Changelog¶
- Note: If a new sub-version is released this does not necessarily mean all boards receive a new version number since most of the time these fixes are targeting a specific board or board family only.
What’s Changed¶
v24.8.4 (2024-10-12)¶
- Recreated images for Radxa Rock 5C, Nanopi M6
v24.8.3 (2024-09-13)¶
- Recreated images for Radxa Rock 5 ITX, Rockpi E, Odroid M1, Nanopi R6S
v24.8.1 (2024-08-31)¶
- Add audio support to hdmi output (meson) by @kernelzru
- Temporally disable broken build configuration by @igorpecovnik
- Odroid XU4: Remove deprecated patches by @igorpecovnik
- RK3588 edge kernel: Add support for Linux 6.10 + introduce stable
currentbranch (6.8) by @ColorfulRhino - rk3588: Add board NanoPi R6C by @ColorfulRhino
- re-add some Khadas Edge 2 patches to edge kernel by @efectn
- Update JetHome JetHub D2 support by @adeepn
- rockchip-rk3588 6.8.y: nanopct6: Add NanoPC T6 SPI Flash (v6.8.y version) by @rpardini
- rockchip64/rk3318-box: move stack further from base addr to allow bigger uboot image by @alex3d
- RK3588 edge: Add H.264 decoder support by @ColorfulRhino
- GH Actions: Fix auto-labeler for “Desktop” category and add categories “Patches” and “Documentation” by @ColorfulRhino
- extlinux: add DEFAULT_OVERLAYS support by @efectn
- Disable autosuspend on Gnome based desktops by @igorpecovnik
- actions: Fix typo in actions/labeler labeler.yml by @ColorfulRhino
- cli: Fix DEFAULT_OVERLAYS array by @ColorfulRhino
- khadas-edge2: rename audios by @efectn
- Fix boot from btrfs fs in uboot 2024.01/2024.04 by @alex3d
- rockchip-rk3588-edge: fix vepu of rk3588 by @amazingfate
- board: orangepi-5-plus: Add mainline U-Boot for edge kernel by @ColorfulRhino
- khadas-edge2: add vendor uboot to images by @igorpecovnik
- board: nanopi-r6s: Add system-power-controller to pmic by @ColorfulRhino
- kernel: mainline: Bump 6.10-rc3 to 6.10-rc4 by @ColorfulRhino
- Sm8250 6.9 by @amazingfate
- Add support for rk3399 based SBC Leez P710 by @andyshrk
- Debian buster: disable non-existing backports repository by @igorpecovnik
- packages: Enable bash-completion on all images by @ColorfulRhino
- station-m2: Use Raxda u-boot 2024.01 by @chainsx
- actions: Fix auto-labeler by checking subdirectories by @ColorfulRhino
- aic8800: update firmware package URL by @RadxaYuntian
- Move Network Manager bits into extensions by @igorpecovnik
- fix armbian-leds-state-save.sh: by @alexl83
- add community support for lckfb taishanpi by @chainsx
- Deboostrap: switch to last known working tag by @igorpecovnik
- i3-wm: remove conflicting userspace packages by @igorpecovnik
- partitioning: fix race condition on loop device allocation by @alex3d
- rockchip-rk3588: edge: add rkvdec2 support by @amazingfate
- Rootfs cache is repeating generation over and over again by @igorpecovnik
- add device-tree-compiler to bsp-cli debian dependencies by @alexl83
- Run shellfmt to complete code by @igorpecovnik
- Networking: set proper hook location for extensions by @igorpecovnik
- ext: fs-cryptroot-support: don’t abuse
add_host_dependenciesby @rpardini - rockchip-rk3588 6.8/610: add
i2c8-m2overlay by @rpardini - rk3588: Enable
currentkernel branch for some boards by @ColorfulRhino - Add orangepi5-plus UART overlays by @alexl83
- networking: main-config: introduce
NETWORKING_STACKto control network exts; allow “none”; fix typo by @rpardini - Helios64: move to supported section by @igorpecovnik
- phytium-embedded: add bpf_syscall support by @chainsx
- Use random-mac only with systemd-networkd (minimal images) by @igorpecovnik
- Rockcchip RK3588: Rename overlay suffix to match reality by @igorpecovnik
- distro: trixie: Add riscv64 to supported architectures by @ColorfulRhino
- Revert “distro: trixie: Add riscv64 to supported architectures” by @ColorfulRhino
- kernel: mainline: Bump 6.10-rc4 to 6.10-rc5 by @ColorfulRhino
- cli: Add command “dts-check” to validate dts files and improve board & patch development overall (resubmission) by @ColorfulRhino
- tools: Update shellfmt from version 3.6.0 to 3.8.0 by @ColorfulRhino
- actions: Use “all-globs” instead of “any-glob” for negated checks by @ColorfulRhino
- Fix aml-s9xx-box bsp-cli package upgrade by @SteeManMI
- DTS-check: Python librarires have troubles to build, disabling for now by @igorpecovnik
- Fix
dts-checkcommand and use Pip for some Python packages instead of APT by @ColorfulRhino - bootscript: Remove deprecated bootarg “swapaccount=1” by @ColorfulRhino
- Odroid M1: add a network rule to rename default name by @igorpecovnik
- Add new “BSP” and “GitHub” label for the auto-labeler by @ColorfulRhino
- rk3588: bump default blobs (DDR:1.16, BL31:1.45); remove board-specific blobs from boards that used those versions by @rpardini
- fix: partitioning: disable
orphan_file(FEATURE_C12) for ext4 filesystems on 1.47+ e2fsprogs host by @rpardini - aml-s9xx-box: Remove u-boot and update generated extlinux.conf by @SteeManMI
- GitHub: Improve issue templates and add new
Tasktemplate for project management by @ColorfulRhino - station-m2: update u-boot patches by @chainsx
- kde-neon: use Neon’s “user” repo for Jammy & return it to
cscstatus by @rpardini - actions: labeler: Fix label colors by removing
#prefix by @ColorfulRhino - Move board-specific config (Odroid C1) away from family config by @ColorfulRhino
- Remove haveged to save space and resources by @alexl83
- Lets not spam users with error message on fresh checkout by @viraniac
- BPI-CM4: bluetooth:
fw version 0xb5d66dcbby @pyavitz - Update odroidxu4-current to 6.6.36 by @belegdol
- Odroid XU4: remove deprecated patch by @igorpecovnik
- Add Matrix to README by @EvilOlaf
- extensions/radxa-aic8800: fix aic8800_dkms_file_name for sdio by @andyshrk
- Bump default boot blobs for RK3528, RK3566 and RK3568 and use them for NanoPi R5C by @ColorfulRhino
- armbianmonitor
-u: rationalize paste server retrying, use ANSI dmesg by @rpardini - cli: uboot: Include PYTHONPATH in env for compiling U-Boot by @ColorfulRhino
- Integrate
mediaboards into therockchip64family by @ColorfulRhino - Cleanup: Remove old torrents by @ColorfulRhino
- Cleanup: Remove leftovers of former
BOARDFAMILYrk322x(now integrated into therockchipfamily) by @ColorfulRhino - odroidm1/orangepi3b: use default (newer) blobs; rewrite patches; bump -rc u-boot to final by @rpardini
- Cleanup: Clean leftovers in
packages/extras-buildpkgsby @ColorfulRhino - Cleanup: Remove some leftover kernel patch folders by @ColorfulRhino
- radxa-zero3: add
edgebranch (6.9.y) by picking DT from linux-rockchip#for-next & using Kwiboo’s 24.07 u-boot by @rpardini - u-boot: add HOME env for make invocations to avoid binman/Python problems with older u-boot versions by @rpardini
- rockchip: fix rk322x-box uboot boot order by @paolosabatino
- Addressing two problems related to
wireless at firstlogin scriptby @igorpecovnik - Remove OrangepiZero2 heavily outdated legacy kernel by @igorpecovnik
- v3: Add new RISCV family “SpacemiT” and board BananaPi F3 by @ColorfulRhino
- Fix btrfs and xfs resize by @Ratio2
- aml-s9xx-box: bsp-cli hashing fixes by @rpardini
- Bump sunxi-current and sunxi64 to latest tag by @EvilOlaf
- improve fs-cryptroot-support.sh by @alexl83
- build(deps): bump setuptools from 70.1.1 to 70.2.0 by @dependabot
- nanopi-r5s: bump blobs & u-boot enhancements for UMS/otg/bootorder by @rpardini
- Update support for recore boards by @eliasbakken
- Fixing syntax at Recore and add missing board level variables by @igorpecovnik
- rootfs: add comment to force rootfs rebuild by @rpardini
- Test automation - adjust kernel test targets. by @igorpecovnik
- Fix Khadas Edge 2 uboot build by @efectn
- Add recore dts patch to series.conf so it gets applied by @eliasbakken
- bsp-cli/bsp-desktop: hashing fixes by @rpardini
- Fix several issues related to building U-Boot by @ColorfulRhino
- Bump rk322x-box and rk3318-box to u-boot v2024.07-rc5 by @paolosabatino
- fix: firefly-itx-3588j fails to boot, and audio output by @SeeleVolleri
- u-boot: use
pipettyin place ofunbufferby @rpardini - Purge
s5p6818board family by @ColorfulRhino - git: git_ensure_safe_directory(): use env vars instead of changing config by @rpardini
- Spacemit: use same kernel config as on known to work image by @igorpecovnik
- Update JetHub boards support by @adeepn
- Next set of U-Boot compilation fixes by @ColorfulRhino
- fix uboot compilation issues on Orange Pi 5/5 Plus by @efectn
- Reverting attempted git-safe folder problem by @igorpecovnik
- Test automation - optimise testing on targets by @igorpecovnik
- mixtile-blade3: use default blobs & bump vendor u-boot to
next-dev-v2024.03by @rpardini - mekotronics: rk3588: u-boot: borrow patch to fix build on newer gcc by @rpardini
- Move OPi5/5B/5 Plus uboots to Radxa git tree by @efectn
- rk35xx: Remove
legacykernel target from board configs by @ColorfulRhino - rockpi-s: Remove
legacykernel 4.4 support by @ColorfulRhino - Armbian-install: add option to wipe target destination by @igorpecovnik
- Allow to pass docker login when in CI, but not in GitHub actions by @adeepn
- Adjust Rockpi S patch to align with upstream changes by @igorpecovnik
- RTW88: 6.6: upstream wireless:
fixupsby @pyavitz - Allwinner: set legacy 6.1.y to last known build tag by @igorpecovnik
- add new board radxa-e52c by @amazingfate
- Bananapi M5: Bump u-boot to v2024.07 final by @igorpecovnik
- u-boot: embed armbian artifact version in CONFIG_LOCALVERSION by @rpardini
- odroidm1: bump to u-boot v2024.07; replace defconfig patches with hook by @rpardini
- bump rk3288 tinkerboard to uboot v2024.07 by @paolosabatino
- Move the
NETWORKING_STACKin main config and add armhf support to Trixie by @ColorfulRhino - multiple boards: bump u-boot from v2024.07-rcX to v2024.07 final by @rpardini
- Beautify
shellfmtand add board configs to formatting list by @ColorfulRhino - thinkpad-x13s: bump to jhovold’s
wip/sc8280xp-6.10-rc6; add fprintd back to Trixie; fixes by @rpardini - mixtile-blade3: u-boot: join rockchip-rk3588’s default
u-boot-radxa-rk35xxscheme by @rpardini - nanopi-r6s: Use mainline U-Boot by @ColorfulRhino
- mekotronics: u-boot: join rockchip-rk3588’s default
u-boot-radxa-rk35xxscheme by @rpardini - Trixie: remove / replace missing packages by @igorpecovnik
- build(deps): bump actions/upload-artifact from 4.3.3 to 4.3.4 by @dependabot
- partitioning: Reduce
commitmount option for btrfs and ext4 to 120 by @ColorfulRhino - sunxi-6.1: switch to tag:v6.1.97, re-extracting the corrected ones by @The-going
- To modify the PWM-fan temperature control policy of fine3399 to adjust the fan speed to a lower level by @Lemon1151
- mt7623: Bump
legacy4.19 tocurrent6.6 kernel by @ColorfulRhino - nanopi-r5s: u-boot: pci enum in preboot; disable armbian-led-state by @rpardini
- wifi: rtl8852bs: fix build for rockchip by @amazingfate
- Fix armbian-firstrun service not disabled on start. by @adeepn
- Add MKNOD capability to dockershell container by @JohnTheCoolingFan
- Improve Actions UI, introduce Actions run names for all workflows by @ColorfulRhino
- Inovato Quadra: enable correct PIN to get wifi working by @igorpecovnik
- Spacemit-k1 / Banananpi F3: adjust u-boot patch by @igorpecovnik
wip/sc8280xp-6.10-rc7by @rpardini - mainline-kernel: bump to
6.10-rc7by @rpardini - wifi: rtl8852bs: add driver for family instead of board by @amazingfate
- Desktops: replace missing packages with correct ones by @igorpecovnik
- firstlogin: quote values if space is legal by @jkt628
- rockchip-rk35xx-vendor enable rtw89_8852be as module by @alexl83
- sunxi-6.1: Reverse commit 75317a0, fix real reason inability to load kernel by @The-going
- BananaPi CM4/M2S:
Bump u-boot to v2024.07by @pyavitz - u-boot: 2024.07: fix boot from btrfs by @alex3d
- Move teres-i in supported by @Kreyren
- Add Libre Computer Alta and Solitude by @Tonymac32
- SpacemiT: BananaPi F3: U-Boot: use TAG and add SCRIPT support. by @pyavitz
update to BL v1.0.8by @pyavitz - cli: uboot: Move
uboot_cflagsvariable to before its first use by @ColorfulRhino - actions: forked-helper: Don’t escape multiline strings by @ColorfulRhino
- Trixie: remove non-existing packages from Budgie desktop by @igorpecovnik
- SpacemiT: Legacy: Wireless RTL8852BS:
Fixupsby @pyavitz - VIM1S/4: follow Khadas’s branch for u-boot by @viraniac
- add customized GHCR_MIRROR_ADDRESS support by @amazingfate
- actions: Create workflow to update shell tools via auto-PR by @ColorfulRhino
- extensions: Establish some consistency with extension logging by @ColorfulRhino
- rk35xx-vendor: bump to latest sdk release rkr3 by @amazingfate
- JetHome: Update bsp: fix jethub-init to support /etc/defaults by @adeepn
- add rk3576 support to rk35xx and armsom sige5 by @amazingfate
- Enable sound and battery for Retro Lite CM5 by @ginkage
- Bump koalaman/shellcheck from 0.9.0 to 0.10.0 in
lib/functions/general/shellcheck.shby @github-actions - build(deps): bump setuptools from 70.2.0 to 70.3.0 by @dependabot
- Bump oras-project/oras from 0.16.0 to 1.2.0 in
lib/functions/general/oci-oras.shby @github-actions - Bump sharkdp/bat from 0.23.0 to 0.24.0 in
lib/functions/general/bat-cat.shby @github-actions - Add board config for Retro Lite CM5 by @ginkage
- oci-oras: fix for ORAS > 1.x, as it now requires
HOMEto be set (fixesdownload-artifact) by @rpardini - mesa-vpu: use kisak mesa ppa instead of oibaf by @amazingfate
- utils-dpkgdeb: force rebuild of all artifacts, due to https://github.com/armbian/build/pull/6964 (ORAS change) by @rpardini
- Temporally move TI build targets to EOS as Git is out of reach by @igorpecovnik
- urgent: Hotfix for rk3399 boot by @paolosabatino
- Bump rockchip64 edge kernel to 6.10 by @paolosabatino
- rockchip: bump edge kernel to 6.10 by @paolosabatino
- Fix rtl8189fs WiFi driver by @schwar3kat
- Update odroidxu4-current to 6.6.41 by @belegdol
- build(deps): bump setuptools from 70.3.0 to 71.1.0 by @dependabot
- Add HDMI-rx to linux 6-10 for rk3588 by @benhoff
- SpacemiT:
write_uboot_platform: eMMC Support by @pyavitz - fix rk3568-roc-pc by @chainsx
- Fixed Tinker-edge-r HDMI 4K bug by @ARC-MX
- Fix for no network inside Docker container by @igorpecovnik
- add new board armsom-aim7-io by @amazingfate
- Repo management: rework to increase reliability and speed by @igorpecovnik
- add new board RK3328 Heltec HT-M2808 by @sicXnull
- mesa-vpu: install backported mesa from obs for bookworm panthor driver by @amazingfate
- Awarding regular contributors - adding a special PR tag by @igorpecovnik
- UEFI x86 and arm64: Bump EDGE kernels to 6.10.y by @igorpecovnik
- Debian: drop support for Budgie on Trixe / Bookworm. by @igorpecovnik
- rockchip64-edge: add rkvdec2 for rk356x by @amazingfate
- Switch Retro Lite CM5 back to legacy U-Boot by @ginkage
- mesa-vpu: install chromium package instead of chromium-browser by @efectn
- Extend mesa-vpu extension to load unpatched Chromium by default by @igorpecovnik
- sun55iw3-syterkit: update kernel config by @chainsx
- Meson64 edge to 6.10 by @SteeManMI
- kernel: meson-s4t7: update config to match latest fenix changes by @viraniac
- Update odroidxu4-current to 6.6.43 by @belegdol
- thinkpad-x13s: bump to jhovold’s 6.10 (from -rc7) by @rpardini
- Update sunxi-6.6, switch to v6.6.43 by @The-going
- build(deps): bump setuptools from 71.1.0 to 72.1.0 by @dependabot
- build(deps): bump ossf/scorecard-action from 2.3.3 to 2.4.0 by @dependabot
- Adjust patches that are broken or they found a way upstream by @igorpecovnik
- Update board config h96-max to mainline u-boot by @hqnicolas
- Repo management: base-files are placed under wrong repo key by @igorpecovnik
- config: rk35xx: vendor: enable CONFIG_NVMEM_ROCKCHIP_OTP by @amazingfate
- Cosmetic fix: do not show repository keys that doesn’t exits by @igorpecovnik
- Set fixed MAC address for Nanaopi R6S series by @igorpecovnik
- bsp: armbian-install: fix the search for eMMC and SD card devices by @The-going
- Move meson edge 6.10 by @SteeManMI
- Armsom5 - switch to vendor branch and add BOARD_MAINTAINER field to suppress warnings by @igorpecovnik
- Re-enabling KDE Neon Jammy builds by @igorpecovnik
- Meson 6.10: adjust patches to align with upstream changes by @igorpecovnik
- Bump Marvell mvebu EDGE family to 6.10.y by @igorpecovnik
- Add latest Linux Mint versions, Virginia and Wilma, to supported hosts. by @schwar3kat
- MBa8MPxL fixes and updates by @tq-schmiedel
- build(deps): bump actions/upload-artifact from 4.3.4 to 4.3.5 by @dependabot
- Odroid XU4: bump EDGE kernel to 6.10.y by @igorpecovnik
- Udoo & Cubox: imx6: bump EDGE kernel to 6.10.y by @igorpecovnik
- RaspberryPi: bump EDGE kernel to 6.10.y by @igorpecovnik
- Improve partitioning, set correct partition type UUID for root filesystem by @ColorfulRhino
- MBa8MPxL: rework uboot patches by @tq-schmiedel
- Clarify label for entering giveaway - code completion, all authors counts by @igorpecovnik
- Odroid XU4: Remove deprecated patches on CURRENT branch by @igorpecovnik
- uboot: rk3576: add patches to enable tf card boot by @amazingfate
- nanopi-r5c: enable KASLR (current|edge) by @alexl83
- orangepi5-plus: patch u-boot 2024.07 to support KASLR by @alexl83
- orangepi5: fix SPI flash boot by @efectn
- sunxi-6.9: Add megous patches and switch EDGE to tag:v6.9.12 by @The-going
- add general 2024.07 patches to orangepi5-plus u-boot by @alexl83
- nanopi-r5c: add general u-boot 2024.07 patches by @alexl83
- Send summaries of PR and merges to main chat by @EvilOlaf
- BigTreeTech CB1 upstreaming by @JohnTheCoolingFan
- disable saving state for invalid leds brought up in latest kernels by @alexl83
- Fix armbian-firmware-full package build. by @h-s-c
- BigTreeTech CB1: current: Enable IR Receiver by @JohnTheCoolingFan
- Allwinner legacy and current - bump to latest version by @igorpecovnik
- Fixed tinker-edgr-r board GPU bug, drivers:regulator:fan53555:add new device chip id by @ARC-MX
- Link to the actual pr rather than commit with no reference by @EvilOlaf
- Discord: fix pr being announce multiple times by @EvilOlaf
- RaspberryPi: Rewrite kernel configs for legacy and current by @igorpecovnik
- UEFI kernels: rewrite kernel config for legacy - current - edge by @igorpecovnik
