Build commands¶
kernel¶
Builds kernel and device tree (where applicable) and places it to the output/debs
Usage:
| Bash | |
kernel-config¶
Automatically call kernel’s make menuconfig (add or remove modules or features)
Usage:
| Bash | |
dts-check¶
Validate dts files and improve board & patch development overall.
This option validates the dts/dtb file for the selected board against the device tree bindings and outputs the validation logs to the user. It can be used when adding a new board, developing or improving a dts file.
Usage:
| Bash | |
inventory-boards¶
Outputs a one-board-per-line CSV inventory of boards.
Sets TARGETS_FILE to something that doesn’t exist, so the default-targets.yaml is used (so same list for everyone, save for userpatched-boards)
Usage:
| Bash | |
kernel-dtb¶
Builds only DTB and outputs full preprocessed dts source
Outputs preprocessed DTS source for the board in question to output/
also outputs the same preprocessed DTS source, ran through dtc with input and output DTS formats for “normalized” comparisons
Usage:
| Bash | |
rewrite-uboot-patches¶
Prepares git, applies patches to git, and rewrites them back from git same as kernel, it does git archeology for mbox-less patches, etc.
- uboot-patches-to-git alias is also added, but my guess is that the rewrite is more useful.
- refactor a common config function for both kernel and uboot.
Usage:
| Bash | |
rewrite-kernel-patches¶
Usage:
| Bash | |
targets¶
Generates output/info/git_sources.json file containing URL, branch, and commit hash combo.
The easiest way to generate file for all devices is to run ./compile.sh targets. Then, at the time of release, we will copy the output/info/git_sources.json file to config/sources/git_sources.json. Once the file is copied, the hash information from the file will be used to fetch resources for git repositories where branches are specified instead of tags or commits.
Usage:
| Bash | |
