Hardware troubleshooting guide¶
First aid video guide:
If you are experiencing at least one of these problems:
- board does not boot
- board freezes, crashes or reboots randomly or when connecting USB devices
- plugged in USB devices are not detected (not listed in
lsusboutput) - error changing the root password at first boot (Authentication token manipulation error)
- error installing or updating packages due to read-only file system
and you are using a stable Armbian image, then most likely you have one of two common problems - powering issue or SD card issue.
Note that
- “I know that my power supply is good”, “it worked yesterday”, “it works with a different device”, etc. are not objective reasons to skip powering related diagnostics
- “I know that my SD card is good”, “it worked yesterday”, “it works with a different device”, etc. are not objective reasons to skip storage related diagnostics
- undervoltage can cause symptoms related to SD card problems such as filesystem corruptions and data loss, so powering has to be checked first
Powering notes¶
- Most boards, even ones fitted with PMIC (power management integrated circuit) do not have any measures to react to undervoltage that could prevent instability
- It does not matter what voltage your power supply outputs, it matters what voltage will reach the onboard voltage regulators
- Peak power consumption of popular boards can vary from 0.9A at 5V (H3 based Orange Pi PC) to 1.7A at 5V (RK3288 based Tinkerboard), both without any attached peripherials like USB devices
- Due to the Ohm’s law voltage drop due to cable and connector resistance will be proportional to the electric current, so most of the time problems will be experienced at current spikes caused by CPU load or peripherials like spinning up HDDs
Power supply¶
- Cheap phone chargers may not provide the current listed on their label, especially for long time periods
- Some cheap phone chargers don’t have proper feedback based stabilization, so output voltage may change depending on load
- Power supplies will degrade over time (especially when working 24/7)
- Some problems like degraded output filtering capacitors cannot be diagnosed even with a multimeter because of the non-linear voltage form
Cable¶
- The longer and thinner the cable - the higher its resistance - the greater the voltage drop will be under load
- Even thick looking cable can have thin wires inside, so do not trust the outside cable diameter
Connector¶
- MicroUSB connector is rated for the maximum current of 1.8A, but even this number cannot be guaranteed. Trying to pass larger current (even momentarily) may result in a voltage dropping below USB specifications
- Most of the boards can also be powered through GPIO pins. This can be used to bypass the microUSB connector and thus to improve stability
SD card notes¶
- A SD card is a complex storage device with an embedded controller that processes read, erase and write operations, wear leveling, error and corruption detection, but it does not provide any diagnostic protocols like S.M.A.R.T.
- SD cards will degrade over time and may fail in the end in different ways - become completely or partially read-only or cause a silent data corruption
SD card brand¶
- Based on current prices and performance tests done by Armbian users Samsung Evo, Samsung Evo Plus and Sandisk Ultra cards are recommended
- Other good alternatives may be added to this page in the future
SD card size and speed class¶
- SD card speed class and size does not influence the reliability directly, but larger size means larger amount of lifetime data written, even if you are using 10-20% of the cards space
SD card testing¶
- There are many fake SD card around. eBay and Amazon Marketplace are notorious for selling fakes, but sometimes even reputable retailers get fooled.
- Most commonly low capacity cards will be reprogrammed to appear as bigger, but any files written beyond the true capacity will be lost or corrupted.
- We recommend to always test the capacity of each new SD cards using f3.
Writing images to the SD card¶
- If you wrote an image to the card it does not mean that it was written successfully without any errors
- so always verify images after write using some tools like balenaEtcher which is currently the only popular and cross-platform tool that does mandatory verify on write (more lightweight alternatives may be added to this page in the future)
- “Check for bad blocks” function available in some tools is mostly useless when dealing with SD cards
- Note that balenaEtcher verifies only 1-2GB that are occupied by the initial unresized image, it does not verify the whole SD card
Network¶
MAC Address Conflicts¶
If you experience strange network problems, especially if you are running several of these SOC-boards with the same operating system, then the problems may be sourced by not having a real hardware MAC address. The operating systems try to generate a hardware MAC address from the CPUid, but what if that SOC has no CPUid either?
Then you have to do it manually. Depending on system and network installation, there are several possibilities:
- the preferred way: change
/boot/armbianEnv.txtand add a line:Text Only 1ethaddr=XX:XX:XX:XX:XX:XX
but that file is interpreted by u-boot, which happens early in boot process, but not every u-boot is able to read that file.
- next possibility to set mac-address is changing network configuration. On systems with ifupdown you can do that by changing
/etc/network/interfaces. Add these lines:Text Only 1 2 3
auto eth0 iface eth0 inet dhcp hwaddress ether XX:XX:XX:XX:XX:XX
- if the above does not work, then your network is probably controlled by Network-manager . In directory
/etc/Networkmanager/system-connectionsis a fileWired connection 1.nmconnection. Change entry cloned-mac-address of group [ethernet] :Text Only 1 2 3 4 5 6
[connection] id=Wired connection 1 type=ethernet [ethernet] cloned-mac-address=XX:XX:XX:XX:XX:XX
Video¶
No Screen on 4k Resolution¶
Some combination of boards/kernel versions does not support 4k resolution. This may cause black screen on connecting the board to 4k resolution devices. A workaround to solve this without changing the kernel is forcing the video mode to 1080p. Add this directive to the /boot/armbianEnv.txt and reboot your system:
| Text Only | |
1 | |
- Despite of this config, some apps may try to use 4k resolution, example: Retroarch. In this case you have to change app configuration to use the 1080p resolution.
- To edit files without video you could connect to the board using ssh. Other option is mount the sd card in another device.
Configuration¶
- Some boards require the setup of the correct device tree file or they will not boot. Check the board specific documentation for details.
How to report bugs properly¶
- Follow instructions on https://armbian.com/bugs/