- Add aic8800 driver for Rock 3C variant by @Zokhoi
- Prevent running announce script in forks by @igorpecovnik
- fix firefly itx3588j u-boot patches not applied by @SeeleVolleri
- aic8800 DKMS driver: fix logic when extension is used by @igorpecovnik
- build(deps): bump actions/upload-artifact from 4.3.5 to 4.3.6 by @dependabot
- build(deps): bump pyyaml from 6.0.1 to 6.0.2 by @dependabot
- attempt to fix pr announce for all contributors by @EvilOlaf
- Add board Alfred Smart Gateway GZ80X by @pyavitz
- JetHome: Put module blacklist in the board configs of the respective boards by @adeepn
- Gateway GZ80X:
use actual u-boot.binby @pyavitz - JetHome: fix uboot patchset for JetHub D2 by @adeepn
- meson64: refresh
drv-spi-spidev-remove-warnings.patchby @alexl83 - JetHome: Update JetHub D2 dts by @adeepn
- rockchip64: refresh
drv-spi-spidev-remove-warnings.patchby @alexl83 - Support kernel compilation with Clang/LLVM by @Randl
- rockchip64: Enable
CONFIG_SECURITY_DMESG_RESTRICTkernel option by @alexl83 - JetHome: update list of preinstalled packages for JetHub devices by @adeepn
- RFC: provide KASLR support to u-boot v2024.07 general availability by @alexl83
- Change KBUILD to
build@armbianfor kernel builds by @ColorfulRhino - rootfs: add comment to force rootfs rebuild by @igorpecovnik
- Mesa extension: adjust KDE related troubles with packages downgrade by @igorpecovnik
- sunxi 6.10: Add megous patches by @The-going
- rockchip-rk3588: Bump
edgekernel from 6.10 to 6.11-rc andcurrentfrom 6.8 to 6.10 by @efectn - fix ps4 controllers and clones on rk3588 vendor and legacy kernel by @monkaBlyat
- actions: forked-helper: Run only if secret is set and simplify workflow by @ColorfulRhino
- Fix loop device search in docker when there are no loop devices before container launch by @JohnTheCoolingFan
- build-framework: Switch to next VERSION and update main README by @igorpecovnik
- rockchip-rk3588: Enable
CONFIG_SECURITY_DMESG_RESTRICTkernel option by @alexl83 - KDE Neon: hack must be implemented only on Ubuntu Noble / Oracular by @igorpecovnik
- Revert “Temporally move TI build targets to EOS as Git is out of reach” by @igorpecovnik
- Release: board status check and adjustment by @igorpecovnik
- Add Board X96Q TV Box LPDDR3 H313 by @sicXnull
- Discord announcement: push only when label “Needs review” is set by @igorpecovnik
- WIP: add initial support for Youyeetoo R1 V3 by @SuperKali
- Build automation: update kernel test targets for many boards by @igorpecovnik
- Build automation: Adjust test targets for remaining boards by @igorpecovnik
- cli: packages: use iputils-ping instead of inetutils-ping by @amazingfate
- rockchip-rk3588: current: add
rfkill-btdevice node to Radxa Rock-5B by @alexl83 - BananaPi M2S:
remove fan controlby @pyavitz - Gateway AM-GZ80x:
Re-brand as Amper & update u-boot to v2024.04by @pyavitz - Update odroidxu4-current to 6.6.47 by @belegdol
- rk3588: Bump kernel from 6.11-rc3 to 6.11-rc4 by @ColorfulRhino
- Add OpenSBI compilation to D1 by @Randl
- Debian Trixie Cinnamon: remove deprecated package by @igorpecovnik
- Framework: disable armbian repository while generating rootfs cache by @igorpecovnik
- build(deps): bump setuptools from 72.1.0 to 72.2.0 by @dependabot
- Framework: expand package installing function with custom parameter by @igorpecovnik
- Expand MESA extension fix to Jammy userspace by @igorpecovnik
- Framework: bump tmpfs size as we are going over by @igorpecovnik
- Mesa fixes applies only to armhf and arm64. Adjusting by @igorpecovnik
- Repository management: add config driven BSP package modification by @igorpecovnik
- Board config ayn-odin2 temporally disable broken build by @igorpecovnik
- Improved freezing mechanism and README by @igorpecovnik
v24.5.5 (2024-25-7)¶
- Recreated Bananapi M7, Khadas Edge 2, Orangepi 5, Orangepi 5 Plus
- Sent rk35xx-vendor (6.1.75) and rk35xx-edge (6.10.y) kernel to the stable repository
v24.5.4 (2024-21-7)¶
- Recreated Radxa ROCK5 ITX images
- Recreated Olimex Teres images since they were broken
- Sent sunxi64-current kernel to the stable repository
- Sent rk35xx-vendor kernel to the stable repository
v24.5.3 (2024-01-7)¶
- Recreated Helios64 since board was moved under supported
- Sent rockchip64-current kernel to the stable repository
v24.5.2 (2024-18-6)¶
- Recreated Khadas Edge 2 images due to lack of 3D / video acceleration support in 6.1.y
- Recreated Orangepi 5 plus images due to missing support for 32GB variant
- Recreated Odroid M1 images with new minimal images and KDE Neon desktop
- Added Orangepi 5 Pro images
v24.5.1 (2024-25-5)¶
Closed projects¶
- AR-1759 Improve Khadas support
- AR-1988 Resolve Rockchip patch maintenance nightmare
- AR-2087 Add functionality to freeze git resources
- AR-2095 Improve support for Radxa Rock S 0 and test USB and Ethernet
- AR-2100 Add KDE Neon desktop to Armbian Jammy
- AR-2144 Add support for the Orange Pi 5 Pro
- AR-2145 Add mainline Panthor driver to 6.1
- AR-2148 Add board Bananapi M7 to vendor kernel 5.10 and 6.1
- AR-2153 Add board FriendlyElec CM3588 NAS board
- AR-2156 Add support for Radxa ROCK 5 ITX
- AR-2158 Add board Radxa Zero 3 with overlays
- AR-2171 Drop DEBUG_KERNEL/DEBUG_INFO disables; force EXPERT=y and bring back CONFIG_GPIO_SYSFS=y for all kernels
- AR-2172 Update meson edge to 6.8 kernel
- AR-2173 Change the way APT repository is getting updated
- AR-2174 Thinkpad-x13s: drop steev’s kernel and switch to jhovold’s wip/sc8280xp-6.9
- AR-2178 Fix u-boot build for Odroid C1 + fix onboard usb hub on Odroid C1
- AR-2179 Phytium_embedded: update kernel config from phytium repo
- AR-2180 Rockchip-rk3308-current: sakura pi rk3308b adds kernel 6.6 and 6.8 support
- AR-2185 Switch odroidxu4-current kernel to 6.6
- AR-2186 VIM1S/VIM4: Allow building on arm64 platform
- AR-2187 VIM1S/VIM4: Add support for emmc + NVME/USB booting
- AR-2196 CLI: Add command “dts-check” to validate dts files and improve board & patch development overall
- AR-2197 Add support for allwinner T527 Avaota-A1
- AR-2203 Rockchip-rk3308-current: add support for sakura pi rk3308b
- AR-2208 Update sm8250: kernel add current and edge branch And Update Odin2: add kernel update hook script
- AR-2212 H96-TVbox-rk3566 Board Bring Up
- AR-2215 Enable vendor kernel branch on Khadas Edge 2
- AR-2216 arm64: swiotlb: Reduce the default size if no ZONE_DMA bouncing needed
- AR-2218 FriendlyElec CM3588-NAS: device tree fixes & improvements
- AR-2222 Rock-5b: move edge (only) to mainline/Kwiboo u-boot 2024.04
- AR-2226 FriendlyElec CM3588 NAS: Add mainline kernel support
- AR-2227 mekotronics: mainline u-boot (next/Kwiboo rk3xxx-2024.04, generic-rk3588_defconfig)
- AR-2229 rk3588: vendor-boogie-panthor
- AR-2230 rockchip-rk3588: it’s vendor boogie panthor time (experimental)
- AR-2235 Bump meson64 edge from 6.7 to 6.8
- AR-2246 Add support for Radxa ZERO 3E/3W
- AR-2250 Rock 4C+: update and cleanup boot config
- AR-2265 cli: rewrite-
-patches: rewrite only patches needing a rebase - AR-2267 Add SK-AM68 board support
- AR-2270 rk35xx/rockchip-rk3588: vendor: switch to armbian/linux-rockchip#rk-6.1-rkr1
- AR-2274 Add tqma8mpxl boards support
- AR-2276 cli: introduce rewrite-uboot-patches cli command, works similar to the kernel one
- AR-2281 Add csc hinlink h6xk boards
- AR-2282 Kernel: Enable *NVMe-over-TCP* for rk35xx/rk3588/rockchip64/uefi/wsl
- AR-2289 qemu-uefi-x86: new board for virtualized environment with serial console support, kernel boot messages
- AR-2290 cli: introduce kernel-dtb cli command, to build only DTB, and output full preprocessed dts source
- AR-2291 cli: introduce inventory-boards cli command, for hopefully painless & useful one-board-per-line CSV output
- AR-2292 Add board: FriendlyElec CM3588 NAS
- AR-2293 Add vendor branch for new 6.1-rkr1 BSP vendor kernel, and keep legacy for the 5.10-rkr6 BSP vendor kernel
- AR-2294 Phytium-embedded: add support for 4Gb Phytium Pi
- AR-2295 Rockchip RK3588-edge: rewrite kernel patches and configs against v6.8-rc6
- AR-2297 Refactor automatic armbian-firstlogin
- AR-2299 Develop build config for board BananaPi M4 Zero
- AR-2301 Develop and add Ayn Odin2 build config
- AR-2307 Thinkpad-x13s: bump to steev’s 6.7.y; enable noble userspace; bump alsa-ucm-conf hack to master
- AR-2308 Debootstrap: use latest git for Ubuntu/Debian debootstrap instead of host-installed
- AR-2322 Develop PPA for (patched) aarch64 Chromium
- AR-2327 Add support for RK3588 based Cool PI CM5 EVB
Closed Tasks¶
- AR-2043 armbian-install should do rsync –one-file-system
- AR-2057 enable DRBD in the kernel config of mvebu
- AR-2077 Orangepi 5: update memory blobs
- AR-2079 Enable ssdm autologin and apply theme
- AR-2092 Drop repository for unsupported Releases
- AR-2096 USB Gadget mode for rockchip 32 bit
- AR-2101 Cleanup desktop packages
- AR-2102 Adjusting pull request template for documentation
- AR-2103 Disable automatic enablement of Nvidia proprietary drivers on x86
- AR-2105 Rockchip bootscripts: `Failed to load ‘…-fixup.scr’` and `Unknown command ‘kaslrseed’`
- AR-2110 Fix rtl8723cs for kernel 6.8
- AR-2111 Bump rockchip edge kernel to 6.8
- AR-2112 Bump rockchip64 edge kernel to 6.8
- AR-2131 Builds fail for EOS distributions (for example focal)
- AR-2132 Fail at check_loop_device: device node doesn’t exist and `$LOOP=`
- AR-2135 Move Firefly station M2 to RK35xx family
- AR-2136 Synchronise Rock 5 ITX from Radxa repository
- AR-2137 Cleanup and merge OPi5 Plus device tree
- AR-2138 Add support for the Orange Pi 5 Pro to 6.1
- AR-2139 Add armsom sige1 support to 6.1
- AR-2140 Add Radxa Rock 5c support to 6.1
- AR-2141 Add dynamic-power-coefficient properties to all cores
- AR-2142 Sync Panthor with drm-misc-next by adding missing commits
- AR-2146 Upgrade RKNPU driver to 0.9.6
- AR-2147 Cleanup Khadas edge 2 device tree
- AR-2149 Use simple-audio-card for HDMI sound for rk3528
- AR-2151 Carrying over some CM5-related commits from Radxa 3.4 branch
- AR-2152 Add missing led gpio for hinlink h66k
- AR-2155 Add cooling-maps and pwm-fan support for Station M3
- AR-2159 Allow FFmpeg to capture from HDMI input
- AR-2160 Add Ubuntu Noble support for Rockchip multimedia extension
- AR-2161 Switch CM3588 NAS to kwiboo uboot
- AR-2162 Declare Ubuntu Noble as supported build target
- AR-2164 Rockchip rk3588 edge: add Hantro G1 VDPU and RGA2
- AR-2165 Rockchip RK3588 EDGE: add generic pwm overlays from vendor kernel
- AR-2166 rk35xx: drop vendor-boogie-panthor BRANCH; it has been integrated into vendor
- AR-2167 Multiple boards: fixes for board file syntax / missing vars (fixing JSON matrix prepare
- AR-2168 VIM1S/VIM4: initialize video firmware symlink
- AR-2169 Use oibaf and v4l2 extension in desktops only
- AR-2170 Treat sid and unstable as synonyms in distro-specific.sh
- AR-2175 Add latest Ubuntu development branch Oracular
- AR-2176 Armsom rk3588 boards: use radxa’s new uboot
- AR-2177 Phytium_embedded: update phytium u-boot binary
- AR-2182 Enable android binder to support android containers like anbox or waydroid on rk3588 edge kernel builds
- AR-2190 Rockchip: bump rk322x u-boot to v2024.01 and support HDMI
- AR-2191 Switch Radxa u-boot to more recent branch
- AR-2192 Odroidn2: u-boot: fix eMMC stability
- AR-2198 Rockchip64: cleanup rk3318-box hdmi patches
- AR-2199 Add current kernel support for phytium-embedded
- AR-2201 Board: h96 rk3566 HDMI sound & audio fix
- AR-2202 Odin2 Use Custom ABL, boot from TF Card
- AR-2204 H96-tvbox-3566 device tree fixes & improvements: wifi fix, Led and IR enable
- AR-2206 rk35xx-vendor: enable panthor gpu driver
- AR-2207 Rockchip64: bump rk3318-box uboot to v2024.01
- AR-2209 Typo: while Fosstodon is the instance, Mastodon is the software used.
- AR-2210 Rockchip64-edge: add pcie support to orangepi rk3399
- AR-2214 Rockchip-rk3588-edge: opi5b: add support for pcie wifi
- AR-2217 rockchip-rk3588-edge: opi5: fix typec and add support for GPU
- AR-2219 Unlock Code and Thunderbird from all distributions
- AR-2223 Add bluedevil for bluetooth support
- AR-2231 rockchip: rewrite dts for rock3c
- AR-2233 DE: KDE: add package kscreen
- AR-2236 Rockpro64: bump u-boot to v2024.04-rc4; use binman-produced bins
- AR-2237 Fix kernel compilation for meson-s4t7 due to Khadas vendor common_drivers not working without DEBUG enabled
- AR-2238 Fix forced kernel options and make kernel-config consistent with rewrite-kernel-config
- AR-2239 Rockchip RK3588 edge: enable nodes for armsom-sige7, rock 5a and h88k
- AR-2240 armsom-sige7: add ap6275p wifi support
- AR-2241 Rockchip-rk3588-edge: refresh cpufreq patches and auto fan control for Edge2
- AR-2242 GH Actions: Beautify kernel hardening analysis
- AR-2243 Khadas-vim3l/khadas-vim3: enable networking cmds in u-boot
- AR-2244 Rockchip-rk3588-edge: khadas-edge2: add support for GPU and improve display modes
- AR-2245 Build script: configuration: Check if ROOTFS_TYPE is supported by build host
- AR-2247 Create linux-libc-dev when building kernel packages
- AR-2248 bsp-cli: include BOOT_SOC to /etc/armbian-release and bsp-cli hash
- AR-2255 Enable module snd_aloop for linux-rk35xx legacy and vendor
- AR-2260 BananaPi M4 Zero: add gpu and uart nodes
- AR-2262 GH Actions: Kernel hardening analysis: Exclude RISC-V configs
- AR-2266 Expand predicted size for rootfs for abl type of images
- AR-2269 Extend PR template when asking for documentation
- AR-2271 rk35xx-vendor: Add kernel patching config
- AR-2272 rk35xx-vendor: add rk3528 and lima driver support
- AR-2275 GH Actions: Update forked-helper and add some doc on secrets in workflow’s README.md
- AR-2277 u-boot: rewrite/rebase u-boot patches for a few boards; bump odroidm1 and orangepi3b
- AR-2280 Show correct reason about omit tmpfs usage if FORCE_USE_RAMDISK is set
- AR-2286 BananaPi M4 Zero: enable 8821cu and blacklist rtw88_8821cu
- AR-2287 lib: drop old boot_logo code; keep png/gif as they’re used for plymouth
- AR-2288 Rk35xx vendor kernel: add some network drivers
- AR-2296 meson-6.7: Copy patches from 6.6
- AR-2298 Prepare-host/host-release: enable noble for building
- AR-2303 kernel: call make with INSTALL_MOD_STRIP=1 so modules are stripped
- AR-2304 wsl2: arm64: current: DRM/FB stuff so wsl2-arm64 can be used in HyperV with video & keyboard
- AR-2305 mekotronics 3588: add SRC_CMDLINE, for use with u-boot-menu extension
- AR-2306 khadas-vim3/khadas-vim3l: u-boot v2024.01: enable more compression, kaslr, and led config options via hook
- AR-2324 Optimize the kernel device tree patch for rk3399-firefly
- AR-2325 Give shellcheck directions (to /dev/null for dynamic, to repo-relative path for static) for all sourced references
- AR-2328 Extensions: rk-panthor: mesa-oibaf + DEFAULT_OVERLAYS=”panthor-gpu”
- AR-2333 Set linux-image packages to provide wireguard-modules
- AR-2335 Add chromium v4l2 encoder/decoder udev rules for all boards
Solved Bugs¶
- AR-650 Odroid N2+ possible boot problems on eMMC
- AR-1582 CI on our runners sometimes throws out error regarding loop devices
- AR-2034 RockPI-S does WiFi broken on kernels >6.5
- AR-2045 Resolve extensions rootfs encryption conflicts
- AR-2070 VIM1S/VIM4: Booting from UHS sdcard only works intermittently
- AR-2076 Fix random MAC address on Orangepi 5 series
- AR-2080 Lightdm greeter is without wallpaper - black background
- AR-2086 Home assistant supervised fails to install on Khadas VIM1S
- AR-2090 Debootstrap is again too old for latest releases
- AR-2094 Build failed during partprobing of /dev/loop device.
- AR-2097 GH Actions: “Kernel hardening analysis (pull request)” kconfig-hardened-check: No such file or directory
- AR-2098 Torrent generation fails silently
- AR-2121 RockPi-S WiFi broken again on kernel’s >6.7
- AR-2125 Deboostrap trixie fails at stage 2
- AR-2143 Fix Orange Pi 5 Plus load average >= 1
- AR-2150 Fixing deadlock issue with spin_lock in interrupt handling
- AR-2154 Fix CEC on rk356X on tv restart
- AR-2157 Rock-5a: pull down data-strobe to fix emmc compatibility
- AR-2163 Restore armbian-config desktop icon
- AR-2181 Rockchip Rock 5C: Fix RK3582 with disabled rkvdec node
- AR-2183 Fix memory size detection for 1.5GB Orange Pi Zero 3 board on v2024.01 u-boot release
- AR-2184 rockchip64: rework drm hunk due to mainlined patch
- AR-2188 Make debian/trixie debootstrap-able again
- AR-2189 Fix PCIe for RK35xx+Fix ROCK5A PCIe device tree
- AR-2193 Hostdep fixes for Noble distutils and pyelftools removed hooks
- AR-2200 Fixing broken device tree for H96 tvbox 3566
- AR-2205 Fixing not operational USB port on Udoo quad
- AR-2211 Ramlog: harden the zram mounting
- AR-2213 Restore wireless functionality on Rock Pi S
- AR-2220 Rockchip: update DTS patches for Orangepi R1 Plus
- AR-2221 riscv64: fixes/skips for building (sans Docker) ON riscv64
- AR-2224 Disable mtd-tools on Armbian Noble for armhf architecture
- AR-2225 Fixing broken user space packages dependencies and small optimisations
- AR-2228 RTW88: 6.x.y patches adjustment due to upstream changes
- AR-2232 Raspberry 5 has troubles booting when faster memory access is enabled
- AR-2234 BananaPi CM4/M2S: The fan on the unit is constantly running. So lets set thermal trip points
- AR-2252 Rockchip RK3588 edge: fix wrong gpu node patch
- AR-2253 Rockchip RK3588 edge: improve display modes support
- AR-2273 Xiaomi elish fix 6.7: fixing broken dsi panel
- AR-2283 Remove hard-coded defaults from repository management tool
- AR-2285 Several small fixes for Banana Pi M4 Zero
- AR-2300 Rockchip RK3588 edge: Orangepi 5 pluse: fix USB3 Host
- AR-2309 Fixing small problems in wireless driver RTW88: RTL8822/21CU code
- AR-2311 Meson64: fixing Librecomputer Lafrite boot failure
- AR-2323 Resolving Armbian Noble incompatibility with Rockchip VPU extension
- AR-2326 Radxa rock-5c: rename wireless interface name to a static one
- AR-2329 Add new user to render group, otherwise the non-root user do not have access /dev/dri/renderD128 on RK3399
- AR-2334 Resolve dependency issues with armbian-config
Closed Sub-task¶
- AR-2082 Make initial devicetree to make most parts work (USB2, USB3, SD etc.)
