Build commands¶
kernel¶
Builds kernel and device tree (where applicable) and places it to the output/debs
Usage:
Bash | |
1 |
dts-check¶
Validate dts files and improve board & patch development overall.
This option validates the dts/dtb file for the selected board against the device tree bindings and outputs the validation logs to the user. It can be used when adding a new board, developing or improving a dts file.
Usage:
Bash | |
1 |
inventory-boards¶
Outputs a one-board-per-line CSV inventory of boards.
Sets TARGETS_FILE
to something that doesn’t exist, so the default-targets.yaml
is used (so same list for everyone, save for userpatched-boards)
Usage:
Bash | |
1 |
kernel-dtb¶
Builds only DTB and outputs full preprocessed dts source
Outputs preprocessed DTS source for the board in question to output/
also outputs the same preprocessed DTS source, ran through dtc
with input and output DTS formats for “normalized” comparisons
Usage:
Bash | |
1 |
rewrite-uboot-patches¶
Prepares git, applies patches to git, and rewrites them back from git same as kernel, it does git archeology for mbox-less patches, etc.
- uboot-patches-to-git alias is also added, but my guess is that the rewrite is more useful.
- refactor a common config function for both kernel and uboot.
Usage:
Bash | |
1 |
targets¶
Generates output/info/git_sources.json file containing URL, branch, and commit hash combo.
The easiest way to generate file for all devices is to run ./compile.sh targets
. Then, at the time of release, we will copy the output/info/git_sources.json file to config/sources/git_sources.json. Once the file is copied, the hash information from the file will be used to fetch resources for git repositories where branches are specified instead of tags or commits.
Usage:
Bash | |
1 |
Build options¶
These parameters are meant to be applied to the ./compile.sh
command. They are all optional. They can also be added to your build configuration file to save time. Default values are marked bold if applicable.
Main options¶
- NETWORKING_STACK ( string ) - network-manager - systemd-networkd - none (to not-add any networking extensions)
Installs desired networking stack. If the parameter is undefined, it sets systemd-networkd
for minimal images (MINIMAL=yes) and network-manager
for the rest. Time synchronization is also changed; chrony is installed with network-manager, while systemd-timesyncd is used with systemd-networkd. In both cases, we control network settings using Netplan.
- DOCKER_ARMBIAN_BASE_IMAGE ( string ) - ubuntu:jammy - ubuntu:noble - debian:bookworm
Defines the build host when using a Docker container (default). Here, you can see which other options are available.
- CI ( string )
- true
- false
If enabled (true
), the Docker build container will receive Docker credentials from the host
(${HOME}/.docker/config.json
) and the OCI_TARGET_BASE
environment variable.
- OCI_TARGET_BASE ( string )
- url/to/container_registry/path
- ${GHCR_SOURCE}/armbian/* (GHCR_SOURCE is defined in
lib/functions/configuration/main-config.sh
Select the target for pull/push OCI cached images. If not set, default is used.
- GHCR_MIRROR_ADDRESS (string)
The default mirror address for ghcr.io, set by GHCR_MIRROR=dockerproxy
, is ghcr.dockerproxy.com. When this address is unavailable, an alternative address can be set with GHCR_MIRROR_ADDRESS
Example:
Text Only | |
1 |
- KERNEL_COMPILER (string)
The compiler used to compile the kernel. Usually, this option is set by the board config, but it can be set to clang
to use LLVM to compile the kernel.
Example:
Text Only | |
1 |
- OPENSSHD_REGENERATE_HOST_KEYS (boolean) - false (skip armbian-firstrun’s OpenSSH host keys deletion and regeneration (eg: to let cloud-init set the SSH host keys) - true (execute armbian-firstrun’s OpenSSH host keys deletion + regeneration)
Manage OpenSSH host key regeneration at armbian-firstrun service.
Example:
Text Only | |
1 |
Build options below need to be retested and added above (COULD BE DEPRECATED)¶
DO NOT USE! Obsolete documentation, new documentation in progress.
