https://github.com/ARM-software/arm-trusted-firmware",
            "ATFSOURCEDIR": "arm-trusted-firmware/af220ebbe467aa580e6b9ba554676f78ffec930f",
            "AUFS": "yes",
            "BOOTPATCHDIR": "u-boot-sun55iw3-syterkit",
            "BOOTSIZE": "256",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "avaota-a1",
            "IMAGE_FILE_ID": "Avaota-a1_sid_legacy_5.15.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-5.15",
            "KERNELPATCHDIR": "sun55iw3-syterkit-legacy",
            "KERNELSOURCE": "https://github.com/AvaotaSBC/linux.git",
                "@TODO",
                "[0]=\"driver_rtl8723cs\""
            "KERNEL_MAJOR": "5",
            "KERNEL_MAJOR_MINOR": "5.15",
            "KERNEL_PATCH_ARCHIVE_BASE": "sun55iw3-syterkit",
            "LINUXCONFIG": "linux-sun55iw3-syterkit-legacy",
            "LINUXFAMILY": "sun55iw3-syterkit",
            "LINUXSOURCEDIR": "linux-kernel-worktree/5.15__sun55iw3-syterkit__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/avaota-a1.csc"
            "SYTERKIT_BOARD_ID": "avaota-a1",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BOARD=avaota-a1'"
                "'BRANCH=legacy'",
                "'BOARD=avaota-a1'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sun55iw3-syterkit-legacy'",
                "'ARMBIAN_KERNEL_DEB_NAME=sun55iw3-syterkit-legacy'",
                "'KERNELBRANCH=branch:linux-5.15'",
                "'KERNEL_MAJOR_MINOR=5.15'",
                "'KERNELSOURCE=https://github.com/AvaotaSBC/linux.git'",
                "'BRANCH=legacy'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=sun55iw3-syterkit'",
                "'KERNELPATCHDIR=sun55iw3-syterkit-legacy'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-sun55iw3-syterkit'",
                "'BOOTBRANCH=tag:v2022.07'",
                "'BRANCH=legacy'",
                "'ARCH=arm64'",
                "'BOARD=avaota-a1'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "ayn-odin2",
                "BOARD_FILE_HARDWARE_DESC": "Qualcomm SM8550 octa core 8GB/12GB/16GB RAM SoC eMMC USB-C WiFi/BT",
                    "FantasyGmm",
                    "Squishy123",
                    "kasimling"
                    "current",
                    "edge"
                    "BOARDFAMILY": "sm8550",
                    "BOARD_FIRMWARE_INSTALL": "-full",
                    "BOARD_MAINTAINER": "FantasyGmm Squishy123 kasimling",
                        "FantasyGmm",
                        "Squishy123",
                        "kasimling"
                    "BOARD_NAME": "Ayn Odin2",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "ayn-odin2/current",
                    "BOARD_VENDOR": "ayntec",
                    "DESKTOP_AUTOLOGIN": "yes",
                    "EXTRAWIFI": "no",
                    "WITH_GRUB": "${WITH_GRUB:-no}"
            "pipeline": {},
            "target_id": "00000000270000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-sm8550",
            "AUFS": "yes",
            "BOOTENV_FILE": "qcom-abl.txt",
            "BOOTIMG_CMDLINE_EXTRA": "clk_ignore_unused pd_ignore_unused rw quiet rootwait",
            "BOOTPATCHDIR": "u-boot-sm8550",
            "BOOTSIZE": "256",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "HOST": "ayn-odin2",
            "IMAGE_FILE_ID": "Ayn-odin2_sid_current_6.18.y_xfce_desktop",
            "KERNELBRANCH": "tag:v6.18.18",
            "KERNELPATCHDIR": "archive/sm8550-6.18",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "sm8550",
            "LINUXCONFIG": "linux-sm8550-current",
            "LINUXFAMILY": "sm8550",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__sm8550__arm64",
            "OFFSET": "4",
            "OVERLAY_DIR": "/boot/dtb/qcom/overlay",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/ayn-odin2.csc"
            "USE_CCACHE": "no",
            "VALID_BOARDS": [
                "@TODO",
                "[0]=\"ayn-odin2\" [1]=\"ayn-odin2portal\" [2]=\"ayn-odin2mini\" [3]=\"ayn-thor\""
                "KERNEL",
                "FULL_FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "full_firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=ayn-odin2'"
                "'BRANCH=current'",
                "'BOARD=ayn-odin2'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
            "WANT_ARTIFACT_FULL_FIRMWARE_INPUTS_ARRAY": [],
                "'LINUXCONFIG=linux-sm8550-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=sm8550-current'",
                "'KERNELBRANCH=tag:v6.18.18'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=sm8550'",
                "'KERNELPATCHDIR=archive/sm8550-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WITH_GRUB": "no"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "FantasyGmm",
                    "Squishy123",
                    "kasimling"
                    "current",
                    "edge"
                        "FantasyGmm",
                        "Squishy123",
                        "kasimling"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "ayn-odin2/edge",
                    "EXTRAWIFI": "no",
            "pipeline": {},
            "target_id": "00000000280000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTSIZE": "256",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Ayn-odin2_sid_edge_6.18.y_xfce_desktop",
                "@TODO",
            "LINUXCONFIG": "linux-sm8550-edge",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
            "VALID_BOARDS": [
                "@TODO",
                "KERNEL",
                "FULL_FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "full_firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=ayn-odin2'"
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sm8550-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=sm8550-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WITH_GRUB": "no"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapi",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner A20 dual core 1Gb RAM SoC 1xSATA GBE",
                    "DylanHP",
                    "janprunk"
                    "current",
                    "edge",
                    "legacy"
                    "BOARDFAMILY": "sun7i",
                    "BOARD_MAINTAINER": "DylanHP janprunk",
                        "DylanHP",
                        "janprunk"
                    "BOARD_NAME": "Banana Pi",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapi/current",
                    "BOARD_VENDOR": "sinovoip",
                    "BOOTCONFIG": "Bananapi_defconfig",
                    "INTRODUCED": "2014",
                    "KERNEL_TARGET": "current,edge,legacy",
            "pipeline": {},
            "target_id": "00000000290000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "ASOUND_STATE": "asound.state.sunxi-next",
            "ATFPATCHDIR": "atf-sunxi",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2024.01",
            "BOOTDELAY": "1",
            "BOOTENV_FILE": "sunxi.txt",
            "BOOTPATCHDIR": "u-boot-sunxi",
            "BOOTSCRIPT": "boot-sunxi.cmd:boot.cmd",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2024.01",
            "CPUMAX": "1010000",
            "CPUMIN": "480000",
            "CRUST_TARGET_MAP": "scp;;build/scp/scp.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapi",
            "IMAGE_FILE_ID": "Bananapi_sid_current_6.18.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/sunxi-6.18",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "sunxi",
            "LINUXCONFIG": "linux-sunxi-current",
            "LINUXFAMILY": "sunxi",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__sunxi__armhf",
            "OFFSET": "4",
            "OVERLAY_DIR": "/boot/dtb/allwinner/overlay",
            "OVERLAY_PREFIX": "sun7i-a20",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapi.conf"
            "UBOOT_FW_ENV": "0x88000,0x20000",
            "UBOOT_TARGET_MAP": ";;u-boot-sunxi-with-spl.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapi'"
                "'BRANCH=current'",
                "'BOARD=bananapi'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi-current'",
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=sunxi'",
                "'KERNELPATCHDIR=archive/sunxi-6.18'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-sunxi'",
                "'BOOTBRANCH=tag:v2024.01'",
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'BOARD=bananapi'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "DylanHP",
                    "janprunk"
                    "current",
                    "edge",
                    "legacy"
                        "DylanHP",
                        "janprunk"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapi/edge",
            "pipeline": {},
            "target_id": "00000000300000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapi",
            "IMAGE_FILE_ID": "Bananapi_sid_edge_7.0.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/sunxi-7.0",
                "@TODO",
            "LINUXCONFIG": "linux-sunxi-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__sunxi__armhf",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=bananapi'"
                "'BRANCH=edge'",
                "'BOARD=bananapi'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi-edge'",
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/sunxi-7.0'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'BOARD=bananapi'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD_CORE_OR_USERPATCHED": "core",
                "BOARD_HAS_VIDEO": true,
                    "DylanHP",
                    "janprunk"
                "BOARD_POSSIBLE_BRANCHES": [
                    "current",
                    "edge",
                    "legacy"
                "BOARD_TOP_LEVEL_VARS": {
                        "DylanHP",
                        "janprunk"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapi/legacy",
                    "KERNEL_TEST_TARGET": "current"
            "pipeline": {},
            "target_id": "00000000310000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "BUILD_DESKTOP": "yes",
                "BUILD_MINIMAL": "no",
                "DESKTOP_ENVIRONMENT": "xfce",
                "DESKTOP_ENVIRONMENT_CONFIG_NAME": "config_base",
                "RELEASE": "sid",
                "REVISION": "26.05.0-trunk"
        "logs": [
        "out": {
            "APT_MIRROR": "deb.debian.org/debian",
            "ARCH": "armhf",
            "ARMBIAN_ARTIFACTS_TO_HANDLERS_DICT": [
                "@TODO",
                "bash associative arrays aka dictionaries are not supported yet",
                "[armbian-base-files]=\"armbian-base-files\" [armbian-desktop]=\"armbian-desktop\" [armbian-bsp-desktop]=\"armbian-bsp-desktop\" [full_firmware]=\"full_firmware\" [armbian-zsh]=\"armbian-zsh\" [armbian-plymouth-theme]=\"armbian-plymouth-theme\" [fake_ubuntu_advantage_tools]=\"fake_ubuntu_advantage_tools\" [rootfs]=\"rootfs\" [armbian-bsp-cli]=\"armbian-bsp-cli\" [u-boot]=\"uboot\" [uboot]=\"uboot\" [kernel]=\"kernel\" [firmware]=\"firmware\" "
            "ARMBIAN_WILL_BUILD_UBOOT": "yes",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "BOOTDIR": "u-boot",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapi",
            "IMAGE_FILE_ID": "Bananapi_sid_legacy_6.12.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-6.12.y",
            "KERNELPATCHDIR": "archive/sunxi-6.12",
                "@TODO",
            "KERNEL_TEST_TARGET": "current",
            "LINUXCONFIG": "linux-sunxi-legacy",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.12__sunxi__armhf",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BOARD=bananapi'"
                "'BRANCH=legacy'",
                "'BOARD=bananapi'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi-legacy'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi-legacy'",
                "'KERNELBRANCH=branch:linux-6.12.y'",
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/sunxi-6.12'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'BOARD=bananapi'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapicm4io",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic A311D 4GB RAM eMMC GBE USB3",
                    "pyavitz"
                    "current",
                    "edge"
                    "BOARD_MAINTAINER": "pyavitz",
                        "pyavitz"
                    "BOARD_NAME": "Banana Pi CM4IO",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapicm4io/current",
                    "BOOTBRANCH_BOARD": "tag:v2026.01",
                    "BOOTCONFIG": "bananapi-cm4-cm4io_defconfig",
                    "BOOTPATCHDIR": "v2026.01",
                    "BOOT_FDT_FILE": "amlogic/meson-g12b-bananapi-cm4-cm4io.dtb",
                    "BOOT_LOGO": "desktop",
                    "FULL_DESKTOP": "yes",
                    "INTRODUCED": "2021",
                    "KERNEL_TARGET": "current,edge",
            "pipeline": {},
            "target_id": "00000000320000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "current",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
            "ARCHITECTURE": "arm64",
                "@TODO",
            "ATF_COMPILE": "no",
            "ATF_COMPILER": "aarch64-linux-gnu-",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2026.01",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2026.01",
            "CHROOT_CACHE_VERSION": "7",
            "COMPRESS_OUTPUTIMAGE": "sha,img",
            "CONSOLE_AUTOLOGIN": "yes",
            "CONSOLE_CHAR": "UTF-8",
            "CPUMAX": "2400000",
            "CPUMIN": "1000000",
            "DEBIAN_MIRROR": "deb.debian.org/debian",
            "DEBIAN_SECURITY": "security.debian.org/",
            "DEB_COMPRESS": "none",
            "DEST_LANG": "en_US.UTF-8",
            "DISABLE_IPV6": "true",
            "DISTRIBUTION": "Debian",
            "EXIT_PATCHING_ERROR": "",
            "EXTRAWIFI": "yes",
            "EXTRA_BSP_NAME": "",
            "EXTRA_IMAGE_SUFFIX": "",
            "EXTRA_PACKAGES_IMAGE": [
                "@TODO",
                "bash simple-arrays are not supported yet",
                "[0]=\"chrony\" [1]=\"network-manager\" [2]=\"network-manager-openvpn\" [3]=\"netplan.io\" [4]=\"network-manager-gnome\" [5]=\"network-manager-ssh\" [6]=\"network-manager-vpnc\""
            "EXTRA_PACKAGES_IMAGE_REFS": [
                "@TODO",
                "[0]=\"extension_prepare_config__install_chrony:/armbian/extensions/network/net-chrony.sh:6\" [1]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [2]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [3]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [4]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [5]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [6]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\""
            "EXTRA_ROOTFS_MIB_SIZE": "0",
            "FAST_CREATE_IMAGE": "yes",
            "GHCR_SOURCE": "ghcr.io",
            "GITHUB_SOURCE": "https://github.com",
            "GOVERNOR": "performance",
            "HOST": "bananapicm4io",
            "IMAGE_FILE_ID": "Bananapicm4io_sid_current_6.18.y_xfce_desktop",
            "IMAGE_TYPE": "user-built",
            "INITRD_ARCH": "arm64",
            "KERNELBRANCH": "branch:linux-6.18.y",
            "KERNELSOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "KERNEL_COMPILER": "aarch64-linux-gnu-",
            "KERNEL_DRIVERS_SKIP": [
                "@TODO",
            "KERNEL_HAS_WORKING_HEADERS": "yes",
            "KERNEL_IMAGE_TYPE": "Image",
            "KERNEL_INSTALL_TYPE": "install",
            "KERNEL_MAJOR": "6",
            "KERNEL_MAJOR_MINOR": "6.18",
            "KERNEL_SRC_ARCH": "arm64",
            "LANGUAGE": "en_US:en",
            "MAINLINE_FIRMWARE_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git",
            "MAINLINE_KERNEL_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "MAINLINE_UBOOT_DIR": "u-boot",
            "MAINLINE_UBOOT_SOURCE": "https://github.com/u-boot/u-boot",
            "MAINTAINER": "John Doe",
            "MAINTAINERMAIL": "john.doe@somewhere.on.planet",
            "MAIN_CMDLINE": "rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles",
            "NAMESERVER": "1.0.0.1",
            "NAME_INITRD": "uInitrd",
            "NAME_KERNEL": "Image",
            "NETWORKING_STACK": "network-manager",
            "OFFSET": "4",
            "PACKAGES_HASHED_STORAGE": "/armbian/output/packages-hashed",
            "PACKAGE_LIST_BOARD": [],
            "PACKAGE_LIST_BOARD_REMOVE": [],
            "PACKAGE_LIST_FAMILY_REMOVE": [],
            "PARTITION_TYPE_UUID_ROOT": "B921B045-1DF0-41C3-AF44-4C6F280D3FAE",
            "PLYMOUTH": "yes",
            "QEMU_BINARY": "qemu-aarch64-static",
            "QEMU_CPU": "cortex-a53",
            "REMOVE_PACKAGES": [
                "@TODO",
                "[0]=\"software-properties-common\" [1]=\"software-properties-gtk\" [2]=\"software-properties-common\""
            "REMOVE_PACKAGES_REFS": [
                "@TODO",
                "[0]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [1]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [2]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\""
            "ROOTFS_CACHE_MAX": "200",
            "ROOTFS_TYPE": "ext4",
            "SELECTED_CONFIGURATION": "desktop",
            "SHOW_WARNING": "yes",
            "SOURCED_BOARD_CONFIGS_FILENAME_LIST": [
                "/armbian/config/boards/bananapicm4io.conf"
            "TZDATA": "Etc/UTC",
            "UBOOT_COMPILER": "aarch64-linux-gnu-",
            "UBUNTU_MIRROR": "ports.ubuntu.com/",
            "USE_CCACHE": "no",
            "VENDOR": "Armbian-unofficial",
            "VENDORBUGS": "https://armbian.atlassian.net/",
            "VENDORCOLOR": "247;16;0",
            "VENDORDOCS": "https://docs.armbian.com/",
            "VENDORLOGO": "armbian-logo",
            "VENDORPRIVACY": "https://duckduckgo.com/",
            "VENDORSUPPORT": "https://community.armbian.com/",
            "VENDORURL": "https://duckduckgo.com/",
            "WANT_ARTIFACT_ALL_ARRAY": [
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_BASE_FILES",
                "ARMBIAN_ZSH",
                "ARMBIAN_PLYMOUTH_THEME",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ARMBIAN_BSP_DESKTOP",
                "ROOTFS"
            "WANT_ARTIFACT_ALL_NAMES_ARRAY": [
                "uboot",
                "kernel",
                "firmware",
                "armbian-base-files",
                "armbian-zsh",
                "armbian-plymouth-theme",
                "armbian-bsp-cli",
                "armbian-desktop",
                "armbian-bsp-desktop",
                "rootfs"
            "WANT_ARTIFACT_ARMBIAN_BASE_FILES_INPUTS_ARRAY": [
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_BSP_CLI_INPUTS_ARRAY": [
                "'EXTRA_BSP_NAME='",
                "'BRANCH=current'",
                "'BOARD=bananapicm4io'"
            "WANT_ARTIFACT_ARMBIAN_BSP_DESKTOP_INPUTS_ARRAY": [
                "'BRANCH=current'",
                "'DESKTOP_ENVIRONMENT=xfce'",
                "'DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base'",
                "'BOARD=bananapicm4io'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_DESKTOP_INPUTS_ARRAY": [
                "'DESKTOP_AGGREGATION_RESULTS=8855c6119660c614d285554e51769066e94fcb75ff215ccc2fa6b4838b18756b'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_PLYMOUTH_THEME_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_ARMBIAN_ZSH_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_FIRMWARE_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_KERNEL_INPUTS_ARRAY": [
                "'KERNELBRANCH=branch:linux-6.18.y'",
                "'KERNEL_MAJOR_MINOR=6.18'",
                "'KERNELSOURCE=https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
            "WANT_ARTIFACT_ROOTFS_INPUTS_ARRAY": [
                "'BUILD_MINIMAL=no'",
                "'SELECTED_CONFIGURATION=desktop'",
                "'DESKTOP_APPGROUPS_SELECTED=no_DESKTOP_APPGROUPS_SELECTED_set'",
                "'EXTRA_PKG_ADD_REMOVE_HASH=9484d87e17c18694c6beeb148595dde16586e36948cc22225c4564e1b0cee6fd'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_UBOOT_INPUTS_ARRAY": [
                "'BOOTPATCHDIR=v2026.01'",
                "'BOOTBRANCH=tag:v2026.01'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "pyavitz"
                    "current",
                    "edge"
                        "pyavitz"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapicm4io/edge",
            "pipeline": {},
            "target_id": "00000000330000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapicm4io_sid_edge_7.0.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-7.0.y",
                "@TODO",
            "KERNEL_MAJOR": "7",
            "KERNEL_MAJOR_MINOR": "7.0",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'KERNELBRANCH=branch:linux-7.0.y'",
                "'KERNEL_MAJOR_MINOR=7.0'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapif3",
                "BOARD_FILE_HARDWARE_DESC": "SpacemiT K1 octa core RISC-V SoC 2GB/4GB RAM 8GB/16GB eMMC 4x USB3 2x GbE",
                    "pyavitz"
                    "legacy",
                    "current",
                    "edge"
                "BOARD_SUPPORT_LEVEL": "conf",
                    "BOARDFAMILY": "spacemit",
                        "pyavitz"
                    "BOARD_NAME": "BananaPi BPI-F3",
                        "legacy",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapif3/legacy",
                    "BOARD_VENDOR": "spacemit",
                    "BOOT_FDT_FILE": "spacemit/k1-bananapi-f3.dtb",
                    "INTRODUCED": "2024",
                    "KERNEL_TARGET": "legacy,current,edge",
                    "PACKAGE_LIST_BOARD": "rfkill bluetooth bluez bluez-tools",
                    "SRC_CMDLINE": "earlycon=sbi console=tty1 console=ttyS0,115200 loglevel=1",
            "pipeline": {},
            "target_id": "00000000340000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "riscv64",
            "ARCHITECTURE": "riscv",
                "@TODO",
            "ATFBRANCH": "tag:k1-bl-v2.2.9-release",
            "ATFDIR": "opensbi",
            "ATFPATCHDIR": "atf-spacemit",
            "ATFSOURCE": "https://github.com/pyavitz/spacemit-opensbi.git",
            "ATFSOURCEDIR": "opensbi/k1-bl-v2.2.9-release",
            "ATF_COMPILER": "riscv64-linux-gnu-",
            "ATF_TARGET_MAP": "PLATFORM_DEFCONFIG=k1_defconfig PLATFORM=generic ;;build/platform/generic/firmware/fw_dynamic.itb",
            "AUFS": "yes",
            "BOARD_TYPE": "conf",
            "BOOTBRANCH": "tag:k1-bl-v2.2.9-release",
            "BOOTCONFIG": "k1_defconfig",
            "BOOTDELAY": "1",
            "BOOTDIR": "u-boot-spacemit",
            "BOOTPATCHDIR": "legacy/u-boot-spacemit-k1",
            "BOOTSOURCE": "https://github.com/pyavitz/spacemit-u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-spacemit/k1-bl-v2.2.9-release",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "HOST": "bananapif3",
            "IMAGE_FILE_ID": "Bananapif3_sid_legacy_6.6.y_xfce_desktop",
            "IMAGE_PARTITION_TABLE": "gpt",
            "INITRD_ARCH": "riscv",
            "KERNELBRANCH": "branch:linux-6.6.y",
            "KERNELPATCHDIR": "archive/spacemit-6.6",
            "KERNELSOURCE": "https://github.com/jmontleon/linux-bianbu.git",
            "KERNEL_COMPILER": "riscv64-linux-gnu-",
                "@TODO",
            "KERNEL_MAJOR_MINOR": "6.6",
            "KERNEL_PATCH_ARCHIVE_BASE": "spacemit",
            "KERNEL_SRC_ARCH": "riscv",
            "LINUXCONFIG": "linux-spacemit-legacy",
            "LINUXFAMILY": "spacemit",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.6__spacemit__riscv64",