- AR-2083 Add Type-C support
- AR-2084 Make AP6275P work on upstream kernel
- AR-2085 Add Khadas Edge2 support to upstream Khadas MCU driver
v24.2.6 (2024-6-5)¶
- recreated images for Bananapi CM40IO, Bananapi M7
v24.2.5 (2024-4-2)¶
v24.2.4 (2024-3-12)¶
- added KDE Neon 6 desktop images for generic UEFI targets, Orangepi 5 / 5+ (with new vendor kernel 6.1.y) and Odroid M1
v24.2.3 (2024-2-26)¶
- recreated images for Bigtreetech CB1
v24.2.1 (2024-02-18)¶
Closed projects¶
- AR-1657 Address DNS resolve with Debian Bookworm
- AR-1797 Auto-testing: install all kernels that are defined
- AR-1888 fix sluggish hdmi console for vim1s and vim4
- AR-2061 Add Orangepi Zero3
- AR-2062 Mixtile Blade 3 refactor / rockchip-rk3588 edge 6.7
- AR-2063 Add new board of ASUS Tinker-Edge-R
- AR-2064 Khadas VIM1S & VIM4 - 5.15 kernel bump
- AR-2065 Add Xiaomi Mi10(umi) support
- AR-2066 aml-s9xx-box: Update u-boot-s905x2-s922 to u-boot version 2024.01
Closed Tasks¶
- AR-1879 JetHome: update u-boot to 2023.10
- AR-1985 Generate new function to display download links
- AR-1990 Move forgotten overlays from Odroid M1
- AR-2033 revert JetHub H1/D1 wifi driver from rtw88 to vendor
- AR-1552 Rework support for jethub devices
- AR-1696 Khadas Edge (RK3399) has wrong name and picture
- AR-1737 Merge Odroid M1 into rockchip64 family
- AR-1870 Git workaround failure
- AR-1925 Move wifi-4003-uwe5622-adjust-for-rockchip to the wireless section
- AR-1984 Move live patch to extension
- AR-2000 Several small maintainace tasks
- AR-2004 Add Ubuntu Noble to the build framework
- AR-2005 Bump all current kernels to 6.6 LTS
- AR-2012 Please set dpkg vendor to Armbian in all images
- AR-2016 Patchset for Rockchip (32b) needs to be ported to 6.7
- AR-2017 Patchset for Rockchip 64b needs to be ported to 6.7
- AR-2021 Add Home assistant extensions
- AR-2032 LVM support, CRYPTROOT and current implementation.
- AR-2035 Cloud-Init Supprot and Armbian First
- AR-2050 Add support for Radxa Rock S 0
Solved Bugs¶
- AR-1704 Bookworm Gnome lacks wallpaper withing lightdm
- AR-1735 Command docker-shell seems to be broken
- AR-1813 Orangepi One + fails to bring up NIC
- AR-1861 Hashing on wireless patches seems to not work
- AR-1908 Khadas VIM3 problem with high res displays
- AR-1915 Extlinux / Khadas Edge 2 install to eMMC fails
- AR-1933 Fix GitHub labeling anomaly
- AR-1981 Edge Kernel (6.6.x) breaks WiFi and Bluetooth support for RockPI-S
- AR-1987 Error when removing BSP package
- AR-2003 None of the builds of Raspberry Pi 5 goes into desktop
- AR-2007 Fix armbian.list.disabled exists
- AR-2009 Extensions from USERPATCHES_PATH are not supported
- AR-2010 Remove broken symlink
- AR-2020 RK35xx is seeking for rk35xx config
- AR-2027 Compressed images failed to upload to GitHub releases
- AR-2038 KHADAS_OOWOW_BOARD_ID is not set, can’t use image-output-oowow
- AR-2051 All installed systemd units are forcefully enabled on first boot
- AR-2052 Cinnamon desktop doesn’t work on vim4
- AR-2053 Desktop environment takes a long time to load on vim4
- AR-2054 Image takes a lot of time to load on vim1s/vim4 bookworm image
v23.11.3 (2023-12-20)¶
v23.11.2 (2023-12-18)¶
- added standard support images for Raspberry Pi 5, Odroid N2/N2+, Odroid M1 due to the boards support status change
- recreated images for Raspberry Pi 4, Nanopi R4S, Orangepi Zero2 due to several bug fixes (check commit log / newsletter for details)
v23.11.1 (2023-11-30)¶
Closed projects¶
- AR-1702 Switch default login manager
- AR-1886 Enable artifacts creation at pull request
- AR-1924 Add support for Hikey 960
- AR-1928 K3: Update edge kernel to v6.5
- AR-1929 New Armbian Wallpapers
- AR-1930 Add orangepi3b build config
- AR-1940 Add edge kernel support for NanoPi R6S/R6C
- AR-1941 Rework ac200 patches and config for current and edge kernel.
- AR-1943 Add initial support for TI SK-TDA4VM board
- AR-1951 add new device xiaomi-elish
- AR-1957 Improve labeling system - refactor labeling logic
- AR-1958 rk3588: configure UEFI_EDK2_BOARD_ID for all UEFI-supported boards
- AR-1959 use GHPROXY_ADDRESS to customize ghproxy url
Closed Tasks¶
- AR-1784 Remove FriendlyElec vendor “driver” patch in mainline
- AR-1907 Add latest patch for eeprom support in JetHub D1+
- AR-1811 Drop host OS-es that can’t compile Crust
- AR-1882 Clean remaining legacy Rockchip kernels
- AR-1897 KDE build seems to be missing features
- AR-1913 Remove midstream kernel
- AR-1919 Change support status to multiple selection
- AR-1942 Add board config for Tanix TX6 tvbox
- AR-1944 Add support for Inovato Quadra
- AR-1945 hinlink-h28k [new board]: support new SoC Rockchip rk3528
- AR-1946 rockchip64/edge 6.6.y: update overlay configfs patch from rpi
- AR-1947 meson-s4t7: Add option to force 16x9 display resolution
- AR-1948 meson-s4t7: add systemd service to enable fan in automatic mode
- AR-1949 mekotronics-r58x-pro.wip: add new board Mekotronics R58X-Pro
- AR-1950 mixtile-blade3: enable pci3x4 nvme boot (requires u.2 -> m.2 adapter from blade3 case kit)
- AR-1952 Update Rock CM5 I/O board config (#5866)
- AR-1953 Add settings & updater for KDE
- AR-1954 add board ArmSoM-w3; with uboot-patch and updated blobs
- AR-1956 Rockchip64: Clean up archive of all EOL kernels
- AR-1960 VIM1S/VIM4: Add bluetooth support
- AR-1969 BPI-CM4: Add support for the waveshare cm4-io-base-b
- AR-1970 BPI-CM4: Enable usb support on waveshare baseboards via overlay
- AR-1971 BPI-SM1: Removed UART_B overlay.
- AR-1972 BPI-SM1: Add UART_A “pin-ctrl: cts rts”
- AR-1973 Aligning display manager with the desktops
- AR-1974 Add Ubuntu Mantic build target
- AR-1979 Update kernel configs for Waydroid and Redroid support
- AR-1980 xiaomi-elish: bump to kernel 6.7-rc2
- AR-1983 xiaomi-elish: add typec pd support
Solved Bugs¶
- AR-1641 simpledrm module prevents Mali G-31 hardware acceleration
- AR-1832 x13s errors with bash: line 1: add-apt-repository: command not found
- AR-1866 UWE5622 driver is broken on 6.5.y
- AR-1876 Shallow clones CI is getting disabled due to inactivity
- AR-1911 Raspberry Pi, upgrade fails
- AR-1923 Rockchip kernels compilation breaking
- AR-1932 Update firmware for Orangepi R1+ LTS
- AR-1936 Khadas Vim1s: Fix display output
- AR-1938 xradio: fix compilation for 6.1+
- AR-1961 rangepi3lts: load wifi module via systemd service otherwise it crash
- AR-1962 Restore LED triggers for each ATA port indicating disk activity in mvebu-edge
- AR-1963 Fix broken HDMI output on rk3328
- AR-1964 Orange Pi 3 LTS: Fix ethernet broken for some users on 6.x kernel
- AR-1965 Fix LicheePi 4A audio problem
- AR-1966 Khadas Vim1s: Fix monitor not detected after its turned off and on again
- AR-1967 xiaomi-elish: update config for 6.6, and fix one bluetooth pairing issue
- AR-1968 bootscript: meson-s4t7: fix booting on ubuntu
- AR-1976 VIM1S: emmc 23.8.4 install fails to boot after running upgrade using beta repository
- AR-1977 Default renderer for NetPlan is not set on Debian variants
- AR-1982 rockpi-s still using ifconfig to set wlan MAC address
v23.08.5 (2023-10-11)¶
- Recreated images for Khadas VIM4
Solved Bugs¶
v23.08.4 (2023-10-09)¶
- Recreated images for Khadas VIM1S, Khadas VIM4
Solved Bugs¶
- AR-1894 HDMI not working in Armbian Image on VIM1S and VIM4. Its fixed and works on most monitor now in Debian based images, Ubuntu images will also be fixed soon.
- AR-1895 Fix HDMI monitor does not work after its turned off and on again on VIM1S
v23.08.3 (2023-09-20)¶
- Recreated images for NanoPi Duo, Orange Pi Zero, Orange Pi Zero 2, Orange Pi 3 LTS
Closed Tasks¶
- AR-1506 Reworked AC200 support for Allwinner current and edge kernels
Solved Bugs¶
- AR-1280 Xradio xr819 wireless driver not available in Allwinner current and edge kernels
- AR-1833 Slow network speed reported by iperf3 and nuttcp on Allwinner boards with Gigabit NIC
- AR-1866 Unisoc UWE5622 wireless driver not available in Allwinner legacy, current and edge kernels
v23.08.2 (2023-09-11)¶
- Recreated images for Orangepi 5 Plus, Bananapi M1
v23.08.1 (2023-09-01)¶
Closed projects¶
- AR-1690 Add Crust to Allwinner boards to enable power management functions
- AR-1700 Add support for most recent memory chips on BPi M5
- AR-1723 Backport Bananapi CM4 to kernel 6.1 LTS
- AR-1744 Provide official distro upgrades
- AR-1838 Adding armbian-gaming as extension
- AR-1841 Introduce grub-with-dtb extension
- AR-1842 Add Lenovo X13S as WIP board
- AR-1843 Khadas VIM3/VIM3L u-boot 23.07-rc4 + SPI-NOR/MTD booting support
- AR-1850 Odroid M1 de-infest Petitboot & use Kwiboo’s 2023.10-rc2+gmac u-boot
Closed Tasks¶
- AR-1647 Enable missing modules in sunxi64
- AR-1718 Optimise images download build lists
- AR-1719 Add and test 4G PCI modem on Bananapi CM4
- AR-1722 Adjust Bananapi WiKi Pages
- AR-1725 Update CM4 download pages
- AR-1726 Add CM4 to auto-testing facility
- AR-1728 Check if appropriate build targets has been generating
- AR-1730 Make a hires photo of CM4 with modules placed on
- AR-1780 Adjust u-boot patches to apply correctly
- AR-1803 Enable wireless driver for MT7921U on all kernels
- AR-1806 Generate all images that are declared in targets.yaml for single device
- AR-1807 Test data visualisation JSON / PHP / HTML
- AR-1824 Move Debian riscv64 from ports as its not 1st class citizen
- AR-1826 Timezone select is too closed on status of the countries
- AR-1834 Add gnome-calculator back to the default package base
- AR-1836 Add SPI boot support for Rock5A
- AR-1837 Add Orange Pi Plus
- AR-1839 Introduce PASTE_URL to make easy to change paste service used
- AR-1840 Add pwm-fan support to Nanopi R4S
- AR-1844 NanoPi Duo2: enable powerbutton and ethernet
- AR-1845 Add bluetooth-hciattach extension to Orange Pi 5
- AR-1846 Add Collabora rockchip-rk3588 mainline based branch
- AR-1847 Add Radxa CM5 with I/O board
- AR-1848 Fix thermal monitoring in 6.1 kernel
- AR-1849 NanoPC-T6 Collabora: add PCIe 3
- AR-1851 Add Debian Trixie host and target support
Solved Bugs¶
- AR-1539 XFCE image Rpi is missing from web download
- AR-1570 Incomplete information in /etc/armbian-(image)-release
- AR-1684 Synaptic search is super slow
- AR-1707 Nightly images are not build with beta repository
- AR-1724 CM4: Onboard WiFi and Bluetooth does not work
- AR-1729 Userpatches support for series.conf seems broken
- AR-1764 Some Allwinner 32bit boards hangs at boot
- AR-1765 Recreate images that are missing in 23.05 release
- AR-1771 Rockpi4c+ link on download page broken
- AR-1772 RockPI-S serial console drops keystrokes
- AR-1787 Installing Khadas Vim3 image directly to eMMC fails
- AR-1798 Orangepi 3 / LTS and Nanopi Black 5 does not boot
- AR-1802 Possible bug in image assembly process
- AR-1814 Installing M2PRO to eMMC fails to boot from eMMC
- AR-1817 Enable wireless driver for MT7915E on all kernels
- AR-1835 mkfs.vfat command is missing in minimal images
v23.05.24 (2023-08-02)¶
- Recreated images for: Banana M2S, Odroid C2, Khadas VIM3
v23.05.2 (2023-06-06)¶
- AR-1765 Recreate images that are broken/missing in 23.05 release
v23.05.1 (2023-05-31)¶
Closed projects¶
- AR-1516 Clean base desktops
- AR-1536 Cleanup CLI packages list
- AR-1543 Update RK35xx legacy kernel to 5.10
- AR-1546 Merge all RK3588 under one kernel
- AR-1549 Unify architecture definitions
- AR-1557 Cleaning and adjusting CLI packages base
- AR-1567 Generating JSON matrix
- AR-1625 Extending JSON generation to support build matrix(es)
- AR-1639 Enable armbian-config ORAS cache
- AR-1693 Test as many images for upcoming 23.05 release as possible
- AR-1748 Generate a sticky topic with instructions how to upgrade to Bookworm
Closed Task¶
- AR-241 Remove NAND hacks from packaging
- AR-345 Label trigger/workflow issue to jira
- AR-773 Add support and bug report URL to /etc/os-release
- AR-1512 Switch Docker pull to armbian/cache repository
- AR-1526 UWE5622 driver consolidation for rockchip64
- AR-1542 Add architecture property for distributions
- AR-1573 Move UEFI kernels to 6.2, move current to legacy
- AR-1574 Move Rpi kernels to 6.2, move current to legacy
- AR-1575 Move Odroid M1 to 6.2.y
- AR-1577 Move mvebu edge kernels to 6.2, current to 6.1, current to legacy
- AR-1590 Add another package to minimal images
- AR-1591 Armbian buster xfce image build fails at installing package numix-icon-theme-circle
- AR-1593 Add & adjust (c) in files
- AR-1598 Minimal builds are missing apt-utils package
- AR-1601 Add sudo, wget and htop to minimal packages
- AR-1602 add `fonts-noto-color-emoji` for terminal Emoji support
- AR-1620 Effectively remove Ubuntu PRO ads
- AR-1627 Automatically clean docker images
- AR-1642 Could not create a username containing a number
- AR-1645 Installer should handle input in the same way everywhere
- AR-1651 Change Debian Bookworm into supported target
- AR-1655 Enable CONFIG_EXFAT_FS on remaining kernels
- AR-1656 Execute build train if kernel config changes
- AR-1660 Enable OrangePi Zero (LTS) TV output
- AR-1663 Add NanoPi R6S / R6C
- AR-1664 Rebuild board selection for generating official images
- AR-1669 Optimise PNG images we are using
- AR-1674 Bump rockchip 32 bit edge to kernel 6.3
- AR-1679 Drop kernel-jetson-nano-legacy
- AR-1680 Drop kernel-rockchip-legacy
- AR-1681 Drop kernel-rk3399-legacy
- AR-1682 Drop kernel-rockchip64-legacy
- AR-1683 Enable H616 CPU freq scaling
- AR-1695 Bump rockchip64 current to 6.1.y
- AR-1697 Add support for FriendlyElec NanoPi R4SE
- AR-1698 Add NILFS2 fs support
- AR-1699 Improve SD card compatibility on Radxa E25
- AR-1706 Disable SKEL update mechanism from postinst
- AR-1708 Improve i3-wm support
- AR-1713 Introduce armbian-base-files artefact
- AR-1717 Disable debug for postinst
- AR-1747 Orangepi-r1plus-lts Network Interface logical names have changed and broken networking
- AR-1760 Move Khadas Edge 2 to supported build targets
- AR-1586 Consolidate RTL8723CS driver for all families
Solved Bug¶
- AR-1443 NanoPi R4S patch overwriting mainline base DTS, needs refactored
- AR-1474 Emoji not shown
- AR-1523 UEFI install seems to be broken to some degree
- AR-1528 Nanopi Neo stuck in boot loop
- AR-1537 Missing man-db in images
- AR-1541 UEFI swap problem and missing UUID for EFI partition
- AR-1545 Update jethub prepackages python modules to install via apt
- AR-1547 Jetson Nano legacy fails do build kernel
- AR-1548 Odroid XU4 kernel compilation is failing current / edge
- AR-1556 “No space left on device” while rsync root files to image
- AR-1569 APT cache needs to be cleaned before closing image
- AR-1578 Missing blobs for Riscv
- AR-1588 Linter checking for bash shebang is incorrect
- AR-1589 Kernel analysis is checking too many files
- AR-1603 Broken wireless driver 8821cu-20210118
- AR-1611 Armbian install broken when installing to USB
- AR-1615 Bad links Orangepizero2
- AR-1621 Raspberry Pi does not build
- AR-1623 Armbian install fails to start on minimal images
- AR-1628 Orange Pi Zero 2 doesn’t work
- AR-1644 armbian-audio-config fails in minimal images; alsa-utils missing
- AR-1648 Debian SID also split non-free firmware packages
- AR-1650 Remote Desktop doesn’t work on desktop images
- AR-1653 Both Firefox and Chromium are not installing from our repo
- AR-1658 Wrong artefacts creation
- AR-1666 File with unexpected execution rights
- AR-1667 RockPI-S audio support is gone
- AR-1671 Packages are being downgraded to their repo versions
- AR-1673 uboot v2018.05-sun50iw9 compile error
- AR-1675 Nezha has wrong manufactur attached
- AR-1676 Can’t build linux-u-boot-radxa-e25-legacy and edge
- AR-1677 Fix building rk322x with vendor 4.4 kernel
- AR-1678 Can’t build Macchiatobin-doubleshot
- AR-1685 Rock 3A is missing current kernel def
- AR-1692 Raspberry Pi does not boot
- AR-1705 Jethome repository missing Lunar and Bookworm index
- AR-1714 Our packages md hash files contains temporally path
- AR-1715 Permission problem when building with GHA
- AR-1733 Base files does not work for riscv64 due to anomaly
- AR-1750 Missing information in BSP about repository and build FW commit
- AR-1751 Ubuntu Advantage is not completely removed
v23.02.1 (2023-02-25)¶
Closed projects¶
- AR-1281 Armbian community automated build
- AR-1360 Bump Rockchip64 u-boot to 2022.07
- AR-1408 Enable EDGE branch on RK3588
- AR-1424 Refactor release index generation
- AR-1432 Adjust 3rd party drivers for kernel 6.1
- AR-1435 Generate CODEOWNER on GitHub
- AR-1444 Move repo management from the build system
- AR-1449 Adjust action scripts to adjusted logic
- AR-1457 Create kernel config security analysis
- AR-1458 Enable AUFS on 6.1.y
- AR-1460 Address corner case when looking for default route
- AR-1461 Move hostapd from packages list
- AR-1470 Improve new issue / request handling
- AR-1484 Move meson64 CURRENT to 6.1.y
- AR-1531 Add support for various HID game controllers and Waydroid
- AR-1532 Split Bananapi M2PRO from M5
Closed Task¶
- AR-1313 Mvebu EDGE needs to be bumped to 6.1.y
- AR-1507 Move UWE5622 from kernel patches to misc
- AR-1379 Add support for minimal images build in CI
- AR-1412 Move btrfs-progs to the minimal images
- AR-1413 Port meson sm1 emmc related patches from edge to current
- AR-1414 Move Bananapi M5 to the previous u-boot version
- AR-1417 Add gnome-disk-utility to the desktops
- AR-1418 Replace nand-sata-install with symlink to armbian-install
- AR-1419 Limit automated swap creation to 16Gb
- AR-1421 Add nfs-common package too all except minimal
- AR-1429 Switch to better 882xbu wireless driver
- AR-1431 Improve audio config script
- AR-1433 Change error reporting when linting scripts
- AR-1434 Bump EDGE kernels to 6.1.y
- AR-1448 Update u-boot patches for JetHub D1/D1+
- AR-1495 Change old not supported releases to EOS
- AR-1509 Orange Pi R1 Plus LTS add 2 device tree overlays for rk3328 uart1 and i2C0. Network and LED’s enhancements.
