How to customize keyboard, time zone?
  • Attention: The preferred method to change most of this stuff is by using the interactive armbian-config tool which is shipped with all Armbian images.
Keyboard:
Text Only
1
dpkg-reconfigure keyboard-configuration
In some cases, e.g. when your keyboard standard is not available in previous command, you may also need to set your keymap config:
Text Only
1
2
3
4
5
# Check your actual keymap config
localectl status | grep -i keymap
# Set the desired keymap config. Example below to 'br-abnt2'
localectl set-keymap br-abnt2
System language:
Text Only
1
2
3
4
# Debian --> https://wiki.debian.org/ChangeLanguage
dpkg-reconfigure locales
# Ubuntu --> https://help.ubuntu.com/community/Locale
update-locale LANG=[options] && dpkg-reconfigure locales
Console font, codepage:
Text Only
1
dpkg-reconfigure console-setup
Time zone:
Text Only
1
dpkg-reconfigure tzdata
Sound output:
Text Only
1
2
3
4
5
6
7
8
# Check the available sound output options:
pacmd list-sinks | less
# The default will be marked with "*"
# Press "q" to close
# Define the new default sound output
pacmd set-default-sink <NAME-OF-DESIRED-OPTION>
The name of HDMI sound output may change accordingly to the device. If you don’t wanna deal with different names you can:
Text Only
1
pacmd set-default-sink $(pactl list short sinks | grep -i 'hdmi' | awk '{print $2}')
The command to define the default sound output is not persistent, to make it persistent add it to the file ~/.bashrc
Screen resolution on other boards:
Text Only
1
2
3
4
5
6
7
8
9
nano /boot/boot.cmd
# example:
# change example from
# disp.screen0_output_mode=1920x1080p60
# to
# disp.screen0_output_mode=1280x720p60
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
Screen resolution within Xorg
Find matching HDMI output:
Text Only
1
xrandr --listmonitors
Calculate VESA CVT mode lines (example for 1440x900)
Text Only
1
cvt 1440 900
Sample output:
Text Only
1
2
1440x900 59.89 Hz (CVT 1.30MA) hsync: 55.93 kHz; pclk: 106.50 MHz
Modeline "1440x900_60.00"  106.50  1440 1528 1672 1904  900 903 909 934 -hsync +vsync )
Create new mode (example):
Text Only
1
xrandr --newmode "1440x900_60.00" 106.50 1440 1528 1672 1904 900 903 909 934 -hsync +vsync
Add resolution (example):
Text Only
1
xrandr --addmode HDMI-1 1440x900_60.00
Set current resolution (example):
Text Only
1
xrandr --output HDMI-1 --mode 1440x900_60.00
If it works as expected add it to Xorg by editing /etc/X11/xorg.conf.d/40-monitor.conf and add (example):
Text Only
1
2
3
4
5
Section "Monitor"
Identifier "HDMI-1"
Option "PreferredMode" "1440x900"
EndSection
Restart Xorg or reboot
How to alter CPU frequency?
Some boards allow to adjust CPU speed
Text Only
1
nano /etc/default/cpufrequtils
Alter min_speed or max_speed variable.
Text Only
1
systemctl restart cpufrequtils
Swap for experts
By default Armbian implements ZRAM (writing nothing to ‘disk’ but compressing memory pages in RAM) but in case you often run into out of memory errors and your device has some capable storage (e.g. a securely attached NVMe or SATA SSD) you might want to use ZSWAP instead.
Check whether your kernel has zswap enabled (dmesg | grep zswap should output something) and if so create a swapfile or swap partition the traditional way, edit/uncomment /etc/default/armbian-zram-config so that it reads SWAP=false, reboot and you’re done.
Zswap performs a lot better than the combination of ZRAM and ‘swap on disk’ in parallel.
How to downgrade a package via apt?
This is useful when you need to fall back to previous kernel version.