            "OFFSET": "4",
                "rfkill",
                "bluetooth",
                "bluez",
                "bluez-tools"
            "PARTITION_TYPE_UUID_ROOT": "72EC70A6-CF74-40E6-BD49-4BDA08E8F224",
            "PLYMOUTH": "yes",
            "QEMU_BINARY": "qemu-riscv64-static",
                "@TODO",
                "[0]=\"cpufrequtils\" [1]=\"software-properties-common\" [2]=\"software-properties-gtk\" [3]=\"software-properties-common\""
                "@TODO",
                "[0]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:394\" [1]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [2]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [3]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\""
                "/armbian/config/boards/bananapif3.conf"
            "UBOOT_COMPILER": "riscv64-linux-gnu-",
            "UBOOT_TARGET_MAP": ";;bootinfo_emmc.bin bootinfo_spinor.bin FSBL.bin fw_dynamic.itb u-boot.itb u-boot-env-default.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=riscv64'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BOARD=bananapif3'"
                "'BRANCH=legacy'",
                "'BOARD=bananapif3'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-spacemit-legacy'",
                "'ARMBIAN_KERNEL_DEB_NAME=spacemit-legacy'",
                "'KERNELBRANCH=branch:linux-6.6.y'",
                "'KERNEL_MAJOR_MINOR=6.6'",
                "'KERNELSOURCE=https://github.com/jmontleon/linux-bianbu.git'",
                "'BRANCH=legacy'",
                "'ARCH=riscv64'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=spacemit'",
                "'KERNELPATCHDIR=archive/spacemit-6.6'"
                "'EXTRA_PKG_ADD_REMOVE_HASH=4fcdc1d12cfca60f7b54a600c5cef6762daa0a5d652910a7508aebb6c0e96dc7'",
                "'ARCH=riscv64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=legacy/u-boot-spacemit-k1'",
                "'BOOTSOURCE=https://github.com/pyavitz/spacemit-u-boot.git'",
                "'BOOTBRANCH=tag:k1-bl-v2.2.9-release'",
                "'BRANCH=legacy'",
                "'ARCH=riscv64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "pyavitz"
                    "legacy",
                    "current",
                    "edge"
                        "pyavitz"
                        "legacy",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapif3/current",
            "pipeline": {},
            "target_id": "00000000350000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "riscv64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapif3_sid_current_6.18.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/spacemit-6.18",
                "@TODO",
            "LINUXCONFIG": "linux-spacemit-current",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__spacemit__riscv64",
            "OFFSET": "4",
                "rfkill",
                "bluetooth",
                "bluez",
                "bluez-tools"
            "PACKAGE_LIST_FAMILY": [],
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=riscv64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BRANCH=current'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-spacemit-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=spacemit-current'",
                "'BRANCH=current'",
                "'ARCH=riscv64'",
                "'EXTRAWIFI=no'",
                "'KERNELPATCHDIR=archive/spacemit-6.18'"
                "'ARCH=riscv64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=riscv64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "pyavitz"
                    "legacy",
                    "current",
                    "edge"
                        "pyavitz"
                        "legacy",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapif3/edge",
            "pipeline": {},
            "target_id": "00000000360000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "riscv64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapif3_sid_edge_7.0.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/spacemit-7.0",
                "@TODO",
            "LINUXCONFIG": "linux-spacemit-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__spacemit__riscv64",
            "OFFSET": "4",
                "rfkill",
                "bluetooth",
                "bluez",
                "bluez-tools"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=riscv64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-spacemit-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=spacemit-edge'",
                "'BRANCH=edge'",
                "'ARCH=riscv64'",
                "'EXTRAWIFI=no'",
                "'KERNELPATCHDIR=archive/spacemit-7.0'"
                "'ARCH=riscv64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=riscv64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim1plus",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner A20 dual core 1Gb SoC GBE WiFi 1xSATA",
                    "current",
                    "edge",
                    "legacy"
                "BOARD_SUPPORT_LEVEL": "csc",
                    "BOARD_NAME": "Banana Pi M1+",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim1plus/current",
                    "BOOTCONFIG": "bananapi_m1_plus_defconfig",
            "pipeline": {},
            "target_id": "00000000370000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOARD_TYPE": "csc",
            "BOOTDELAY": "1",
            "BOOTSOURCE": "https://github.com/u-boot/u-boot",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "GOVERNOR": "ondemand",
            "HOST": "bananapim1plus",
            "IMAGE_FILE_ID": "Bananapim1plus_sid_current_6.18.y_xfce_desktop",
            "IMAGE_PARTITION_TABLE": "msdos",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapim1plus.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim1plus'"
                "'BRANCH=current'",
                "'BOARD=bananapim1plus'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD_MAINTAINERS": [],
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim1plus/edge",
            "pipeline": {},
            "target_id": "00000000380000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOARD_MAINTAINER": "",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim1plus_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim1plus/legacy",
            "pipeline": {},
            "target_id": "00000000390000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
            "ARCHITECTURE": "arm",
                "@TODO",
            "ATF_COMPILE": "yes",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim1plus_sid_legacy_6.12.y_xfce_desktop",
            "INITRD_ARCH": "arm",
            "KERNEL_COMPILER": "arm-linux-gnueabihf-",
                "@TODO",
            "KERNEL_MAJOR_MINOR": "6.12",
            "KERNEL_SRC_ARCH": "arm",
            "OFFSET": "4",
            "PARTITION_TYPE_UUID_ROOT": "69DAD710-2CE4-4E3C-B16C-21A1D49ABED3",
            "PLYMOUTH": "yes",
            "QEMU_BINARY": "qemu-arm-static",
                "@TODO",
                "@TODO",
            "UBOOT_COMPILER": "arm-linux-gnueabihf-",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'KERNEL_MAJOR_MINOR=6.12'",
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim2plus",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner H3 quad core 1Gb RAM SoC Wifi GBE",
                    "leggewie"
                    "current",
                    "edge",
                    "legacy"
                    "BOARDFAMILY": "sun8i",
                    "BOARD_MAINTAINER": "leggewie",
                        "leggewie"
                    "BOARD_NAME": "Banana Pi M2+",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim2plus/current",
                    "BOOTCONFIG": "bananapi_m2_plus_h3_defconfig",
                    "DEFAULT_OVERLAYS": "analog-codec",
                    "MODULES_CURRENT": "g_serial",
                    "MODULES_LEGACY": "g_serial",
                    "SERIALCON": "ttyS0,ttyGS0"
            "pipeline": {},
            "target_id": "00000000400000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMAX": "1400000",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim2plus",
            "IMAGE_FILE_ID": "Bananapim2plus_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "OVERLAY_PREFIX": "sun8i-h3",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "SERIALCON": "ttyS0,ttyGS0",
                "/armbian/config/boards/bananapim2plus.conf"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim2plus'"
                "'BRANCH=current'",
                "'BOARD=bananapim2plus'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "leggewie"
                    "current",
                    "edge",
                    "legacy"
                        "leggewie"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim2plus/edge",
            "pipeline": {},
            "target_id": "00000000410000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim2plus_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "leggewie"
                    "current",
                    "edge",
                    "legacy"
                        "leggewie"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim2plus/legacy",
                    "INTRODUCED": "2016",
            "pipeline": {},
            "target_id": "00000000420000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim2plus_sid_legacy_6.12.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim2pro",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic S905X3 quad core 2-4GB RAM SoC eMMC GBE USB3 SPI Wifi",
                    "igorpecovnik"
                    "current",
                    "edge"
                    "BOARDFAMILY": "meson-sm1",
                    "BOARD_MAINTAINER": "igorpecovnik",
                        "igorpecovnik"
                    "BOARD_NAME": "Banana Pi M2Pro",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim2pro/current",
                    "BOOTBRANCH_BOARD": "tag:v2024.07",
                    "BOOTCONFIG": "bananapi-m2-pro_defconfig",
                    "BOOTPATCHDIR": "v2024.07",
                    "BOOT_FDT_FILE": "amlogic/meson-sm1-bananapi-m2-pro.dtb",
                    "MODULES_BLACKLIST": "simpledrm",
                    "SERIALCON": "ttyAML0"
            "pipeline": {},
            "target_id": "00000000430000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ASOUND_STATE": "asound.state.meson64",
            "ATFPATCHDIR": "atf-meson64",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2024.07",
            "BOOTENV_FILE": "meson.txt",
            "BOOTSCRIPT": "boot-meson64.cmd:boot.cmd",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2024.07",
            "CPUMAX": "2100000",
            "CPUMIN": "667000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim2pro",
            "IMAGE_FILE_ID": "Bananapim2pro_sid_current_6.18.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/meson64-6.18",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "meson64",
            "LINUXCONFIG": "linux-meson64-current",
            "LINUXFAMILY": "meson64",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__meson64__arm64",
            "OFFSET": "4",
            "OVERLAY_DIR": "/boot/dtb/amlogic/overlay",
            "OVERLAY_PREFIX": "meson",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "SERIALCON": "ttyAML0",
                "/armbian/config/boards/bananapim2pro.conf"
            "SRC_LOADADDR": "LOADADDR=0x1080000",
            "UBOOT_TARGET_MAP": "u-boot-dtb.img;;u-boot.bin.sd.bin:u-boot.bin u-boot-dtb.img",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim2pro'"
                "'BRANCH=current'",
                "'BOARD=bananapim2pro'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-meson64-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=meson64-current'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=meson64'",
                "'KERNELPATCHDIR=archive/meson64-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2024.07'",
                "'BOOTBRANCH=tag:v2024.07'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "igorpecovnik"
                    "current",
                    "edge"
                        "igorpecovnik"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim2pro/edge",
            "pipeline": {},
            "target_id": "00000000440000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "CPUMIN": "667000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim2pro_sid_edge_7.0.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/meson64-7.0",
                "@TODO",
            "LINUXCONFIG": "linux-meson64-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__meson64__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-meson64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=meson64-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/meson64-7.0'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim2s",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic A311D 4GB RAM eMMC 2xGBE USB3",
                    "jeanrhum",
                    "pyavitz"
                    "current",
                    "edge"
                    "BOARDFAMILY": "meson-g12b",
                    "BOARD_MAINTAINER": "jeanrhum pyavitz",
                        "jeanrhum",
                        "pyavitz"
                    "BOARD_NAME": "Banana Pi M2S",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim2s/current",
                    "BOOTCONFIG": "bananapi-m2s_defconfig",
                    "BOOT_FDT_FILE": "amlogic/meson-g12b-a311d-bananapi-m2s.dtb",
            "pipeline": {},
            "target_id": "00000000450000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim2s",
            "IMAGE_FILE_ID": "Bananapim2s_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapim2s.conf"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim2s'"
                "'BRANCH=current'",
                "'BOARD=bananapim2s'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTSOURCE=https://github.com/u-boot/u-boot'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "jeanrhum",
                    "pyavitz"
                    "current",
                    "edge"
                        "jeanrhum",
                        "pyavitz"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim2s/edge",
            "pipeline": {},
            "target_id": "00000000460000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim2s_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim2ultra",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner R40 quad core 2Gb SoC Wifi eMMC",
                    "current",
                    "edge",
                    "legacy"
                    "BOARD_NAME": "Banana Pi M2 Ultra",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim2ultra/current",
                    "BOOTCONFIG": "Bananapi_M2_Ultra_defconfig",
                    "OVERLAY_PREFIX": "sun8i-r40"
            "pipeline": {},
            "target_id": "00000000470000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim2ultra",
            "IMAGE_FILE_ID": "Bananapim2ultra_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "OVERLAY_PREFIX": "sun8i-r40",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapim2ultra.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim2ultra'"
                "'BRANCH=current'",
                "'BOARD=bananapim2ultra'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim2ultra/edge",
            "pipeline": {},
            "target_id": "00000000480000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
            "warn: Not-installing software-properties-common For distro 'Debian' release 'sid'\\n"
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim2ultra_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim2ultra/legacy",
            "pipeline": {},
            "target_id": "00000000490000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim2ultra_sid_legacy_6.12.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim2zero",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner H2+ quad core 512MB SoC Wi-Fi/BT",
                    "mhawkins-consultant"
                    "current",
                    "edge",
                    "legacy"
                    "BOARD_MAINTAINER": "mhawkins-consultant",
                    "BOARD_NAME": "Banana Pi M2 Zero",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim2zero/current",
                    "BOOTCONFIG": "bananapi_m2_zero_defconfig",
                    "INTRODUCED": "2017",
            "pipeline": {},
            "target_id": "00000000500000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim2zero",
            "IMAGE_FILE_ID": "Bananapim2zero_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapim2zero.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim2zero'"
                "'BRANCH=current'",
                "'BOARD=bananapim2zero'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim2zero/edge",
            "pipeline": {},
            "target_id": "00000000510000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim2zero_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim2zero/legacy",
            "pipeline": {},
            "target_id": "00000000520000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim2zero_sid_legacy_6.12.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim3",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner A83T octa core 2Gb SoC Wifi",
                    "AaronNGray"
                    "current",
                    "edge",
                    "legacy"
                    "BOARD_MAINTAINER": "AaronNGray",
                        "AaronNGray"
                    "BOARD_NAME": "Banana Pi M3",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim3/current",
                    "BOOTCONFIG": "Sinovoip_BPI_M3_defconfig",
                    "BOOTPATCHDIR": "u-boot-sunxi/board_${BOARD}",
                    "INTRODUCED": "2015",
                    "OVERLAY_PREFIX": "sun8i-a83t"
            "pipeline": {},
            "target_id": "00000000530000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "BOOTPATCHDIR": "u-boot-sunxi/board_bananapim3",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim3",
            "IMAGE_FILE_ID": "Bananapim3_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "OVERLAY_PREFIX": "sun8i-a83t",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapim3.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim3'"
                "'BRANCH=current'",
                "'BOARD=bananapim3'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-sunxi/board_bananapim3'",
                "'BRANCH=current'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "AaronNGray"
                    "current",
                    "edge",
                    "legacy"
                        "AaronNGray"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim3/edge",
            "pipeline": {},
            "target_id": "00000000540000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim3_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "KERNEL_IMAGE_TYPE": "zImage",
            "KERNEL_INSTALL_TYPE": "zinstall",
            "NAME_KERNEL": "zImage",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "AaronNGray"
                    "current",
                    "edge",
                    "legacy"
                        "AaronNGray"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim3/legacy",
            "pipeline": {},
            "target_id": "00000000550000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim3_sid_legacy_6.12.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim4berry",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner H618 quad core 2/4GB RAM 8GB eMMC SoC WiFi\\Bt HDMI SPI USB-C",
                    "The-going"
                    "current",
                    "edge"
                    "BOARDFAMILY": "sun50iw9-bpi",
                    "BOARD_MAINTAINER": "The-going",
                        "The-going"
                    "BOARD_NAME": "BananaPi M4 Berry",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim4berry/current",
                    "BOOTBRANCH_BOARD": "tag:v2025.04",
                    "BOOTCONFIG": "bananapi_m4_berry_defconfig",
                    "BOOTPATCHDIR": "v2025-sunxi",
                    "BOOT_FDT_FILE": "sun50i-h618-bananapi-m4-berry.dtb",
                    "INTRODUCED": "2023",
                    "OVERLAY_PREFIX": "sun50i-h616",
                    "PACKAGE_LIST_BOARD": "rfkill bluetooth bluez bluez-tools hostapd"
            "pipeline": {},
            "target_id": "00000000560000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFBRANCH": "tag:lts-v2.12.9",
            "ATFPATCHDIR": "atf-sunxi64",
            "ATFSOURCEDIR": "arm-trusted-firmware/lts-v2.12.9",
            "ATF_PLAT": "sun50i_h616",
            "ATF_TARGET_MAP": "PLAT=sun50i_h616 DEBUG=1 bl31;;build/sun50i_h616/debug/bl31.bin",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2025.04",
            "BOOTDELAY": "1",
            "BOOTSCRIPT": "boot-sun50i-next.cmd:boot.cmd",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2025.04",
            "CPUMAX": "1512000",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim4berry",
            "IMAGE_FILE_ID": "Bananapim4berry_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "sunxi64",
            "LINUXCONFIG": "linux-sunxi64-current",
            "LINUXFAMILY": "sunxi64",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__sunxi64__arm64",
            "OFFSET": "4",
                "rfkill",
                "bluetooth",
                "bluez",
                "bluez-tools",
                "hostapd"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapim4berry.conf"
            "UBOOT_TARGET_MAP": "BINMAN_ALLOW_MISSING=1;;u-boot-sunxi-with-spl.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim4berry'"
                "'BRANCH=current'",
                "'BOARD=bananapim4berry'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi64-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi64-current'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=sunxi64'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2025-sunxi'",
                "'BOOTBRANCH=tag:v2025.04'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "The-going"
                    "current",
                    "edge"
                        "The-going"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim4berry/edge",
            "pipeline": {},
            "target_id": "00000000570000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim4berry_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "LINUXCONFIG": "linux-sunxi64-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__sunxi64__arm64",
            "OFFSET": "4",
                "rfkill",
                "bluetooth",
                "bluez",
                "bluez-tools",
                "hostapd"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi64-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim4zero",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner H618 quad core 1/2/4GB RAM SoC WiFi SPI USB-C",
                    "pyavitz"
                    "current",
                    "edge"
                        "pyavitz"
                    "BOARD_NAME": "BananaPi BPI-M4-Zero",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim4zero/current",
                    "BOOTCONFIG": "bananapi_m4zero_defconfig",
                    "BOOT_FDT_FILE": "sun50i-h618-bananapi-m4-zero.dtb",
                    "DEFAULT_OVERLAYS": "bananapi-m4-sdio-wifi-bt",
                    "FORCE_BOOTSCRIPT_UPDATE": "yes",
                    "MODULES_BLACKLIST": "rtw88_8821c rtw88_8821cu",
            "pipeline": {},
            "target_id": "00000000580000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim4zero",