- AR-1521 Add next Debian Bookworm
- AR-1533 Disable event debugging
- AR-1534 Add wpasupplicant to bookworm
Solved Bugs¶
- AR-1367 PCIe is stuck at Gen1 speed even tho overlay pcie-gen2 is specificed
- AR-1416 Missing font in Bullseye desktop cause strange fonts in Terminator
- AR-1437 Change to GitHub workflow badge routes
- AR-1438 rockPi-S patchset overwriting mainline device tree
- AR-1439 Rockchip64 NanoPi patches overwriting mainline DTS
- AR-1450 MOTD shows error on some devices
- AR-1463 Remove code was added to the sources, which creates a mess in rk3399-rock-pi-4.dts
- AR-1467 Raspberry Pi 3 is unbootable, 4 boots
- AR-1476 Missing firmware on Nanopi R2S
- AR-1482 Do not generate swap larger the 16Gb
- AR-1522 Fix SDIO port irq level bug found in 6.0+ kernel
- AR-1524 Cracklib check library must be present in all
- AR-1527 Update patches for RTL8822CS
v22.11.4 (2023-01-23)¶
- Added image for Bananapi R2 PRO
- kernel(s) update
v22.11.3 (2022-12-31)¶
- Added image for Orange Pi 5 (WIP)
- Updated images for Bananapi M5/M2P
- Updated images for Orangepi Zero 2
v22.11.2 (2022-12-09)¶
- Re-added image for Nanopi Duo
- Regenerated images Rock 5b (updated kernel)
v22.11.1 (2022-12-03)¶
Closed projects¶
- AR-1278 Implement plymouth for kernel > 5.19.y
- AR-1319 Upgrade Allwinner boot loader to 2022.08
- AR-1335 Add gpiod library to armhf and arm64 server + desktop images
- AR-1346 Grub optimisations
- AR-1355 Add support for UEFI install to the nand-sata-install
- AR-1362 Add Bananapi M5 to the build system
- AR-1389 Refactor u-boot patches
- AR-1390 Add Riscv64 support
- AR-1399 Enable BASH linter at PR on changed files
- AR-1402 Enable ES8316 audio properly on Radxa Rock Pi 4
Closed Task¶
- AR-668 Using extlinux.conf instead of the legacy set of boot.scr + text files.
- AR-949 Initial board setup
- AR-977 Add package version number to the rootfs cache
- AR-1034 Add missing Docker dependencies
- AR-1112 Add ZFS repository
- AR-1301 Add Rockpi 4C plus
- AR-1312 Clean bootlogo patches
- AR-1317 Remove nfs-kernel-server from default install
- AR-1325 Deploy Chromium repo and keys to CLI images too
- AR-1326 Add SKEL distribution to all existing users to the postinst script
- AR-1336 Fix wallpaper not showing correct in virtual desktop
- AR-1337 Re-enable Thunderbird email client for Debian Sid
- AR-1338 Add Codium to Debian builds
- AR-1342 Switch Codium with Code on x86
- AR-1343 Update UEFI configs with latest Ubuntu desktop 22.04
- AR-1349 Add Intel sound firmware to the desktops
- AR-1350 Deprecating Buster and Focal
- AR-1351 Adjust desktop support status
- AR-1352 Add initial configuration for Terminator
- AR-1353 Define panel shortcuts for Gnome x64 per appgroup
- AR-1373 Port legacy kernel Rockchip Hardware Random Number Generator forward into Edge
- AR-1376 Replace Ubuntu PRO advertisement
- AR-1377 Add plymouth package to base images except minimal
- AR-1388 Change purge releases action
- AR-1404 Updated box86 and box64
Solved Bugs¶
- AR-577 Fix USB port on Rockpi S
- AR-1060 Freshly build image doesn’t have BRANCH info in /etc/armbian-release
- AR-1186 Screen power savings does not work
- AR-1265 Rock PI-S images will not boot from internal EMMC (SDNAND)
- AR-1268 RockPI-S WiFi throughput only 300K bytes/second
- AR-1269 RockPI WiFi assigned different MAC address on each boot
- AR-1305 CI build wrong images in cron
- AR-1309 Some images doesn’t want to be built, some are corrupted
- AR-1310 Update JetHub D1 (j100) u-boot patchset
- AR-1318 Replace expired GPG key for Github CLI
- AR-1330 CLI images can ran out of space
- AR-1332 Missing dependency in Docker images
- AR-1334 Nanopi Neo3 does not have DT file in EDGE
- AR-1340 Disable event debugging on UEFI builds
- AR-1341 Missing wallpaper in XFCE login screen Armbian Sid
- AR-1344 Wrong location of package uninstall
- AR-1345 Thunderbird 32b is no more, refactoring - provide it only for 64b
- AR-1348 Pine64H b and NPI R1 does not build u-boot
- AR-1363 Kernel freezing in armbian-kernel might not work correctly
- AR-1374 Hostapd needs to be workarounded
- AR-1381 XU4: On a fresh install, after moving root to f2fs eMMC, it fails to boot
- AR-1384 Fix RTL8822CS driver. Update build config
- AR-1385 Ambian’s password rules are annoying
- AR-1391 MOTD is not displaying messages correctly
- AR-1392 Error triggered when changing BSP package
- AR-1393 Converting to u-boot fails on riscv
- AR-1394 Update kernel meson mmc driver to set phase clock from dts
- AR-1395 Don’t add PPA’s to the CLI images
- AR-1398 nand-sata-install must fail with a proper error message if the chosen mkfs.xyz is not installed
- AR-1400 Raspberry Pi is unbootable
- AR-1403 Wrong post install handling on install
- AR-1405 When using PPA sources we need to run install_ppa_prerequisites
v22.08.8 (2022-10-29)¶
- added test images for Odroid M1
- update rockchip64 kernels
- Regenerated images for Rockpro64, Rock64, Nanopi M4, Nanopi M4V2, Bananapi, Bananapi PRO, Bananapi M2Plus
v22.08.7 (2022-10-20)¶
- Regenerated images for Rockpi S, Bananapi M1, PRO, M2+, M5, M64, UEFI, RPi4, ClockworkPi, Nanopi Neo3, Pinebook PRO, Renegade, Tinkerboard, OrangePi Zero, OrangePi Zero 2, OrangePi Zero plus
v22.08.5 (2022-10-14)¶
- Regenerated images for arm64 and x86 UEFI with improved installer
v22.08 (2022-08-30)¶
Solved Bugs¶
- AR-1304 Boot splash is broken due to changes in kernel source
- AR-1299 Debian throws out locale garbage at 1st login
- AR-1296 JetHub D1 u-boot 2022.07+ bug
- AR-1295 Switch KDE plasma to Wayland
- AR-1294 Remove broken packages from Debian SID
- AR-1291 Several wireless drivers break down starting with 5.19.2
- AR-1287 Debian SID package deprecation
- AR-1285 Primary interface problem
- AR-1282 Upstream wireless driver is broken
- AR-1270 RockPi cannot host a desktop because it outputs no video
- AR-1266 Media EDGE and media CURRENT are not compiling
- AR-1263 Fix armbian-led-state-save.sh wrong behavior on boards without gpio leds.
- AR-1235 Fix NanoPi (rk3399) boards missing correct device tree files in rk3399-legacy
- AR-1224 AUFS breaks on 5.15.y
- AR-1206 Firefox from Mozilla team is n/a on Focal
- AR-1203 Rock3a only has one recommended target
- AR-1202 Tinkerboard has only one recommended image on the download page
- AR-1092 Docker is not working on some 5.15.y. / 5.16.y
- AR-1037 Missing some repository install options
- AR-1025 Samba timeouts and throws out error
- AR-982 Broken / invisible fonts on KDE plasma
- AR-932 HDMI rules could make troubles on some boards
Story¶
- AR-1303 Merging download target
- AR-1288 Move DUT ip addresses to the database
- AR-1284 Improve GitHub UX
- AR-1277 Refactor rootfs cache system
- AR-1248 Add support for month offset when creating cache
- AR-1239 Wrong board status report at first login
- AR-1238 Github Actions fine tuning
- AR-1236 Add images integrity checking script
- AR-1230 Refactor rootfs cache system
- AR-1229 Enable code security analysis
- AR-1220 Create nightly images directly on Github
- AR-1130 Improve Pull request review culture and participation
- AR-1081 Setup own mirror for kernel.org git
- AR-580 Generate CONTRIBUTION.md at build script repository
Closed Sub-task¶
Closed Task¶
- AR-1300 Add patches to support PiKVM
- AR-1292 Conduct forum upgrade to latest version
- AR-1279 Upgrade Rockchip (32 bit) edge kernel to v5.19
- AR-1272 Move CSC targets that doesn’t build to EOS
- AR-1251 When generating rootfs cache also store package versions
- AR-1249 Enable Debian Sid Gnome, Budgie and Cinnamon to some powerful boards
- AR-1237 Add a small tool to help with unifying kernel configs
- AR-1232 JetHome: add JetHub D1p support
- AR-1223 Desktops are missing calculator
- AR-1211 add rock-3a emmc support
- AR-1210 add spi boot support for rock-3a
- AR-1182 Orange Pi 4 LTS support
- AR-1132 Update meson64 edge¤t kernels
- AR-1127 Change build train runners to use our runners
- AR-1073 Remove /lib/build-all.sh
- AR-1042 Sum important information in CONTRIBUTION.md
- AR-1028 Add support for rootfs / toolchain bind mount
- AR-984 Integrate Khadas boards related fixes
v22.05.4 (2022-07-14)¶
- Added more desktop flavors for boards which are capable (Budgie, Gnome, KDE Plasma, Xfce and Cinnamon)
v22.05.3 (2022-06-23)¶
- All board images have been rebuilt due to corruption found in certain images
- Fixed Orange Pi 3 LTS bluetooth support
- AR-1182 - Added board images for Orange Pi 4 LTS
- AR-1228 - Upgraded bootloader to 22.04 for Rockchip family boards
v22.05 (2022-05-28)¶
Solved Bugs¶
- AR-1204 - Orangepi R1plus-lts - USB3 Ethernet not working
- AR-1202 - Tinkerboard has only one recommended image on the download page
- AR-1199 - Orangepizero2 legacy images doesn’t boot
- AR-1197 - Support status shows unsupported even distro variant is supported (random Focal image)
- AR-1196 - Mainline Kernel patch breaks spidev in 5.15+
- AR-1195 - Odroid N2 legacy kernel image does not build on Jammy
- AR-1194 - Legacy kernels doesn’t want to be added to repository
- AR-1193 - Images without device tree blobs fails to build via CI
- AR-1192 - Allwinner H5 boards fails on ATF compilation
- AR-1190 - Docker image creation fails on Jammy host
- AR-1189 - U-boot xt-q8l-v10 legacy fails to build at CI
- AR-1185 - Remmina is missing RDP and VNC options
- AR-1178 - Docker images creation is broken
- AR-1173 - Github action for generating desktops does not start
- AR-1172 - Load induced RX bug in the r8152 driver on 5.15 and 5.17
- AR-1171 - Budgie desktop fails to build on Jammy
- AR-1170 - Switching to beta repository at images sometimes failed
- AR-1169 - Chromium does not install on Jammy desktops
- AR-1167 - Update config to support Linux 5.15.36
- AR-1160 - When seeking changed kernels two are always marked as changed
- AR-1151 - Kernel 5.10.y need patch adjustment for boot splash
- AR-1149 - Current build failure due to packages
- AR-1148 - radxa zero 512MB (no eMMC) does not load img from SD
- AR-1141 - Ubuntu Budgie on Focal Jammy / Focal fails
- AR-1135 - fix armbian ramlog instability
- AR-1129 - Gnome desktop on Jammy fails to start
- AR-1115 - Package discrepancy in Jammy
- AR-1102 - Missing wallpapers in desktop packages
- AR-1097 - net: stmmac: dwmac-meson8b: interface sometimes does not come up at boot.
- AR-1091 - Wireless driver for 8822bs is not compatible with 5.15.y and up
- AR-1061 - udev HDMI rules are causing flickering
- AR-1033 - U-boot packages doesn’t want to be assembled with Docker
- AR-1015 - Toolchain download only from a single source
- AR-712 - Broken framebuffer on A20
- AR-583 - RK3328 DMC driver needs small (hopefully) update for kernel 5.10
- AR-191 - SATA doesn’t show up on Banana
Story¶
- AR-988 - Add support for running x86_64 applications
- AR-775 - Bring Marvell A3700-utils-marvell and mv-ddr-marvell.git to follow master
- AR-273 - Improve CI autotests facility
Closed tasks¶
- AR-1180 - Merge rk35xx-edge into rockchip64-edge
- AR-1177 - Update only supported repositories
- AR-1175 - Temperature monitoring for Jetson nano
- AR-1166 - Add box86 package from 3rd party repository
- AR-1165 - Update JetHub D1 u-boot patches
- AR-1164 - Upgrade mvebu64 kernel to 5.17.y
- AR-1159 - Upgrade UEFI EDGE kernels to 5.17.y
- AR-1150 - Adjust hash calculating method
- AR-1132 - Update meson64 edge¤t kernels
- AR-1128 - Add Nvidia driver to the x86 desktop images
- AR-1126 - Enable desktop compilation at merge request
- AR-1120 - Sync beta repository in the CI process
- AR-1108 - Missing images in download section for following boards
- AR-1076 - Add support for Orangepi 3 LTS
- AR-1057 - Advertise recommended targets at download pages
- AR-1008 - Update vars in amlogic u-boot script to match names of default u-boot vars
- AR-959 - Unifying TAGS as much as possible - as universal as possible
- AR-628 - Bump Meson64 u-boot
- AR-296 - Remove compressed indexes for apt?
v22.02 (2022-02-28)¶
Solved Bugs¶
- AR-1101 - DRM patch is failing on Rockchip
- AR-1079 - Ubuntu archive redirector is not providing best service
- AR-1077 - Fix RPi4 userland audio
- AR-1069 - First login doesn’t pick up correct shell
- AR-1065 - Twitter forum registration is not working
- AR-1063 - X86 desktop images are not enabled in CI
- AR-1062 - When selecting repository install u-boot might not be flashed
- AR-1055 - Aptly repository seems to be out of business
- AR-1048 - Rpi kernel image is not updated on upgrade
- AR-1043 - linux-firmware repository change branch from “master” to “main”
- AR-973 - boot building is failing after update to 2021.10
- AR-871 - Debian SID broken wallpaper
Story¶
- AR-1074 - Switch all CURRENT to 5.15.y and EDGE to 5.16.y
- AR-1009 - Armbian Framework extensions and UEFI support
Closed tasks¶
- AR-1100 - Support for Orange Pi R1 Plus LTS
- AR-1084 - 3D support on Debian desktop
- AR-1078 - Add additional forum plugins and adjust settings
- AR-1068 - Add gnome-system-monitor to Focal and Jammy
- AR-1049 - Add ZFS that supports kernel 5.15.y
- AR-1044 - Improve Raspberry Pi support
- AR-1041 - JetHome: fix brcm (AP6255) firmware links
- AR-1040 - Refactor armbian-bsp-cli package creation
- AR-931 - Using Docker image for building kernels
- AR-893 - Cleanup rockchip64 u-boot scenarios
- AR-757 - Adding Raspberry Pi
- AR-586 - Implement fan controller for Nanopi M4V2
v21.08 (2021-08-31)¶
Solved Bugs¶
- AR-886 - u-boot package naming
- AR-885 - Odroid C4 / HC4 boot failure
- AR-881 - First login shows “degraded”
- AR-879 - RK3328 5.10 + GPU failure
- AR-875 - Homepage fix
- AR-874 - Add SATA fix for eBin
- AR-873 - khadas vim3 no sound
- AR-872 - When reverting u-boot to last known, some boards are broken
- AR-867 - H6 Freezing
- AR-863 - Unstable u-boot also noticed on H3 based boards
- AR-862 - normalize RK3399 xorg configs
- AR-857 - Qemu custom hook executing on non-targeted images
- AR-854 - Pinebook PRO desktop doesn’t build in CI
- AR-853 - Missing folder when making BSP file
- AR-852 - Error when placing wallpaper
- AR-850 - Disable XFWM compositor on XFCE4 desktop to make it run smoother
- AR-844 - CI is picking up wrong kernel
- AR-835 - Amlogic GLX desktop fails
- AR-834 - edge v network weirdness
- AR-833 - Khadas Edge V no HDMI audio
- AR-830 - CI needs to rsync cache before start to building new images.
