Automatic first boot configuration¶
Reading presets from local config¶
It is possible to configure your device automatically at first boot. Settings like: root password, IP address, connecting to wireless.
After flashing an image to boot media, mount it and add a file containing your config to /root/.not_logged_in_yet
Tip
You may also mount the image and edit it prior to flashing, if this is preferable.
Loading a remote config¶
It is also possible to load this config file from a remote server, as above, however the only directive you should include is:
| /root/.not_logged_in_yet | |
Configuration directives¶
- The directives in this file are specified using
key="value"format. - To ask for a value interactively, leave it unset or comment out the directive.
- For fully-unattended setup, specify all values.
Caution
No validation of this network config is performed, wrong settings will lead to broken network.
Armbian supports netplan.io, this is the preferred config method.
See netplan guides for various example configurations.
Netplan config is stored in /etc/netplan/.
| Configuration directive | [default] | option |
Description: |
PRESET_CONFIGURATION |
http://path/to/config/file |
See Loading a remote config |
PRESET_NET_CHANGE_DEFAULTS |
[0] | 1 |
Change default network settings if unset, no network changes will be applied |
PRESET_NET_ETHERNET_ENABLED |
0 | 1 |
Enable Ethernet, ignored if WiFi enabled |
PRESET_NET_WIFI_ENABLED |
0 | 1 |
Enable WiFi, takes priority over Ethernet |
PRESET_NET_WIFI_SSID |
MySSID |
WiFi SSID |
PRESET_NET_WIFI_KEY |
MyWPA-PSK |
WiFi Pre-Shared Key (Password), stored in plaintext |
PRESET_NET_WIFI_COUNTRYCODE |
CC |
Country code, required for WiFi e.g. GB, US, DE; see Wikipedia/ISO_3166 |
PRESET_CONNECT_WIRELESS |
Y | n |
Set to Y for interactive mode, n uses values from file |
PRESET_NET_USE_STATIC |
[0] | 1 |
Use the static IP provided, DHCP is the default Leaving any value unset will result in a broken config |
PRESET_NET_STATIC_IP |
xxx.xxx.xxx.xxx |
Static IPv4 address, dotted decimal notation |
PRESET_NET_STATIC_MASK |
xxx.xxx.xxx.xxx |
Subnet mask, typically 255.255.255.0 |
PRESET_NET_STATIC_GATEWAY |
xxx.xxx.xxx.xxx |
Default gateway address |
PRESET_NET_STATIC_DNS |
x.x.x.x x.x.x.x |
DNS Servers to use, separated by a space. If unsure: CloudFlare is 1.1.1.1 1.0.0.1Google is 8.8.8.8 8.8.4.4 |
SET_LANG_BASED_ON_LOCATION |
Y | n |
“Set user language based on your location?” |
PRESET_LOCALE |
locale |
Locale e.g. en_GB.UTF-8, de_DE.UTF-8, zh_TW.UTF-8 |
PRESET_TIMEZONE |
timezone |
Timezone e.g. Etc/UTC, |
PRESET_ROOT_PASSWORD |
[1234] | password |
Preset root passwordStored in plaintext, SSH keys are safer! |
PRESET_ROOT_KEY |
https://path/to/key.file |
Fetches public key from specified URL for root user |
PRESET_USER_NAME |
username |
Username to create |
PRESET_USER_PASSWORD |
password |
Preset created user password Stored in plaintext, SSH keys are safer! |
PRESET_USER_KEY |
Fetches public key from specified URL for created user |
PRESET_DEFAULT_REALNAME |
Real Name |
RealName to use for created user |
PRESET_USER_SHELL |
shell |
Currently only bash (default) or zsh (armbian-zsh) supported |
Sample config file¶
The following is an example configuration, it may be used as a template
Tip
If you want to use first run automatic configuration at build time, check this GitHub pull request.
tl;dr;
- Copy the template with
cp extensions/preset-firstrun.sh userpatches/extensions/ - Edit the template
userpatches/extensions/preset-firstrun.shaccording to your situation - Build your Armbian image using the additional parameter
ENABLE_EXTENSIONS=preset-firstrun