            "IMAGE_FILE_ID": "Bananapim4zero_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
                "rfkill",
                "bluetooth",
                "bluez",
                "bluez-tools"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapim4zero.conf"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim4zero'"
                "'BRANCH=current'",
                "'BOARD=bananapim4zero'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "pyavitz"
                    "current",
                    "edge"
                        "pyavitz"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim4zero/edge",
            "pipeline": {},
            "target_id": "00000000590000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim4zero_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
                "rfkill",
                "bluetooth",
                "bluez",
                "bluez-tools"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim5",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic S905X3 quad core 2-4GB RAM SoC eMMC GBE USB3 SPI",
                    "igorpecovnik"
                    "current",
                    "edge"
                        "igorpecovnik"
                    "BOARD_NAME": "Banana Pi M5",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim5/current",
                    "BOOTCONFIG": "bananapi-m5_defconfig",
                    "BOOT_FDT_FILE": "amlogic/meson-sm1-bananapi-m5.dtb",
            "pipeline": {},
            "target_id": "00000000600000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "CPUMIN": "667000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim5",
            "IMAGE_FILE_ID": "Bananapim5_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapim5.conf"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim5'"
                "'BRANCH=current'",
                "'BOARD=bananapim5'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "igorpecovnik"
                    "current",
                    "edge"
                        "igorpecovnik"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapim5/edge",
            "pipeline": {},
            "target_id": "00000000610000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "CPUMIN": "667000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim5_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim5pro",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3576 SoC octa core 8-64GB SoC 2*GBe eMMC USB3 NvME WIFI",
                    "efectn"
                    "edge",
                    "vendor"
                    "BOARDFAMILY": "rk35xx",
                    "BOARD_MAINTAINER": "efectn",
                        "efectn"
                    "BOARD_NAME": "Banana Pi M5 Pro",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "bananapim5pro/edge",
                    "BOOTCONFIG": "bananapi-m5-pro-rk3576_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3576-bananapi-m5-pro.dtb",
                    "KERNEL_TARGET": "edge,vendor"
            "pipeline": {},
            "target_id": "00000000620000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-rockchip64",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3576_bl31_v1.20.elf",
            "BOOTBRANCH": "branch:next-dev-v2024.10",
            "BOOTDELAY": "0",
            "BOOTENV_FILE": "rockchip64.txt",
            "BOOTPATCHDIR": "legacy/u-boot-radxa-rk35xx",
            "BOOTSCRIPT": "boot-rk3576.cmd:boot.cmd",
            "BOOTSOURCE": "https://github.com/radxa/u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/next-dev-v2024.10",
            "BOOT_SCENARIO": "spl-blobs",
            "BOOT_SOC": "rk3576",
            "BOOT_SOC_MKIMAGE": "rk3576",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3576_ddr_lp4_2112MHz_lp5_2736MHz_v1.08.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim5pro",
            "IMAGE_FILE_ID": "Bananapim5pro_sid_edge_7.0.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/rockchip64-7.0",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "rockchip64",
            "KERNEL_TARGET": "edge,vendor",
            "LINUXCONFIG": "linux-rockchip64-edge",
            "LINUXFAMILY": "rockchip64",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__rockchip64__arm64",
            "LOADER_UBOOT_OFFSET": "0x200000",
            "OFFSET": "16",
            "OVERLAY_DIR": "/boot/dtb/rockchip/overlay",
            "OVERLAY_PREFIX": "rk35xx",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "RKBIN_DIR": "/armbian/cache/sources/rkbin-tools",
            "SERIALCON": "ttyS0",
                "/armbian/config/boards/bananapim5pro.conf"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3576_bl31_v1.20.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=bananapim5pro'"
                "'BRANCH=edge'",
                "'BOARD=bananapim5pro'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rockchip64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=rockchip64-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rockchip64'",
                "'KERNELPATCHDIR=archive/rockchip64-7.0'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=legacy/u-boot-radxa-rk35xx'",
                "'BOOTSOURCE=https://github.com/radxa/u-boot.git'",
                "'BOOTBRANCH=branch:next-dev-v2024.10'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "efectn"
                    "edge",
                    "vendor"
                        "efectn"
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "bananapim5pro/vendor",
            "pipeline": {},
            "target_id": "00000000630000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
            "warn: Not-installing software-properties-common For distro 'Debian' release 'sid'\\n",
            "[LEAKED]:** No matches found for Bash declare regex (origin: unknown), line ==>declare -i KERNEL_GIT_CACHE_TTL=\"120\"<=="
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-rk35xx",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTDIR": "u-boot-rockchip64",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-rockchip64/next-dev-v2024.10",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim5pro_sid_vendor_6.1.y_xfce_desktop",
            "KERNELBRANCH": "branch:rk-6.1-rkr5.1",
            "KERNELPATCHDIR": "rk35xx-vendor-6.1",
            "KERNELSOURCE": "https://github.com/armbian/linux-rockchip.git",
                "@TODO",
            "KERNEL_MAJOR_MINOR": "6.1",
            "KERNEL_PATCH_ARCHIVE_BASE": "rk35xx",
            "LINUXCONFIG": "linux-rk35xx-vendor",
            "LINUXFAMILY": "rk35xx",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.1__rk35xx__arm64",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "SERIALCON": "ttyFIQ0",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BRANCH=vendor'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rk35xx-vendor'",
                "'ARMBIAN_KERNEL_DEB_NAME=rk35xx-vendor'",
                "'KERNELBRANCH=branch:rk-6.1-rkr5.1'",
                "'KERNEL_MAJOR_MINOR=6.1'",
                "'KERNELSOURCE=https://github.com/armbian/linux-rockchip.git'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rk35xx'",
                "'KERNELPATCHDIR=rk35xx-vendor-6.1'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim64",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner A64 quad core 2GB RAM SoC WiFi/BT eMMC GBE",
                    "devdotnetorg"
                    "current",
                    "edge",
                    "legacy"
                    "BOARDFAMILY": "sun50iw1",
                    "BOARD_MAINTAINER": "devdotnetorg",
                        "devdotnetorg"
                    "BOARD_NAME": "Banana Pi M64",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim64/current",
                    "BOOTCONFIG": "bananapi_m64_defconfig",
                    "BOOTCONFIG_DEFAULT": "sun50iw1p1_config",
                    "CRUSTCONFIG": "a64_defconfig",
            "pipeline": {},
            "target_id": "00000000640000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ASOUND_STATE": "asound.state.pinebook-next",
            "ATFDIR": "arm-trusted-firmware",
            "ATFSOURCE": "https://github.com/ARM-software/arm-trusted-firmware",
            "ATF_PLAT": "sun50i_a64",
            "ATF_TARGET_MAP": "PLAT=sun50i_a64 DEBUG=1 bl31;;build/sun50i_a64/debug/bl31.bin",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "BOOTDIR": "u-boot-crust",
            "BOOTPATCHDIR": "u-boot-sunxi u-boot-sunxi-crust",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-crust/v2024.01",
            "CPUMIN": "480000",
            "CRUSTBRANCH": "tag:v0.6",
            "CRUSTDIR": "crust-sunxi-mainline",
            "CRUSTSOURCE": "https://github.com/crust-firmware/crust",
            "CRUSTSOURCEDIR": "crust-sunxi-mainline/v0.6",
            "CRUST_COMPILER": "or1k-elf-",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim64",
            "IMAGE_FILE_ID": "Bananapim64_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "OVERLAY_PREFIX": "sun50i-a64",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapim64.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim64'"
                "'BRANCH=current'",
                "'BOARD=bananapim64'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-sunxi u-boot-sunxi-crust'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "devdotnetorg"
                    "current",
                    "edge",
                    "legacy"
                        "devdotnetorg"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim64/edge",
            "pipeline": {},
            "target_id": "00000000650000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim64_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "devdotnetorg"
                    "current",
                    "edge",
                    "legacy"
                        "devdotnetorg"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapim64/legacy",
            "pipeline": {},
            "target_id": "00000000660000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOARD_VENDOR": "sinovoip",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim64_sid_legacy_6.12.y_xfce_desktop",
                "@TODO",
            "KERNEL_TARGET": "current,edge,legacy",
            "LINUXCONFIG": "linux-sunxi64-legacy",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.12__sunxi64__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi64-legacy'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi64-legacy'",
                "'BRANCH=legacy'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapim7",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588 octa core 8-32GB RAM SoC 2*2.5GBe eMMC USB3 NvME WIFI",
                    "amazingfate"
                    "current",
                    "edge",
                    "vendor"
                    "BOARDFAMILY": "rockchip-rk3588",
                    "BOARD_MAINTAINER": "amazingfate",
                        "amazingfate"
                    "BOARD_NAME": "Banana Pi M7",
                        "current",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "bananapim7/current",
                    "BOOT_FDT_FILE": "rockchip/rk3588-bananapi-m7.dtb",
                    "KERNEL_TARGET": "current,edge,vendor",
                    "KERNEL_TEST_TARGET": "vendor,current"
            "pipeline": {},
            "target_id": "00000000670000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3588_bl31_v1.38.elf",
            "BOOTCONFIG": "armsom-sige7-rk3588_defconfig",
            "BOOTDELAY": "0",
            "BOOTENV_FILE": "rk35xx.txt",
            "BOOTSCRIPT": "boot-rockchip64.cmd:boot.cmd",
            "BOOT_SOC": "rk3588",
            "BOOT_SOC_MKIMAGE": "rk3588",
            "BOOT_SPI_RKSPI_LOADER": "yes",
            "BOOT_SUPPORT_SPI": "yes",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3588_ddr_lp4_2112MHz_lp5_2736MHz_v1.11.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapim7",
            "IMAGE_FILE_ID": "Bananapim7_sid_current_6.18.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/rockchip64-6.18",
                "@TODO",
            "KERNEL_TEST_TARGET": "vendor,current",
            "LINUXCONFIG": "linux-rockchip64-current",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__rockchip64__arm64",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rockchip-rk3588",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "ROCKUSB_BLOB": "rk35/rk3588_spl_loader_v1.16.113.bin",
            "SERIALCON": "ttyS2",
                "/armbian/config/boards/bananapim7.conf"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3588_bl31_v1.38.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb rkspi_loader.img",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapim7'"
                "'BRANCH=current'",
                "'BOARD=bananapim7'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rockchip64-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=rockchip64-current'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/rockchip64-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD_CORE_OR_USERPATCHED": "core",
                "BOARD_HAS_VIDEO": true,
                    "amazingfate"
                "BOARD_POSSIBLE_BRANCHES": [
                    "current",
                    "edge",
                    "vendor"
                "BOARD_TOP_LEVEL_VARS": {
                        "amazingfate"
                        "current",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "bananapim7/edge",
            "pipeline": {},
            "target_id": "00000000680000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "BUILD_DESKTOP": "yes",
                "BUILD_MINIMAL": "no",
                "DESKTOP_ENVIRONMENT": "xfce",
                "DESKTOP_ENVIRONMENT_CONFIG_NAME": "config_base",
                "RELEASE": "sid",
                "REVISION": "26.05.0-trunk"
        "logs": [
        "out": {
            "APT_MIRROR": "deb.debian.org/debian",
            "ARCH": "arm64",
            "ARMBIAN_ARTIFACTS_TO_HANDLERS_DICT": [
                "@TODO",
                "bash associative arrays aka dictionaries are not supported yet",
                "[armbian-base-files]=\"armbian-base-files\" [armbian-desktop]=\"armbian-desktop\" [armbian-bsp-desktop]=\"armbian-bsp-desktop\" [full_firmware]=\"full_firmware\" [armbian-zsh]=\"armbian-zsh\" [armbian-plymouth-theme]=\"armbian-plymouth-theme\" [fake_ubuntu_advantage_tools]=\"fake_ubuntu_advantage_tools\" [rootfs]=\"rootfs\" [armbian-bsp-cli]=\"armbian-bsp-cli\" [u-boot]=\"uboot\" [uboot]=\"uboot\" [kernel]=\"kernel\" [firmware]=\"firmware\" "
            "ARMBIAN_WILL_BUILD_UBOOT": "yes",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTDIR": "u-boot",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim7_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "amazingfate"
                    "current",
                    "edge",
                    "vendor"
                        "amazingfate"
                        "current",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "bananapim7/vendor",
            "pipeline": {},
            "target_id": "00000000690000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTSCRIPT": "boot-rk35xx.cmd:boot.cmd",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapim7_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BRANCH=vendor'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapipro",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner A20 dual core 1GB RAM SoC 1xSATA GBE Wifi",
                    "current",
                    "edge",
                    "legacy"
                    "BOARDFAMILY": "sun7i",
                    "BOARD_NAME": "Banana Pi Pro",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapipro/current",
                    "BOOTCONFIG": "Bananapro_defconfig",
                    "INTRODUCED": "2014",
                    "KERNEL_TEST_TARGET": "current"
            "pipeline": {},
            "target_id": "00000000700000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "current",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "ASOUND_STATE": "asound.state.sunxi-next",
            "ATFPATCHDIR": "atf-sunxi",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2024.01",
            "BOOTDELAY": "1",
            "BOOTENV_FILE": "sunxi.txt",
            "BOOTPATCHDIR": "u-boot-sunxi",
            "BOOTSCRIPT": "boot-sunxi.cmd:boot.cmd",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2024.01",
            "CHROOT_CACHE_VERSION": "7",
            "COMPRESS_OUTPUTIMAGE": "sha,img",
            "CONSOLE_AUTOLOGIN": "yes",
            "CONSOLE_CHAR": "UTF-8",
            "CPUMAX": "1010000",
            "CPUMIN": "480000",
            "CRUST_TARGET_MAP": "scp;;build/scp/scp.bin",
            "DEBIAN_MIRROR": "deb.debian.org/debian",
            "DEBIAN_SECURITY": "security.debian.org/",
            "DEB_COMPRESS": "none",
            "DEST_LANG": "en_US.UTF-8",
            "DISABLE_IPV6": "true",
            "DISTRIBUTION": "Debian",
            "EXIT_PATCHING_ERROR": "",
            "EXTRAWIFI": "yes",
            "EXTRA_BSP_NAME": "",
            "EXTRA_IMAGE_SUFFIX": "",
            "EXTRA_PACKAGES_IMAGE": [
                "@TODO",
                "bash simple-arrays are not supported yet",
                "[0]=\"chrony\" [1]=\"network-manager\" [2]=\"network-manager-openvpn\" [3]=\"netplan.io\" [4]=\"network-manager-gnome\" [5]=\"network-manager-ssh\" [6]=\"network-manager-vpnc\""
            "EXTRA_PACKAGES_IMAGE_REFS": [
                "@TODO",
                "[0]=\"extension_prepare_config__install_chrony:/armbian/extensions/network/net-chrony.sh:6\" [1]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [2]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [3]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [4]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [5]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [6]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\""
            "EXTRA_ROOTFS_MIB_SIZE": "0",
            "FAST_CREATE_IMAGE": "yes",
            "GHCR_SOURCE": "ghcr.io",
            "GITHUB_SOURCE": "https://github.com",
            "HOST": "bananapipro",
            "IMAGE_FILE_ID": "Bananapipro_sid_current_6.18.y_xfce_desktop",
            "IMAGE_TYPE": "user-built",
            "KERNELBRANCH": "branch:linux-6.18.y",
            "KERNELPATCHDIR": "archive/sunxi-6.18",
            "KERNELSOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "KERNEL_DRIVERS_SKIP": [
                "@TODO",
            "KERNEL_HAS_WORKING_HEADERS": "yes",
            "KERNEL_MAJOR": "6",
            "KERNEL_MAJOR_MINOR": "6.18",
            "KERNEL_PATCH_ARCHIVE_BASE": "sunxi",
            "KERNEL_TEST_TARGET": "current",
            "LANGUAGE": "en_US:en",
            "LINUXCONFIG": "linux-sunxi-current",
            "LINUXFAMILY": "sunxi",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__sunxi__armhf",
            "MAINLINE_FIRMWARE_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git",
            "MAINLINE_KERNEL_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "MAINLINE_UBOOT_DIR": "u-boot",
            "MAINLINE_UBOOT_SOURCE": "https://github.com/u-boot/u-boot",
            "MAINTAINER": "John Doe",
            "MAINTAINERMAIL": "john.doe@somewhere.on.planet",
            "MAIN_CMDLINE": "rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles",
            "NAMESERVER": "1.0.0.1",
            "NAME_INITRD": "uInitrd",
            "NETWORKING_STACK": "network-manager",
            "OFFSET": "4",
            "OVERLAY_DIR": "/boot/dtb/allwinner/overlay",
            "OVERLAY_PREFIX": "sun7i-a20",
            "PACKAGES_HASHED_STORAGE": "/armbian/output/packages-hashed",
            "PACKAGE_LIST_BOARD": [],
            "PACKAGE_LIST_BOARD_REMOVE": [],
            "PACKAGE_LIST_FAMILY_REMOVE": [],
            "PLYMOUTH": "yes",
            "REMOVE_PACKAGES": [
                "@TODO",
                "[0]=\"software-properties-common\" [1]=\"software-properties-gtk\" [2]=\"software-properties-common\""
            "REMOVE_PACKAGES_REFS": [
                "@TODO",
                "[0]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [1]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [2]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\""
            "ROOTFS_CACHE_MAX": "200",
            "ROOTFS_TYPE": "ext4",
            "SELECTED_CONFIGURATION": "desktop",
            "SHOW_WARNING": "yes",
            "SOURCED_BOARD_CONFIGS_FILENAME_LIST": [
                "/armbian/config/boards/bananapipro.csc"
            "TZDATA": "Etc/UTC",
            "UBOOT_FW_ENV": "0x88000,0x20000",
            "UBOOT_TARGET_MAP": ";;u-boot-sunxi-with-spl.bin",
            "UBUNTU_MIRROR": "ports.ubuntu.com/",
            "USE_CCACHE": "no",
            "VENDOR": "Armbian-unofficial",
            "VENDORBUGS": "https://armbian.atlassian.net/",
            "VENDORCOLOR": "247;16;0",
            "VENDORDOCS": "https://docs.armbian.com/",
            "VENDORLOGO": "armbian-logo",
            "VENDORPRIVACY": "https://duckduckgo.com/",
            "VENDORSUPPORT": "https://community.armbian.com/",
            "VENDORURL": "https://duckduckgo.com/",
            "WANT_ARTIFACT_ALL_ARRAY": [
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_BASE_FILES",
                "ARMBIAN_ZSH",
                "ARMBIAN_PLYMOUTH_THEME",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ARMBIAN_BSP_DESKTOP",
                "ROOTFS"
            "WANT_ARTIFACT_ALL_NAMES_ARRAY": [
                "uboot",
                "kernel",
                "firmware",
                "armbian-base-files",
                "armbian-zsh",
                "armbian-plymouth-theme",
                "armbian-bsp-cli",
                "armbian-desktop",
                "armbian-bsp-desktop",
                "rootfs"
            "WANT_ARTIFACT_ARMBIAN_BASE_FILES_INPUTS_ARRAY": [
                "'ARCH=armhf'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_BSP_CLI_INPUTS_ARRAY": [
                "'EXTRA_BSP_NAME='",
                "'BRANCH=current'",
                "'BOARD=bananapipro'"
            "WANT_ARTIFACT_ARMBIAN_BSP_DESKTOP_INPUTS_ARRAY": [
                "'BRANCH=current'",
                "'DESKTOP_ENVIRONMENT=xfce'",
                "'DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base'",
                "'BOARD=bananapipro'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_DESKTOP_INPUTS_ARRAY": [
                "'DESKTOP_AGGREGATION_RESULTS=8855c6119660c614d285554e51769066e94fcb75ff215ccc2fa6b4838b18756b'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_PLYMOUTH_THEME_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_ARMBIAN_ZSH_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_FIRMWARE_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_KERNEL_INPUTS_ARRAY": [
                "'LINUXCONFIG=linux-sunxi-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi-current'",
                "'KERNELBRANCH=branch:linux-6.18.y'",
                "'KERNEL_MAJOR_MINOR=6.18'",
                "'KERNELSOURCE=https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git'",
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=sunxi'",
                "'KERNELPATCHDIR=archive/sunxi-6.18'"
            "WANT_ARTIFACT_ROOTFS_INPUTS_ARRAY": [
                "'BUILD_MINIMAL=no'",
                "'SELECTED_CONFIGURATION=desktop'",
                "'DESKTOP_APPGROUPS_SELECTED=no_DESKTOP_APPGROUPS_SELECTED_set'",
                "'EXTRA_PKG_ADD_REMOVE_HASH=9484d87e17c18694c6beeb148595dde16586e36948cc22225c4564e1b0cee6fd'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_UBOOT_INPUTS_ARRAY": [
                "'BOOTPATCHDIR=u-boot-sunxi'",
                "'BOOTBRANCH=tag:v2024.01'",
                "'BRANCH=current'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapipro/edge",
            "pipeline": {},