- AR-829 - CI pipeline could not find some files when signing rootfs cache
- AR-825 - Fixing I2S related errors on RK3399
- AR-824 - Broken wifi on Station boards and kernel 5.12.y
- AR-823 - Pine H64 doesn’t boot kernel 5.12.y
- AR-822 - Motd false reporting of unsupported
- AR-821 - Docker creation failed to load repository keys
- AR-820 - Broken Odroid C2 audio patch
- AR-819 - Wireguard repo errors
- AR-818 - When building selected images via CI, status is changed to user-built
- AR-816 - ZRAM is missing in Jeston Nano legacy
- AR-780 - Nanopi R4S USB broken
- AR-779 - New bsp package is common. Per branch changes doesn’t work anymore
- AR-777 - Docker doesn’t install on Hirsute host
- AR-776 - Tinkerboard legacy have some troubles booting
- AR-774 - Orangepi Lite 2 EDGE is failing
- AR-770 - U-boot fails to install when switching kernel to EDGE
- AR-764 - Htop configuration exploit / vulnerability
- AR-749 - Allwinner A20 bootloops on 5.12.y / 2021.04
- AR-748 - Headers install broken
- AR-747 - Deeping Desktop doesn’t want to reboot / poweroff
- AR-744 - Nanopi K2 S905 network is broken
- AR-741 - Pinebook pro desktop missing tweaks
- AR-740 - Vnstat throws out garbage
- AR-737 - Jetson nano throws out some error on boot loader compilation
- AR-736 - Rockpi S u-boot doesn’t build on GCC.-10
- AR-713 - Board specific desktop things are going into common desktop package
- AR-593 - Rockpi S doesn’t boot mainline based kernel
Epic¶
- AR-788 - Add Official Support for Some Khadas devices
Story¶
- AR-877 - build_all needs separate logs per image
- AR-847 - Tinkerboard 2 Support
- AR-746 - Upgrade EDGE to 5.12.y
- AR-734 - CSC Support for Avnet MicroZed
- AR-214 - CI improvements
- AR-202 - Drop packaging patches and introduce own packaging
- AR-42 - Merge packaging patches
Closed tasks¶
- AR-892 - Promoting Bullseye to supported
- AR-890 - Desktop analysis with 3D enabled
- AR-887 - Re-enable Debian Stretch repository update
- AR-882 - Optimise image compression
- AR-876 - Make package lists in one row
- AR-869 - Upgrade ZFS on Linux to v2.1.0 (Focal / Bionic only)
- AR-865 - Updating driver for 2.5G NIC on Helios64
- AR-864 - Upgrading EDGE to K5.13.y
- AR-859 - set - apt.armbian.com - redirect default to http instead of https
- AR-856 - Basic RC Branch build support
- AR-846 - Add Ubuntu 21.10 Impish
- AR-794 - Khadas Edge-V support
- AR-793 - Khadas VIM3L support
- AR-792 - Preliminary Khadas VIM3 support
- AR-791 - Khadas VIM2 support
- AR-790 - Preliminary Khadas VIM1 support
- AR-785 - Move mainline boot console to UART0 on Rockpi S
- AR-784 - Add Nvidia Jetson Nano legacy kernel
- AR-782 - Provides NFS mount functionality out of the box on CLI images
- AR-778 - Do not pre-install obsolete apt-transport-https
- AR-768 - Move Odroid XU4 EDGE to mainline source
- AR-745 - chroot packaging: build script as separate function
- AR-743 - Delay first-run autologin
- AR-732 - Unlock Ubuntu Hirsute as supported target
- AR-714 - Adjusting support status
- AR-665 - rk3399 patch failure
- AR-649 - Adding Rockchip VPU support for 5.11.y
- AR-635 - Add legacy kernel for Zero2
- AR-537 - Create Armbian “virtual” build target to run as VM
- AR-519 - Odroid N2 Mainline u-boot for edge kernel
- AR-315 - Add support for GPT table inside armbian-install
v21.05.6 (2021-06-21)¶
Solved Bugs
- AR-593 - Rockpi S doesn’t boot mainline kernel
v21.05.3 (2021-05-24)¶
Solved Bugs
v21.05.2 (2021-05-24)¶
Solved Bugs
- AR-764 - Fixing Htop security issue
Closed Tasks
ZFS updated to v2.0.4 (tested on 32bit Odroid HC1 and 64bit N2, Focal and Bionic userland) Added Hirsute CLI images with EDGE Linux 5.12.y for most of the boards
v21.05 (2021-05-09)¶
Solved Bugs
- AR-730 - Duplicate packages error when updating repository
- AR-729 - Fix Partition Alignment for resizes and armbian-install
- AR-711 - Network troubles on Nanopi K2 / Odroids
- AR-709 - Tinkerboard AP crash on client connect
- AR-708 - Missing library for compiling u-boot
- AR-707 - Wrong keyboard code detected
- AR-705 - Compilation issues when building old u-boot
- AR-698 - XU4 - current kernel oddness with docker
- AR-697 - Fix Meson64 Default Governor
- AR-688 - Firefly boot broken
- AR-674 - Users can’t change desktop wallpaper on Gnome
- AR-666 - ZSH is disabled on upgrade
- AR-662 - Distribution support status is not written to the /etc/armbian-release
- AR-659 - Rootfs image runs out of inodes during build
- AR-653 - builder issue with gnome
- AR-647 - Wireless driver 8811CU is broken on 5.11.y
- AR-646 - Bootsplash breaks compilation on 5.11.y
- AR-644 - Wireless driver 8188 EU broken and disabled since 5.9.y
- AR-636 - Odroid N2+ lost additional freq values
- AR-585 - HDMI-CEC not working on rockchip64 Legacy
- AR-88 - Banana Pi M3 does not boot
Finished projects
- AR-694 - Create Jira-based checklist for Desktop Testing
- AR-457 - Enable native arm/arm64 building
- AR-454 - Additional Desktop Configurations for use with new framework
- AR-444 - Improving download infrastructure Phase 2
- AR-200 - Improving Desktop images
Closed Tasks
- AR-710 - Create imx edge branch
- AR-706 - Bump Allwinner u-boot to 2021.04
- AR-704 - Distinguish between edge and normal image in motd
- AR-696 - Improve Nvidia Jetson Nano support
- AR-673 - Add few missing packages
- AR-670 - Add additonal mirros for linux-firmware beside kernel source
- AR-667 - Move Meson64 DEV to 5.10.y
- AR-657 - Add instructions how to manual flash boot loader
- AR-656 - Implement timeout on cache download
- AR-654 - Fix stability issues of NanoPi M4V2 in current and dev
- AR-651 - NanoPC-T4 legacy: enable USB-C DisplayPort & eDP outs
- AR-648 - Resolve GPIO & PWM patches on mvebu
- AR-645 - Detach rtl8812au from fixed commit ID if it builds from master
- AR-643 - Bump DEV kernels to 5.11.y
- AR-634 - Add Orangepi R1 Plus
- AR-633 - Enable hardware PRNG/TRNG/SHA on sun8i-ce platform
- AR-613 - test/beta img auto builder
- AR-612 - Update pine64 install instructions
- AR-600 - RK3399’s: Add multimedia and OC overlays
- AR-599 - Enable HDMI-CEC and ISP1 camera support for rk3399 and rockchip64 legacy
- AR-369 - Check kernel config changes
v21.02.4 (2021-04-04)¶
Added Nvidia Jetson Nano (community supported target)
Rebuild images for Odroid N2, H4, HC4
v21.02.3 (2021-03-09)¶
All kernels received upstream updates
All images has been rebuilt
Fixed reboot troubles on meson64 family (Odroid N2, C2, H4, HC4)
ZSH upgrade fixed
Type-C DP support for the NanoPC T4
- AR-654 - NanoPi M4V2 stability fix for current and dev
Allwinner a20 fail to init hdmi in many cases / fixed (all images need to be rebuilt)
- AR-660 - Attempt to improve stability on Helios64
v21.02.2 (2021-02-16)¶
v21.02.1 (2021-02-03)¶
Finished projects
- AR-235 - Implement Device Tree Editor
- AR-476 - Add sound to Odroid N2
- AR-485 - Improve multicore compilation
- AR-487 - Rework download pages
- AR-508 - Add Odroid HC4
- AR-546 - Added Pine64 Pinecube
- AR-566 - Add Nanopi R4S
- AR-568 - Add Orangepizero 2 WIP target
- AR-571 - Move Meson64 DEV to 5.10.y
- AR-589 - Add ZShell via armbian-zsh package
- AR-590 - ZRAM Enhancements - decouple swap config from tmp
Solved bugs
- AR-365 - 4k not detected properly on Amlogic, Rockchip devices
- AR-440 - Errors shown at 1st login under certain conditions
- AR-512 - Fix Ethernet for Opi3 and other devices with phymode for kernel 5.10
- AR-514 - Download and verify not fully reliable
- AR-547 - First login: adding a non-existing keyboard variant
- AR-548 - mvebu DFS seems to cause system hang under high I/O
- AR-557 - GCC compatibility issues
- AR-559 - First login script - not all locales have UTF8 encoding
- AR-565 - SATA on HC4 is not recognized
- AR-570 - Improper order in getty override.conf
- AR-584 - Nanopi M4V2 hangs on bluetooth loading
- AR-595 - Rockpi 4B 1GB not booting
- AR-605 - Booting troubles on Odroid C4 / HC4
- AR-606 - Force boot script update throws out some error
- AR-608 - Broken building out-of-tree modules
- AR-610 - Nanopi Neo2 black sometimes nic doesn't init
- AR-615 - Helios64 unstable 2.5Gbps Interface on LK5.x
- AR-616 - Ubuntu Bionic ZSH / BASH changing issue
- AR-617 - Locales detection doesn't work properly in some cases
- AR-627 - Ubuntu update is overwriting our welcome screen
- AR-629 - Odroid HC4 SATA failure
- AR-631 - Orangepi Zero2 broken network
- AR-632 - Desktop fails to load at second run
Closed task
- AR-163 - Systematically cleanup distribution defaults
- AR-206 - Improve memory performance on Renegade (roc-rk3328-cc) in current
- AR-399 - Improve Pinebook PRO support
- AR-467 - Enable AUFS support back
- AR-472 - Added support for Ubuntu 20.10 Groovy
- AR-517 - Mark Bionic builds host as deprecated
- AR-520 - Move Rock64 to CSC in build script
- AR-525 - Bump Rockchip 32bit to 5.9.y
- AR-526 - Move mvebu-dev kernel to 5.9+
- AR-551 - Update fan configuration, enable network LED and enable UPS timer
- AR-552 - Re-enable UHS SDR104 mode for Helios64 and roc-rk3399-pc
- AR-553 - Update builder to retrieve web seeds from mirrors api
- AR-554 - OdroidN2 Ethernet Failure Pt2
- AR-556 - Adding vnstat and ZFS support to MOTD
- AR-558 - Switch mvebu current to K5.9
- AR-563 - Improve headers compilation
- AR-576 - Enabled debug on RockpiS
- AR-579 - Improve (oh-my)ZSH loading speed
- AR-587 - Fix kernel switching for rk3399 family
- AR-594 - Upgrade Meson64 u-boot to 2020.10
- AR-598 - Switch rockchip64 u-boot to 2020.10
- AR-601 - Move sunxi-current to 5.10.y
- AR-603 - Enable SPI boot option for roc-rk3399-pc
- AR-607 - Move Meson64 Current to 5.10.y
- AR-609 - Move Mvebu Current to 5.10.y
- AR-611 - Switch rockchip64-current to 5.10.y
- AR-614 - Upgrade ZFS packages
- AR-618 - Upgrade mvebu64 current to 5.10.y
- AR-619 - Bump rockchip current to 5.10.y
- AR-620 - Enable network link leds for NanoPi R4S by default
- AR-622 - Enable DMC for Station-M1 in current and dev
- AR-623 - Enable RTC (hym8563) for Station P1 in dev and current
- AR-624 - Provide an option to skip autodetection at first login
- AR-628 - Bump Meson64 u-boot to 2021.01
- AR-630 - Bump Odroid XU4 DEV to 5.10.y
v20.11.10 (2021-01-25)¶
All images rebuild due to torrent system corruption
v20.11.9 (2021-01-23)¶
Broken Nanopi Neo buster image rebuild, adding Station M1 and P1 legacy images, Odroid XU4 update
v20.11.8 (2021-01-17)¶
- AR-614 - Upgrade ZFS on Focal and Buster (64bit only) to v2.0.1
v20.11.7 (2021-01-06)¶
all images were rebuilt - we had a few corrupted ones in previous build
v20.11.6 (2021-01-03)¶
- AR-235 - Implement Device Tree Editor in armbian-config
- AR-589 - Add armbian-zsh package
- AR-554 - Fix Odroid N2 Ethernet Failure
- AR-565 - Fix SATA on HC4 is not recognized
- AR-595 - Fix Rockpi 4B 1GB not booting
v20.11.5 (2020-12-31)¶
AR-566 - Add Nanopi R4S preview images
v20.11.4 (2020-12-15)¶
- Re-adding accidentally removed network driver on Helios64 added OpenHab 3 to the armbian-config software installer
v20.11.3 (2020-12-12)¶
Bugfix release
v20.11.1 (2020-12-04)¶
- AR-565 - SATA on HC4 is not recognized Updated Odroid C4/HC4, Helios64, Rockpi 4* images and rockchip64 kernels
v20.11 (2020-11-24)¶
Finished projects
- AR-2 - Improving download infrastructure Phase 1
- AR-151 - Integrate JMCCs Multimedia script
- AR-230 - Decide what to do with TVboxes
- AR-412 - Update Odroid XU4 kernels
- AR-424 - Improve HTOP config
- AR-456 - Upgrading Allwinner u-boot to 2020.10
- AR-509 - Upgrade meson64 to 5.9.y
- AR-510 - Move meson (Odroid C1) to 5.9.y
- AR-532 - Move Odroid C4 from legacy u-boot toward mainline
Solved bugs
- AR-314 - Links to SHA files at download pages are wrong
- AR-372 - Meson64 Reboot failure kernel 5.7
- AR-373 - Rock64 no HDMI (must be unplugged)
- AR-382 - Fix zram creation on bigger memory devices
- AR-391 - Warning a reboot is needed doesn’t go away after reboot
- AR-407 - Bug in first login script
- AR-417 - HTOP in Bullseye needs higher package version
- AR-420 - GPIO SPI patch is failing on Rockchip64
- AR-422 - Improper version showing at upgrade
- AR-425 - Resize is finished but message doesn’t disappear
- AR-428 - Firefox initial config has different location then ESR variant
- AR-436 - Rockpi S reports some error in postinst scripts
- AR-437 - MOTD cosmetic issue
- AR-439 - Automated rebuilds set image status to USER_BUILT
- AR-441 - Odroid C4 legacy bootscript problem
- AR-452 - Fix first boot locales selection and add desktop lang switching
- AR-459 - Missing package libreoffice-style-tango from Bullseye desktop
- AR-471 - Mitigate Git server failures
- AR-482 - Htop doesn’t show CPU speed to normal user but shows properly to root
- AR-484 - Odroid C4 refuse to boot
- AR-491 - LEDs on Helios4 not working
- AR-493 - Patches are not creating
- AR-494 - Fix armbian-hardware-opitimization not being run
- AR-505 - armbian-hardware-optimization: eth0 tweak applied before it is appear on /proc/interrupts
- AR-527 - Rockchip 32bit sources were removed
- AR-528 - Improve creating images from repository
- AR-529 - Z28 PRO device tree doesn’t exists in mainline
Closed tasks
- AR-284 - Discuss if there is a cleaner way to install Chromium
- AR-350 - Switch rock64 to mainline u-boot
- AR-351 - Switch rockpro64 to mainline u-boot
- AR-363 - Switch mvebu current to K5.8.y
- AR-380 - Revisit RTL8812AU driver
- AR-387 - Switch from rk3399-bluetooth service to btbcm for loading firmware/patchram in dev/current
- AR-388 - XU4 - Introduce new Mem freq scaling patch and re-enable
- AR-390 - Add Radxa Rockpi 4C
- AR-400 - Enable overlays in rockchip64-legacy
- AR-401 - Enable creation of SPI flash u-boot image for ROCK Pi 4
- AR-403 - Enable overlays in rk3399-legacy
- AR-404 - Switch renegade to mainline u-boot
- AR-409 - Move imx6 current kernels to 5.8.y
- AR-413 - Improve reliability of Helios64’s eMMC module
- AR-415 - Improve reboot reliability for Helios64
- AR-416 - Move Rockchip 32bit to 5.8.y
- AR-419 - Add dedicated DT for Nanopi Neo3
- AR-445 - systemd-journal not rotated with armbian-ramlog
- AR-458 - Update board support statuses
- AR-461 - Add Armbian to Neofetch
- AR-462 - Adapt helios64 device tree name to match upstream Linux
- AR-464 - Move Libre Computer Renegade to mainline u-boot
- AR-473 - Add interactive option to use precompiled packages from Armbian repository
- AR-477 - Advanced recovery options for rockchip64 boards
- AR-483 - Fix analog (3.5 jack) audio on ROCK Pi 4C
- AR-490 - Enable RTC on Odroid N2
- AR-495 - Allow building images with kernels 5.8.17+ and 5.9.2+
- AR-499 - Enable Watchdog for G12/Odroidn2
- AR-504 - Helios64: Switch fusb302 driver to mainline and enable DP over TypeC
- AR-511 - Switch rockchip64-current to linux 5.9.y
- AR-513 - Move Odroid XU4 kernels up
- AR-515 - Upgrade imx6 to 5.9.y
- AR-521 - Exchange mv with rsync
- AR-522 - Allow setting MTU for Rockchip64’s dwmac interface
- AR-523 - enable CONFIG_TARGET_CORE for iSCSI target support
- AR-524 - Upgrade rockpis legacy kernel
- AR-531 - Check why disabling one update-initramfs breaks Ubuntu initrd making on update
v20.08.22 (2020-11-8)¶
Added WIP images for Odroid HC4 Updated images for Odroid C4, N2, C2, Lafrite, Lepotato, KVIM1
v20.08.13 (2020-10-19)¶
- AR-466 - Enable Recovery button on Helios64
- AR-476 - Add sound to Odroid N2 update all kernels Rebuild images for Helios4, Helios64 and Odroid N2
v20.08.11 (2020-10-16)¶
- AR-465 - Helios64 cannot boot from eMMC enable Ubuntu 20.10 Groovy as a CSC build option (need build parameter EXPERT=”yes”) update u-boot loader to 2020.10 on Allwinner platform update all kernels update images for Helios 64 add option to build images from prebuild packages from repository which drastically improves build time in case you don’t need to rebuild kernel
v20.08.8 (2020-10-05)¶
- AR-463 - Improve Helios64 Stability, updated images Adapt Helios64 devicetree name to match upstream Linux
v20.08.4 (2020-09-23)¶
- AR-399 - Improve Pinebook PRO support, updated images Updated Helios64 images
v20.08.3 (2020-09-21)¶
- updated mainline kernel based images to Linux 5.8.10
- all other kernels updated to respective latest version
- improved htop with showing network status dynamically, GPU temp, improved CPU speed display
- fixed usbip for sharing usb over network
- fixed Odroid C4 boot script bug; adding normal and higher CPU speeds
- added many improvements for Helios64
- enabled GPU temperatures in htop for XU4, meson64 (Odroid N2/N2+) and rockchip64/32
- fixed initial configuration for Firefox
- fixed tx offloading for Rockchip64 NIC’s
- move rockchip 32bit to 5.8.y (Tinkerboard / MiQi)
- improved RK3399 stability by mingling OPP
- fixed a bunch of bugs related to encrypted root filesystem
- enabled hardware watchdog support for mvebu64 / Espressobin
- cosmetic fixes to motd
- enabling I2S and spdif on Nanopi Neo3 by default
- fixes wrong memory calculation on ZRAM display
- fixing firstlogin bug preventing running xrdp
- move Espressobin kernel to 5.8.y
- adjust / fix Kali Linux wifi injections patches
Known bugs:
- Some Rockpro64 boards have troubles with upgrade
- Bananapi M3 eMMC can’t boot from eMMC (solution is available)
- H6 stability issues on some boards
- RockpiS shows some error on upgrade but upgrade suceeds
- 4K and audio on mainline based meson64 boards
v20.08 (2020-08-20)¶
Finished projects
- AR-45 - Make first login more user friendly
- AR-71 - Create a document: How we will use Jira
- AR-182 - Unify / merge kernel configs
- AR-201 - Introduce CI autotest facility
- AR-227 - Move Espressobin current to K5.6
- AR-313 - Ability to work in offline mode
- AR-320 - Initial support for Rockpi E
- AR-324 - Add Rockchip RK322X SoC support
- AR-328 - Meson64 move current to 5.7.y
- AR-329 - Switch sunxi dev target to kernel 5.7
- AR-331 - Enable kernel boot splash as an option
- AR-335 - Improve patch making
- AR-392 - Add Odroid N2+
- AR-402 - Add Helios64
Solved bugs
- AR-282 - Rockpi 4B 1Gb doesn’t boot modern kernel / u-boot
- AR-295 - Odroid C2: no more USB devices after upgrade
- AR-298 - Missing default SElinux policy
- AR-303 - Create a download page for BPI M2 zero
- AR-305 - K-worker creates load on Allwinner devices
- AR-319 - Armbian config failed to switch kernels
- AR-330 - Shell check bugs
- AR-332 - When making all kernels - building sometimes fails
- AR-337 - Odroid XU4 Memcopy Slow on all Kernel 5.x 80MB/sec instead of 370+MB/sec
- AR-338 - Bananapi R2 does not boot at all
- AR-340 - Fix WiFi on Nanopi M4V2
- AR-348 - Confirm RK3399 TcpOffloading bug
- AR-352 - Fix Random MAC on H3 boards
- AR-354 - Support User Provided EDID Firmware
- AR-355 - backport Linux v5.8 fbtft/fb_st7789v invert colors, proper gamma
- AR-356 - Building multiple u-boot targets breaks
- AR-371 - CPU frequency scaling broken on H6
- AR-378 - Increase address room for initial ramdisk
- AR-381 - selinux-policy-default missing on Debian Bullseye
- AR-393 - Ask for setting locale at first run
Closed tasks
- AR-28 - Added new GCC compilers
- AR-225 - Introduce PACKAGE_LIST for BOARD and FAMILY
- AR-300 - Enable HDMI audio for OrangePi 4
- AR-317 - Move Odroid XU4 dev to mainline + patches
- AR-318 - Upgrade Odroid XU4 legacy kernel
- AR-321 - Upgrade Meson (C1) current to 5.7.y
- AR-323 - Allow install to SD NAND for Rockpi S
- AR-326 - Make USB3 support of ROCK Pi E on par with other rk3328 boards
- AR-327 - Bump imx6 current kernel to 5.7.y
- AR-333 - Update Odroid XU4 kernels
- AR-334 - Cleanup boot environment files
- AR-336 - Add support for cheap 2.5GB USB network dongles
- AR-341 - Follow-up N2 CPU Affinity
- AR-349 - Update mainline u-boot to v2020.07 for rockchip64 and rk3399
- AR-357 - IRQ affinity improvements for G12B
- AR-358 - Added initial support for Neo 3
- AR-361 - Update Odroid XU4 boot.ini
- AR-362 - HDMI sound support for Allwinner A10, A20, A31
- AR-364 - Change sunxi legacy to 5.4.y, current to 5.7.y
- AR-366 - Move rockchip/64 current to 5.7.y
- AR-383 - Upgrades for Tapatalk plugin
- AR-389 - Add PACKAGE_LIST_BOARD_REMOVE option
v20.05.7 (2020-07-02)¶
- AR-308 - Disable HDMI in u-boot for rk3399 boards
- AR-337 - Odroid XU4 Memcopy Slow on all Kernel 5.x 80MB/sec instead of 370+MB/sec Update images for: NanoPC T4, Nanopi M4,Nanopi M4v2, Nanopi Neo4, Orangepi 4, Firefly RK3399, Bananapi R2, Odroid XU4
v20.05.6 (2020-06-19)¶
v20.05.5¶
never released/skipped
v20.05.4 (2020-06-16)¶
- AR-311 - Initrd on Focal can get corrupted followup fix
v20.05.3 (2020-06-10)¶
- AR-282 - Rockpi 4B 1Gb doesn't boot modern kernel / u-boot
v20.05.2 (2020-06-05)¶
- AR-294 - Initrd on Focal can get corrupted
v20.05.1 (2020-05-31)¶
Kagu