- BUILD_ONLY (comma-separated list): defines what artifacts should be built. The default value is an empty string - it will build all artifacts. Changing this option can be useful to build partial artifacts only. - u-boot: build U-Boot - kernel: build kernel - armbian-config: build Armbian config - armbian-zsh: build Armbian zsh - plymouth-theme-armbian: build Armbian Plymouth theme - armbian-firmware: build Armbian firmware - armbian-bsp: build Armbian board support package - chroot: build additional packages - bootstrap: build bootstrap package - default: build full OS image for flashing
- KERNEL_CONFIGURE ( string or boolean ):
- prebuilt: use precompiled packages (only for maintained hardware)
- yes: automatically call kernel’s
make menuconfig
(add or remove modules or features) - no: use provided kernel configuration provided by Armbian - leave empty to display the selection dialog each time - CLEAN_LEVEL (comma-separated list): defines what should be cleaned. Default value is
"make,debs"
- clean sources and remove all packages. Changing this option can be useful when rebuilding images or building more than one image - make-atf = make clean for ATF, if it is built. - make-uboot = make clean for uboot, if it is built. - make-kernel = make clean for the kernel if it is built. very slow.
important: “make” by itself has been disabled since Armbian now knows how to handle Make timestamping.
- debs, alldebs = delete all packages in “./output/debs” - images = delete “./output/images” - cache = delete “./output/cache” - sources: deletecache/sources
(all downloaded sources) - oldcache = remove old cached rootfs except for the newest 8 files - extras: delete additional packages for the current release inoutput/debs/extra
- REPOSITORY_INSTALL (comma-separated list): list of core packages that will be installed from the repository
- Available options:
u-boot
,kernel
,bsp
,armbian-bsp-cli
,armbian-bsp-desktop
,armbian-desktop
,armbian-config
,armbian-firmware
- Set to “” to use packages one from local output or build if not available - KERNEL_KEEP_CONFIG ( yes | no ): - yes: use kernel config file from previous compilation for the same branch, device family, and version - no: use default or user-provided config file
- BUILD_MINIMAL ( yes | no ):
- yes: build a bare CLI image suitable for application deployment. This option is not compatible with
BUILD_DESKTOP="yes"
andBUILD_EXTERNAL="yes"
- no: default CLI package selection - BUILD_DESKTOP ( yes | no ): - yes: build an image with a minimal desktop environment - no: build image with console interface only
- EXTERNAL ( yes | no ): - yes: compile and install extra applications and firmware
- BSPFREEZE ( yes | no ): - yes: freeze (from update) armbian packages when building images (U-Boot, kernel, DTB)
- INSTALL_HEADERS ( no | yes ): - yes: install kernel headers
- EXTERNAL_NEW ( no | prebuilt | compile ): - prebuilt: install extra applications from the repository - compile: compile extra applications in chroot
- CREATE_PATCHES ( yes | no )
Warning: This option is deprecated and may be removed in future releases - use the new
kernel-patch
/uboot-patch
/atf-patch
CLI commands instead. - yes: prompt right before the compilation starts to make changes to the source code for both U-Boot and kernel. From these changes, patch files will be created and placed in theoutput
directory. If you want these patches included in a normal run (without CREATE_PATCHES to say), these files must be copied to the appropriate directories. Also, see user-provided patches. - BUILD_ALL ( yes | no | demo ): cycle through all available board and kernel configurations and make images for all combinations
- CARD_DEVICE ( /dev/sdX ): set to the device of your SD card. The image will be burned and verified using Etcher for CLI.