            "target_id": "00000000710000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapipro_sid_edge_7.0.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-7.0.y",
            "KERNELPATCHDIR": "archive/sunxi-7.0",
                "@TODO",
            "KERNEL_MAJOR": "7",
            "KERNEL_MAJOR_MINOR": "7.0",
            "LINUXCONFIG": "linux-sunxi-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__sunxi__armhf",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi-edge'",
                "'KERNELBRANCH=branch:linux-7.0.y'",
                "'KERNEL_MAJOR_MINOR=7.0'",
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/sunxi-7.0'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "bananapipro/legacy",
            "pipeline": {},
            "target_id": "00000000720000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bananapipro_sid_legacy_6.12.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-6.12.y",
            "KERNELPATCHDIR": "archive/sunxi-6.12",
                "@TODO",
            "LINUXCONFIG": "linux-sunxi-legacy",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.12__sunxi__armhf",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi-legacy'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi-legacy'",
                "'KERNELBRANCH=branch:linux-6.12.y'",
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/sunxi-6.12'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapir2",
                "BOARD_FILE_HARDWARE_DESC": "Mediatek MT7623n quad core 2GB mPci 2xSATA 2xUSB3.0 5xGBE",
                    "current"
                    "BOARDFAMILY": "mt7623",
                    "BOARD_NAME": "Banana Pi R2",
                        "current"
                    "BOARD_SLASH_BRANCH": "bananapir2/current",
                    "BOOTCONFIG": "mt7623n_bpir2_defconfig",
                    "BOOT_FDT_FILE": "mediatek/mt7623n-bananapi-bpi-r2",
                    "HAS_VIDEO_OUTPUT": "yes",
                    "INTRODUCED": "2019",
                    "KERNEL_TARGET": "current",
            "pipeline": {},
            "target_id": "00000000730000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "ATFPATCHDIR": "atf-mt7623",
            "ATF_COMPILE": "no",
            "AUFS": "yes",
            "BOOTENV_FILE": "mt7623.txt",
            "BOOTSCRIPT": "boot-mt7623.cmd:boot.cmd",
            "CPUMAX": "1300000",
            "CPUMIN": "98000",
            "EXTRAWIFI": "no",
                "@TODO",
                "[0]=\"systemd-timesyncd\" [1]=\"netplan.io\""
                "@TODO",
                "[0]=\"extension_prepare_config__install_systemd-timesyncd:/armbian/extensions/network/net-systemd-timesyncd.sh:6\" [1]=\"extension_prepare_config__install_systemd_networkd:/armbian/extensions/network/net-systemd-networkd.sh:11\""
            "HOST": "bananapir2",
            "IMAGE_FILE_ID": "Bananapir2_sid_current_6.6.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-6.6.y",
            "KERNELPATCHDIR": "archive/mt7623-6.6",
                "@TODO",
            "KERNEL_MAJOR_MINOR": "6.6",
            "KERNEL_PATCH_ARCHIVE_BASE": "mt7623",
            "LINUXCONFIG": "linux-mt7623-current",
            "LINUXFAMILY": "mt7623",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.6__mt7623__armhf",
            "NETWORKING_STACK": "systemd-networkd",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bananapir2.csc"
            "UBOOT_TARGET_MAP": ";;/armbian/packages/blobs/mt7623n/BPI-R2-HEAD440-0k.img /armbian/packages/blobs/mt7623n/BPI-R2-HEAD1-512b.img /armbian/packages/blobs/mt7623n/BPI-R2-preloader-2k.img /armbian/packages/blobs/mt7623n/BPI-R2-EMMC-boot0-0K-0905.img u-boot.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapir2'"
                "'BRANCH=current'",
                "'BOARD=bananapir2'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-mt7623-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=mt7623-current'",
                "'KERNELBRANCH=branch:linux-6.6.y'",
                "'KERNEL_MAJOR_MINOR=6.6'",
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=mt7623'",
                "'KERNELPATCHDIR=archive/mt7623-6.6'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bananapir2pro",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3568 quad core 2GB-4GB 5GBE eMMC SATA USB3 Mini PCIE M.2 key-e",
                    "current",
                    "edge"
                    "ASOUND_STATE": "asound.state.station-p2",
                    "BOARDFAMILY": "rockchip64",
                    "BOARD_NAME": "Banana Pi R2 Pro",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapir2pro/current",
                    "BOOTBRANCH_BOARD": "tag:v2024.01",
                    "BOOTCONFIG": "bpi-r2-pro-rk3568_defconfig",
                    "BOOTPATCHDIR": "v2024.01",
                    "BOOT_FDT_FILE": "rockchip/rk3568-bpi-r2-pro.dtb",
                    "BOOT_LOGO": "desktop",
                    "FULL_DESKTOP": "yes",
                    "IMAGE_PARTITION_TABLE": "gpt",
                    "INTRODUCED": "2021",
                    "KERNEL_TARGET": "current,edge",
                    "SRC_CMDLINE": "console=ttyS02,1500000 console=tty0",
                    "SRC_EXTLINUX": "yes"
            "pipeline": {},
            "target_id": "00000000740000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
            "ARCHITECTURE": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "ATF_COMPILER": "aarch64-linux-gnu-",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3568_bl31_v1.44.elf",
            "BOOTDELAY": "0",
            "BOOT_SOC": "rk3568",
            "BOOT_SOC_MKIMAGE": "rk3568",
            "CPUMAX": "1992000",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3568_ddr_1560MHz_v1.21.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bananapir2pro",
            "IMAGE_FILE_ID": "Bananapir2pro_sid_current_6.18.y_xfce_desktop",
            "INITRD_ARCH": "arm64",
            "KERNEL_COMPILER": "aarch64-linux-gnu-",
                "@TODO",
            "KERNEL_IMAGE_TYPE": "Image",
            "KERNEL_INSTALL_TYPE": "install",
            "KERNEL_SRC_ARCH": "arm64",
            "NAME_KERNEL": "Image",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rockchip",
            "PACKAGE_LIST_FAMILY": [
                "ethtool"
            "PARTITION_TYPE_UUID_ROOT": "B921B045-1DF0-41C3-AF44-4C6F280D3FAE",
            "PLYMOUTH": "yes",
            "QEMU_BINARY": "qemu-aarch64-static",
            "QEMU_CPU": "cortex-a53",
                "@TODO",
                "@TODO",
            "ROCKUSB_BLOB": "rk35/rk356x_spl_loader_v1.21.113.bin",
                "/armbian/config/boards/bananapir2pro.csc"
            "SRC_EXTLINUX": "yes",
            "UBOOT_COMPILER": "aarch64-linux-gnu-",
            "UBOOT_TARGET_MAP": "ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3568_ddr_1560MHz_v1.21.bin BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3568_bl31_v1.44.elf spl/u-boot-spl u-boot.bin flash.bin;;idbloader.img u-boot.itb",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bananapir2pro'"
                "'BRANCH=current'",
                "'BOARD=bananapir2pro'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2024.01'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge"
                "BOARD_SUPPORT_LEVEL": "csc",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bananapir2pro/edge",
            "pipeline": {},
            "target_id": "00000000750000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOARD_TYPE": "csc",
            "BOOTDELAY": "0",
            "BOOTSOURCE": "https://github.com/u-boot/u-boot",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "GOVERNOR": "ondemand",
            "IMAGE_FILE_ID": "Bananapir2pro_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "beaglebone-ai64",
                "BOARD_FILE_HARDWARE_DESC": "BeagleBone AI-64 Texas Instruments TDA4VM dual core 4GB GBE USB3 OSPI DisplayPort HDMI",
                "BOARD_MAINTAINERS": [
                    "Grippy98"
                    "vendor",
                    "vendor-rt",
                    "edge"
                "BOARD_SUPPORT_LEVEL": "conf",
                    "ATF_BOARD": "generic",
                    "ATF_PLAT": "k3",
                    "BOARDFAMILY": "k3",
                    "BOARD_MAINTAINER": "Grippy98",
                        "Grippy98"
                    "BOARD_NAME": "BeagleBone AI-64",
                        "vendor",
                        "vendor-rt",
                        "edge"
                    "BOARD_SLASH_BRANCH": "beaglebone-ai64/vendor",
                    "BOARD_VENDOR": "beagleboard",
                    "BOOTCONFIG": "j721e_beagleboneai64_a72_defconfig",
                    "BOOTFS_TYPE": "fat",
                    "BOOT_FDT_FILE": "ti/k3-j721e-beagleboneai64.dts",
                    "BOOT_SOC": "j721e",
                    "DEFAULT_CONSOLE": "serial",
                    "INTRODUCED": "2022",
                    "KERNEL_TARGET": "vendor,vendor-rt,edge",
                    "KERNEL_TEST_TARGET": "vendor",
                    "OPTEE_ARGS": "",
                    "OPTEE_PLATFORM": "k3-j721e",
                    "SYSFW_FILE": "sysfw-j721e-gp-evm.itb",
                    "TIBOOT3_BOOTCONFIG": "j721e_beagleboneai64_r5_defconfig",
                    "TIBOOT3_FILE": "tiboot3-j721e-gp-evm.bin",
                    "TISPL_FILE": "tispl.bin_unsigned",
                    "UBOOT_FILE": "u-boot.img_unsigned"
            "pipeline": {},
            "target_id": "00000000760000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "APA_IS_ACTIVE": "true",
            "ARCH": "arm64",
                "@TODO",
            "ATFBRANCH": "commit:76500ceaeefcda967d8a1f4e30bb04f9fe0425a2",
            "ATFPATCHDIR": "atf-k3",
            "ATFSOURCEDIR": "arm-trusted-firmware/76500ceaeefcda967d8a1f4e30bb04f9fe0425a2",
            "ATF_COMPILE": "yes",
            "ATF_PLAT": "k3",
            "ATF_TARGET_MAP": "PLAT=k3 TARGET_BOARD=generic SPD=opteed  all;;build/k3/generic/release/bl31.bin:bl31.bin ",
            "AUFS": "yes",
            "BOARD_TYPE": "conf",
            "BOOTBRANCH": "tag:12.00.00.07",
            "BOOTPATCHDIR": "u-boot-k3",
            "BOOTSCRIPT": "boot-k3.cmd:uEnv.txt",
            "BOOTSOURCE": "https://github.com/TexasInstruments/ti-u-boot",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/12.00.00.07",
            "BOOT_FS_LABEL": "boot",
            "CLEAN_LEVEL": "make-atf,make-uboot",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "HOST": "beaglebone-ai64",
            "IMAGE_FILE_ID": "Beaglebone-ai64_sid_vendor_6.18.y_xfce_desktop",
            "IMAGE_PARTITION_TABLE": "msdos",
            "INSTALL_HEADERS": "yes",
            "KERNELBRANCH": "tag:12.00.00.07",
            "KERNELPATCHDIR": "archive/k3-6.18",
            "KERNELSOURCE": "https://github.com/TexasInstruments/ti-linux-kernel",
            "KERNEL_DESCRIPTION": "Texas Instruments currently supported Processor SDK kernel",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "k3",
            "LINUXCONFIG": "linux-k3-vendor",
            "LINUXFAMILY": "k3",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__k3__arm64",
            "OFFSET": "4",
            "OPTEE_ARGS": "",
            "OPTEE_BRANCH": "commit:f2a7ad0638aeff5243593b33cc56ad064cae7615",
            "OVERLAY_DIR": "/boot/dtb/ti/overlay",
            "PACKAGE_LIST_FAMILY": [],
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "ROOT_FS_LABEL": "root",
                "/armbian/config/boards/beaglebone-ai64.conf"
            "TI_LINUX_FIRMWARE_BRANCH": "tag:12.00.00.07",
            "TI_PACKAGES": [
                "@TODO",
            "TI_PSDK_TAG": "12.00.00.07",
            "UBOOT_FILE": "u-boot.img_unsigned",
            "UBOOT_TARGET_MAP": "BL31=bl31.bin  TEE=/armbian/cache/sources/optee-os/out/arm-plat-k3/core/tee-pager_v2.bin BINMAN_INDIRS=/armbian/cache/sources/ti-linux-firmware all;;tiboot3.bin sysfw.itb tispl.bin u-boot.img",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=beaglebone-ai64'"
                "'BRANCH=vendor'",
                "'BOARD=beaglebone-ai64'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-k3-vendor'",
                "'ARMBIAN_KERNEL_DEB_NAME=k3-vendor'",
                "'KERNELBRANCH=tag:12.00.00.07'",
                "'KERNELSOURCE=https://github.com/TexasInstruments/ti-linux-kernel'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=k3'",
                "'KERNELPATCHDIR=archive/k3-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-k3'",
                "'BOOTSOURCE=https://github.com/TexasInstruments/ti-u-boot'",
                "'BOOTBRANCH=tag:12.00.00.07'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "Grippy98"
                    "vendor",
                    "vendor-rt",
                    "edge"
                    "ATF_PLAT": "k3",
                        "Grippy98"
                        "vendor",
                        "vendor-rt",
                        "edge"
                    "BOARD_SLASH_BRANCH": "beaglebone-ai64/vendor-rt",
                    "OPTEE_ARGS": "",
            "pipeline": {},
            "target_id": "00000000770000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor-rt",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATF_PLAT": "k3",
            "AUFS": "yes",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Beaglebone-ai64_sid_vendor-rt_6.18.y_xfce_desktop",
                "@TODO",
            "LINUXCONFIG": "linux-k3-vendor-rt",
            "OFFSET": "4",
            "OPTEE_ARGS": "",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "TI_PACKAGES": [
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor-rt'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-k3-vendor-rt'",
                "'ARMBIAN_KERNEL_DEB_NAME=k3-vendor-rt'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=k3'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "Grippy98"
                    "vendor",
                    "vendor-rt",
                    "edge"
                    "ATF_PLAT": "k3",
                        "Grippy98"
                        "vendor",
                        "vendor-rt",
                        "edge"
                    "BOARD_SLASH_BRANCH": "beaglebone-ai64/edge",
                    "OPTEE_ARGS": "",
            "pipeline": {},
            "target_id": "00000000780000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFBRANCH": "branch:master",
            "ATFSOURCEDIR": "arm-trusted-firmware/master",
            "ATF_PLAT": "k3",
            "AUFS": "yes",
            "BOOTBRANCH": "branch:master",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/master",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Beaglebone-ai64_sid_edge_6.18.y_xfce_desktop",
            "KERNEL_DESCRIPTION": "Latest upstream mainline kernel",
                "@TODO",
            "LINUXCONFIG": "linux-k3-edge",
            "OFFSET": "4",
            "OPTEE_ARGS": "",
            "OPTEE_BRANCH": "branch:master",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "TI_LINUX_FIRMWARE_BRANCH": "branch:ti-linux-firmware",
            "TI_PACKAGES": [
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-k3-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=k3-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=k3'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTBRANCH=branch:master'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "beagleplay",
                "BOARD_FILE_HARDWARE_DESC": "BeaglePlay Texas Instruments AM62 quad core 2GB DDR4 eMMC GBE SPE HDMI",
                    "Grippy98"
                    "vendor",
                    "vendor-rt",
                    "edge"
                    "ATF_BOARD": "lite",
                    "ATF_PLAT": "k3",
                        "Grippy98"
                    "BOARD_NAME": "BeaglePlay",
                        "vendor",
                        "vendor-rt",
                        "edge"
                    "BOARD_SLASH_BRANCH": "beagleplay/vendor",
                    "BOOTCONFIG": "am62x_beagleplay_a53_defconfig",
                    "BOOT_FDT_FILE": "ti/k3-am625-beagleplay.dts",
                    "BOOT_SOC": "am62",
                    "OPTEE_ARGS": "CFG_TEE_CORE_LOG_LEVEL=1",
                    "OPTEE_PLATFORM": "k3-am62x",
                    "TIBOOT3_BOOTCONFIG": "am62x_beagleplay_r5_defconfig",
                    "TIBOOT3_FILE": "tiboot3-am62x-gp-evm.bin",
            "pipeline": {},
            "target_id": "00000000790000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATF_PLAT": "k3",
            "ATF_TARGET_MAP": "PLAT=k3 TARGET_BOARD=lite SPD=opteed  all;;build/k3/lite/release/bl31.bin:bl31.bin ",
            "AUFS": "yes",
            "BOOT_SOC": "am62",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "HOST": "beagleplay",
            "IMAGE_FILE_ID": "Beagleplay_sid_vendor_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/beagleplay.conf"
            "TI_PACKAGES": [
                "@TODO",
            "UBOOT_TARGET_MAP": "BL31=bl31.bin  TEE=/armbian/cache/sources/optee-os/out/arm-plat-k3/core/tee-pager_v2.bin BINMAN_INDIRS=/armbian/cache/sources/ti-linux-firmware all;;tiboot3.bin  tispl.bin u-boot.img",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=beagleplay'"
                "'BRANCH=vendor'",
                "'BOARD=beagleplay'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=k3'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "Grippy98"
                    "vendor",
                    "vendor-rt",
                    "edge"
                    "ATF_PLAT": "k3",
                        "Grippy98"
                        "vendor",
                        "vendor-rt",
                        "edge"
                    "BOARD_SLASH_BRANCH": "beagleplay/vendor-rt",
                    "BOOT_SOC": "am62",
            "pipeline": {},
            "target_id": "00000000800000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATF_PLAT": "k3",
            "AUFS": "yes",
            "BOOT_SOC": "am62",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Beagleplay_sid_vendor-rt_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "TI_PACKAGES": [
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=k3'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "Grippy98"
                    "vendor",
                    "vendor-rt",
                    "edge"
                    "ATF_PLAT": "k3",
                        "Grippy98"
                        "vendor",
                        "vendor-rt",
                        "edge"
                    "BOARD_SLASH_BRANCH": "beagleplay/edge",
                    "BOOT_SOC": "am62",
            "pipeline": {},
            "target_id": "00000000810000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATF_PLAT": "k3",
            "AUFS": "yes",
            "BOOT_SOC": "am62",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Beagleplay_sid_edge_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "TI_PACKAGES": [
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=k3'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTSOURCE=https://github.com/u-boot/u-boot'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "beagley-ai",
                "BOARD_FILE_HARDWARE_DESC": "BeagleY-AI Texas Instruments AM67A quad core 4GB DDR4 USB3  4TOPS",
                    "Grippy98"
                    "vendor",
                    "vendor-rt",
                    "edge"
                    "ATF_PLAT": "k3",
                    "BOARDFAMILY": "k3-beagle",
                        "Grippy98"
                    "BOARD_NAME": "BeagleY-AI",
                        "vendor",
                        "vendor-rt",
                        "edge"
                    "BOARD_SLASH_BRANCH": "beagley-ai/vendor",
                    "BOOTCONFIG": "am67a_beagley_ai_a53_defconfig",
                    "BOOT_FDT_FILE": "k3-am67a-beagley-ai.dts",
                    "BOOT_SOC": "j722s",
                    "CC33XX_SUPPORT": "yes",
                    "INTRODUCED": "2024",
                    "OPTEE_ARGS": "",
                    "TIBOOT3_BOOTCONFIG": "am67a_beagley_ai_r5_defconfig",
                    "TIBOOT3_FILE": "tiboot3-j722s-hs-fs-evm.bin"
            "pipeline": {},
            "target_id": "00000000820000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFBRANCH": "tag:11.00.09",
            "ATFPATCHDIR": "atf-k3-beagle",
            "ATFSOURCE": "https://github.com/TexasInstruments/arm-trusted-firmware",
            "ATFSOURCEDIR": "arm-trusted-firmware/11.00.09",
            "ATF_PLAT": "k3",
            "AUFS": "yes",
            "BOOTBRANCH": "branch:v2025.07-am6232-pocketbeagle2",
            "BOOTPATCHDIR": "u-boot-k3-beagle",
            "BOOTSOURCE": "https://github.com/beagleboard/u-boot",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2025.07-am6232-pocketbeagle2",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "HOST": "beagley-ai",
            "IMAGE_FILE_ID": "Beagley-ai_sid_vendor_6.12.y_xfce_desktop",
            "KERNELBRANCH": "branch:v6.12.49-ti-arm64-r56",
            "KERNELPATCHDIR": "archive/k3-beagle-6.12",
            "KERNELSOURCE": "https://github.com/beagleboard/linux",
            "KERNEL_DESCRIPTION": "BeagleBoard.org (vendor) kernel",
                "@TODO",
            "KERNEL_MAJOR_MINOR": "6.12",
            "KERNEL_PATCH_ARCHIVE_BASE": "k3-beagle",
            "LINUXCONFIG": "linux-k3-beagle-vendor",
            "LINUXFAMILY": "k3-beagle",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.12__k3-beagle__arm64",
            "OFFSET": "4",
            "OPTEE_ARGS": "",
            "OPTEE_BRANCH": "tag:4.6.0",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/beagley-ai.conf"
            "TIBOOT3_FILE": "tiboot3-j722s-hs-fs-evm.bin",
            "TI_LINUX_FIRMWARE_BRANCH": "tag:11.00.09",
            "TI_PACKAGES": [
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=beagley-ai'"
                "'BRANCH=vendor'",
                "'BOARD=beagley-ai'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-k3-beagle-vendor'",
                "'ARMBIAN_KERNEL_DEB_NAME=k3-beagle-vendor'",
                "'KERNELBRANCH=branch:v6.12.49-ti-arm64-r56'",
                "'KERNEL_MAJOR_MINOR=6.12'",
                "'KERNELSOURCE=https://github.com/beagleboard/linux'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=k3-beagle'",
                "'KERNELPATCHDIR=archive/k3-beagle-6.12'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-k3-beagle'",
                "'BOOTSOURCE=https://github.com/beagleboard/u-boot'",
                "'BOOTBRANCH=branch:v2025.07-am6232-pocketbeagle2'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "Grippy98"
                    "vendor",
                    "vendor-rt",
                    "edge"
                    "ATF_PLAT": "k3",
                        "Grippy98"
                        "vendor",
                        "vendor-rt",
                        "edge"
                    "BOARD_SLASH_BRANCH": "beagley-ai/vendor-rt",
                    "OPTEE_ARGS": "",
            "pipeline": {},
            "target_id": "00000000830000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATF_PLAT": "k3",
            "AUFS": "yes",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Beagley-ai_sid_vendor-rt_6.12.y_xfce_desktop",
                "@TODO",
            "LINUXCONFIG": "linux-k3-beagle-vendor-rt",
            "OFFSET": "4",
            "OPTEE_ARGS": "",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "TI_PACKAGES": [
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-k3-beagle-vendor-rt'",
                "'ARMBIAN_KERNEL_DEB_NAME=k3-beagle-vendor-rt'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "Grippy98"
                    "vendor",
                    "vendor-rt",
                    "edge"
                    "ATF_PLAT": "k3",
                        "Grippy98"