Finished projects
- AR-108 - Upgrade remaining kernels to 5.4.y
- AR-158 - Update 3rd party wireless drivers
- AR-159 - Switch fake-hwclock to hardware RTC on mvebu family
- AR-168 - Add NanoPi R2S board support
- AR-180 - Update Wireguard drivers on kernels below 5.4.y
- AR-184 - Improve slow booting on Rockchip RK3399 devices
- AR-185 - Change download images compression format
- AR-190 - Update wireless driver for RTL88x2BU
- AR-196 - Upgrade u-boot to 2020.04 where possible
- AR-207 - Merge rockpis-dev into rockchip64
- AR-208 - Consolidate u-boot variants for mvebu family
- AR-210 - Add support for more HDMI resolutions on Rockchip RK3288 devices
- AR-215 - Move meson64 dev branch to 5.6.y
- AR-221 - Upgrade imx6 current to 5.6.y
- AR-222 - Port Docker image building to Ubuntu 20.04
- AR-226 - Add Hardkernel Odroid C4 mainline u-boot / kernel
- AR-236 - Attach Meson64 CURRENT to 5.6.y
- AR-238 - Updating hostapd, PSD and theme package in repository
- AR-247 - Revitalise Udoo board
- AR-250 - Improve usage of external patches
- AR-253 - Add prerm script for headers
- AR-254 - Add Banana Pi M2 Zero
- AR-257 - Bring Odroid C1 back from the EOL with latest upstream kernel
- AR-260 - Add Nanopi A64 board support
- AR-261 - Add Rockpi S mainline board support
- AR-262 - Move Allwinner development branch to 5.6.y
- AR-278 - Add snap free Chromium to Ubuntu Focal
- AR-279 - Add Hardkernel Odroid C4 stock kernel
Solved bugs
- AR-109 - Upgrade is not done properly on some boards
- AR-165 - Instability with Rock64 and Rock PRO
- AR-177 - No serial gadget console on Nanopi Neo2 black
- AR-181 - Odroid N2 crashes during USB rsync backups
- AR-198 - Olimex Lime 2 doesn’t boot from eMMC
- AR-204 - CPUfreq defaults missing on update
- AR-205 - No sound output with OrangePi 4 in dev and current
- AR-211 - Chrony fails to start on Ubuntu Focal
- AR-212 - Random MAC on Nanopi R2S
- AR-220 - Disable 3D support in Bionic due to broken mesa packages
- AR-231 - Unstable stmmac network driver on Meson64
- AR-237 - Desktop install on Ubuntu Focal installs Gnome3 desktop
- AR-239 - Chrony fails to start on Focal
- AR-240 - Broken VFAT kernel upgrade
- AR-244 - Thermal throttling on H5 doesn’t work properly
- AR-245 - Hostapd doesn’t go up
- AR-248 - Odroid C4 CPU speed is limited to 1.5Ghz
- AR-249 - Problems with CI testings
- AR-251 - Fix kernel 5.7.y packages patch
- AR-255 - Fix Debian mirrors URL
- AR-263 - Fix audio on Renegade
- AR-269 - Add correct CPU regulator configuration for the NanoPI R1
- AR-274 - Add missing iozone3 package to the minimal image
- AR-277 - Distinguish nightly and stable images at the download pages
- AR-286 - Armbian-resize-filesystem fails on first run due to missing fdisk in Bullseye
- AR-287 - Make sure cryptsetup-initramfs is installed in any case
Closed tasks
- AR-150 - Disable Stretch image creation for Helios4 and Clearfog
- AR-157 - Add Ubuntu Focal 20.04 as a supported build host
- AR-186 - Blacklist 3D engine on headless images
- AR-189 - Move wireless driver for 8189ES from patch to git
- AR-195 - Adding Ubuntu 20.04 to all builds
- AR-209 - Disable CONFIG_VIDEO_DE2 in u-boot for Allwinner devices
- AR-213 - Make manual for .xz images and check their authentication
- AR-228 - Enable audio and USB on Nanopi A64
- AR-229 - Bump with AUFS for DEV kernels
- AR-232 - Switch Odroid XU4 DEV branch to Libreelec branch
- AR-234 - Disable ZSH update prompt on every two weeks
- AR-242 - Enable SELinux
- AR-252 - Improve source code cleaning
- AR-258 - Enables PCIE PHY with Mezzanine NVME
- AR-259 - Add mp8859 regulator to current for RK3399-ROC-PC
- AR-264 - Enable RTL8723DS WiFI driver
- AR-265 - Remove Xenial from supported host OS
- AR-266 - Fix dependency for native building on Linux Mint and Debian Buster
- AR-267 - Enable Cedrus video acceleration on Allwinner kernels
- AR-268 - Add higher clock for Allwinner H6
- AR-270 - Add support for alternate console UARTs in Allwinner H3 u-boot
- AR-271 - Lower DDR clock rate to 504MHz for H5 boards
- AR-280 - Update CONF, CSC and WIP statuses according to support level
- AR-285 - Improve thermal throttling on Allwinner H6
- AR-288 - Add vendor name to the board config files
v20.02.12 (2020-04-27)¶
- Added preview images for Odroid C4
v20.02.8 (2020-03-26)¶
- update kernels with upstream versions, synchronise and test kernel sources download
v20.02.7 (2020-03-26)¶
- Updated images for Rockpi S, Odroid XU4 and FriendlyARM Nanopc T3, T3+, M3, Fire3
v20.02.6 (2020-03-23)¶
- Updated images for Rockpi S and Orangepi 4
- Updated armbian-config (fixed OMV installer)
v20.02.5 (2020-03-19)¶
- Updated images for Orangepi 4, Bananapi and Rockpi S
v20.02.4 (2020-03-18)¶
- Added images for Nanopi R2S and Bananapi M2 Zero
- Kernel update for Odroud XU4
v20.02.3 (2020-02-21)¶
- Updating images for Le potato, Khadas Vim1,La Frite, Nanopik2 S905, Odroid N2/C2 - fixing audio
- Updating images for Orangepi 4 - boot loader problem
v20.02.2 (2020-02-18)¶
Chiru
Tasks
- AR-46 - Support for single function run
- AR-47 - Adding Docker shell support
- AR-49 - Move sunxi kernel to 5.4.y
- AR-79 - Check and adjust AUFS patch for 5.4.y
- AR-80 - Move imx6 to 5.4.y
- AR-81 - Enable Meson64 DEV at 5.4.y
- AR-82 - Move Mvebu64 / Espressobin dev kernel to 5.4.y
- AR-84 - Move rockchip64 current to 5.4.y
- AR-85 - Adjusted Sunvell R69
- AR-90 - Add support for Nanopi M4 v2
- AR-92 - Enable stable MAC address from cpuid on rk3399
- AR-96 - Update Xradio wireless driver
- AR-97 - Tag supported builds properly at download pages
- AR-98 - Enable missing Kuberenetes kernel dependency
- AR-100 - Add Debian Bullseye and Ubuntu Focal
- AR-112 - Enabled internal WLAN on RockPi S
- AR-113 - Install wireguard tools only when selected
- AR-114 - Enable audio codec on Orangepi Win
- AR-115 - Add drivers for Realtek RTL8811CU and RTL8821C chipsets
- AR-116 - Remove annoying debug message filling logs on 8189es
- AR-117 - Add Pine H64 model B
- AR-124 - Enable wireless on Rockpi-S
- AR-127 - Refactoring wifi patches
- AR-128 - Adding WIP support for Pinebook PRO
- AR-129 - Move NanopiM4 V2 and Pine H64 under supported
- AR-134 - Update AUFS version on Odroid XU4 and Nanopi Fire3/T3/T3+
- AR-138 - Update RK3399 legacy kernel (Nanopi M4, T4, Neo4) to latest upstream version
- AR-139 - Nanpi R1 - move primary serial console to ttyS1 which is on the chassis
- AR-143 - Create OpenHab installation instructions for their official documentation
- AR-146 - Update rockchip-legacy to most recent upstream kernel version
- AR-147 - Enable analogue audio on Allwinner H6
- AR-148 - [ mvebu-current ] Fix cpufreq (dynamic frequency scaling)
- AR-149 - [ mvebu-current ] Fix pcie issues
- AR-153 - Enable USB3 for Rock64/Renegade with RK3328 on mainline kernel
- AR-154 - Add analogue audio driver to Allwinner H6
- AR-155 - Enable Cedrus video acceleration support on Allwinner boards
- AR-167 - Add upstream patches for Odroid XU4
- AR-172 - USB3 Support for Rockchip
Bugs
- AR-74 - User patches directories not created
- AR-76 - Rockchip64 missing CPU_MIN variable
- AR-77 - Wrong board name variable for Orangepi RK 3399
- AR-83 - Packaging patch broken for kernel 5.4.y
- AR-86 - CPU freq scaling for H6 doesn't work in K5.4
- AR-89 - Tinkerboard S doesn't start from eMMC
- AR-91 - Broken Allwinner overlays
- AR-94 - Espressobin v7 with 2gb of ram fail to boot
- AR-102 - Missing packaging patch for Rockpis legacy kernel
- AR-103 - PPA way of adding sources are failing on Ubuntu
- AR-104 - 32bit rust compiler doesn't run new kernels
- AR-105 - Orangepi Zero Plus 2 doesn't boot
- AR-106 - Wireguard breaks building on 5.4.y
- AR-107 - Improve compiler and rootfs download process
- AR-110 - Missing Bionic image for Nanopi Neo Plus2
- AR-111 - Some versions of Orangepi Win does not boot modern kernel
- AR-118 - NanoPi M4V2 ethernet partialy broken in one side
- AR-123 - OpenHAB2 installation is failing
- AR-125 - Wireless driver for 8188EUS breaks on K4.14
- AR-126 - Nanopi M3/Fire3/PC3 compilation breaks
- AR-130 - Instability with various A64 boards
- AR-131 - Add support for 3rd version of Pinebook A64 panel
- AR-133 - Odroid XU4 legacy kernel images instability
- AR-141 - Odroid XU4 current with kernel 5.4.y seems unstable
- AR-142 - Cryptsetup disk encryption build feature broken
- AR-144 - Tinkerboard break booting
- AR-145 - Missing HDMI audio on H3 boards
- AR-152 - Display issues with Bionic Mesa update
- AR-164 - Htop package does not build in qemu under Ubuntu Focal 20.04
- AR-166 - Rootfs cache number creates a window of 12h when users are forced to rebuild cache
- AR-170 - Wireless not connecting for SBCs
- AR-171 - Fix broken loading process on MiQi
- AR-173 - Fix makefile of kernel headers 4.4.210 for rk3399
- AR-174 - Teres Keyboard Not Working
Stories
v19.11.3 (2019-11-20)¶
Tasks
- AR-1 - Adding support category for distributions
- AR-4 - Remove Allwinner legacy
- AR-5 - Drop Udoo family and move Udoo board into newly created imx6 family
- AR-9 - Rename sunxi-next to sunxi-legacy
- AR-10 - Rename sunxi-dev to sunxi-current
- AR-11 - Adding Radxa Rockpi S support
- AR-13 - Rename rockchip64-default to rockchip64-legacy
- AR-14 - Add rockchip64-current as mainline source
- AR-15 - Drop Rockchip 4.19.y NEXT, current become 5.3.y
- AR-16 - Rename RK3399 default to legacy
- AR-17 - Rename Odroid XU4 next and default to legacy 4.14.y, add DEV 5.4.y
- AR-18 - Add Odroid N2 current mainline
- AR-19 - Move Odroid C1 to meson family
- AR-20 - Rename mvebu64-default to mvebu64-legacy
- AR-21 - Rename mvebu-default to mvebu-legacy
- AR-22 - Rename mvebu-next to mvebu-current
- AR-23 - Drop meson64 default and next, current becomes former DEV 5.3.y
- AR-24 - Drop cubox family and move Cubox/Hummingboard boards under imx6
- AR-26 - Adjust motd
- AR-27 - Enabling distribution release status
- AR-29 - Implementing Ubuntu Eoan
- AR-30 - Add desktop packages per board or family
- AR-31 - Remove (Ubuntu/Debian) distribution name from image filename
- AR-32 - Move arch configs from configuration.sh to separate arm64 and armhf config files
- AR-33 - Revision numbers for beta builds changed to day_in_the_year
- AR-34 - Patches support linked patches
- AR-35 - Break meson64 family into gxbb and gxl
- AR-36 - Add Nanopineo2 Black
- AR-38 - Upgrade option from old branches to new one via armbian-config
- AR-41 - Show full timezone info
- AR-43 - Merge Odroid N2 to meson64
- AR-44 - Enable FORCE_BOOTSCRIPT_UPDATE for all builds
- AR-57 - New kernel feature requested CONFIG_BLK_DEV_DRBD
- AR-60 - Modified logrotate.service
- AR-63 - Docker maintenance features
Bugs
- AR-25 - Armbian resize stopped working in Ubuntu 19.10 or higher
- AR-40 - When changing console layout it does not change
- AR-51 - Prevent configuring locale
- AR-52 - Broken desktop install
- AR-54 - Upstream package name changed
- AR-55 - Wireless driver remove patch for Odroid XU4 broke down
- AR-56 - Missing CPU regulator
- AR-58 - Troubles with wireless on Nanopi DUO & Opi Zero
- AR-59 - Compressed files are getting back to /var/log
- AR-62 - No HDMI sound on various meson64 boards
- AR-64 - Docker require root
- AR-68 - Broken Ethernet on Pine64+
Stories
- AR-61 - Adding support for LOCAL_MIRROR
- AR-65 - Moving configs under userpatches
- AR-66 - Enable build system torrent download by default
- AR-67 - Install Docker when we want to build under Docker
- AR-69 - Use kernel command line instead of a patch
- AR-70 - Enable Lima kernel driver on meson64
- AR-73 - Enable PCI on Rockpi 4 and overlay for GEN2 speed
v5.98 (2019-10-09)¶
- changed ntptime with chrony
- fixed serial console on several hosts
- added FriendlyARM ZeroPi
- enabled gadgets on rockchip64
- bumped RK3399 boards to latest kernel, recreate images and repository
- merged odroidxu4 down to default since we only have one kernel
- fixed Cubox images, move them to stock kernel
- fixed low Synaptic search speed
Build script:
- script configurations were migrated to userpatches
- added option to create minimal images with around 500Mb in size BUILD_MINIMAL=”yes”
- added initial support of MCIMX7SABRE board (CSC)
- updates for xt-q8l-v10 (CSC)
- Docker is installed automatically if one want use it (Debian based build host only)
- refactor build all images scripting that images can be build in full parallel mode
- added one file for storing which combinations shell be made for each board
- replaced Etcher with dd + verify for directly burning images when done
- cleaned initial config and remove confusing advanced options out
v5.92 (2019-08-02)¶
- updated sunxi NEXT (4.19.63) and DEV (5.2.5) kernels
- updated htop application to show cpu speed and temperature (buster / disco)
v5.91 (2019-07-31)¶
- created new images for Helios4 and Clearfog Pro/Base
- moved mvebu DEFAULT, NEXT and DEV branch to next kernel (LTS) and U-boot version
- fixed armada_thermal sensor reading, adjusted Helios4 fancontrol configuration
- fixed ODT on data signals of DDR RAM for Armada A388 SOMs
- recreated Armbian Buster images due to a bug in Network manager which in some cases failed to initiate network connection
Armbian-config:
- added Emby installation
- updated Plex install to use official repo
- added netmask-to-CIDR function for manual IP configuration
v5.90 (2019-07-07)¶
- added Armbian Buster images for all boards
- added Macchiatobin Doubleshot CSS target and images
- added images with test kernel v5.1.y for: Orangepi3, Lite2, One+, PineH64, Odroid C1, Teres, Pinebook
- added wireless drivers for 88x2bu
- added eMMC support for Nanopi K2 (booting from doesn’t work yet)
- added dual w1 overlay for meson64 family
- updated wireless drivers for Realtek 8811, 8812, 8814 and 8821
- updated wireless drivers for rtl8188eus & rtl8188eu & rtl8188etv
- added latest Wireguard driver
- enable eMMC on Orangepi Win Plus
- enable Bluetooth on Tinkerboard, Nanopi4, Rockpi 4 CLI images
- improved ALSA config on Tinkerboard
- fixed Bluetooth on Nanopi M4/Neo4/T4 and Rockpi4
- fixed wireless drivers on OPi3 & Lite2
- fixed temperature readout on Allwinner H5 boards
- fixed SPI related bug on Allwinner 5.1.y kernel
- fixed HDMI output and bump kernel to 5.1.y on imx6 boards
- fixed eMMC install, add rootdev= to armbianEnv if missing
- fixed A10/A20 SATA write speed
- set default build target from Debian Stretch to Buster for all boards
- changed CPU clock back to 1.5/1.8Ghz defaults on boards with RK3399 to minimise thermal throttling
- changed motd console welcome text to: “Welcome to Debian Stretch with Armbian Linux 5.1.6-sunxi”
- changed display manager to lightdm by default and remove nodm completely
- changed u-boot for A64 to upstream sources
- changed RK3399 to U-boot 2019.04
- added URL to the build script and commit hash to /etc/armbian-release file
- added synaptic package manager and on-board keyboard to the desktop base
- added “logout” to the panel/menu
- added normal users to additional groups: disk tty users games
- updated all kernels with upstream
- updated ATF and bootloader on Espressobin, supporting all versions
Build script:
- added mirrors for speed-up building in China mainland
- added support for download compilers and rootfs cache via torrent network
- added new output image compression option (xz)
- enabled Debian Buster and Ubuntu Disco (unsupported) targets
- few Docker building improvements, caching image
- replace curl with aria2
- Linaro compilers update to 2019.02
Armbian-config:
- added Gimp installation
- added enable/disable Avahi
- updated OMV installer, OMV5 preparations
- enable screen resolution changer for Odroid N2
- enable CPU speed and governor adjustment
v5.87 (2019-05-26)¶
- added support for Odroid N2, Nanopi R1, Nanopi Duo2
- enabled nightly images for Orangepi3, One+, Lite2, PineH64, Rock64pro, RockPi4b
- enabled nigtly Buster and Disco images for Le Potato
- recompiled all images and pushed update where updates are known to work (sunxi, sunxi64, meson64, …)
- improved SATA write speed on A20 chips for up to 300%
- fixed thermal throtling for H5 devices
- mainline u-boot moved 2019.04
- most development kernels moved to 5.1.y
- added separate DT for espressobinv7, updated boot loader
- enable WoL for eth0 on Helios4
Build script:
- added Debian Buster and Ubuntu Disco (WIP)
- improved building under Docker. Source code is not copied to docker image, caching image
- fixed incomplete cleaning of the source code
Armbian-config:
- fixed kernel changing
- fixed sources download
- fixed Hass.IO and TVheadend install
- added menu driven CPU frequency/governor adjustement
- improved two-factor authentication
- added meson64 and rockchip to overlay/hardware configuration
- improved hostapd management
Infrastructure:
- main download server has been hooked to 10GbE connection.
- added web/http seeds to torrent download. Torrent download could/should fully utilize your download capacity.
- major forum upgrade (v4.4.3)
- added another IPV6 capable EU mirror https://mirrors.dotsrc.org
v5.76 (2019-02-11)¶
- remove Exagear Desktop
v5.75 (2019-02-10)¶
- added updated driver for Realtek 8811, 8812, 8814 and 8821 chipsets
- added Wireguard support to remaining kernels (except lower than 3.10)
- images rebuild with latest upstream sources, mainline u-boot was bumped to 2018.11
v5.74 (2019-01-31)¶
- fixing systemd related bug found in sunxi legacy 3.4.y kernels
v5.73 (2019-01-29)¶
- much faster armbian-install operations. Thanks to @dedalodaelus
- added support for @wireguard on all kernels higher than 3.10.y
- fixed drivers for popular DVB tuner S960 (all kernels)
- fixed bug in wireless drivers on Cubietruck, BananpiPRO, Bananapi+
- fixed AP mode on Orangepi PC+, Prime, One, .. when using kernel 4.19.y
- added prolific USB-to-USB bridges in mvebu-next/dev
- added nftables masquerade in mvebu64-next
- added MD raid support for SUNXI64
- upgrade bugfix for Helios4
- updated hostapd to 2.7
- fixed 1512MHz OPP on Renegade
- fixed DRM crashing for rockchip64
- mainline u-boot bumped to 2018.11 (update goes manually from armbian-install utility)
- added testing images for Orangepi RK3399 and Radxa Rockpi 4B
v5.72 (2019-01-16)¶
- added additional repository mirror (updated armbian-config)
- fixed Tinkerboard DTB in repository and images rebuild
v5.71 (2019-01-16)¶
- updated images for Odroid C2, Lepotato and Nanopik2-S905 due to this bug
v5.70 (2019-01-12)¶
- sunxi-next and sunxi64-next were moved from 4.14.y to 4.19.y (remake of all AW images)
- better DVFS on H3/H5/A64, enabled higher cpu speed.
- added overlay support for Tinkerboard/rockchip next and kernel upped to 4.19.y
- updated next kernel for Odroid XU4 to 4.19.y
- updated next kernel for Odroid C2, Lepotato and Nanopik2-S905 to 4.19.y with overlay support
- fixed poweroff on H5
- H5/A64 lost experimental status,
- upgraded images and upstream/bugfix kernel upgrade for Rock64, Renegade,
- u-boot update is moved from automated to manual (armbian-config) to minimize boot related troubles
- added two repository mirrors: China and France (armbian-config -> Personal -> Mirror)
- changed switching to alternative kernels from armbian-config. It is possible to select a direct version and it only replaces kernel (safer)
- first official build for Olimex Teres
- mainline kernel builds for: Pine64, Pine64so, Olinuxino A64, OrangepiWin
- added more download variants for Rock64, Renegade, Tritium H3&H5
- updated images for Z28PRO, Bananapi PRO, Espressobin, Olimex Micro, Lime, Udoo, Bananapi M2, Bananapi M2U,
v5.68 (2018-12-30)¶
- updated Espressobin images, kernel updated to 4.19.y
v5.67 (2018-11-26)¶
- updated Helios4 images
- added experimental mainline kernel images for Pinebook and Pinebook 1080p
v5.67 (2018-11-12)¶
- updated images for Bananapi R2 with eMMC install support.
v5.66 (2018-11-08)¶
- added Mediatek MT7623 family.
- added images for Bananapi R2 with kernel 4.19.y without official support.
v5.66 (2018-11-07)¶
- removing Odroid C2 official support, drop its default 3.16.y kernel from build engine and merge with the meson64 family.
- attach meson64 dev to 4.19.y
- drop Udoo Neo completly, drop Udoo Quad default and dev kernel.
- Odroid XU4: drop kernel 3.10.y, default branch is upgraded to offical 4.14.y, next becomes vanilla 4.19.y
v5.65 (2018-11-06)¶
- Cubox-i/Hummigboard: drop kernel 3.14.y and move 4.14.y to default, next becomes 4.19.y, dev 4.19.y with a mainline u-boot
v5.64 (2018-10-09)¶
- updated images and packages for Helios4.
- added images for Nanopi Neo4.
v5.63 (2018-10-08)¶
- updated images for Helios4 with SPI booting support.