- EXT=rkdevflash to flash Rockchip images to eMMC either during image build or separately with flash CLI command (only works bare Linux, not Docker)
- CRYPTROOT_ENABLE ( yes | no ): enable LUKS encrypted rootfs
CRYPTROOT_PASSPHRASE="MYSECRECTPASS"
mandatory -CRYPTROOT_SSH_UNLOCK=yes
Default:yes
-CRYPTROOT_SSH_UNLOCK_PORT=2222
Default:2022
-CRYPTROOT_PARAMETERS="custom cryptsetup options"
Default:--pbkdf pbkdf2
(May not contain=
; separate with spaces) - Note: This function might not work well with all distributions. Debian Buster and Stretch were tested. For building under Docker, you have to use privileged mode, which can be enabled inuserpatches/config-docker
. - Warning: This feature was added as a community contribution and is mostly functional. Under some circumstances, though, the prompt will not be shown. Therefore, it should be considered experimental. Check here and here - Hint: If you want to do the encryption part from scratch, check out this forum post.
Hidden options to minimize user input for build automation¶
- BOARD (
string
): set the name of the board manually to skip the dialog prompt - BRANCH (
legacy
|current
|edge
): set kernel and U-Boot branch manually to skip dialog prompt; some options may not be available for all devices - RELEASE (
bullseye
|bookworm
|jammy
): set OS release manually to skip dialog prompt; use this option withKERNEL_ONLY=yes
to create board support package - ARMBIAN_CACHE_ROOTFS_PATH (
string
): bind mount cache/rootfs to defined folder - ARMBIAN_CACHE_TOOLCHAIN_PATH (
string
): bind mount cache/toolchain path to defined folder
Hidden options for advanced users (default values are marked bold)¶
- EXPERT ( yes | no ): show development features and boards regardless of their status in interactive mode
- USERPATCHES_PATH ( userpatches/ ): set alternate path for the location of the
userpatches
folder - USE_CCACHE ( yes | no ): use a C compiler cache to speed up the build process
- PRIVATE_CCACHE ( yes | no ): use
$DEST/ccache
as ccache home directory - SKIP_EXTERNAL_TOOLCHAINS ( yes | no ): don’t download and use Linaro toolchains, by default placed in cache/toolchain (and configurable with ARMBIAN_CACHE_TOOLCHAIN_PATH)
- PROGRESS_DISPLAY ( none | plain | dialog ): way to display output of verbose processes - compilation, packaging, debootstrap
- PROGRESS_LOG_TO_FILE ( yes | no ): duplicate output, affected by the previous option, to log files
output/debug/*.log
- NO_APT_CACHER ( yes | no ): disable usage of APT cache. Default
yes
in containers, but can be overridden - DISABLE_IPV6 ( true | false ): The distant future, the year Two-Thousand. Set false to allow Aria2c to use a modern ip protocol.
- NO_HOST_RELEASE_CHECK ( yes | no ): overrides the check for a supported host system
- USE_MAINLINE_GOOGLE_MIRROR ( yes | no ): use the
googlesource.com
mirror for downloading mainline kernel sources, which may be faster thangit.kernel.org
depending on your location - USE_GITHUB_UBOOT_MIRROR ( yes | no ): use an unofficial GitHub mirror for downloading mainline U-Boot sources, may be faster than
git.denx.de
depending on your location - SYNC_CLOCK ( yes | no ): sync system clock on builder before start image creation process
- OFFLINE_WORK ( yes | no ): skip downloading and updating sources and time and host check. Set to “yes,” and you can collect packages without accessing the internet
- FORCE_USE_RAMDISK ( yes | no ): overrides autodetect for using tmpfs in new debootstrap and image creation process
- FIXED_IMAGE_SIZE (
integer
): create an image file of this size (in megabytes) instead of minimal - BOOTSIZE (
integer
96 ): set size (in megabytes) for separate /boot filesystem. Used if ROOTFS_TYPE set to non-ext4 - COMPRESS_OUTPUTIMAGE (comma-separated list): create a compressed archive with an image file and GPG signature for redistribution
- sha: generate SHA256 hash for image
- gpg: sign image using gpg
- 7z: compress image, hash, and signature to 7z archive
- gz: compress image only using gz format
- xz: compress image only using xz format
- yes: compatibility shortcut for
sha,gpg,7z
- IMAGE_XZ_COMPRESSION_RATIO ( 1 - 9 ) images compression levels when using xz compressor. Beware of memory consumption when going higher
- SEVENZIP ( yes | no ): create .7z archive with extreme compression ratio instead of .zip
- BUILD_KSRC ( yes | no ): create kernel source packages while building…
- INSTALL_KSRC ( yes | no ): … and pre-install these kernel sources on the image
- ROOTFS_TYPE ( ext4 | f2fs | btrfs | nilfs2 | xfs | nfs ): create image with different root filesystems instead of default
ext4
. Requires settingFIXED_IMAGE_SIZE
to something smaller than the size of your SD card forF2FS
- BTRFS_COMPRESSION ( lzo | none | zlib | zstd ): when choosing
ROOTFS_TYPE=btrfs
, selectbtrfs
filesystem compression method and compression level. By default, the compression iszlib
When selectingzstd
or setting zlib compression level(zlib:[1-9]
) user must ensure kernel version is >=4.14.x.