                        "vendor",
                        "vendor-rt",
                        "edge"
                    "BOARD_SLASH_BRANCH": "beagley-ai/edge",
                    "OPTEE_ARGS": "",
            "pipeline": {},
            "target_id": "00000000840000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATF_PLAT": "k3",
            "AUFS": "yes",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Beagley-ai_sid_edge_6.18.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/k3-beagle-6.18",
                "@TODO",
            "LINUXCONFIG": "linux-k3-beagle-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__k3-beagle__arm64",
            "OFFSET": "4",
            "OPTEE_ARGS": "",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "TI_PACKAGES": [
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-k3-beagle-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=k3-beagle-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/k3-beagle-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "beelinkx2",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner H3 quad core 1GB SoC WiFi eMMC",
                "BOARD_MAINTAINERS": [],
                    "current",
                    "edge",
                    "legacy"
                "BOARD_SUPPORT_LEVEL": "tvb",
                    "BOARDFAMILY": "sun8i",
                    "BOARD_MAINTAINER": "",
                    "BOARD_NAME": "Beelink X2",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "beelinkx2/current",
                    "BOARD_VENDOR": "beelink",
                    "BOOTCONFIG": "beelink_x2_defconfig",
            "pipeline": {},
            "target_id": "00000000850000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
            "ARCHITECTURE": "arm",
                "@TODO",
            "AUFS": "yes",
            "BOARD_TYPE": "tvb",
            "BOOTDELAY": "1",
            "CPUMAX": "1400000",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "beelinkx2",
            "IMAGE_FILE_ID": "Beelinkx2_sid_current_6.18.y_xfce_desktop",
            "INITRD_ARCH": "arm",
            "KERNEL_COMPILER": "arm-linux-gnueabihf-",
                "@TODO",
            "KERNEL_SRC_ARCH": "arm",
            "OFFSET": "4",
            "OVERLAY_PREFIX": "sun8i-h3",
            "PARTITION_TYPE_UUID_ROOT": "69DAD710-2CE4-4E3C-B16C-21A1D49ABED3",
            "PLYMOUTH": "yes",
            "QEMU_BINARY": "qemu-arm-static",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/beelinkx2.tvb"
            "UBOOT_COMPILER": "arm-linux-gnueabihf-",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=beelinkx2'"
                "'BRANCH=current'",
                "'BOARD=beelinkx2'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'BOARD=beelinkx2'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "beelinkx2/edge",
            "pipeline": {},
            "target_id": "00000000860000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Beelinkx2_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=beelinkx2'"
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'BOARD=beelinkx2'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "beelinkx2/legacy",
                    "INTRODUCED": "2015",
            "pipeline": {},
            "target_id": "00000000870000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Beelinkx2_sid_legacy_6.12.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BOARD=beelinkx2'"
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'BOARD=beelinkx2'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bestv-r3300-l",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic S905L-B 1GB RAM 8GB eMMC microSD FE USB2 RTL8189FTV WiFi",
                    "retro98boy"
                    "current",
                    "edge"
                    "BOARDFAMILY": "meson-gxl",
                    "BOARD_MAINTAINER": "retro98boy",
                        "retro98boy"
                    "BOARD_NAME": "BesTV R3300-L",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bestv-r3300-l/current",
                    "BOARD_VENDOR": "bestv",
                    "BOOTBRANCH_BOARD": "tag:v2026.01",
                    "BOOTCONFIG": "bestv-r3300-l_defconfig",
                    "BOOTPATCHDIR": "v2026.01",
                    "BOOT_FDT_FILE": "amlogic/meson-gxl-s905x-bestv-r3300-l.dtb",
                    "PACKAGE_LIST_BOARD": "alsa-ucm-conf",
                    "SERIALCON": "ttyAML0"
            "pipeline": {},
            "target_id": "00000000880000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-meson64",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2026.01",
            "BOOTENV_FILE": "meson.txt",
            "BOOTSCRIPT": "boot-meson64.cmd:boot.cmd",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2026.01",
            "CPUMAX": "1536000",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bestv-r3300-l",
            "IMAGE_FILE_ID": "Bestv-r3300-l_sid_current_6.18.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/meson64-6.18",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "meson64",
            "LINUXCONFIG": "linux-meson64-current",
            "LINUXFAMILY": "meson64",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__meson64__arm64",
            "OFFSET": "4",
            "OVERLAY_DIR": "/boot/dtb/amlogic/overlay",
            "OVERLAY_PREFIX": "meson",
                "alsa-ucm-conf"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "SERIALCON": "ttyAML0",
                "/armbian/config/boards/bestv-r3300-l.csc"
            "SRC_LOADADDR": "LOADADDR=0x1080000",
            "UBOOT_TARGET_MAP": "u-boot.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bestv-r3300-l'"
                "'BRANCH=current'",
                "'BOARD=bestv-r3300-l'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-meson64-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=meson64-current'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=meson64'",
                "'KERNELPATCHDIR=archive/meson64-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2026.01'",
                "'BOOTBRANCH=tag:v2026.01'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "retro98boy"
                    "current",
                    "edge"
                        "retro98boy"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bestv-r3300-l/edge",
            "pipeline": {},
            "target_id": "00000000890000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bestv-r3300-l_sid_edge_7.0.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/meson64-7.0",
                "@TODO",
            "LINUXCONFIG": "linux-meson64-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__meson64__arm64",
            "OFFSET": "4",
                "alsa-ucm-conf"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-meson64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=meson64-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/meson64-7.0'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bigtreetech-cb1",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner H616 quad core 512MB/1GB RAM SoC WiFi",
                    "JohnTheCoolingFan"
                    "current",
                    "edge"
                    "BOARDFAMILY": "sun50iw9",
                    "BOARD_MAINTAINER": "JohnTheCoolingFan",
                        "JohnTheCoolingFan"
                    "BOARD_NAME": "BigTreeTech CB1",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bigtreetech-cb1/current",
                    "BOARD_VENDOR": "bigtreetech",
                    "BOOTCONFIG": "bigtreetech_cb1_defconfig",
                    "BOOT_FDT_FILE": "sun50i-h616-bigtreetech-cb1-sd.dtb",
                    "BOOT_FS_LABEL": "BOOT",
                    "OVERLAY_PREFIX": "sun50i-h616",
            "pipeline": {},
            "target_id": "00000000900000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFBRANCH": "tag:lts-v2.12.9",
            "ATFPATCHDIR": "atf-sunxi64",
            "ATFSOURCEDIR": "arm-trusted-firmware/lts-v2.12.9",
            "ATF_PLAT": "sun50i_h616",
            "ATF_TARGET_MAP": "PLAT=sun50i_h616 DEBUG=1 bl31;;build/sun50i_h616/debug/bl31.bin",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "BOOTSCRIPT": "boot-sun50i-next.cmd:boot.cmd",
            "CPUMAX": "1512000",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bigtreetech-cb1",
            "IMAGE_FILE_ID": "Bigtreetech-cb1_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "sunxi64",
            "LINUXCONFIG": "linux-sunxi64-current",
            "LINUXFAMILY": "sunxi64",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__sunxi64__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bigtreetech-cb1.conf"
            "UBOOT_TARGET_MAP": "BINMAN_ALLOW_MISSING=1;;u-boot-sunxi-with-spl.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bigtreetech-cb1'"
                "'BRANCH=current'",
                "'BOARD=bigtreetech-cb1'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi64-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi64-current'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=sunxi64'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "JohnTheCoolingFan"
                    "current",
                    "edge"
                        "JohnTheCoolingFan"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bigtreetech-cb1/edge",
                    "FORCE_BOOTSCRIPT_UPDATE": "yes",
            "pipeline": {},
            "target_id": "00000000910000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bigtreetech-cb1_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "LINUXCONFIG": "linux-sunxi64-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__sunxi64__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi64-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "bigtreetech-cb2",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3566 quad core 2GB-8GB GBE eMMC NVMe USB3 WiFi",
                    "JohnTheCoolingFan"
                    "current",
                    "edge"
                        "JohnTheCoolingFan"
                    "BOARD_NAME": "BigTreeTech CB2",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bigtreetech-cb2/current",
                    "BOOTCONFIG": "bigtreetech-cb2-rk3566_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3566-bigtreetech-pi2.dtb",
                    "BOOT_SOC": "rk3566",
                    "OVERLAY_PREFIX": "rk3566"
            "pipeline": {},
            "target_id": "00000000920000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2024.10",
            "BOOTDELAY": "1",
            "BOOTPATCHDIR": "v2024.10/board_bigtreetech-cb2",
            "BOOTSOURCE": "https://github.com/u-boot/u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2024.10",
            "CPUMAX": "1800000",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3566_ddr_1056MHz_v1.21.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "bigtreetech-cb2",
            "IMAGE_FILE_ID": "Bigtreetech-cb2_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rk3566",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/bigtreetech-cb2.conf"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3568_bl31_v1.44.elf ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3566_ddr_1056MHz_v1.21.bin;;u-boot-rockchip.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=bigtreetech-cb2'"
                "'BRANCH=current'",
                "'BOARD=bigtreetech-cb2'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2024.10/board_bigtreetech-cb2'",
                "'BOOTSOURCE=https://github.com/u-boot/u-boot.git'",
                "'BOOTBRANCH=tag:v2024.10'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "JohnTheCoolingFan"
                    "current",
                    "edge"
                        "JohnTheCoolingFan"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "bigtreetech-cb2/edge",
            "pipeline": {},
            "target_id": "00000000930000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Bigtreetech-cb2_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "cainiao-cniot-core",
                "BOARD_FILE_HARDWARE_DESC": "Amlogic A311D 2GB RAM 16GB eMMC GBE USB3 RTL8822CS WiFi/BT",
                    "retro98boy"
                    "current",
                    "edge"
                    "BOARDFAMILY": "meson-g12b",
                        "retro98boy"
                    "BOARD_NAME": "CAINIAO CNIoT-CORE",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "cainiao-cniot-core/current",
                    "BOARD_VENDOR": "cainiao",
                    "BOOTCONFIG": "cainiao-cniot-core_defconfig",
                    "BOOT_FDT_FILE": "amlogic/meson-g12b-a311d-cainiao-cniot-core.dtb",
                    "MODULES_BLACKLIST": "simpledrm",
            "pipeline": {},
            "target_id": "00000000940000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ASOUND_STATE": "asound.state.meson64",
            "AUFS": "yes",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "cainiao-cniot-core",
            "IMAGE_FILE_ID": "Cainiao-cniot-core_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
                "alsa-ucm-conf"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/cainiao-cniot-core.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=cainiao-cniot-core'"
                "'BRANCH=current'",
                "'BOARD=cainiao-cniot-core'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "retro98boy"
                    "current",
                    "edge"
                        "retro98boy"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "cainiao-cniot-core/edge",
            "pipeline": {},
            "target_id": "00000000950000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "CPUMIN": "500000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Cainiao-cniot-core_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
                "alsa-ucm-conf"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "cherryba-m1",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner H618 quad core 1GB 2GB 4GB RAM SoC WiFi USB-C emmc",
                    "IsMrX"
                    "current",
                    "edge"
                    "BOARD_MAINTAINER": "IsMrX",
                        "IsMrX"
                    "BOARD_NAME": "CherryBa M1",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "cherryba-m1/current",
                    "BOARD_VENDOR": "allwinner",
                    "BOOTBRANCH_BOARD": "tag:v2025.04",
                    "BOOTCONFIG": "cherryba-m1_defconfig",
                    "BOOTPATCHDIR": "v2025.04",
                    "KERNEL_TEST_TARGET": "current,edge"
            "pipeline": {},
            "target_id": "00000000960000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "cherryba-m1",
            "IMAGE_FILE_ID": "Cherryba-m1_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "KERNEL_TEST_TARGET": "current,edge",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/cherryba-m1.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=cherryba-m1'"
                "'BRANCH=current'",
                "'BOARD=cherryba-m1'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2025.04'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "IsMrX"
                    "current",
                    "edge"
                        "IsMrX"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "cherryba-m1/edge",
            "pipeline": {},
            "target_id": "00000000970000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
            "warn: Not-installing software-properties-common For distro 'Debian' release 'sid'\\n"
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Cherryba-m1_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "clockworkpi-a06",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3399 hexa core 4GB RAM SoC WiFi/BT",
                    "current",
                    "edge"
                    "BOARD_NAME": "Clockworkpi A06",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "clockworkpi-a06/current",
                    "BOARD_VENDOR": "clockwork",
                    "BOOTBRANCH_BOARD": "tag:v2022.04",
                    "BOOTCONFIG": "clockworkpi-a06-rk3399_defconfig",
                    "BOOTPATCHDIR": "u-boot-rockchip64-v2022.04",
                    "BOOT_LOGO": "no",
                    "INTRODUCED": "2020",
            "pipeline": {},
            "target_id": "00000000980000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-rockchip64",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk33/rk3399_bl31_v1.35.elf",
            "BOOTBRANCH": "tag:v2022.04",
            "BOOTDELAY": "0",
            "BOOTENV_FILE": "rockchip64.txt",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2022.04",
            "BOOT_LOGO": "no",
            "BOOT_SCENARIO": "only-blobs",
            "BOOT_SOC": "rk3399",
            "BOOT_SOC_MKIMAGE": "rk3399",
            "CPUMAX": "2016000",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk33/rk3399_ddr_933MHz_v1.25.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "clockworkpi-a06",
            "IMAGE_FILE_ID": "Clockworkpi-a06_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "rockchip64",
            "LINUXFAMILY": "rockchip64",
            "LOADER_UBOOT_OFFSET": "0x200000",
            "MINILOADER_BLOB": "rk33/rk3399_miniloader_v1.26.bin",
            "OFFSET": "16",
            "OVERLAY_DIR": "/boot/dtb/rockchip/overlay",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "RKBIN_DIR": "/armbian/cache/sources/rkbin-tools",
                "/armbian/config/boards/clockworkpi-a06.csc"
            "UBOOT_TARGET_MAP": "u-boot-dtb.bin;;idbloader.bin uboot.img trust.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=clockworkpi-a06'"
                "'BRANCH=current'",
                "'BOARD=clockworkpi-a06'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rockchip64'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-rockchip64-v2022.04'",
                "'BOOTBRANCH=tag:v2022.04'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "clockworkpi-a06/edge",
                    "BOOT_LOGO": "no",
            "pipeline": {},
            "target_id": "00000000990000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOT_LOGO": "no",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Clockworkpi-a06_sid_edge_7.0.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/rockchip64-7.0",
                "@TODO",
            "LINUXCONFIG": "linux-rockchip64-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__rockchip64__arm64",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rockchip64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=rockchip64-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/rockchip64-7.0'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "cm3588-nas",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588 octa core 16GB RAM SoC eMMC 4x NVMe 2x USB3 USB2 USB-C 2.5GbE",
                    "ColorfulRhino"
                    "current",
                    "edge",
                    "vendor"
                    "BOARD_MAINTAINER": "ColorfulRhino",
                        "ColorfulRhino"
                    "BOARD_NAME": "FriendlyElec CM3588 NAS",
                        "current",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "cm3588-nas/current",
                    "BOARD_VENDOR": "friendlyelec",
                    "BOOTCONFIG": "cm3588-nas-rk3588_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3588-friendlyelec-cm3588-nas.dtb",
                    "BOOT_SCENARIO": "tpl-blob-atf-mainline",
                    "INTRODUCED": "2023",
                    "UEFI_EDK2_BOARD_ID": "nanopc-cm3588-nas"
            "pipeline": {},
            "target_id": "00000001000000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFBRANCH": "tag:v2.13.0",
            "ATFDIR": "arm-trusted-firmware",
            "ATFPATCHDIR": "atf-rockchip64/v2.13",
            "ATFSOURCE": "https://github.com/ARM-software/arm-trusted-firmware",
            "ATFSOURCEDIR": "arm-trusted-firmware/v2.13.0",
            "ATF_TARGET_MAP": "M0_CROSS_COMPILE=arm-linux-gnueabi- PLAT=rk3588 bl31;;build/rk3588/release/bl31/bl31.elf:bl31.elf",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3588_bl31_v1.48.elf",
            "BOARDFAMILY": "rockchip-rk3588",
            "BOOTBRANCH": "tag:v2026.04",
            "BOOTDELAY": "1",
            "BOOTDIR": "u-boot-cm3588-nas",
            "BOOTPATCHDIR": "v2026.04",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-cm3588-nas/v2026.04",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.18.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "cm3588-nas",
            "IMAGE_FILE_ID": "Cm3588-nas_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "KERNEL_TARGET": "current,edge,vendor",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/cm3588-nas.csc"
            "UBOOT_TARGET_MAP": "BL31=bl31.elf ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.18.bin;;u-boot-rockchip.bin",
            "UEFI_EDK2_BOARD_ID": "nanopc-cm3588-nas",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=cm3588-nas'"
                "'BRANCH=current'",
                "'BOARD=cm3588-nas'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2026.04'",
                "'BOOTBRANCH=tag:v2026.04'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "ColorfulRhino"
                    "current",
                    "edge",
                    "vendor"
                        "ColorfulRhino"
                        "current",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "cm3588-nas/edge",
                    "BOOT_SOC": "rk3588",
            "pipeline": {},
            "target_id": "00000001010000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "BOOTENV_FILE": "rk35xx.txt",
            "BOOTSCRIPT": "boot-rockchip64.cmd:boot.cmd",
            "BOOT_SOC_MKIMAGE": "rk3588",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Cm3588-nas_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rockchip-rk3588",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "ROCKUSB_BLOB": "rk35/rk3588_spl_loader_v1.16.113.bin",
            "SERIALCON": "ttyS2",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD_CORE_OR_USERPATCHED": "core",
                "BOARD_HAS_VIDEO": true,
                    "ColorfulRhino"
                "BOARD_POSSIBLE_BRANCHES": [
                    "current",
                    "edge",
                    "vendor"
                "BOARD_TOP_LEVEL_VARS": {
                        "ColorfulRhino"
                        "current",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "cm3588-nas/vendor",
            "pipeline": {},
            "target_id": "00000001020000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "BUILD_DESKTOP": "yes",
                "BUILD_MINIMAL": "no",
                "DESKTOP_ENVIRONMENT": "xfce",
                "DESKTOP_ENVIRONMENT_CONFIG_NAME": "config_base",
                "RELEASE": "sid",
                "REVISION": "26.05.0-trunk"
        "logs": [
            "warn: Not-installing software-properties-common For distro 'Debian' release 'sid'\\n",
            "[LEAKED]:** No matches found for Bash declare regex (origin: unknown), line ==>declare -i KERNEL_GIT_CACHE_TTL=\"120\"<=="
        "out": {
            "APT_MIRROR": "deb.debian.org/debian",
            "ARCH": "arm64",
            "ARMBIAN_ARTIFACTS_TO_HANDLERS_DICT": [
                "@TODO",
                "bash associative arrays aka dictionaries are not supported yet",
                "[armbian-base-files]=\"armbian-base-files\" [armbian-desktop]=\"armbian-desktop\" [armbian-bsp-desktop]=\"armbian-bsp-desktop\" [full_firmware]=\"full_firmware\" [armbian-zsh]=\"armbian-zsh\" [armbian-plymouth-theme]=\"armbian-plymouth-theme\" [fake_ubuntu_advantage_tools]=\"fake_ubuntu_advantage_tools\" [rootfs]=\"rootfs\" [armbian-bsp-cli]=\"armbian-bsp-cli\" [u-boot]=\"uboot\" [uboot]=\"uboot\" [kernel]=\"kernel\" [firmware]=\"firmware\" "