- updated armbian-config. Added advanced ZSH shell install with most used plugins and tmux.
v5.62 (2018-10-01)¶
v5.61 (2018-09-26)¶
- updated armbian-config,
- fixed Chromium on Debian builds with a workaround. We are overwriting package with last known working one. It will show some error on startup which is safe to ignore. This workaround will fade out with Chromium upstream update.
v5.60 (2018-09-19)¶
Changes overview:
General:
- Ubuntu Xenial was replaced with Bionic unless kernel was too old for the change,
- Debian Jessie becomes EOL and its building is not maintained anymore while you will still receive kernel updates,
- Emergency swap file creation is disabled by default since we use compressed memory (ZRAM) as an alternative,
vm.swappinesshas been changed from 0 to 100 (if you run databases on your board you might want to revert this change in/etc/sysctl.conf),- RAM logging also uses ZRAM now and rotates logs automagically,
- all images were rebuilt, except boards for which support ended,
- significantly lighter - browser only - desktop images (< 1.5G),
- fixed hanging on headers installation,
- install boot script (BSP package) if not present. This fixes upgrade or kernel switching problems,
- Proper bind mount directory when installing to SATA/USB and booting from SD,
- update for wireless drivers 8812/11/14AU, 8188EU and AUFS,
- Bugfix when a temperature is not present or readings are invalid,
- Also showing bridge IP addresses in MOTD,
- storing package list compressed - saves 50-70Mb,
- enlarging automated apt-get update and purge intervals,
- smaller overhead for CLI images,
- improved alternative kernel switching,
- stop setting Google’s DNS server as default for privacy reasons.
Family:
- sunxi and sunxi64, u-boot was bumped to 2018.05, NEXT branch was updated to the latest 4.14.y, DEV is attached to 4.18.y + fixed overlay support,
- mvebu64, default BSP kernel was upgraded to 4.14.y, NEXT to 4.18.y,
- odroidc1, experimental NEXT kernel branch was attached to 4.18.y,
- odroidc2 kernel was merged with meson64 on the source level,
- meson64 u-boot was pushed to 2018.05, a default was updated to the latest 4.14.y, NEXT to 4.18.y,
- rk3288, u-boot was pushed to 2018.05, legacy kernel cleaned and fixed after upstream troubles, NEXT branch was updated to the latest 4.14.y,
- rockchip64, rk3399 was split into rk3399 for Friendly ARM boards and rockchip64 for Rock64 and RockPro, Ayufan repository. Merging is postponed for the future,
- s5p6818 family support added NEXT branch was updated to the latest 4.14.y,
- mvebu, NEXT branch was updated to latest 4.14.y, DEV attached to 4.18.y,
- fixed randomly failing X server on imx6 family,
Board:
- added WIP support for Firefly RK3399, Lime A64, Renegade, Rockpro64, Olimex Teres
- added experimental images for Bananapi M3 and Cubietruck+,
- adeed support for: Tinkerboard S, Rock64, Orangepi Zero Plus, Nanopi Neo Core2, Nanopi M4,
- added NEO 1.1 regulator overlay,
- added Helios4 device tree with FAN control for modern kernel,
- enabled SPI access on Espressobin,
- updated SPI boot firmware on Espressobin (18.09.1) with many fixes and support for booting from USB, SATA, eMMC or SD,
- added Tinkerboard S DC-IN voltage to armbianmonitor,
- fixed network interface initialization,
- fixed clock drift on Bananapi boards,
- enabled concurrent AP/STA mode on Tinkerboard,
- improved support for NanoPi Fire 3 (added SPU1705, DVFS, thermal tables, etc.),
- fixed network crashing on high load. Affected: Odroid C1/C2, Le Potato kernel 4.18.y,
- fixed wireless, eMMC and Bluetooth on (unsupported) Z28 PRO and changed boot order,
- fixed eMMC install on NanoPC T3+ and Docker dependencies on Fire3, M3, NanoPC T3+,
- added eMMC and DVFS support on Espressobin mainline kernel,
- ported Tinkerboard UMS to modern u-boot,
- enabled 1392 MHz cpufreq OPP on all RK3328 devices,
- enabled 1992/1512MHz cpufreq OPP on all RK3399 devices,
- added eMMC to OlinuXino A64 kernel and u-boot,
- added Sunvell R69 CSC target,
- OrangepiWin: fixed BT,
- fixed ethernet on (unsupported) Bananapi M64.
Build script:
- changed recommended build host to Bionic, Xenial still supported for everything except building Bionic images,
- added support for burning image directly to SD card when your build is done by using Etcher for CLI,
- added support for making LUKS encrypted root images, parameters: CRYPTROOT_ENABLE=yes, CRYPTROOT_PASSPHRASE=unlockpass,
- fixed building under Docker, bumped to Bionic host,
- added building Bionic and block building it for images with too old kernels,
- added multibranch support (LIB_TAG).
Infrastructure:
- build machine main SSD and memory upgrade, switched from bare metal Ubuntu Xenial to fully optimsed Debian KVM server, free build capacity is avaliable for any armbian related activity upon request,
- download server drive capacity and download speed upgrade, IPV6,
- geo load balancing for repository and download server is under testing,
- improved repository management. Possibility to add packages via Github,
- introducing new internal parameter, example: BUILD_ALL=”yes” REBUILD_IMAGES=”bananapi,udoo,rock64” to specify which images need rebuilding,
- main torrent server cleanup, removed deprecated images,
- creating report https://beta.armbian.com/buildlogs/report.html when building all kernels. Prepared to include simple per board testing report where exists armbian/testings.
Known bugs:
- modern kernel support on A64 boards is mainly broken.
v5.59 (2018-08-18)¶
- rebuilt images for Espressobin with kernel 4.18.y, Nanopc T4
v5.58 (2018-08-13)¶
- rebuilt images for Bananapi, Bananapi Pro, Bananapi+, Odroid C2, Odroid XU4
- updated repository for Odroid C2/XU4, changed NEXT from 4.9.y to 4.14.y
v5.58 (2018-08-13)¶
v5.57 (2018-08-11)¶
- added Bionic desktop and Stretch CLI images for RK3399 powered Nanopc T4
v5.56 (2018-08-10)¶
- rebuilt images for Pinebook. Added Bionic build
v5.55 (2018-08-09)¶
- rebuilt images for Orangepi One+, Orangepi Lite 2 and Pine H64. Enabled USB3, network, THS, DVFS, higher frequencies, HDMI on 4.18.y DEV branch images.
v5.55 (2018-08-03)¶
- added Stretch and Bionic mainline kernel images for Odroid C1 (testing),
- rebuilt images for Bananapi M3 (fixed ethernet)
v5.54 (2018-07-25)¶
- updated images for Odroid C2, Nanopi M3, Nanopi Fire 3 and NanoPC T3+, Espressobin, Cubox-i/HB and Le potato
- added preview images without end user support for Bananapi M3,Cubietruck+ and Bananapi M2 Berry.
v5.53 (2018-07-23)¶
- Z28PRO images updated. Fixed wireless and Bluetooth
- FriendlyARM Nanopi K2 S905 images updated. Fixed ethernet problems.
- FriendlyARM Nanopi K1+ images updated. Fixed HDMI out and wireless
v5.51 (2018-07-04)¶
- Helios4 Stretch and Bionic images update
v5.50 (2018-06-28)¶
- Espressobin images rebuild and repository update, default 4.4.138, next 4.17.3, dev 4.18.RC, hardware crypto support in 4.17.y, zram and zswap
- Odroid C2 bugfix update
v5.49 (2018-06-28)¶
- Amlogic Meson64 family (Odroid C2, Lepotato and FriendlyARM K2 S905) were merged into one kernel. Default images comes with kernel 4.14.52, next with 4.17.3 and DEV with 4.18.RC, updated boot scripts, implemented latest kernel bug fixes
- updated kernels, desktop packages and armbian config on the stable repository (apt update & upgrade)
v5.48 (2018-06-26)¶
- added nightly images for Odroid C2 with 4.16.y (NEXT) and 4.18.y (DEV) and hopefully fixed ethernet driver
v5.47 (2018-06-22)¶
- Odroid C2 images rebuild. Legacy kernel was upgraded to 3.16.57, next to 4.14.51, u-boot to 2018.05
- Added Tritium H5
v5.46 (2018-06-20)¶
- Added Olimex Teres nightly builds
- Added FriendlyARM Nanopi K1 plus
v5.46 (2018-06-06)¶
- Added Orange Pi Lite 2 and One plus nightly builds
v5.45 (2018-05-23)¶
- Orangepi Zero+ images rebuild
v5.44 (2018-05-10)¶
- Espressobin images were rebuilt and moved under stable. Kernel 4.14.40, Stretch, Xenial and Bionic. Fixed bootloader, ath10 wireless card support
- added initial Bionic storage to the main apt repository
- Cubox-i / Hummingboard bugfix update to 4.16.y and images rebuild
v5.41 (2018-02-10)¶
- fixed LED driver on Helios4
- bugfix update on sunxi/sunxi64 kernel. Updated to 4.14.18
- kernel update for MVEBU next (4.14.18 and default 4.4.115) for Clearfog and Helios4. Upstream fixes,AUFS and Realtek 881yAU drivers update
v5.40 (2018-02-05)¶
- fixed eMMC support on Odroid C2 NEXT, kernel 4.14.y
- updated PWM driver on Helios4
- kernel update for MVEBU next (Clearfog, Helios4)
v5.38 (2018-01-29)¶
- updated all images
- added H3/H5 testing images with kernel 4.14.y
- added Nanopi M3/T3+/Fire testing image
- fixed Bluetooth on Orangepi Win
- main repository update with recent kernel on all NEXT builds
v5.37 (2018-01-23)¶
- bugfix release
- armbianmonitor -u fix
- setting cronjob permissions
- replace broken u-boot packages on A20 boards
- updated utilities: hostapd, sunxi-tools, armbian-config
- updated images: Bananapi, PRO, M2, BeelinkX2, Clearfog,Cubieboard2, Cubietruck, Cubox-i/HB, Espressobin, Helios4
v5.36 (2017-12-03)¶
v5.35 (2017-11-25)¶
- mainline kernel updated to 4.13.y
- mainline u-boot updated to v2017.09
- added new sunxi Device Tree overlays, fixed and improved old overlays
- Micro-USB g_serial console is enabled by default on most small Allwiner based boards
- Olimex Lime2 and Micro: merging eMMC and normal versions
- Odroid C2: next and dev branches migrated to mainline u-boot
- Odroid XU4: added dev branch, next branch migrated to mainline u-boot
- Clearfog: added dev branch with mainline u-boot
- added supports for 7” RPi display to Tinkerboard with legacy kernel
- All mainline kernels: added Realtek 8811AU/8812AU/8814AU USB wireless driver with monitor mode and frame injection
- All boards: added kernel source packages to the repository (Package names
linux-source-${BRANCH}-${LINUXFAMILY}, i.e.linux-source-sunxi-next) - Kernel headers are no longer installed by default to new images
- Additional out of tree drivers and USB Redirector are no longer installed by default to new images
- Switching from emergency swap to zram on new Ubuntu Xenial images
- New hardware support (stable/supported images): NanoPi Duo, Orange Pi R1, Pinebook
- New hardware support (experimental): Le Potato, NanoPi NEO 2, Orange Pi Zero Plus, Orange Pi Zero Plus 2 (H5)
- sunxi mainline u-boot: reenabled USB keyboard support and disabled stopping the boot sequence with any key - autoboot now can be aborted with
Desktop images:
- xterm was replaced with full featured xfce terminal,
- added memory profile caching for Chromium,
- added OpenVPN connector,
- shortcuts to armbian-config, support and donate were moved to menu,
- default icon theme was changed to lighter one (Numix),
- fixed login greeter theme,
- changed wallpaper.
- changed CMA handling on Allwinner legacy kernels
armbian-config:
- was splitted from board support packages to a new package
armbian-config - managing board hardware configurations, hotspot, Bluetooth, SSH server
- freezing/unfreezing kernel upgrade
- switching between stable and beta builds,
- switching between alternative kernels,
- installing/uninstalling kernel headers,
- changing timezone, locales, hostname,
- running diagnostic tools,
- enabling/disabling RDP server,
- 3rd party software installer: Samba, OMV, Pi hole, Transmission, …
Build script:
- added Debian Stretch
- most tweaks moved from inline files to separate files in board support package
- firmware blobs moved to a separate repository
- disabled distcc in extra software compilation process due to toolchain compatibility issues
- Allwinner A20/sun7i legacy boards. Changed CMA settings prevents playing video. You need to add cma=96M to kernel command line
v5.34 (2017-10-18)¶
- bugfix Odroid XU4/HC1 image rebuild due to broken USB install on kernel 4.9.x
- added Le Potato and Orange Pi Zero testing image (mainline kernel)
- Tinkerboard, MiQi and Pinebook images rebuilt
v5.33 (2017-09-24)¶
- Odroid XU4/HC1 images were rebuilt.
v5.33 (2017-09-21)¶
- Tinkerboard and MiQi images were rebuilt. Rockchip legacy kernel was updated to 4.4.88 and mainline (NEXT) to 4.13.3.
v5.32 (2017-06-23)¶
- bugfix release due to broken crypto functions on kernel 4.11.x
v5.31 (2017-06-15)¶
- bugfix release due to network failure on some A10 / A20 boards
End of support notice
Following boards are no longer receiving support and updates since this version:
- Cubieboard (Allwinner A10) - not enough hardware samples to maintain support
- Lamobo R1 (Allwinner A20) - hardware design flaws, poor software support for the onboard switch
- Olimex Lime A10
v5.30 (2017-06-14)¶
- mainline kernel updated to 4.11
- mainline u-boot updated to v2017.05
- Firefox was replaced with Chromium (desktop images)
- sunxi mainline configuration: added Device Tree overlays support (new images only)
armbian-add-overlayhelper for compiling and activating DT overlays (new images only) - log2ram: fixed saving
/var/logcontents on shutdown - new hardware support (stable/supported images): Xunlong Orange Pi Zero Plus 2 (H3), ASUS TinkerBoard, MiQi
- reworked package updates MOTD script to speed up the login process
- added config file
/etc/default/armbian-motdfor disabling MOTD components - added
armbian-configdialog-based configuration program (WIP) - Banana Pi M2: fixed HDMI video output
- Clearfog: adjusted temperature readout
- i.MX6 mainline: enabled support for HDMI audio and PCIe bus
- Orange Pi (Allwinner A20) - no hardware samples, out of stock
- Orange Pi Mini (Allwinner A20) - no hardware samples, out of stock
- LeMaker Guitar (Actions S500)
- Roseapple Pi (Actions S500)
v5.26, v5.27 (2017-02-24)¶
- security update for most kernels (packages only)
- fixes for hostapd configuration
v5.25 (2017-02-02)¶
- armbian-install expanded functionality: you can partition destination and choose file-system type: ext2, ext3, ext4 and BTRFS (BTRFS requires kernel 4.4+)
- added new boards: Clearfog Base, Lime2 eMMC, Lime A33, NanoPi M1+, OrangePi Zero, OrangePi PC2 (mainline only, experimental)
- new default kernel for Clearfog(s), changed kernel family to “mvebu” to avoid conflicts
- disabled wireless power management by default to improve performance with certain drivers
- added wireless drivers to mainline kernels: OrangePi Zero, Neo Air
- implemented initrd loading support for all boards
- moved all images to single ext4 partition scheme
- changed default wallpaper, startup icon, shadows to windows on desktop builds
- Firefox web cache moved to memory
- added g_serial driver to boards without a network connector, working on both kernel (Opi Zero,Opi Lite,FA Neo Air)
- added “Software boutique” application installer on desktop builds (currently not working properly on arm64)
- added per board patching option
- added u-boot video driver and boot logo to H3 based boards
- added simplefb video driver (HDMI only) to mainline H3 kernel
- updated MALI driver on H3 platform, fixed problems on 2GB boards
- changed Ethernet switch driver on Lamobo R1 to DSA based one (mainline kernel)
- fixed soft cursor (CLI) for H3 legacy and Odroid C2
- expand and adjust multiple kernel configurations based on user requests
- adjusted sunxi boot script to support booting in SPI flash + USB storage scenario (w/o the SD card)
- dropped support for Debian Wheezy and Ubuntu Trusty releases
- sunxi mainline kernel was updated to 4.9.x, some dev kernels to 4.10
- added log2ram (Ramlog alternative) to default installation
- changed first run logic, disabled forced automatic reboot
- changed new user account creation logic, disabled forced reboot on user creation failure
v5.24¶
- this version is not released, it was used for the nightly or user-built images
v5.23 (2016-10-23)¶
- fixed bug in armbian-install
- fixed u-boot update bug on Allwinner platform
Known problems:
- Lamobo R1 fails to boot upon upgrade
v5.22 (2016-10-22)¶
- fixed eMMC install on Odroid C2
- firmware package was splitted into minimal (default) and full versions
- patched Dirty COW exploit on all kernels
- added Odroid XU4 mainline kernel image
- added Olimex A33 mainline kernel image
- added Overlay FS for Cubox, Udoo and Udoo Neo
- booting problems fixed on more boards
- updated wireless driver on M2+ (dhd)
- updated driver for OV5640 on sun8i default kernel
- sunxi-next kernel version updated to 4.8.4
- BananaPi M1+ now uses upstream DTB file
sun7i-a20-bananapi-m1-plus.dtb, boot script adjusting may be required for existing images
Desktop images:
- prebuilt mpv and FFmpeg were removed in favor of providing only configuration files
- fixed an issue with video brightness on A10/A20 based boards
Build script:
- DEBUG_MODE was renamed to CREATE_PATCHES
- GLshim was moved to a private directory, it can be activated for selected applications by changing
LD_LIBRARY_PATH
Known problems:
- eMMC install fails (will be fixed in bugfix update)
- H3 development kernel (4.8.4) update fails to boot
- C2 upgrade hangs on compiling headers (Jessie)
v5.20 (2016-09-16)¶
- added FriendlyARM Neo legacy and mainline images (experimental)
- added Orange Pi PC+ mainline kernel (experimental)
- added Pine64 / Pine64+ images with legacy kernel
- added UUID support for NAND/SATA/USB installer
- added desktop images for Cubox(s) / Hummingboard(s) with mainline kernel
- enabled MIDI sequencer and snd-rawmidi-seq in H3 legacy kernel
- added H3 consumption tool to control board consumtion level on legacy kernel
- fixed and enabled Bluetooth on Cubietruck and Cubox(s) / Hummigboard(s) desktop, both kernels
- masked p2p0 wifi direct device on Bluetooth legacy kernel
- Odroid C1/C2 upgrade fail fixed
- wireless enabled by default on Banana Pi PRO
- added new screen resolutions to H3 boards with legacy kernel
- DeviceTree Overlay ConfigFS interface for H3 mainline kernel
- update of mainline u-boot to 2016.09 should fix boot failures on H3 boards with eMMC
- disabled USB keyboard support in mainline u-boot should fix boot failures with connected USB devices
Desktop images:
- WICD was replaced with NetworkManager
- ALSA was replaced with PulseAudio
- sunxi boards: GLshim was added to desktop images with Mali support (except for Orange Pi Plus and Orange Pi Plus 2e)
- sunxi boards: prebuilt mpv now supports OSD and subtitles, activated by setting environment variable
VDPAU_OSD=1
Build script:
- complete desktop building rework - now packages are built from sources
- added Lime 2 eMMC as build target (WIP)
- added Pine64 / Pine64+ mainline (dev) target (experimental)
- added FriendlyArm Neo as build target
- fixed MT7601 wifi driver building
- github download rework
- external toolchain rework
Added additional packages, not installed by default:
- hostapd-realtek: replacement for hostapd with support for several Realtek Wi-Fi adapters
- fswebcam-gc2035: replacement for fswebcam with support for GC2035 camera driver for H3 based boards
- guvcview: replacement for stock guvcview with support for H3-based Orange Pi CMOS cameras
Known problems:
- Mali OpenGL ES does not work on H3 boards with 2GB RAM (Orange Pi Plus 2, Orange Pi Plus 2e)
- Hardware video decoding on A10/A20 based boards produces dark video
- Some applications that depend on livav libraries (i.e. minidlna) may not work on Jessie images
v5.17 (2016-07-07)¶
- bugfix release on some boards.
v5.16 (2016-07-05)¶
- bugfix release. In 5.15 we accidentaly overwrote default network settings. Check /etc/network/interfaces if you use advanced network settings or fixed ip.
