Building with Docker¶
Officially supported and tested method for building with Docker¶
This method works for building u-boot and kernel packages as well as building full OS images.
Note!
To write fresh-builded image directly to sdcard or other block device you have to enable
Docker run in privileged mode.
Uncomment line DOCKER_FLAGS+=(--privileged) in file userpatches\config-docker.conf or your own docker-config file.
Building additional packages (EXTERNAL_NEW) is not supported.
Requirements¶
- x86/x64/aarch64/armhf Linux host that supports running a recent Docker daemon. Refer to Docker documentation for details.
- Docker version 17.06 CE or newer.
- Enough free disk space on the storage used for Docker containers and named volumes. Named volumes path can be changed using standard Docker utilites, refer to Docker documentation for details.
Installation (https://docs.docker.com/engine/install/)
Details¶
There are 3 options to start build process:
1. By passing configuration file name (config-<conf_name>.conf), stored in userpatches directory, as an argument:
| Text Only | |
compile.sh after docker:
| Text Only | |
| Text Only | |
The process creates and runs a named Docker container armbian with two named volumes armbian-cache and armbian-ccache,
and mounts local directories output and userpatches.
Options 1 and 2 compile the same as without Docker but in separate environment to prevent changes to the base system.
The dockerfile of the created container is placed in userpatches directory, and all container-related options can be changed
in userpatches/config-docker.conf file. Templates of both files are located in the config/templates directory.
docker-shell interactive mode¶
The docker-shell interactive mode is useful for when you need to do more than just “make an image.” This mode allows you to edit U-Boot and kernel sources before and after applying patches, investigate compilation errors, and so on.
This mode also allows you to manually run individual steps of the build process.
First, start docker-shell on the host build system:
| Text Only | |
RELEASE=bullseye BOARD=rockpi-4a BRANCH=edge are passed into shell and will be set into
envirounment variables.
Next, we can simply start building an image:
| Text Only | |
For example, to compile U-Boot, prepare the environment with:
| Text Only | |
| Text Only | |
| Text Only | |
