Automatic first boot configuration¶
Reading presets from local config¶
It is possible to configure your device automatically at first boot. Settings like: root password, IP address, connecting to wireless.
After flashing an image to boot media, mount it and add a file containing your config to /root/.not_logged_in_yet
Tip
You may also mount the image and edit it prior to flashing, if this is preferable.
Loading a remote config¶
It is also possible to load this config file from a remote server, as above, however the only directive you should include is:
| /root/.not_logged_in_yet | |
1 | |
Configuration directives¶
- The directives in this file are specified using
key="value"format. - To ask for a value interactively, leave it unset or comment out the directive.
- For fully-unattended setup, specify all values
| Configuration directive | [default] | option |
Description: |
PRESET_CONFIGURATION |
http://path/to/config/file |
See Loading a remote config |
PRESET_NET_CHANGE_DEFAULTS |
[0] | 1 |
Change default network settings if unset, no network changes will be applied |
PRESET_NET_ETHERNET_ENABLED |
0 | 1 |
Enable Ethernet, ignored if WiFi enabled |
PRESET_NET_WIFI_ENABLED |
0 | 1 |
Enable WiFi, takes priority over Ethernet |
PRESET_NET_WIFI_SSID |
MySSID |
WiFi SSID |
PRESET_NET_WIFI_KEY |
MyWPA-PSK |
WiFi Pre-Shared Key (Password), stored in plaintext |
PRESET_NET_WIFI_COUNTRYCODE |
CC |
Country code, required for WiFi e.g. GB, US, DE; see Wikipedia/ISO_3166 |
PRESET_CONNECT_WIRELESS |
Y | n |
Set to Y for interactive mode, n uses values from file |
PRESET_NET_USE_STATIC |
[0] | 1 |
Use the static IP provided, DHCP is the default Leaving any value unset will result in a broken config |
PRESET_NET_STATIC_IP |
xxx.xxx.xxx.xxx |
Static IPv4 address, dotted decimal notation |
PRESET_NET_STATIC_MASK |
xxx.xxx.xxx.xxx |
Subnet mask, typically 255.255.255.0 |
PRESET_NET_STATIC_GATEWAY |
xxx.xxx.xxx.xxx |
Default gateway address |
PRESET_NET_STATIC_DNS |
x.x.x.x x.x.x.x |
DNS Servers to use, separated by a space. If unsure: CloudFlare is 1.1.1.1 1.0.0.1Google is 8.8.8.8 8.8.4.4 |
SET_LANG_BASED_ON_LOCATION |
Y | n |
“Set user language based on your location?” |
PRESET_LOCALE |
locale |
Locale e.g. en_GB.UTF-8, de_DE.UTF-8, zh_TW.UTF-8 |
PRESET_TIMEZONE |
timezone |
Timezone e.g. Etc/UTC, |
PRESET_ROOT_PASSWORD |
[1234] | password |
Preset root passwordStored in plaintext, SSH keys are safer! |
PRESET_ROOT_KEY |
https://path/to/key.file |
Fetches public key from specified URL for root user |
PRESET_USER_NAME |
username |
Username to create |
PRESET_USER_PASSWORD |
password |
Preset created user password Stored in plaintext, SSH keys are safer! |
PRESET_USER_KEY |
Fetches public key from specified URL for created user |
PRESET_DEFAULT_REALNAME |
Real Name |
RealName to use for created user |
PRESET_USER_SHELL |
shell |
Currently only bash (default) or zsh (armbian-zsh) supported |
Sample config file¶
The following is an example configuration, it may be used as a template
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 | |
Tip
If you want to use first run automatic configuration at build time, check this GitHub pull request.
tl;dr;
- Copy the template with
cp extensions/preset-firstrun.sh userpatches/extensions/ - Edit the template
userpatches/extensions/preset-firstrun.shaccording to your situation - Build your Armbian image using the additional parameter
ENABLE_EXTENSIONS=preset-firstrun