- small changes.
v5.15 (2016-07-01)¶
- Added improved camera driver for Xunlong’s cheap 2MP GC2035 camera
- Improved throttling/DRAM settings for the new 3 overheating H3 devices (BPi M2+, NanoPi M1, Beelink X2)
- Added official support for Beelink X2, NanoPi M1, Banana Pi M2+
- Improved console output (serial + display)
- Finally got rid of (broken) board auto detection. We do not ship any more one image for several devices that tries to detect/fix things on 1st boot but provide one dedicated image per board (Plus and Plus 2 and both NanoPi M1 variants being handled as the same device since only size of DRAM/eMMC differs)
- Tried to improve user experience with better/unified led handling (light directly after boot, communicate booting states through blinking)
- Improve partitioning and filesystem resize on 1st boot making it easier to clone every installation media afterwards
- fully support installation on eMMC on all H3 devices (
u-bootandarmbian-install.shfixes) - Improved performance/thermal/throttling behaviour on all H3 boards (especially newer Oranges)
- Prevent HDMI screen artefacts (disabling interfering TV Out by default)
- Enhanced 8189ETV driver for older Oranges
- Added support for OPi Lite, PC Plus and Plus 2E including new 8189FTV Wi-Fi (client, AP and monitoring mode, added fix for random MAC address)
- Added in-kernel corekeeper patch (bringing back killed CPU cores after heavy overheating situations when thermal situation is ok again)
- Added TV Out patch for Orange Pi PC
- Further improve driver compilation due to improved kernel headers scripts compilation
- Initrd support
- increased kernel version to 3.4.112
- Exchanged whole kernel source tree to newer BSP variant, cleaned up sources, rebased all +100 patches (fixed display issues and kswapd bug, new and more performant GPU driver, increase Mali400MP2 clock to 600MHz)
- Added RTL2832U drivers to kernel (DVB-T)
- Fixed Docker on Odroid XU4
- Added overlay fs to Clearfog and Odroid XU4
- Many minor fixes
v5.14 (2016-06-14)¶
- all images rebuilt, most of them were manually tested
- added Beelink X2 image
- Cubox / Hummingboard kernel upgrade to 3.14.72 and 4.6.2
- Trusty was replaced with Xenial
v5.12 (2016-05-31)¶
- updated C1 images
- added wifi driver for new Oranges (modprobe 8189fs)
- added Orange Pi Lite, PC Plus and Plus 2E images
v5.11 (2016-05-24)¶
- Various bug fixes
- new working images for Actions Semi S500 boards
v5.10 (2016-05-01)¶
Images:
- all 3.10+ kernels are Docker ready
- all A10/A20/H3 comes with HW accelerated video playback in desktop build
- fixed root exploit on H3 boards
- fixed kswapd 100% bug on H3 boards
- fixed SPDIF / I2S audio driver in legacy kernel
- fixed Udoo Neo wireless
- fixed slow SD cards boot
- fixed Allwinner SS driver
- fixed bluetooth on Cubietruck, both kernels
- fixed wireless driver on H3 boards
- fixed R1 switch driver
- kernel for Allwinner boards was upgraded to 3.4.112 & 4.5.2
- kernel for iMx6 boards was upgraded to 3.14.67 & 4.5.2
- kernel for Armada (Clearfog) was upgraded to 3.10.101 & 4.5.2
- kernel for Udoo boards was updated to 3.14.67 & 4.4.8
- kernel for Guitar (Lemaker) was upgraded to 3.10.101
- kernel for H3/sun8i legacy come from new Allwinner updated source (friendlyarm)
- added support for Olimex Lime2 eMMC
- increased MALI clockspeed on sun8i/legacy
- added Armbianmonitor
- added Odroid C1, C2(arm64), Nanopi M1, Banana M2+, Pcduino 2 and Pcduino 3. CLI and desktop
- added wifi radar to desktop
- added preview mainline kernel images for H3 boards (4.6.RC1)
- added initrd creation on all Allwinner images
- added Hummigboard 2 with working PCI and onboard wireless with legacy kernel 3.14.65
- added eMMC installer for H3
- added support for IFB and net scheduling for sun7i-legacy
- added ax88179_178a USB 3.0 Ethernet driver for sun7i-legacy
- hostapd comes as separate package (armbian-hostapd)
- changed first boot procedure and force user creation
- verbose / no verbose boot works almost on all boards
- enabled I2S on sun8i
- removed Debian Wheezy from auto build
- installing headers autocompile scripts
- all images come compressed with 7zip
Build script:
- GCC 5 support for mainline and allwinner legacy
- RAW images are not compressed by default
- added arm64 building support
- added docker as host
- Added Belink X2 (H3 based media player), and Roseapple (S500) as WIP target
- introducted CLI_TARGET per board
- prepared Xenial target
- fixed USB redirector building on all kernels
- support for Xenial as a build host is 95% ready.
- implemented automatic toolchain selection
- come cleanup, configurations are subfoldered
- extended_deboostrap becomes default
Known bugs:
- Udoo Neo reboots takes a while, 1min+
- headers within sun8i needs some fixing
- H3 board autodetection fail under certain conditions
v5.06 (2016-03-18)¶
- increase kernel version to 3.4.111
- headers auto creation while install (eases kernel/driver compilation)
- improved SD card partitioning to help old/slow cards with wear leveling and garbage collection
- Possible to use Ubuntu Xenial Xerus as target
- changed behaviour of board leds (green == power, red == warning)
- speed improvements for 1st automated reboot
- Integrates OverlayFS backport
v5.05 (2016-03-08)¶
- Auto detection for the Orange Pi 2 does work now
- Mali acceleration works for all users not only root
- verbose boot logging on 1st boot and after crashes (you can toggle verbose logging using
sudo armbianmonitor -b) - more WiFi dongles supported due to backported firmware loader patch
- all 3 USB ports on Orange Pi One (Lite) available (2 of them need soldering)
- I2S possible on all Orange Pis (compare with the mini tutorial since you need to tweak script.bin)
- default display resolution set to 720p60 to fix possible overscan issues on 1st boot
- HW accelerated video decoding works for most formats
- Booting from eMMC on OPi Plus now possible
- Udoo quad images upgraded to 4.4.4
v5.04 (2016-03-01)¶
- HDMI/DVI works (bug in boot.cmd settings)
- Reboot issues fixed (bug in fex settings)
- 1-Wire useable (we chose to stay compatible to loboris’ images so the data pin is 37 by default. You’re able to change this in the fex file)
- changing display resolution and choosing between HDMI and DVI is now possible with the included h3disp tool (should also work in the stand-alone version with Debian based OS images from loboris/Xunlong). Use
sudo h3dispin a terminal to get the idea. - Ethernet issues fixed (combination of kernel and fex fixes)
- USB-to-SATA bridge on the Orange Pi Plus works
- stability problems on Orange Pi One fixed (due to undervoltage based on wrong fex settings)
- problems with 2 USB ports on the PC fixed (wrong kernel config)
- Mali400MP acceleration (EGL/GLES) works now
- suspend to RAM and resume by power button works now (consumption less than 0.4W without peripherals)
- Enforce user account creation before starting the GUI
- USB and Ethernet IRQs distributed nicely accross CPU cores
- Full HDMI colour-range adjustable/accessible through h3disp utility
- already useable as stable headless/server board
- rebuilt Cubieboard 1 & 2 with 3.4.110 and 4.4.3
- fixed Bluetooth on Cubietruck + rebuild with 3.4.110 and 4.4.3
- all new images has no login policy: forced user generation
v5.03 (2016-02-20)¶
- H3 images rebuilt
v5.02 (2016-02-18)¶
- H3 images rebuilt
v5.01 (2016-02-17)¶
- Bugfix update for Allwinner boards
- Update for H3 based boards
v5.00 (2016-02-12)¶
- mainline kernel for Allwinner based boards upgraded to 4.4.1
- Allwinner audio driver playback and capture on kernel 4.4.1, UAS, USB OTG, battery readings,
- added Marvel Armada kernel 3.10.96, 4.4.1 and patches for changing mPCI to SATA
- added Cubox / Hummingboard kernel 4.4.1 (serial console only)
- firstrun does autoreboot only if needed: wheezy and some legacy kernels.
- added motd to /etc/updated.motd … redesign, added battery info for Allwinner boards, bugfix, coloring
- fixed temperature reading on Cubox / Hummingboard legacy kernel
- fixed FB turbo building on Allwinner
- fixed NAND install on A10 boards (Legacy kernel only)
- fixed USB boot, added PWM on mainline
- fixed Banana PRO/+ onboard wireless on mainline kernel - running with normal Banana DT.
- readded USB sound
- added A13 Olimex SOM
- added LIRC GPIO receive and send driver for legacy Allwinner
- added LED MMC activity to mainline kernels for Cubietruck and Cubieboard A10
- build script: option to build images with F2FS root filesystem for Allwinner boards
- build script: added alternative kernel for Lemaker Guitar (NEXT), Cubox (DEV)
v4.81 (2015-12-28)¶
- complete build script rework
- new development kernel package linux-image-dev-sunxi (4.4RC6) for Allwinner boards
- added Lemaker Guitar, kernel 3.10.55
- added Odroid XU3/4, kernel 3.10.94 and mainline 4.2.8
- mainline kernel for Allwinner based boards upgraded to 4.3.3
- Udoo mainline upgraded to 4.2.8, legacy to 3.14.58
- cubox / hummingboard upgraded to 3.14.58, added mainline kernel 4.4
- fixed Jessie RTC bug, systemd default on Jessie images
v4.70 (2015-11-30)¶
- Bugfix update(apt-get update && apt-get upgrade)
- small changes and fixes
v4.6 (2015-11-24)¶
- Update only (apt-get update && apt-get upgrade)
- mainline kernel for Allwinner based boards upgraded to 4.2.6
- Legacy kernel for Allwinner based boards upgraded to 3.4.110
- added new board: Udoo Neo
- added USB printer, CAN, CMA, ZSWAP, USB video class, CDROM fs, sensor classs, … to Allwinner mainline kernel
- armbian-install scripts rewrite. Now it’s possible to install to any partition.
- fixed nand install for Allwinner A10 based boards: Cubieboard 1 / Lime A10
- universal upgrade script bugfix / rewrite.
- 8 channel HDMI support for legacy Allwinner kernel
- unattended upgrade fixed
- sunxi tools fixed
- added two new options to build script: keep kernel config and use_ccache
- added kernel version to motd
v4.5 (2015-10-14)¶
- mainline kernel upgraded to 4.2.3 for Allwinner based boards
- legacy kernel for Allwinner compiled from new sources (linux-sunxi)
- udoo mainline upgraded to 4.2.3
- cubox / hummingboard upgraded to 3.14.54
- changed kernel naming: A10 = linux-image-sun4i, A20 = linux-image-sun7i
- new boards: Banana M2, Orange+(A31S), Cubieboard 1, Cubieboard 2 Dual SD, Lime A10
- fixed Udoo legacy wireless problems
- fixed Jessie boot problems by disabling systemd. It’s possible to re-enable within boot scripts
- added ramlog to Jessie because we don’t have systemd anymore
- changed wireless driver for Cubietruck and Banana PRO (now it’s ap6210)
- added ZRAM to mainline kernel
- fixed dvbsky modules
and a bunch of small fixes.
v4.4 (2015-10-01)¶
Images:
- mainline kernel upgrade to 4.2.2 (Allwinner, Udoo Quad),
- legacy kernel upgraded to 3.4.109 (Allwinner),
- added I2C support and bunch of multimedia modules (DVB) (mainline Allwinner),
- Udoo quad images with fixed legacy kernel 3.14.28,
- Cubox and Hummingboard kernel upgrade to 3.14.53,
- brcmfmac driver fixes for mainline kernel (Banana PRO / Cubietruck)
- performance tweak: choosing a closest Debian mirror (Debian images)
- added Astrometa DVB firmware and dvb-tools
- added Nikkov SPDIF / I2S recent patch (legacy Allwinner)
- added patch for rtl8192cu: Add missing case in rtl92cu_get_hw_reg (Lamobo R1)
- bigger NAND boot partition on install
- install script bug fixes
Script:
- force apt-get update on older rootfs cache,
- image harden manipulation security,
- packages NAND/FAT/same version install faling fixed,
- image shrinking function rework,
- better packages installation install checking,
- added Debian keys to suppress warnings in debootstrap process,
- added fancy progress bars,
- added whiptail downloading prior to usage (bugfix).
v4.3 (2015-09-17)¶
- kernel 4.2 for Allwinner based boards
- kernel 4.2 for Udoo Quad
- walk-around if ethernet is not detected on some boards due to RTC not set(?)
- update is done (semi) automatic if you are using Armbian 4.2. You only need to issue command: apt-get update && apt-get upgrade. If you are coming from older system, check Documentation
- U-boot on R1 is now updated to latest stable version (2015.07)
- Fixed AW SOM. Working with latest u-boot but you need to build image by yourself.
- Enabled whole USB net and HID section in kernel for Allwinner boards v4.2
- Fixed upgrade script – only some minor bugs remains.
- Fixes to build script that it’s working under Ubuntu 15.04
- Adding Bananapi Wireless driver (ap6210) back to legacy kernel
- Udoo official kernel (3.14.28) not updated due too many troubles.
v4.2 (2015-09-01)¶
Images:
- Upgraded NAND / SATA installer. Possible to install to SATA/NAND boot in one step.
- Easy kernel switching between old 3.4 and 4.x
- Automatic kernel updating (to disable comment armbian repo /etc/apt/sources.list)
- Allwinner boards share one 4.x kernel and two 3.4
- All boards share the same revision number
- One minimal Ubuntu Desktop per board (Wicd, Firefox, Word)
- u-boot v2015.07 for most boards
- Aufs file system support
- kernel 4.1.6 and 3.4.108
- Added Orangepi Mini, Cubieboard 1 (4.x only), Udoo with official kernel
- Repository for Wheezy, Jessie and Trusty
- enabled USB audio in kernel 4.x
- kernel headers fixed. No need to rebuild when you update the kernel.
- fixed boot scripts that can load from FAT partition too
- removed Cubox binnary repository because of troubles
- Docker support (kernel 4.x). Already here for a while / forget to mention.
- nodm change default login
Build script:
- changed structure: sources now in folder sources, output is what we produce, deb in one folder
- expanded desktop part
- possible to build all images at once, create package repository
- SD card initial size is 4Gb, variable transfered into configuration.sh
- Avaliable board list is now created from file configuration.sh
- Fixed image shrinking problem
- Patching part rework
- Using first FAT boot partition now fixes boot scripts
- Uboot TAG moved to configuration.sh and differs for some boards
- new variables for source branches. Only too remove errors when checking out
v4.1 (2015-08-05)¶
- Added desktop image
- U-Boot 2015.07 with many new features
- Added auto system update via repository apt.armbian.com
- Root password change is initialized at first boot.
- 3.4.108 kernel fixes, 4.1.4 Allwinner Security System
v4.0 (2015-07-12)¶
- Fixed stability issues, temperature display in 4.x
- Kernel upgrades to 3.4.108 and 4.1.2
v3.9 (2015-06-11)¶
- Bugfix release
- Kernel 4.0.5 traffic control support
- SATA / USB install fixed on kernel 4.x
- Added 256Mb emergency swap area, created automatically @first boot
v3.8 (2015-05-21)¶
- Bugfix release: Cubietruck images successfully booted on Cubietruck. I waited for automatic reboot than tested remote login.
- Kernel 4.0.4 added support for power on/off button
- Both: Jessie fixed, Ethernet init fixed (uboot)
- armbian.com introduction
v3.7 (2015-05-14)¶
- Kernel 4.0.3 some new functionality
- Kernel 3.4.107 added sunxi display manager to change FB on demand
- Both: Ubuntu and jessie install errors fixed, removed busybox-syslogd and changed to default logger due to problems in Jessie and Ubuntu, apt-get upgrade fixed, documentations update, Uboot fixed to 2015.4 – no more from dev branch
- Build script rework - image size shrink to actual size, possible to have fat boot partition on SD card, several script bug fixes
v3.6 (2015-04-29)¶
- Kernel 3.19.6
- Kernel 3.4.107 with better BT loading solution
v3.5 (2015-04-18)¶
- Kernel 3.19.4: fixed AP mode, fixed USB, added 8192CU module
- Common: apt-get upgrade ready but not enabled yet, serial console fixed, fixed hostapd under jessie, easy kernel switching, latest patched hostapd for best performance – normal and for realtek adaptors, auto IO scheduler script
- Build script: everything packed as DEB
v3.4 (2015-03-28)¶
- Kernel 3.19.3: docker support, apple hid, pmp, nfsd, sata peformance fix
- Kernel 3.4.106: pmp, a20_tp - soc temp sensor
- Common: console setup fixed, headers bugfix, nand install fix
- Build script: kernel build only, custom packets install, hardware accelerated desktop build as option
v3.3 (2015-02-28)¶
- Kernel 3.19.0: many new functionality and fixes.
- Bugfixes: CT wireless works in all kernels
v3.2 (2015-01-24)¶
- Possible to compile external modules on both kernels
- Kernel 3.19.0 RC5
- Bugfixes: install script, headers, bashrc, spi
v3.1 (2015-01-16)¶
- Kernel 3.19.0 RC4
- Added Cubieboard 1 images
- Dualboot for CB2 and CT dropped due to u-boot change. Now separate images.
- New user friendly SATA + USB installer, also on mainline
v3.0 (2014-12-29)¶
- Kernel 3.18.1 for mainline image
- Added Ubuntu Trusty (14.04 LTS) image
- Bugfixes: auto packages update
v2.9 (2014-12-03)¶
- Kernel 3.4.105 with new MALI driver and other fixes
- Added: Jessie image
- Major build script rewrite - much faster image building
- Fixed: failed MIN/MAX settings
v2.8 (2014-10-17)¶
- Added: ondemand governor, fhandle, squashfs and btrfs
- Removed: bootsplash, lvm, version numbering in issue
- Fixed: custom scripts, Jessie upgrade
- Disabled: BT firmware loading, enable back with: insserv brcm40183-patch
- Added working driver for RT 8188C, 8192C
v2.7 (2014-10-01)¶
- Kernel 3.4.104
- Automatic Debian system updates
- VGA output is now default but if HDMI is attached at first boot than it switch to HDMI for good. After first restart!
- Fixed NAND install script. /boot is mounted by default. Kernel upgrade is now the same as on SD systems.
- Cubieboard2 - disabled Cubietruck dedicated scripts (BT firmware, LED disable)
- Added network bonding and configuration for “notebook” mode (/etc/network/interfaces.bonding)
- IR receiver is preconfigured with default driver and LG remote (/etc/lirc/lircd.conf), advanced driver is present but disabled
- Added SPI and LVM functionality
- Added Debian logo boot splash image
- Added build essentials package
v2.6 (2014-08-22)¶
- Kernel 3.4.103 and 3.17.0-RC1
- Added GPIO patch (only for 3.4.103)
v2.5 (2014-08-02)¶
- Kernel 3.4.101 and 3.16.0-RC4
- major build script rewrite
v2.4 (2014-07-11)¶
- Kernel 3.4.98
- default root password (1234) expires at first login
- build script rewrite, now 100% non-interactive process, time zone as config option
- bug fixes: removed non-existing links in /lib/modules
v2.3 (2014-07-02)¶
- Kernel 3.4.96
- cpuinfo serial number added
- bug fixes: stability issues - downclocked to factory defaults, root SSH login enabled in Jessie, dedicated core for eth0 fix
- disp_vsync kernel patch
v2.2 (2014-06-26)¶
- Kernel 3.4.94
- Added Jessie distro image
- Updated hostapd, bashrc, build script
- bug fixes: disabled upgrade and best mirror search @firstboot, bluetooth enabler fix
- MD5 hash image protection
v2.1 (2014-06-13)¶
- Kernel 3.4.93
- Onboard Bluetooth finally works
- Small performance fix
- Allwinner Security System cryptographic accelerator
v2.0 (2014-06-02)¶
- Kernel 3.4.91 with many fixes
- Cubieboard 2 stability issues fix
- eth0 interrupts are using dedicated core
- Global bashrc /etc/bash.bashrc
- Verbose output and package upgrade @ first run
v1.9 (2014-04-27)¶
- Kernel headers included
- Clustering support
- Advanced IR driver with RAW RX and TX
- Bluetooth ready (working only with supported USB devices)
- Bugfixes: VLAN, login script, build script
- New packages: lirc, bluetooth
v1.8 (2014-03-27)¶
- Kernel 3.4.79
- Alsa I2S patch + basic ALSA utils
- Performance tweaks: CPU O.C. to 1.2Ghz, IO scheduler NOOP for SD, CFQ for sda, journal data writeback enabled
- Avaliable memory = 2000MB
- Minimized console output at boot
- MAC address from chip ID, manual optional
- Latest (Access point) hostapd, 2.1 final release
- Login script shows current CPU temp, hard drive temp & actual free memory
- Fastest Debian mirror auto selection @first boot
- New packages: alsa-utils netselect-apt sysfsutils hddtemp bc
v1.7 (2014-02-26)¶
- Flash media performance tweaks, reduced writings, tmp & logging to RAM with ramlog app – sync logs on shutdown
- SATA install script
- Dynamic MOTD: Cubieboard / Cubietruck
- Disabled Debian logo at startup
- New packages: figlet toilet screen hdparm libfuse2 ntfs-3g bash-completion
v1.6 (2014-02-09)¶
- Added support for Cubieboard 2
- Build script creates separate images for VGA and HDMI
- NAND install script added support for Cubieboard 2
v1.52 (2014-02-07)¶
- Various kernel tweaks, more modules enabled
- Root filesystem can be moved to USB drive
- Bugfixes: NAND install script
v1.5 (2014-01-22)¶
- Hotspot Wifi Access Point / Hostapd 2.1
- Bugfixes: MAC creation script, SSH keys creation, removed double packages, …
- Graphics desktop environment upgrade ready
v1.4 (2014-01-12)¶
- Patwood’s kernel 3.4.75+ with many features
- Optimized CPU frequency scaling 480-1010Mhz with interactive governor
- NAND install script included
- Cubietruck MOTD
- USB redirector – for sharing USB over TCP/IP
v1.3 (2014-01-03)¶
- CPU frequency scaling 30-1000Mhz
- Patch for gpio
v1.23 (2014-01-01)¶
- added HDMI version
- added sunxi-tools
- build.sh transfered to Github repository
- disabled LED blinking
v1.2 (2013-12-26)¶
- changed kernel and hardware config repository
- kernel 3.4.61+
- wi-fi working
- updated manual how-to
v1.0 (2013-12-24)¶
- total memory available is 2G (disabled memory for GPU by default)
- gigabit ethernet is fully operational
- sata driver enabled
- root filesystem autoresize
- MAC address fixed at first boot
- Kernel 3.4.75
- root password=1234
- Bugs: wifi and BT not working
