Important!
Following instructions are valid for next generation of Armbian config utility which is due for integration in Armbian v24.11. Until then please follow this installation instructions to test it out:
armbian/configng?tab=readme-ov-file#add--install-from-development-repository
Armbian Configuration Utility
Utility for configuring your board, adjusting services, and installing applications. It comes with Armbian by default.
To start the Armbian configuration utility, use the following command:
Text Only
1
sudo armbian-config