            "ARMBIAN_WILL_BUILD_UBOOT": "yes",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Cm3588-nas_sid_vendor_6.1.y_xfce_desktop",
            "KERNELBRANCH": "branch:rk-6.1-rkr5.1",
            "KERNELPATCHDIR": "rk35xx-vendor-6.1",
            "KERNELSOURCE": "https://github.com/armbian/linux-rockchip.git",
                "@TODO",
            "KERNEL_MAJOR_MINOR": "6.1",
            "KERNEL_PATCH_ARCHIVE_BASE": "rk35xx",
            "LINUXCONFIG": "linux-rk35xx-vendor",
            "LINUXFAMILY": "rk35xx",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.1__rk35xx__arm64",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "SERIALCON": "ttyFIQ0",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BRANCH=vendor'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rk35xx-vendor'",
                "'ARMBIAN_KERNEL_DEB_NAME=rk35xx-vendor'",
                "'KERNELBRANCH=branch:rk-6.1-rkr5.1'",
                "'KERNEL_MAJOR_MINOR=6.1'",
                "'KERNELSOURCE=https://github.com/armbian/linux-rockchip.git'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rk35xx'",
                "'KERNELPATCHDIR=rk35xx-vendor-6.1'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "coolpi-cm5",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588 SoC octa core 4-16GB SoC 2.5GBe PoE eMMC USB3 NVME",
                    "andyshrk"
                    "edge"
                    "BOARD_FIRMWARE_INSTALL": "-full",
                    "BOARD_MAINTAINER": "andyshrk",
                        "andyshrk"
                    "BOARD_NAME": "CoolPi CM5",
                        "edge"
                    "BOARD_SLASH_BRANCH": "coolpi-cm5/edge",
                    "BOARD_VENDOR": "cool-pi",
                    "BOOTCONFIG": "coolpi-cm5-evb-rk3588_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3588-coolpi-cm5-evb.dtb",
                    "BOOT_SCENARIO": "spl-blobs",
                    "BOOT_SPI_RKSPI_LOADER": "yes",
                    "BOOT_SUPPORT_SPI": "yes",
                    "KERNEL_TARGET": "edge"
            "pipeline": {},
            "target_id": "00000001030000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2024.07",
            "BOOTBRANCH_BOARD": "tag:v2024.07",
            "BOOTDELAY": "0",
            "BOOTDIR": "u-boot-coolpi-cm5",
            "BOOTPATCHDIR": "v2024.07-coolpi-cm5",
            "BOOTSOURCE": "https://github.com/Kwiboo/u-boot-rockchip.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-coolpi-cm5/v2024.07",
            "CHROOT_CACHE_VERSION": "7",
            "COMPRESS_OUTPUTIMAGE": "sha,img",
            "CONSOLE_AUTOLOGIN": "yes",
            "CONSOLE_CHAR": "UTF-8",
            "CPUMIN": "408000",
            "DEBIAN_MIRROR": "deb.debian.org/debian",
            "DEBIAN_SECURITY": "security.debian.org/",
            "DEB_COMPRESS": "none",
            "DEST_LANG": "en_US.UTF-8",
            "DISABLE_IPV6": "true",
            "DISTRIBUTION": "Debian",
            "EXIT_PATCHING_ERROR": "",
            "EXTRAWIFI": "yes",
            "EXTRA_BSP_NAME": "",
            "EXTRA_IMAGE_SUFFIX": "",
            "EXTRA_PACKAGES_IMAGE": [
                "@TODO",
                "bash simple-arrays are not supported yet",
                "[0]=\"chrony\" [1]=\"network-manager\" [2]=\"network-manager-openvpn\" [3]=\"netplan.io\" [4]=\"network-manager-gnome\" [5]=\"network-manager-ssh\" [6]=\"network-manager-vpnc\""
            "EXTRA_PACKAGES_IMAGE_REFS": [
                "@TODO",
                "[0]=\"extension_prepare_config__install_chrony:/armbian/extensions/network/net-chrony.sh:6\" [1]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [2]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [3]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [4]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [5]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [6]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\""
            "EXTRA_ROOTFS_MIB_SIZE": "0",
            "FAST_CREATE_IMAGE": "yes",
            "GHCR_SOURCE": "ghcr.io",
            "GITHUB_SOURCE": "https://github.com",
            "HOST": "coolpi-cm5",
            "IMAGE_FILE_ID": "Coolpi-cm5_sid_edge_7.0.y_xfce_desktop",
            "IMAGE_TYPE": "user-built",
            "KERNELSOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "KERNEL_DRIVERS_SKIP": [
                "@TODO",
            "KERNEL_HAS_WORKING_HEADERS": "yes",
            "KERNEL_TARGET": "edge",
            "LANGUAGE": "en_US:en",
            "MAINLINE_FIRMWARE_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git",
            "MAINLINE_KERNEL_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "MAINLINE_UBOOT_DIR": "u-boot",
            "MAINLINE_UBOOT_SOURCE": "https://github.com/u-boot/u-boot",
            "MAINTAINER": "John Doe",
            "MAINTAINERMAIL": "john.doe@somewhere.on.planet",
            "MAIN_CMDLINE": "rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles",
            "NAMESERVER": "1.0.0.1",
            "NAME_INITRD": "uInitrd",
            "NETWORKING_STACK": "network-manager",
            "OFFSET": "16",
            "PACKAGES_HASHED_STORAGE": "/armbian/output/packages-hashed",
            "PACKAGE_LIST_BOARD": [],
            "PACKAGE_LIST_BOARD_REMOVE": [],
                "ethtool"
            "PACKAGE_LIST_FAMILY_REMOVE": [],
            "PLYMOUTH": "yes",
            "REMOVE_PACKAGES": [
                "@TODO",
                "[0]=\"software-properties-common\" [1]=\"software-properties-gtk\" [2]=\"software-properties-common\""
            "REMOVE_PACKAGES_REFS": [
                "@TODO",
                "[0]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [1]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [2]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\""
            "ROOTFS_CACHE_MAX": "200",
            "ROOTFS_TYPE": "ext4",
            "SELECTED_CONFIGURATION": "desktop",
            "SHOW_WARNING": "yes",
            "SOURCED_BOARD_CONFIGS_FILENAME_LIST": [
                "/armbian/config/boards/coolpi-cm5.csc"
            "TZDATA": "Etc/UTC",
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3588_bl31_v1.48.elf ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.18.bin;;u-boot-rockchip.bin u-boot-rockchip-spi.bin",
            "UBUNTU_MIRROR": "ports.ubuntu.com/",
            "USE_CCACHE": "no",
            "VENDOR": "Armbian-unofficial",
            "VENDORBUGS": "https://armbian.atlassian.net/",
            "VENDORCOLOR": "247;16;0",
            "VENDORDOCS": "https://docs.armbian.com/",
            "VENDORLOGO": "armbian-logo",
            "VENDORPRIVACY": "https://duckduckgo.com/",
            "VENDORSUPPORT": "https://community.armbian.com/",
            "VENDORURL": "https://duckduckgo.com/",
            "WANT_ARTIFACT_ALL_ARRAY": [
                "UBOOT",
                "KERNEL",
                "FULL_FIRMWARE",
                "ARMBIAN_BASE_FILES",
                "ARMBIAN_ZSH",
                "ARMBIAN_PLYMOUTH_THEME",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ARMBIAN_BSP_DESKTOP",
                "ROOTFS"
            "WANT_ARTIFACT_ALL_NAMES_ARRAY": [
                "uboot",
                "kernel",
                "full_firmware",
                "armbian-base-files",
                "armbian-zsh",
                "armbian-plymouth-theme",
                "armbian-bsp-cli",
                "armbian-desktop",
                "armbian-bsp-desktop",
                "rootfs"
            "WANT_ARTIFACT_ARMBIAN_BASE_FILES_INPUTS_ARRAY": [
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_BSP_CLI_INPUTS_ARRAY": [
                "'EXTRA_BSP_NAME='",
                "'BRANCH=edge'",
                "'BOARD=coolpi-cm5'"
            "WANT_ARTIFACT_ARMBIAN_BSP_DESKTOP_INPUTS_ARRAY": [
                "'BRANCH=edge'",
                "'DESKTOP_ENVIRONMENT=xfce'",
                "'DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base'",
                "'BOARD=coolpi-cm5'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_DESKTOP_INPUTS_ARRAY": [
                "'DESKTOP_AGGREGATION_RESULTS=8855c6119660c614d285554e51769066e94fcb75ff215ccc2fa6b4838b18756b'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_PLYMOUTH_THEME_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_ARMBIAN_ZSH_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_FULL_FIRMWARE_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_KERNEL_INPUTS_ARRAY": [
                "'KERNELSOURCE=https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
            "WANT_ARTIFACT_ROOTFS_INPUTS_ARRAY": [
                "'BUILD_MINIMAL=no'",
                "'SELECTED_CONFIGURATION=desktop'",
                "'DESKTOP_APPGROUPS_SELECTED=no_DESKTOP_APPGROUPS_SELECTED_set'",
                "'EXTRA_PKG_ADD_REMOVE_HASH=9484d87e17c18694c6beeb148595dde16586e36948cc22225c4564e1b0cee6fd'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_UBOOT_INPUTS_ARRAY": [
                "'BOOTPATCHDIR=v2024.07-coolpi-cm5'",
                "'BOOTSOURCE=https://github.com/Kwiboo/u-boot-rockchip.git'",
                "'BOOTBRANCH=tag:v2024.07'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "coolpi-genbook",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588 SoC octa core 4-16GB SoC eMMC USB3 NVME",
                    "andyshrk"
                    "edge",
                    "vendor"
                        "andyshrk"
                    "BOARD_NAME": "CoolPi GenBook",
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "coolpi-genbook/edge",
                    "BOOTCONFIG": "coolpi-cm5-genbook-rk3588_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3588-coolpi-cm5-genbook.dtb",
                    "KERNEL_TARGET": "edge,vendor"
            "pipeline": {},
            "target_id": "00000001040000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2025.04",
            "BOOTDELAY": "0",
            "BOOTDIR": "u-boot",
            "BOOTPATCHDIR": "v2025.01-rc3-coolpi-cm5",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2025.04",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "coolpi-genbook",
            "IMAGE_FILE_ID": "Coolpi-genbook_sid_edge_7.0.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-7.0.y",
                "@TODO",
            "KERNEL_MAJOR": "7",
            "KERNEL_MAJOR_MINOR": "7.0",
            "KERNEL_TARGET": "edge,vendor",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/coolpi-genbook.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FULL_FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "full_firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=coolpi-genbook'"
                "'BRANCH=edge'",
                "'BOARD=coolpi-genbook'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'KERNELBRANCH=branch:linux-7.0.y'",
                "'KERNEL_MAJOR_MINOR=7.0'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2025.01-rc3-coolpi-cm5'",
                "'BOOTBRANCH=tag:v2025.04'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "andyshrk"
                    "edge",
                    "vendor"
                        "andyshrk"
                        "edge",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "coolpi-genbook/vendor",
            "pipeline": {},
            "target_id": "00000001050000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-rk35xx",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTDIR": "u-boot-rockchip64",
            "BOOTSCRIPT": "boot-rk35xx.cmd:boot.cmd",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-rockchip64/v2025.04",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Coolpi-genbook_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "KERNEL_MAJOR": "6",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FULL_FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "full_firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BRANCH=vendor'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "cubieboard2",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner A20 dual core 1Gb SoC 1xSATA",
                    "current",
                    "edge",
                    "legacy"
                    "BOARDFAMILY": "sun7i",
                    "BOARD_NAME": "Cubieboard 2",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "cubieboard2/current",
                    "BOARD_VENDOR": "cubietech",
                    "BOOTCONFIG": "Cubieboard2_config",
                    "INTRODUCED": "2012",
                    "KERNEL_TARGET": "current,edge,legacy",
                    "KERNEL_TEST_TARGET": "current"
            "pipeline": {},
            "target_id": "00000001060000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "current",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "ASOUND_STATE": "asound.state.sunxi-next",
            "ATFPATCHDIR": "atf-sunxi",
            "AUFS": "yes",
            "BOOTBRANCH": "tag:v2024.01",
            "BOOTDELAY": "1",
            "BOOTENV_FILE": "sunxi.txt",
            "BOOTPATCHDIR": "u-boot-sunxi",
            "BOOTSCRIPT": "boot-sunxi.cmd:boot.cmd",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2024.01",
            "CPUMAX": "1010000",
            "CPUMIN": "480000",
            "CRUST_TARGET_MAP": "scp;;build/scp/scp.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "cubieboard2",
            "IMAGE_FILE_ID": "Cubieboard2_sid_current_6.18.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-6.18.y",
            "KERNELPATCHDIR": "archive/sunxi-6.18",
                "@TODO",
            "KERNEL_IMAGE_TYPE": "zImage",
            "KERNEL_INSTALL_TYPE": "zinstall",
            "KERNEL_MAJOR_MINOR": "6.18",
            "KERNEL_PATCH_ARCHIVE_BASE": "sunxi",
            "KERNEL_TEST_TARGET": "current",
            "LINUXCONFIG": "linux-sunxi-current",
            "LINUXFAMILY": "sunxi",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__sunxi__armhf",
            "NAME_KERNEL": "zImage",
            "OFFSET": "4",
            "OVERLAY_DIR": "/boot/dtb/allwinner/overlay",
            "OVERLAY_PREFIX": "sun7i-a20",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/cubieboard2.csc"
            "UBOOT_FW_ENV": "0x88000,0x20000",
            "UBOOT_TARGET_MAP": ";;u-boot-sunxi-with-spl.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=cubieboard2'"
                "'BRANCH=current'",
                "'BOARD=cubieboard2'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
            "WANT_ARTIFACT_FIRMWARE_INPUTS_ARRAY": [],
                "'LINUXCONFIG=linux-sunxi-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi-current'",
                "'KERNELBRANCH=branch:linux-6.18.y'",
                "'KERNEL_MAJOR_MINOR=6.18'",
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=sunxi'",
                "'KERNELPATCHDIR=archive/sunxi-6.18'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-sunxi'",
                "'BOOTBRANCH=tag:v2024.01'",
                "'BRANCH=current'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "cubieboard2/edge",
            "pipeline": {},
            "target_id": "00000001070000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Cubieboard2_sid_edge_7.0.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/sunxi-7.0",
                "@TODO",
            "LINUXCONFIG": "linux-sunxi-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__sunxi__armhf",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi-edge'",
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/sunxi-7.0'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "cubieboard2/legacy",
            "pipeline": {},
            "target_id": "00000001080000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Cubieboard2_sid_legacy_6.12.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-6.12.y",
            "KERNELPATCHDIR": "archive/sunxi-6.12",
                "@TODO",
            "LINUXCONFIG": "linux-sunxi-legacy",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.12__sunxi__armhf",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sunxi-legacy'",
                "'ARMBIAN_KERNEL_DEB_NAME=sunxi-legacy'",
                "'KERNELBRANCH=branch:linux-6.12.y'",
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/sunxi-6.12'"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "cubietruck",
                "BOARD_FILE_HARDWARE_DESC": "Allwinner A20 dual core 2GB RAM SoC 1xSATA GBE WiFi/BT",
                    "current",
                    "edge",
                    "legacy"
                "BOARD_SUPPORT_LEVEL": "csc",
                    "BOARD_NAME": "Cubietruck",
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "cubietruck/current",
                    "BOOTCONFIG": "Cubietruck_config",
                    "INTRODUCED": "2013",
            "pipeline": {},
            "target_id": "00000001090000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOARD_TYPE": "csc",
            "BOOTDELAY": "1",
            "BOOTSOURCE": "https://github.com/u-boot/u-boot",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "GOVERNOR": "ondemand",
            "HOST": "cubietruck",
            "IMAGE_FILE_ID": "Cubietruck_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/cubietruck.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=cubietruck'"
                "'BRANCH=current'",
                "'BOARD=cubietruck'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "cubietruck/edge",
            "pipeline": {},
            "target_id": "00000001100000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Cubietruck_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge",
                    "legacy"
                        "current",
                        "edge",
                        "legacy"
                    "BOARD_SLASH_BRANCH": "cubietruck/legacy",
            "pipeline": {},
            "target_id": "00000001110000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "legacy",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "ATF_COMPILE": "yes",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "480000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Cubietruck_sid_legacy_6.12.y_xfce_desktop",
            "IMAGE_PARTITION_TABLE": "msdos",
                "@TODO",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'BRANCH=legacy'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=legacy'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "cyber-aib-rk3588",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588 octa core 8/16GB RAM SoC 64/128GB eMMC NVMe 1x USB3 1x USB-C 2x 2.5GbE 2x HDMI",
                    "vendor",
                    "edge"
                    "BOARD_NAME": "Cyber Aib RK3588",
                        "vendor",
                        "edge"
                    "BOARD_SLASH_BRANCH": "cyber-aib-rk3588/vendor",
                    "BOARD_VENDOR": "rockchip",
                    "BOOTCONFIG": "rk3588-cyber-aib_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3588-cyber-aib.dtb",
                    "BOOT_LOGO": "desktop",
                    "FULL_DESKTOP": "yes",
                    "IMAGE_PARTITION_TABLE": "gpt",
                    "KERNEL_TARGET": "vendor,edge"
            "pipeline": {},
            "target_id": "00000001120000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
            "ARCHITECTURE": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "ATF_COMPILE": "no",
            "ATF_COMPILER": "aarch64-linux-gnu-",
            "AUFS": "yes",
            "BOOTBRANCH": "branch:next-dev-v2024.10",
            "BOOTDELAY": "0",
            "BOOTPATCHDIR": "legacy/u-boot-radxa-rk35xx",
            "BOOTSOURCE": "https://github.com/radxa/u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-rockchip64/next-dev-v2024.10",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "cyber-aib-rk3588",
            "IMAGE_FILE_ID": "Cyber-aib-rk3588_sid_vendor_6.1.y_xfce_desktop",
            "INITRD_ARCH": "arm64",
            "KERNEL_COMPILER": "aarch64-linux-gnu-",
                "@TODO",
            "KERNEL_IMAGE_TYPE": "Image",
            "KERNEL_INSTALL_TYPE": "install",
            "KERNEL_SRC_ARCH": "arm64",
            "KERNEL_TARGET": "vendor,edge",
            "NAME_KERNEL": "Image",
            "OFFSET": "16",
            "PACKAGE_LIST_FAMILY": [
                "ethtool"
            "PARTITION_TYPE_UUID_ROOT": "B921B045-1DF0-41C3-AF44-4C6F280D3FAE",
            "PLYMOUTH": "yes",
            "QEMU_BINARY": "qemu-aarch64-static",
            "QEMU_CPU": "cortex-a53",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/cyber-aib-rk3588.csc"
            "UBOOT_COMPILER": "aarch64-linux-gnu-",
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3588_bl31_v1.48.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=cyber-aib-rk3588'"
                "'BRANCH=vendor'",
                "'BOARD=cyber-aib-rk3588'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=legacy/u-boot-radxa-rk35xx'",
                "'BOOTSOURCE=https://github.com/radxa/u-boot.git'",
                "'BOOTBRANCH=branch:next-dev-v2024.10'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "vendor",
                    "edge"
                        "vendor",
                        "edge"
                    "BOARD_SLASH_BRANCH": "cyber-aib-rk3588/edge",
            "pipeline": {},
            "target_id": "00000001130000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/next-dev-v2024.10",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Cyber-aib-rk3588_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "dg-svr-865-tiny",
                "BOARD_FILE_HARDWARE_DESC": "Qualcomm QCS8250 (SM8250) octa core 12/16GB RAM 256GB UFS GBE",
                    "FantasyGmm"
                    "current",
                    "edge"
                "BOARD_SUPPORT_LEVEL": "conf",
                    "BOARDFAMILY": "sm8250",
                    "BOARD_MAINTAINER": "FantasyGmm",
                        "FantasyGmm"
                    "BOARD_NAME": "DG SVR 865 Tiny",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "dg-svr-865-tiny/current",
                    "BOARD_VENDOR": "dg741a",
                    "BOOTCONFIG": "none",
                    "BOOTIMG_CMDLINE_EXTRA": "clk_ignore_unused pd_ignore_unused loglevel=8 panic=30 audit=0 allow_mismatched_32bit_el0 mem_sleep_default=s2idle console=tty0 earlycon=qcom_geni,0xa90000 console=ttyMSM0,115200n8 pcie_pme=nomsi",
                    "EXTRAWIFI": "no",
                    "KERNEL_TARGET": "current,edge",
                    "SERIALCON": "${SERIALCON:-tty1}"
            "pipeline": {},
            "target_id": "00000001140000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ABL_DTB_LIST": [
                "@TODO",
                "[0]=\"qcs8250-dg-svr-865-tiny\""
            "ARCH": "arm64",
                "@TODO",
            "ARMBIAN_WILL_BUILD_UBOOT": "no",
            "ATFBRANCH": "commit:af220ebbe467aa580e6b9ba554676f78ffec930f",
            "ATFPATCHDIR": "atf-sm8250",
            "ATFSOURCEDIR": "arm-trusted-firmware/af220ebbe467aa580e6b9ba554676f78ffec930f",
            "AUFS": "yes",
            "BOARD_TYPE": "conf",
            "BOOTBRANCH": "tag:v2022.07",
            "BOOTENV_FILE": "qcom-abl.txt",
            "BOOTPATCHDIR": "u-boot-sm8250",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2022.07",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "HOST": "dg-svr-865-tiny",
            "IMAGE_FILE_ID": "Dg-svr-865-tiny_sid_current_6.18.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/sm8250-6.18",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "sm8250",
            "LINUXCONFIG": "linux-sm8250-current",
            "LINUXFAMILY": "sm8250",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__sm8250__arm64",
            "OFFSET": "4",
            "OVERLAY_DIR": "/boot/dtb/qcom/overlay",
            "PACKAGE_LIST_FAMILY": [],
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "SERIALCON": "tty1",
