Armbian Build Framework Quick Start Guide¶
Requirements¶
- x86_64 / aarch64 / riscv64 machine
- at least 8GB (less for non-BTF builds) of memory and ~50GB of disk space for VM, container, or bare-metal installation
- Armbian / Ubuntu Jammy 22.04.x for native building or any Docker capable Linux for containerised
- Windows 10/11 with WSL2 subsystem running Armbian / Ubuntu Jammy 22.04.x
- Superuser rights (configured sudo or root access).
- Make sure your system is up-to-date! Outdated Docker binaries, for example, can cause trouble
Clone repository¶
Note
- Make sure that full path to the build script does not contain spaces
- For stable branch use last point release
--branch=v24.11
gitGraph
commit
commit
checkout main
commit id: "v24.08" tag: "v24.08"
branch v24.08
commit
commit
commit
commit
checkout main
commit id: "v24.11" tag: "v24.11"
branch v24.11
commit
commit
commit
commit
checkout main
commit
commit
commit
commit
commit
commit
commit id: "main" type: REVERSE tag: "Trunk"
Interactive¶
Run framework:
Bash | |
Video
CLI¶
Bash | |
Only one command can be specified.
Switches are parameter settings that are used by the build framework itself
(e.g. DEBUG=yes
) or the specific command.
Config files are bash shell scripts that are sourced in the order
specified. They are primarily used to set switches but might also set hook
functions. They must be located in the userpatches
directory and must
be named config-${arg}.conf
or config-${arg}.conf.sh
(where ${arg}
is
the argument from the command line): one or the other, but not both.
Switches set on the commandline override settings from the config files, regardless of the order they appear on the comandline.
Comprehensive list of build Commands and Switches
Example:
Bash | |
Or, using config file userpatches/config-myboard.conf
that sets all these switches:
Interpretation?
This command will generate Ubuntu 24.04 Noble based Gnome desktop environment image for Intel based hardware (uefi-x86). Besides bare desktop, it will contain packages from browsers and desktop_tool sections and it will use unchanged kernel from current kernel branch.
Logging¶
Logs are written to output/logs. Old logs (all but the current build) are compressed and moved to output/logs/archive.
Log formats are:
- ANSI - text with ANSI escapes for color coding - *.log.ans
- ASCII (if ansi2txt is available) - text without color coding escapes - *.log
- Markdown summary - *.md
- Raw (if RAW_LOG=yes) - tar file containg all the raw logs - *.raw.tar
For much more verbose logs set switch ‘DEBUG=yes’.
GitHub Actions¶
If you do not have the proper equipment to build images on your own, you can use our GitHub Action.
