Armbian Build Framework Quick Start Guide¶
Requirements¶
- x86_64 / aarch64 machine
- at least 2GB of memory and ~35GB of disk space for VM, container or bare metal installation
- Armbian / Ubuntu Jammy 22.04.x for native building or any Docker capable Linux for containerised
- Windows 10/11 with WSL2 subsystem running Armbian / Ubuntu Jammy 22.04.x
- Superuser rights (configured sudo or root access).
- Make sure your system is up-to-date! Outdated Docker binaries, for example, can cause trouble
- Install git (apt-get -y -qq install git)
Danger
Make sure that full path to the build script does not contain spaces.
Clone repository:
| Bash | |
1 2 | |
Interactive¶
Run framework:
| Bash | |
1 | |
graph LR
A[./compile.sh] --> B{Change<br>kernel<br>config};
B ---> |yes| C["HW"];
B ---> |no| C["HW"];
C ---> |branch| D["legacy<br>vendor<br>current<br>edge"];
D --> |base| E["Debian<br>Ubuntu"];
E ---> |type| F["CLI"];
F ---> |type| G["Server"];
F ---> |type| H["Minimal"];
E ---> I["Desktop"];
I ---> K["XFCE"];
I ---> L["Gnome"];
I ---> M["Cinammon"];
I ---> N["KDE Neon"];
Video instructions: https://www.youtube.com/watch?v=kQcEFsXEJEE
CLI¶
Comprehensive list of build Options
Example:
| Bash | |
1 2 3 4 5 6 7 8 9 10 | |
Interpretation?
This command will generate Ubuntu 24.04 Noble based Gnome desktop environment image for Intel based hardware (uefi-x86). Besides bare desktop, it will contain packages from browsers and desktop_tool sections and it will use unchanged kernel from current kernel branch.
GitHub actions¶
If you do not own the proper equipment to build images on your own, you can use our GitHub action.