                "/armbian/config/boards/dg-svr-865-tiny.conf"
            "USE_CCACHE": "no",
                "KERNEL",
                "FULL_FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "full_firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=dg-svr-865-tiny'"
                "'BRANCH=current'",
                "'BOARD=dg-svr-865-tiny'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sm8250-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=sm8250-current'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'LINUXFAMILY=sm8250'",
                "'KERNELPATCHDIR=archive/sm8250-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "FantasyGmm"
                    "current",
                    "edge"
                        "FantasyGmm"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "dg-svr-865-tiny/edge",
                    "EXTRAWIFI": "no",
            "pipeline": {},
            "target_id": "00000001150000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ABL_DTB_LIST": [
                "@TODO",
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "EXTRAWIFI": "no",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Dg-svr-865-tiny_sid_edge_6.19.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-6.19.y",
            "KERNELPATCHDIR": "archive/sm8250-6.19",
                "@TODO",
            "KERNEL_MAJOR_MINOR": "6.19",
            "LINUXCONFIG": "linux-sm8250-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.19__sm8250__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "KERNEL",
                "FULL_FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "full_firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-sm8250-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=sm8250-edge'",
                "'KERNELBRANCH=branch:linux-6.19.y'",
                "'KERNEL_MAJOR_MINOR=6.19'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=no'",
                "'KERNELPATCHDIR=archive/sm8250-6.19'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "dshanpi-a1",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3576 SoC octa core 4-32GB SoC 2*GBe eMMC USB3 NvME WIFI",
                    "vendor"
                    "BOARDFAMILY": "rk35xx",
                    "BOARD_NAME": "100ASK DShanPI A1",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "dshanpi-a1/vendor",
                    "BOARD_VENDOR": "dongshanpi",
                    "BOOTCONFIG": "dshanpi-a1-rk3576_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3576-100ask-dshanpi-a1.dtb",
                    "INTRODUCED": "2025",
                    "KERNEL_TARGET": "vendor",
                    "KERNEL_TEST_TARGET": "vendor"
            "pipeline": {},
            "target_id": "00000001160000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3576_bl31_v1.20.elf",
            "BOOTDELAY": "0",
            "BOOTSCRIPT": "boot-rk3576.cmd:boot.cmd",
            "BOOT_SOC": "rk3576",
            "BOOT_SOC_MKIMAGE": "rk3576",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3576_ddr_lp4_2112MHz_lp5_2736MHz_v1.08.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "dshanpi-a1",
            "IMAGE_FILE_ID": "Dshanpi-a1_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "KERNEL_TEST_TARGET": "vendor",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rk35xx",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/dshanpi-a1.csc"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3576_bl31_v1.20.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=dshanpi-a1'"
                "'BRANCH=vendor'",
                "'BOARD=dshanpi-a1'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "dshanpi-r1",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3568 quad core 1-8GB SoC GBe eMMC USB3",
                    "vendor"
                    "BOARD_NAME": "100ASK DShanPI R1",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "dshanpi-r1/vendor",
                    "BOOTCONFIG": "dshanpi-r1-rk3568_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3568-dshapi-r1.dtb",
                    "INTRODUCED": "2024",
            "pipeline": {},
            "target_id": "00000001170000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3568_bl31_v1.44.elf",
            "BOOTDELAY": "1",
            "BOOTDIR": "u-boot-dshanpi-r1",
            "BOOTPATCHDIR": "v2024.10",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-dshanpi-r1/v2024.10",
            "BOOT_SOC": "rk3568",
            "BOOT_SOC_MKIMAGE": "rk3568",
            "CPUMAX": "1992000",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3568_ddr_1560MHz_v1.21.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "dshanpi-r1",
            "IMAGE_FILE_ID": "Dshanpi-r1_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "ROCKUSB_BLOB": "rk35/rk356x_spl_loader_v1.21.113.bin",
                "/armbian/config/boards/dshanpi-r1.csc"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3568_bl31_v1.44.elf ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3568_ddr_1560MHz_v1.21.bin;;u-boot-rockchip.bin u-boot-rockchip-spi.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=dshanpi-r1'"
                "'BRANCH=vendor'",
                "'BOARD=dshanpi-r1'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2024.10'",
                "'BOOTSOURCE=https://github.com/u-boot/u-boot'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "dusun-dsom-010r",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3328 quad core 1GB-4GB 1xFE USB3 [WiFi]",
                    "paolosabatino"
                    "current",
                    "edge"
                    "BOARDFAMILY": "rockchip64",
                    "BOARD_MAINTAINER": "paolosabatino",
                        "paolosabatino"
                    "BOARD_NAME": "Dusun DSOM 010R SoM",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "dusun-dsom-010r/current",
                    "BOOTBRANCH_BOARD": "tag:v2026.04",
                    "BOOTCONFIG": "dusun-dsom-010r-rk3328_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3328-dusun-dsom-010r.dtb",
                    "BOOT_SCENARIO": "binman-atf-mainline",
                    "DDR_BLOB": "rk33/rk3328_ddr_933MHz_v1.16.bin",
                    "DEFAULT_CONSOLE": "serial",
                    "DEFAULT_OVERLAYS": "dusun-010r-rp3328b",
            "pipeline": {},
            "target_id": "00000001180000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATF_TARGET_MAP": "M0_CROSS_COMPILE=arm-linux-gnueabi- PLAT=rk3328 bl31;;build/rk3328/release/bl31/bl31.elf:bl31.elf",
            "AUFS": "yes",
            "BL31_BLOB": "rk33/rk322xh_bl31_v1.44.elf",
            "BOOTDELAY": "0",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2026.04",
            "BOOT_SOC": "rk3328",
            "BOOT_SOC_MKIMAGE": "rk3328",
            "CPUMAX": "1296000",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "dusun-dsom-010r",
            "IMAGE_FILE_ID": "Dusun-dsom-010r_sid_current_6.18.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/rockchip64-6.18",
                "@TODO",
            "LINUXCONFIG": "linux-rockchip64-current",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__rockchip64__arm64",
            "MINILOADER_BLOB": "rk33/rk322xh_miniloader_v2.50.bin",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rockchip",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/dusun-dsom-010r.csc"
            "UBOOT_TARGET_MAP": "BL31=bl31.elf ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk33/rk3328_ddr_933MHz_v1.16.bin;;u-boot-rockchip.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=dusun-dsom-010r'"
                "'BRANCH=current'",
                "'BOARD=dusun-dsom-010r'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rockchip64-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=rockchip64-current'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/rockchip64-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD_MAINTAINERS": [
                    "paolosabatino"
                    "current",
                    "edge"
                        "paolosabatino"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "dusun-dsom-010r/edge",
            "pipeline": {},
            "target_id": "00000001190000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Dusun-dsom-010r_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "ebyte-ecb41-pge",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3506G2 triple core 128MB SoC 2x100MBe NAND SD USB2",
                    "vidplace7"
                    "vendor"
                    "BOARDFAMILY": "rockchip",
                    "BOARD_MAINTAINER": "vidplace7",
                        "vidplace7"
                    "BOARD_NAME": "EByte ECB41-PGE",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "ebyte-ecb41-pge/vendor",
                    "BOARD_VENDOR": "ebyte",
                    "BOOTCONFIG": "ebyte-ecb41-pge_defconfig",
                    "BOOT_FDT_FILE": "rk3506g-ebyte-ecb41-pge.dtb",
                    "BOOT_SOC": "rk3506",
                    "DDR_BLOB": "rk35/rk3506_ddr_750MHz_v1.06.bin",
            "pipeline": {},
            "target_id": "00000001200000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
            "ARCHITECTURE": "arm",
                "@TODO",
            "ATFPATCHDIR": "atf-rockchip",
            "AUFS": "yes",
            "BOOTBRANCH": "commit:0b8e25bd9e16e8043b600e8f49b926b95572dc47",
            "BOOTDELAY": "1",
            "BOOTDIR": "u-boot-rk3506",
            "BOOTENV_FILE": "rk3506.txt",
            "BOOTPATCHDIR": "u-boot-rk3506",
            "BOOTSCRIPT": "boot-rk3506.cmd:boot.cmd",
            "BOOTSOURCE": "https://source.denx.de/u-boot/contributors/kwiboo/u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot-rk3506/0b8e25bd9e16e8043b600e8f49b926b95572dc47",
            "CPUMAX": "1900000",
            "CPUMIN": "600000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "ebyte-ecb41-pge",
            "IMAGE_FILE_ID": "Ebyte-ecb41-pge_sid_vendor_6.1.y_xfce_desktop",
            "INITRD_ARCH": "arm",
            "KERNEL_COMPILER": "arm-linux-gnueabihf-",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "rockchip",
            "KERNEL_SRC_ARCH": "arm",
            "LINUXCONFIG": "linux-rockchip-vendor",
            "LINUXFAMILY": "rockchip",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.1__rockchip__armhf",
            "OFFSET": "16",
            "PARTITION_TYPE_UUID_ROOT": "69DAD710-2CE4-4E3C-B16C-21A1D49ABED3",
            "PLYMOUTH": "yes",
            "QEMU_BINARY": "qemu-arm-static",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/ebyte-ecb41-pge.csc"
            "TEE_BLOB": "rk35/rk3506_tee_v2.10.bin",
            "UBOOT_COMPILER": "arm-linux-gnueabihf-",
            "UBOOT_TARGET_MAP": "ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3506_ddr_750MHz_v1.06.bin TEE=/armbian/cache/sources/rkbin-tools/rk35/rk3506_tee_v2.10.bin;;u-boot-rockchip.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=ebyte-ecb41-pge'"
                "'BRANCH=vendor'",
                "'BOARD=ebyte-ecb41-pge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rockchip-vendor'",
                "'ARMBIAN_KERNEL_DEB_NAME=rockchip-vendor'",
                "'BRANCH=vendor'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rockchip'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-rk3506'",
                "'BOOTSOURCE=https://source.denx.de/u-boot/contributors/kwiboo/u-boot.git'",
                "'BOOTBRANCH=commit:0b8e25bd9e16e8043b600e8f49b926b95572dc47'",
                "'BRANCH=vendor'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "fine3399",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3399 hexa core 4GB SoC eMMC GBE USB3 WiFi",
                    "Lemon1151"
                    "current",
                    "edge"
                    "BOARD_MAINTAINER": "Lemon1151",
                        "Lemon1151"
                    "BOARD_NAME": "Fine3399",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "fine3399/current",
                    "BOOTCONFIG": "fine3399-rk3399_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3399-fine3399.dtb",
                    "SRC_CMDLINE": "console=ttyS2,1500000 console=tty0",
                    "SRC_EXTLINUX": "yes"
            "pipeline": {},
            "target_id": "00000001210000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTPATCHDIR": "u-boot-rockchip64",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "fine3399",
            "IMAGE_FILE_ID": "Fine3399_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/fine3399.csc"
            "SRC_EXTLINUX": "yes",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=fine3399'"
                "'BRANCH=current'",
                "'BOARD=fine3399'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=u-boot-rockchip64'",
                "'BOOTBRANCH=tag:v2022.07'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'BOARD=fine3399'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "Lemon1151"
                    "current",
                    "edge"
                        "Lemon1151"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "fine3399/edge",
            "pipeline": {},
            "target_id": "00000001220000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "fine3399",
            "IMAGE_FILE_ID": "Fine3399_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=fine3399'"
                "'BRANCH=edge'",
                "'BOARD=fine3399'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'BOARD=fine3399'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "firefly-itx-3588j",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588j Octa core 4GB-32GB eMMC GBE HDMI HDMI-IN PCIe SATA USB3 WiFi 4G 5G",
                    "SeeleVolleri"
                    "vendor"
                    "BOARD_MAINTAINER": "SeeleVolleri",
                        "SeeleVolleri"
                    "BOARD_NAME": "Firefly ITX-3588J",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "firefly-itx-3588j/vendor",
                    "BOARD_VENDOR": "firefly",
                    "BOOTCONFIG": "rock-5b-rk3588_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3588-firefly-itx-3588j.dtb",
                    "UEFI_EDK2_BOARD_ID": "firefly-itx-3588j"
            "pipeline": {},
            "target_id": "00000001230000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "firefly-itx-3588j",
            "IMAGE_FILE_ID": "Firefly-itx-3588j_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/firefly-itx-3588j.csc"
            "UEFI_EDK2_BOARD_ID": "firefly-itx-3588j",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=firefly-itx-3588j'"
                "'BRANCH=vendor'",
                "'BOARD=firefly-itx-3588j'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "firefly-rk3399",
                "BOARD_MAINTAINERS": [],
                    "current",
                    "edge"
                    "BOARD_MAINTAINER": "",
                    "BOARD_NAME": "Firefly RK3399",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "firefly-rk3399/current",
                    "BOOTCONFIG": "firefly-rk3399_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3399-firefly.dtb",
                    "INTRODUCED": "2017",
            "pipeline": {},
            "target_id": "00000001240000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "firefly-rk3399",
            "IMAGE_FILE_ID": "Firefly-rk3399_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/firefly-rk3399.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=firefly-rk3399'"
                "'BRANCH=current'",
                "'BOARD=firefly-rk3399'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "firefly-rk3399/edge",
            "pipeline": {},
            "target_id": "00000001250000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Firefly-rk3399_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "forlinx-ok3506-s12",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3506B/J triple core 512MB SoC 1x100MBe NAND SD USB2",
                    "vidplace7"
                    "vendor"
                        "vidplace7"
                    "BOARD_NAME": "ForLinx OK3506-S12",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "forlinx-ok3506-s12/vendor",
                    "BOARD_VENDOR": "forlinx",
                    "BOOTCONFIG": "forlinx-ok3506-s12-rk3506j_defconfig",
                    "BOOT_FDT_FILE": "rk3506j-forlinx-OK3506-S12_nand-microsd.dtb",
                    "DDR_BLOB": "rk35/rk3506b_ddr_750MHz_v1.06.bin",
            "pipeline": {},
            "target_id": "00000001260000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "armhf",
                "@TODO",
            "AUFS": "yes",
            "BOOTDELAY": "1",
            "CPUMIN": "600000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "forlinx-ok3506-s12",
            "IMAGE_FILE_ID": "Forlinx-ok3506-s12_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/forlinx-ok3506-s12.csc"
            "UBOOT_TARGET_MAP": "ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3506b_ddr_750MHz_v1.06.bin TEE=/armbian/cache/sources/rkbin-tools/rk35/rk3506_tee_v2.10.bin;;u-boot-rockchip.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=forlinx-ok3506-s12'"
                "'BRANCH=vendor'",
                "'BOARD=forlinx-ok3506-s12'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=armhf'",
                "'EXTRAWIFI=yes'",
                "'ARCH=armhf'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=armhf'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "fxblox-rk1",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588 SoC octa core 8-32GB SoC eMMC USB-C DP NvME SATA M2",
                    "mahdichi"
                    "vendor"
                    "BOARD_MAINTAINER": "mahdichi",
                        "mahdichi"
                    "BOARD_NAME": "FxBlox RK1",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "fxblox-rk1/vendor",
                    "BOOTCONFIG": "fxblox-rk1-rk3588_defconfig",
                    "BOOT_FDT_FILE": "rockchip/rk3588-fxblox-rk1.dtb",
                    "INTRODUCED": "2022",
                    "UEFI_EDK2_BOARD_ID": "fxblox-rk1"
            "pipeline": {},
            "target_id": "00000001270000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "fxblox-rk1",
            "IMAGE_FILE_ID": "Fxblox-rk1_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/fxblox-rk1.csc"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3588_bl31_v1.48.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb rkspi_loader.img",
            "UEFI_EDK2_BOARD_ID": "fxblox-rk1",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=fxblox-rk1'"
                "'BRANCH=vendor'",
                "'BOARD=fxblox-rk1'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "h96-tvbox-3566",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3566 quad core SoC WIFI/BT eMMC USB2/3",
                    "hqnicolas"
                    "current",
                    "edge"
                "BOARD_SUPPORT_LEVEL": "tvb",
                    "BOARD_MAINTAINER": "hqnicolas",
                        "hqnicolas"
                    "BOARD_NAME": "h96-tvbox-3566",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "h96-tvbox-3566/current",
                    "BOOT_FDT_FILE": "rockchip/rk3566-h96-tvbox.dtb",
            "pipeline": {},
            "target_id": "00000001280000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
            "[LEAKED]:expr: syntax error: unexpected argument '.*\\\\(rk[[:digit:]]\\\\+.*\\\\)_.*'",
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOARD_TYPE": "tvb",
            "BOOTBRANCH": "tag:v2025.01",
            "BOOTCONFIG": "h96max-v56_defconfig",
            "BOOTDELAY": "0",
            "BOOTPATCHDIR": "v2025.01/board_h96-tvbox-3566",
            "BOOTSOURCE": "https://github.com/u-boot/u-boot.git",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2025.01",
            "BOOT_SOC": "",
            "BOOT_SOC_MKIMAGE": "",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "h96-tvbox-3566",
            "IMAGE_FILE_ID": "H96-tvbox-3566_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/h96-tvbox-3566.tvb"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3568_bl31_v1.44.elf ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk35/rk3568_ddr_1560MHz_v1.21.bin;;u-boot-rockchip.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=h96-tvbox-3566'"
                "'BRANCH=current'",
                "'BOARD=h96-tvbox-3566'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2025.01/board_h96-tvbox-3566'",
                "'BOOTSOURCE=https://github.com/u-boot/u-boot.git'",
                "'BOOTBRANCH=tag:v2025.01'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "hqnicolas"
                    "current",
                    "edge"
                        "hqnicolas"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "h96-tvbox-3566/edge",
            "pipeline": {},
            "target_id": "00000001290000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOT_SOC": "",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "H96-tvbox-3566_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "helios64",
                "BOARD_FILE_HARDWARE_DESC": "RK3399 hexa core 4GB SoC 2.5GbE eMMC USB3 SATA M.2 UPS",
                    "prahal"
                    "current",
                    "edge"
                    "BOARD_MAINTAINER": "prahal",
                        "prahal"
                    "BOARD_NAME": "Helios64",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "helios64/current",
                    "BOARD_VENDOR": "kobol",
                    "BOOTBRANCH": "tag:v2026.01",
                    "BOOTCONFIG": "helios64-rk3399_defconfig",
                    "BOOTPATCHDIR": "v2026.01/board_helios64",
                    "CPUMAX": "1800000",
                    "MODULES": "lm75 ledtrig-netdev",
                    "MODULES_LEGACY": "lm75",
                    "PACKAGE_LIST_BOARD": "mdadm i2c-tools fancontrol",
                    "PACKAGE_LIST_BOARD_REMOVE": "fake-hwclock"
            "pipeline": {},
            "target_id": "00000001300000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATF_TARGET_MAP": "M0_CROSS_COMPILE=arm-linux-gnueabi- PLAT=rk3399 bl31;;build/rk3399/release/bl31/bl31.elf:bl31.elf",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTSOURCEDIR": "u-boot-worktree/u-boot/v2026.01",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "[0]=\"watchdog\" [1]=\"chrony\" [2]=\"network-manager\" [3]=\"network-manager-openvpn\" [4]=\"netplan.io\" [5]=\"network-manager-gnome\" [6]=\"network-manager-ssh\" [7]=\"network-manager-vpnc\""
                "@TODO",
                "[0]=\"extension_prepare_config__add_to_image_watchdog:/armbian/extensions/watchdog.sh:6\" [1]=\"extension_prepare_config__install_chrony:/armbian/extensions/network/net-chrony.sh:6\" [2]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [3]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [4]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [5]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [6]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [7]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\""
            "HOST": "helios64",
            "IMAGE_FILE_ID": "Helios64_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
                "mdadm",
                "i2c-tools",
                "fancontrol"
                "fake-hwclock"
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/helios64.conf"
            "UBOOT_TARGET_MAP": "BL31=bl31.elf ROCKCHIP_TPL=/armbian/cache/sources/rkbin-tools/rk33/rk3399_ddr_933MHz_v1.25.bin;;u-boot-rockchip.bin",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=helios64'"
                "'BRANCH=current'",
                "'BOARD=helios64'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'EXTRA_PKG_ADD_REMOVE_HASH=4223401b3af34064887fe146d9c026baaf69237d965e9b033cea4e891c8f8b6d'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BOOTPATCHDIR=v2026.01/board_helios64'",
