Advanced Features¶
How to switch kernels?¶
Check this for more info.
How to troubleshoot?¶
How to unbrick the system?¶
Both of above headings have been moved to a new page and expanded upon: Recovery
How to build a wireless driver?¶
Install and recreate kernel headers scripts (optional)
Text Only | |
1 2 3 4 5 |
Go back to root directory and fetch sources (working example, use ARCH=arm64
on 64bit system)
Text Only | |
1 2 3 4 5 |
Refer to Linux Kernel Documentations: Building External Modules for more information.
Load driver for test
Text Only | |
1 |
Check dmesg
and the last entry will be:
Text Only | |
1 |
Plug the USB wireless adaptor and issue a command:
Text Only | |
1 |
You should see this:
Text Only | |
1 2 3 4 5 6 7 8 9 |
Check which wireless stations / routers are in range
Text Only | |
1 |
How to run Docker?¶
Docker works reliably with the distribution-provided builds. It is as simple as apt-get install docker.io
If you prefer to use the latest Docker builds provided directly by Docker, please follow the guide below.
Though if you run into trouble using those please revert back to distribution binaries before complaining.
Preinstallation requirements:
- Armbian 20.08.17 or newer with Kernel 3.10 or higher
- Debian Buster (might work elsewhere with some modifications)
- root access
This method is based on Docker Debian installation documentation. Execute this as root:
Bash | |
1 2 3 4 5 6 7 |
Test if Docker works correctly:
Bash | |
1 |
If you get that kind of output, then Docker install went fine:
Bash | |
1 2 |
If you would like to use Docker as a non-root user, you should now consider adding your user to the docker
group with something like:
Bash | |
1 |
You will have to log out, and log in once more in order to be able to run Docker without being root.
Let’s try a last test to see if a Docker container can be seen outside of your Armbian machine:
Bash | |
1 |
… and point the browser of any device in the same network to http://<IP OF YOUR DEVICE>/
How to set wireless access point?¶
There are two different HostAP daemons. One is default and the other one is for some Realtek wifi cards. Both have their own basic configurations and both are patched to gain maximum performances.
Sources: igorpecovnik/hostapd
Default binary and configuration location:
Text Only | |
1 2 |
Realtek binary and configuration location:
Text Only | |
1 2 |
Since its hard to define when to use which you always try both combinations in case of troubles. To start AP automatically:
- Edit /etc/init.d/hostapd and add/alter location of your conf file DAEMON_CONF=/etc/hostapd.conf and binary DAEMON_SBIN=/usr/sbin/hostapd
- Copy /etc/network/interfaces.hostapd to /etc/network/interfaces
- Reboot
- Predefined network name: “BOARD NAME” password: 12345678
- To change parameters, edit /etc/hostapd.conf BTW: You can get WPAPSK the long blob from wpa_passphrase YOURNAME YOURPASS
How to connect IR remote?¶
Required conditions:
- IR hardware
- loaded driver
Get your remote configuration (lircd.conf) or learn.
You are going to need the list of all possible commands which you can map to your IR remote keys:
Text Only | |
1 |
To start with learning process you need to delete old config:
Text Only | |
1 |
Then start the process with:
Text Only | |
1 |
And finally start your service when done with learning:
Text Only | |
1 |
Test your remote:
Text Only | |
1 |
Outdated¶
How to freeze your filesystem? (outdated)¶
In certain situations it is desirable to have a virtual read-only root filesystem. This prevents any changes from occurring on the root filesystem that may alter system behavior and it allows a simple reboot to restore a system to its clean state.
You need an ODROID XU4 or Allwinner A10, A20 or H3 board with legacy kernel where we added support for overlayfs. Works only on Ubuntu Xenial. Login as root and execute:
Text Only | |
1 2 3 |
After your system boots up it will always remain as is. If you want to make any permanent changes, you need to run:
Text Only | |
1 |
Changes inside this will be preserved.
