Armbian Build Framework Quick Start Guide¶
Requirements¶
- x86_64 / aarch64 / riscv64 machine
- at least 4GB of memory and ~50GB of disk space for VM, container or bare metal installation
- Armbian / Ubuntu Jammy 22.04.x for native building or any Docker capable Linux for containerised
- Windows 10/11 with WSL2 subsystem running Armbian / Ubuntu Jammy 22.04.x
- Superuser rights (configured sudo or root access).
- Make sure your system is up-to-date! Outdated Docker binaries, for example, can cause trouble
Clone repository¶
Note
- Make sure that full path to the build script does not contain spaces
- For stable branch use last point release
--branch=v24.11
gitGraph
commit
commit
checkout main
commit id: "v24.08" tag: "v24.08"
branch v24.08
commit
commit
commit
commit
checkout main
commit id: "v24.11" tag: "v24.11"
branch v24.11
commit
commit
commit
commit
checkout main
commit
commit
commit
commit
commit
commit
commit id: "main" type: REVERSE tag: "Trunk"
Interactive¶
Run framework:
| Bash | |
Video
CLI¶
Comprehensive list of build Commands and Switches
Example:
| Bash | |
Interpretation?
This command will generate Ubuntu 24.04 Noble based Gnome desktop environment image for Intel based hardware (uefi-x86). Besides bare desktop, it will contain packages from browsers and desktop_tool sections and it will use unchanged kernel from current kernel branch.
GitHub actions¶
If you do not own the proper equipment to build images on your own, you can use our GitHub action.