                "'BOOTBRANCH=tag:v2026.01'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'BOARD=helios64'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "prahal"
                    "current",
                    "edge"
                        "prahal"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "helios64/edge",
                    "DDR_BLOB": "rk33/rk3399_ddr_933MHz_v1.25.bin",
                    "INTRODUCED": "2020",
            "pipeline": {},
            "target_id": "00000001310000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "AUFS": "yes",
            "BL31_BLOB": "rk33/rk3399_bl31_v1.35.elf",
            "BOOTDELAY": "0",
            "BOOTENV_FILE": "rockchip64.txt",
            "BOOT_SOC": "rk3399",
            "BOOT_SOC_MKIMAGE": "rk3399",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "helios64",
            "IMAGE_FILE_ID": "Helios64_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "rockchip64",
            "LINUXFAMILY": "rockchip64",
            "LOADER_UBOOT_OFFSET": "0x200000",
            "MINILOADER_BLOB": "rk33/rk3399_miniloader_v1.26.bin",
            "OFFSET": "16",
            "OVERLAY_DIR": "/boot/dtb/rockchip/overlay",
                "mdadm",
                "i2c-tools",
                "fancontrol"
                "fake-hwclock"
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "RKBIN_DIR": "/armbian/cache/sources/rkbin-tools",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=helios64'"
                "'BRANCH=edge'",
                "'BOARD=helios64'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rockchip64'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'BOARD=helios64'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "hikey960",
                "BOARD_FILE_HARDWARE_DESC": "Kirin 960 octa core 3/4GB SoC eMMC USB3 WiFi/BT",
                    "current",
                    "edge"
                    "BOARDFAMILY": "uefi-arm64",
                    "BOARD_NAME": "HiKey 960",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "hikey960/current",
                    "BOARD_VENDOR": "huawei",
                    "BOOT_FDT_FILE": "hisilicon/hi3660-hikey960.dtb",
                    "GRUB_CMDLINE_LINUX_DEFAULT": "efi=noruntime console=ttyAMA6,115200n8",
            "pipeline": {},
            "target_id": "00000001320000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-arm64",
            "AUFS": "yes",
            "BOOTPATCHDIR": "u-boot-arm64",
            "BOOTSIZE": "0",
            "DISTRO_FIRMWARE_PACKAGES": "",
            "DISTRO_GENERIC_KERNEL": "no",
            "DISTRO_KERNEL_PACKAGES": "",
            "DISTRO_KERNEL_VER": "arm64",
            "EXTRAWIFI": "yes",
            "EXTRA_BSP_NAME": "-grub",
                "@TODO",
                "[0]=\"chrony\" [1]=\"network-manager\" [2]=\"network-manager-openvpn\" [3]=\"netplan.io\" [4]=\"network-manager-gnome\" [5]=\"network-manager-ssh\" [6]=\"network-manager-vpnc\" [7]=\"efibootmgr\" [8]=\"efivar\" [9]=\"cloud-initramfs-growroot\" [10]=\"busybox\" [11]=\"os-prober\" [12]=\"grub-efi-arm64-bin\" [13]=\"grub-efi-arm64\""
                "@TODO",
                "[0]=\"extension_prepare_config__install_chrony:/armbian/extensions/network/net-chrony.sh:6\" [1]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [2]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [3]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [4]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [5]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [6]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [7]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [8]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [9]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [10]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [11]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [12]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\" [13]=\"extension_prepare_config__prepare_grub_standard:/armbian/extensions/grub.sh:77\""
            "HOST": "hikey960",
            "IMAGE_FILE_ID": "Hikey960_sid_current_6.18.y_xfce_desktop",
            "KERNELDIR": "linux-uefi-arm64",
            "KERNELPATCHDIR": "archive/uefi-arm64-6.18",
                "@TODO",
            "KERNEL_PATCH_ARCHIVE_BASE": "arm64",
            "LINUXCONFIG": "linux-uefi-arm64-current",
            "LINUXFAMILY": "arm64",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.18__arm64__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
            "POWER_MANAGEMENT_FEATURES": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/hikey960.csc"
            "UEFISIZE": "260",
            "UEFI_ENABLE_BIOS_AMD64": "yes",
            "UEFI_EXPORT_KERNEL_INITRD": "no",
            "UEFI_GRUB_DISABLE_OS_PROBER": "",
            "UEFI_GRUB_DISTRO_NAME": "Armbian",
            "UEFI_GRUB_TARGET": "arm64-efi",
            "UEFI_GRUB_TARGET_BIOS": "",
            "UEFI_GRUB_TERMINAL": "gfxterm",
            "UEFI_GRUB_TIMEOUT": "3",
            "USE_CCACHE": "no",
                "KERNEL",
                "FULL_FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "full_firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'EXTRA_BSP_NAME=-grub'",
                "'BRANCH=current'",
                "'BOARD=hikey960'"
                "'BRANCH=current'",
                "'BOARD=hikey960'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-uefi-arm64-current'",
                "'ARMBIAN_KERNEL_DEB_NAME=arm64-current'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=arm64'",
                "'KERNELPATCHDIR=archive/uefi-arm64-6.18'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "hikey960/edge",
            "pipeline": {},
            "target_id": "00000001330000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFDIR": "arm-trusted-firmware",
            "ATFSOURCE": "https://github.com/ARM-software/arm-trusted-firmware",
            "AUFS": "yes",
            "BOOTSIZE": "0",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "hikey960",
            "IMAGE_FILE_ID": "Hikey960_sid_edge_7.0.y_xfce_desktop",
            "KERNELPATCHDIR": "archive/uefi-arm64-7.0",
                "@TODO",
            "LINUXCONFIG": "linux-uefi-arm64-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__arm64__arm64",
            "OFFSET": "4",
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "UEFISIZE": "260",
            "USE_CCACHE": "no",
                "KERNEL",
                "FULL_FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "kernel",
                "full_firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BOARD=hikey960'"
                "'BRANCH=edge'",
                "'BOARD=hikey960'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-uefi-arm64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=arm64-edge'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/uefi-arm64-7.0'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "hinlink-h28k",
                "BOARD_CORE_OR_USERPATCHED": "core",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3528 quad core 1-8GB SoC GBe eMMC PCIE2.0/USB3",
                "BOARD_HAS_VIDEO": true,
                    "sputnik2019"
                "BOARD_POSSIBLE_BRANCHES": [
                    "vendor"
                "BOARD_TOP_LEVEL_VARS": {
                    "BOARD_MAINTAINER": "sputnik2019",
                        "sputnik2019"
                    "BOARD_NAME": "HinLink H28k",
                        "vendor"
                    "BOARD_SLASH_BRANCH": "hinlink-h28k/vendor",
                    "BOARD_VENDOR": "hinlink",
                    "BOOTCONFIG": "hinlink_rk3528_defconfig",
                    "BOOTFS_TYPE": "ext4",
                    "BOOT_FDT_FILE": "rockchip/rk3528-hinlink-h28k.dtb",
            "pipeline": {},
            "target_id": "00000001340000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "BUILD_DESKTOP": "yes",
                "BUILD_MINIMAL": "no",
                "DESKTOP_ENVIRONMENT": "xfce",
                "DESKTOP_ENVIRONMENT_CONFIG_NAME": "config_base",
                "RELEASE": "sid",
                "REVISION": "26.05.0-trunk"
        "logs": [
            "warn: Not-installing software-properties-common For distro 'Debian' release 'sid'\\n",
            "[LEAKED]:** No matches found for Bash declare regex (origin: unknown), line ==>declare -i KERNEL_GIT_CACHE_TTL=\"120\"<=="
        "out": {
            "APT_MIRROR": "deb.debian.org/debian",
            "ARCH": "arm64",
            "ARMBIAN_ARTIFACTS_TO_HANDLERS_DICT": [
                "@TODO",
                "bash associative arrays aka dictionaries are not supported yet",
                "[armbian-base-files]=\"armbian-base-files\" [armbian-desktop]=\"armbian-desktop\" [armbian-bsp-desktop]=\"armbian-bsp-desktop\" [full_firmware]=\"full_firmware\" [armbian-zsh]=\"armbian-zsh\" [armbian-plymouth-theme]=\"armbian-plymouth-theme\" [fake_ubuntu_advantage_tools]=\"fake_ubuntu_advantage_tools\" [rootfs]=\"rootfs\" [armbian-bsp-cli]=\"armbian-bsp-cli\" [u-boot]=\"uboot\" [uboot]=\"uboot\" [kernel]=\"kernel\" [firmware]=\"firmware\" "
            "ARMBIAN_WILL_BUILD_UBOOT": "yes",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3528_bl31_v1.17.elf",
            "BOOTDELAY": "0",
            "BOOT_SOC": "rk3528",
            "BOOT_SOC_MKIMAGE": "rk3528",
            "CPUMAX": "2016000",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3528_ddr_1056MHz_v1.09.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "hinlink-h28k",
            "IMAGE_FILE_ID": "Hinlink-h28k_sid_vendor_6.1.y_xfce_desktop",
            "KERNELBRANCH": "branch:rk-6.1-rkr5.1",
            "KERNELPATCHDIR": "rk35xx-vendor-6.1",
            "KERNELSOURCE": "https://github.com/armbian/linux-rockchip.git",
                "@TODO",
            "KERNEL_MAJOR_MINOR": "6.1",
            "KERNEL_PATCH_ARCHIVE_BASE": "rk35xx",
            "LINUXCONFIG": "linux-rk35xx-vendor",
            "LINUXFAMILY": "rk35xx",
            "LINUXSOURCEDIR": "linux-kernel-worktree/6.1__rk35xx__arm64",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "ROCKUSB_BLOB": "rk35/rk3528_spl_loader_v1.07.104.bin",
            "SERIALCON": "ttyFIQ0",
                "/armbian/config/boards/hinlink-h28k.csc"
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3528_bl31_v1.17.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb rkspi_loader.img",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'BOARD=hinlink-h28k'"
                "'BRANCH=vendor'",
                "'BOARD=hinlink-h28k'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rk35xx-vendor'",
                "'ARMBIAN_KERNEL_DEB_NAME=rk35xx-vendor'",
                "'KERNELBRANCH=branch:rk-6.1-rkr5.1'",
                "'KERNEL_MAJOR_MINOR=6.1'",
                "'KERNELSOURCE=https://github.com/armbian/linux-rockchip.git'",
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'LINUXFAMILY=rk35xx'",
                "'KERNELPATCHDIR=rk35xx-vendor-6.1'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=vendor'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "hinlink-h66k",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3568 quad core 1-8GB SoC 2.5GBe eMMC USB3",
                    "current",
                    "edge"
                    "BOARD_NAME": "Hinlink H66K",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "hinlink-h66k/current",
                    "BOOTCONFIG": "radxa-e25-rk3568_defconfig",
                    "BOOTFS_TYPE": "fat",
                    "BOOT_FDT_FILE": "rockchip/rk3568-hinlink-h66k.dtb",
                    "BOOT_SCENARIO": "spl-blobs",
            "pipeline": {},
            "target_id": "00000001350000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-rockchip64",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTENV_FILE": "rk35xx.txt",
            "CHROOT_CACHE_VERSION": "7",
            "COMPRESS_OUTPUTIMAGE": "sha,img",
            "CONSOLE_AUTOLOGIN": "yes",
            "CONSOLE_CHAR": "UTF-8",
            "CPUMIN": "408000",
            "DEBIAN_MIRROR": "deb.debian.org/debian",
            "DEBIAN_SECURITY": "security.debian.org/",
            "DEB_COMPRESS": "none",
            "DEST_LANG": "en_US.UTF-8",
            "DISABLE_IPV6": "true",
            "DISTRIBUTION": "Debian",
            "EXIT_PATCHING_ERROR": "",
            "EXTRAWIFI": "yes",
            "EXTRA_BSP_NAME": "",
            "EXTRA_IMAGE_SUFFIX": "",
            "EXTRA_PACKAGES_IMAGE": [
                "@TODO",
                "bash simple-arrays are not supported yet",
                "[0]=\"chrony\" [1]=\"network-manager\" [2]=\"network-manager-openvpn\" [3]=\"netplan.io\" [4]=\"network-manager-gnome\" [5]=\"network-manager-ssh\" [6]=\"network-manager-vpnc\""
            "EXTRA_PACKAGES_IMAGE_REFS": [
                "@TODO",
                "[0]=\"extension_prepare_config__install_chrony:/armbian/extensions/network/net-chrony.sh:6\" [1]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [2]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [3]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:11\" [4]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [5]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\" [6]=\"extension_prepare_config__install_network_manager:/armbian/extensions/network/net-network-manager.sh:15\""
            "EXTRA_ROOTFS_MIB_SIZE": "0",
            "FAST_CREATE_IMAGE": "yes",
            "GHCR_SOURCE": "ghcr.io",
            "GITHUB_SOURCE": "https://github.com",
            "HOST": "hinlink-h66k",
            "IMAGE_FILE_ID": "Hinlink-h66k_sid_current_6.18.y_xfce_desktop",
            "IMAGE_TYPE": "user-built",
            "KERNELSOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "KERNEL_DRIVERS_SKIP": [
                "@TODO",
            "KERNEL_HAS_WORKING_HEADERS": "yes",
            "LANGUAGE": "en_US:en",
            "MAINLINE_FIRMWARE_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git",
            "MAINLINE_KERNEL_SOURCE": "https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git",
            "MAINLINE_UBOOT_DIR": "u-boot",
            "MAINLINE_UBOOT_SOURCE": "https://github.com/u-boot/u-boot",
            "MAINTAINER": "John Doe",
            "MAINTAINERMAIL": "john.doe@somewhere.on.planet",
            "MAIN_CMDLINE": "rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles",
            "NAMESERVER": "1.0.0.1",
            "NAME_INITRD": "uInitrd",
            "NETWORKING_STACK": "network-manager",
            "OFFSET": "16",
            "PACKAGES_HASHED_STORAGE": "/armbian/output/packages-hashed",
            "PACKAGE_LIST_BOARD": [],
            "PACKAGE_LIST_BOARD_REMOVE": [],
                "ethtool"
            "PACKAGE_LIST_FAMILY_REMOVE": [],
            "PLYMOUTH": "yes",
            "REMOVE_PACKAGES": [
                "@TODO",
                "[0]=\"software-properties-common\" [1]=\"software-properties-gtk\" [2]=\"software-properties-common\""
            "REMOVE_PACKAGES_REFS": [
                "@TODO",
                "[0]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [1]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\" [2]=\"fix_userspace_packages_release_and_distro:/armbian/lib/functions/main/config-prepare.sh:399\""
            "ROOTFS_CACHE_MAX": "200",
            "ROOTFS_TYPE": "ext4",
            "SELECTED_CONFIGURATION": "desktop",
            "SERIALCON": "ttyS2",
            "SHOW_WARNING": "yes",
            "SOURCED_BOARD_CONFIGS_FILENAME_LIST": [
                "/armbian/config/boards/hinlink-h66k.csc"
            "TZDATA": "Etc/UTC",
            "UBOOT_TARGET_MAP": "BL31=/armbian/cache/sources/rkbin-tools/rk35/rk3568_bl31_v1.44.elf spl/u-boot-spl.bin u-boot.dtb u-boot.itb;;idbloader.img u-boot.itb",
            "UBUNTU_MIRROR": "ports.ubuntu.com/",
            "USE_CCACHE": "no",
            "VENDOR": "Armbian-unofficial",
            "VENDORBUGS": "https://armbian.atlassian.net/",
            "VENDORCOLOR": "247;16;0",
            "VENDORDOCS": "https://docs.armbian.com/",
            "VENDORLOGO": "armbian-logo",
            "VENDORPRIVACY": "https://duckduckgo.com/",
            "VENDORSUPPORT": "https://community.armbian.com/",
            "VENDORURL": "https://duckduckgo.com/",
            "WANT_ARTIFACT_ALL_ARRAY": [
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_BASE_FILES",
                "ARMBIAN_ZSH",
                "ARMBIAN_PLYMOUTH_THEME",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ARMBIAN_BSP_DESKTOP",
                "ROOTFS"
            "WANT_ARTIFACT_ALL_NAMES_ARRAY": [
                "uboot",
                "kernel",
                "firmware",
                "armbian-base-files",
                "armbian-zsh",
                "armbian-plymouth-theme",
                "armbian-bsp-cli",
                "armbian-desktop",
                "armbian-bsp-desktop",
                "rootfs"
            "WANT_ARTIFACT_ARMBIAN_BASE_FILES_INPUTS_ARRAY": [
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_BSP_CLI_INPUTS_ARRAY": [
                "'EXTRA_BSP_NAME='",
                "'BRANCH=current'",
                "'BOARD=hinlink-h66k'"
            "WANT_ARTIFACT_ARMBIAN_BSP_DESKTOP_INPUTS_ARRAY": [
                "'BRANCH=current'",
                "'DESKTOP_ENVIRONMENT=xfce'",
                "'DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base'",
                "'BOARD=hinlink-h66k'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_DESKTOP_INPUTS_ARRAY": [
                "'DESKTOP_AGGREGATION_RESULTS=8855c6119660c614d285554e51769066e94fcb75ff215ccc2fa6b4838b18756b'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_ARMBIAN_PLYMOUTH_THEME_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_ARMBIAN_ZSH_INPUTS_ARRAY": [],
            "WANT_ARTIFACT_KERNEL_INPUTS_ARRAY": [
                "'KERNELSOURCE=https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git'",
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
            "WANT_ARTIFACT_ROOTFS_INPUTS_ARRAY": [
                "'BUILD_MINIMAL=no'",
                "'SELECTED_CONFIGURATION=desktop'",
                "'DESKTOP_APPGROUPS_SELECTED=no_DESKTOP_APPGROUPS_SELECTED_set'",
                "'EXTRA_PKG_ADD_REMOVE_HASH=9484d87e17c18694c6beeb148595dde16586e36948cc22225c4564e1b0cee6fd'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
            "WANT_ARTIFACT_UBOOT_INPUTS_ARRAY": [
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "hinlink-h66k/edge",
            "pipeline": {},
            "target_id": "00000001360000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTDIR": "u-boot",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Hinlink-h66k_sid_edge_7.0.y_xfce_desktop",
            "KERNELBRANCH": "branch:linux-7.0.y",
            "KERNELPATCHDIR": "archive/rockchip64-7.0",
                "@TODO",
            "KERNEL_MAJOR": "7",
            "KERNEL_MAJOR_MINOR": "7.0",
            "LINUXCONFIG": "linux-rockchip64-edge",
            "LINUXSOURCEDIR": "linux-kernel-worktree/7.0__rockchip64__arm64",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'LINUXCONFIG=linux-rockchip64-edge'",
                "'ARMBIAN_KERNEL_DEB_NAME=rockchip64-edge'",
                "'KERNELBRANCH=branch:linux-7.0.y'",
                "'KERNEL_MAJOR_MINOR=7.0'",
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'KERNELPATCHDIR=archive/rockchip64-7.0'"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "hinlink-h68k",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3568 quad core 1-8GB SoC 2xGBe 2x2.5GBe eMMC USB3",
                    "current",
                    "edge"
                    "BOARD_NAME": "Hinlink H68K",
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "hinlink-h68k/current",
                    "BOOT_FDT_FILE": "rockchip/rk3568-hinlink-h68k.dtb",
            "pipeline": {},
            "target_id": "00000001370000001328",
            "vars": {
                "BETA": "",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "BOOTSCRIPT": "boot-rk35xx.cmd:boot.cmd",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "hinlink-h68k",
            "IMAGE_FILE_ID": "Hinlink-h68k_sid_current_6.18.y_xfce_desktop",
                "@TODO",
            "KERNEL_MAJOR": "6",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
                "/armbian/config/boards/hinlink-h68k.csc"
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'BOARD=hinlink-h68k'"
                "'BRANCH=current'",
                "'BOARD=hinlink-h68k'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=current'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                    "current",
                    "edge"
                        "current",
                        "edge"
                    "BOARD_SLASH_BRANCH": "hinlink-h68k/edge",
            "pipeline": {},
            "target_id": "00000001380000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "edge",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BOOTDELAY": "0",
            "CPUMIN": "408000",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "IMAGE_FILE_ID": "Hinlink-h68k_sid_edge_7.0.y_xfce_desktop",
                "@TODO",
            "KERNEL_TEST_TARGET": "current",
            "OFFSET": "16",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
            "USE_CCACHE": "no",
                "UBOOT",
                "KERNEL",
                "FIRMWARE",
                "ARMBIAN_ZSH",
                "ARMBIAN_BSP_CLI",
                "ARMBIAN_DESKTOP",
                "ROOTFS"
                "uboot",
                "kernel",
                "firmware",
                "armbian-zsh",
                "armbian-bsp-cli",
                "armbian-desktop",
                "rootfs"
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'BRANCH=edge'",
                "'RELEASE=sid'"
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
                "'EXTRAWIFI=yes'",
                "'ARCH=arm64'",
                "'RELEASE=sid'"
                "'BRANCH=edge'",
                "'ARCH=arm64'",
        "config_ok": true,
        "in": {
            "configs": [],
            "inventory": {
                "BOARD": "hinlink-h88k",
                "BOARD_FILE_HARDWARE_DESC": "Rockchip RK3588 SoC octa core 4-16GB eMMC USB3 NVMe SATA 4G WiFi/BT HDMI DP HDMI-In",
                    "vendor",
                    "edge"
                    "BOARDFAMILY": "rockchip-rk3588",
                    "BOARD_FIRMWARE_INSTALL": "-full",
                    "BOARD_NAME": "Hinlink H88K",
                        "vendor",
                        "edge"
                    "BOARD_SLASH_BRANCH": "hinlink-h88k/vendor",
                    "BOOT_FDT_FILE": "rockchip/rk3588-hinlink-h88k.dtb",
                    "UEFI_EDK2_BOARD_ID": "h88k"
            "pipeline": {},
            "target_id": "00000001390000001328",
            "vars": {
                "BETA": "",
                "BRANCH": "vendor",
                "RELEASE": "sid",
        "logs": [
        "out": {
            "ARCH": "arm64",
                "@TODO",
            "ATFPATCHDIR": "atf-rk35xx",
            "ATFSOURCE": "",
            "AUFS": "yes",
            "BL31_BLOB": "rk35/rk3588_bl31_v1.48.elf",
            "BOOTDELAY": "0",
            "BOOTDIR": "u-boot-rockchip64",
            "BOOT_SOC": "rk3588",
            "BOOT_SOC_MKIMAGE": "rk3588",
            "CPUMIN": "408000",
            "DDR_BLOB": "rk35/rk3588_ddr_lp4_2112MHz_lp5_2400MHz_v1.18.bin",
            "EXTRAWIFI": "yes",
                "@TODO",
                "@TODO",
            "HOST": "hinlink-h88k",
            "IMAGE_FILE_ID": "Hinlink-h88k_sid_vendor_6.1.y_xfce_desktop",
                "@TODO",
            "OFFSET": "16",
            "OVERLAY_PREFIX": "rockchip-rk3588",
                "ethtool"
            "PLYMOUTH": "yes",
                "@TODO",
                "@TODO",