Text Only
1
apt install linux-image-sun8i=5.13
This example is for H3 legacy kernel. Check this page for others.
How to toggle boot output?
Edit and change boot parameters in /boot/boot.cmd (not recommended) or variables in /boot/armbianEnv.txt:
Text Only
1
2
- console=both
+ console=serial
To disable console entirely (not recommended) set console to none.
Recompile boot.cmd to boot.scr if it was changed:
Text Only
1
Reboot.
Serial console on imx6 boards are ttymxc0 (Hummingboard, Cubox-i) or ttymxc1 (Udoo).
How to toggle verbose boot?
Using Armbian 5.05 to 5.20 you would need to touch/rm /boot/.force-verbose to increase boot verbosity. With more recent Armbian builds you would have to alter the verbosity= line in /boot/armbianEnv.txt (defaults to 1 which means less verbose, maximum value is 7).
How to provide boot logs for inspection?
When your SBC behaves strange first step is to check power supply and integrity of boot media (armbianmonitor -c "$HOME"). Then look into your kernel logs. We made a tool that grabs info and pastes it to an online pasteboard service. Please increase boot verbosity as shown above (verbosity=7), reboot and then run
Text Only
1
sudo armbianmonitor -u
Copy and past URL of your log to the forum, mail, …
How to change network configuration?
To get Wi-Fi working simply use nmtui, a simple console based UI for network-manager (an example how to set up an AP with network-manager can be found here). To deal with different Ethernet/Wi-Fi combinations there are six predefined configurations available, you can find them in those files:
Text Only
1
2
3
4
5
6
/etc/network/interfaces.bonding
/etc/network/interfaces.default
/etc/network/interfaces.hostapd
/etc/network/interfaces.network-manager
/etc/network/interfaces.r1
/etc/network/interfaces.r1switch
By default /etc/network/interfaces is a copy of /etc/network/interfaces.default
  1. BONDING: your network adapters are bonded in fail safe / “notebook” way.
  2. DEFAULT: your network adapters are connected classical way.
  3. HOSTAPD: your network adapters are bridged together and bridge is connected to the network. This allows you to have your AP connected directly to your router.
  4. All interfaces are handled by network-manager (nmtui/nmcli or using the GUI)
  5. Router configuration for Lamobo R1 / Banana R1.
  6. Switch configuration for Lamobo R1 / Banana R1.
You can switch configuration with copying.
Text Only
1
2
cd /etc/network
cp interfaces.x interfaces
(x = default,hostapd,bonding,r1)
Then check / alter your interfaces:
Text Only
1
nano /etc/network/interfaces
Choosing an apt mirror
Armbian has its own apt repository and mirrors for armbian-specific packages. The default of http://apt.armbian.com is a round-robin to all mirrors. If you are having trouble updating or slow speeds you may want to choose a specific mirror.
Do the following:
Assure jq is installed
apt install -y jq
Get a list of available mirrors from our https://apt.armbian.com/mirrors endpoint.
Bash
1
curl -s http://apt.armbian.com/mirrors|jq
You will see a result set similar to this, listing mirrors by region:
JSON
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
  "AS": [
    "https://mirrors.tuna.tsinghua.edu.cn/armbian/",
    "https://minio.k-space.ee/armbian/apt/"
  "NA": [
    "https://armbian.tnahosting.net/apt/",
    "https://us.mirrors.fossho.st/armbian/apt/"
  "EU": [
    "https://minio.k-space.ee/armbian/apt/",
    "https://armbian.systemonachip.net/apt/",
    "https://mirrors.netix.net/armbian/apt/",
    "https://mirrors.dotsrc.org/armbian-apt/",
    "https://armbian.hosthatch.com/apt/"
  "default": [
    "https://us.mirrors.fossho.st/armbian/apt/",
Edit /etc/apt/sources.list.d/armbian.list and replace the url http://apt.armbian.com with your preferred mirror.