When selecting the zstd compression level (zstd:[1-15]
), both the host and the target kernel version must be >=5.1.x since the kernel started supporting the zstd compression ratio only from 5.1 on.
Note: The script does not check the legality of the input variable (compression ratio). Input likezlib:1234
is legal to the script but illegal to the kernel. Beware that setting this option does affect image creation only (shrinking disk size) and will not adjust/etc/fstab
, so it is up to the user to later edit/etc/fstab
if compression in daily operation is also wanted (beware of severe performance penalties with random IO patterns and heavy compression algorithms!). - FORCE_BOOTSCRIPT_UPDATE ( yes | no ): - yes: force bootscript to get updated during bsp package upgrade
- NAMESERVER (
IPv4 address
): the DNS resolver used inside the build chroot. Does not affect the final image. Default:1.0.0.1
- DOWNLOAD_MIRROR (
china
|bfsu
): select download mirror fortoolchain
anddebian/ubuntu packages
-china
: usemirrors.tuna.tsinghua.edu.cn
; it will be very fast thanks to Tsinghua University -bfsu
: usemirrors.bfsu.edu.cn
, the mirror of Beijing Foreign Studies University
- leave empty to use official source - ARMBIAN_MIRROR (auto): override automated mirror selection, example ‘ARMBIAN_MIRROR=”https://yourlocalmirror.com”‘
- MAINLINE_MIRROR (
google
|tuna
|bfsu
): select mainline mirror oflinux-stable.git
-google
: use the mirror provided by Google, the same asUSE_MAINLINE_GOOGLE_MIRROR=yes
-tuna
: use the mirror provided by Tsinghua University -bfsu
: use the mirror provided by Beijing Foreign Studies University, which is similar totuna
- leave empty to use the officialgit.kernel.org
, which may be very slow for mainland China users - UBOOT_MIRROR (
github
|gitee
: select mainline mirror ofu-boot.git
-github
: use the mirror provided by github, the same asUSE_GITHUB_UBOOT_MIRROR=yes
-gitee
: use the mirror provided by Gitee, a Chinese git services - leave empty to use the officialsource.denx.de
, which may be very slow for mainland China users - GITHUB_MIRROR (
fastgit
|gitclone
|cnpmjs
): select download mirror for GitHub hosted repository -fastgit
: use the mirror provided by fastgit.org -gitclone
: use the mirror provided by gitclone.com -cnpmjs
: use the mirror provided by cnpmjs.org - leave empty to connect directly to GitHub, which may be very slow for mainland China users - REGIONAL_MIRROR (
china
): select mirrors based on regional setting, will not overwrite explicitly specified mirror option -china
: MAINLINE_MIRROR=tuna
, UBOOT_MIRROR=gitee
, GITHUB_MIRROR=fastgit
, DOWNLOAD_MIRROR=china
- leave empty to use default settings - USE_TORRENT ( yes | no ): use torrent to download toolchains and rootfs
- ROOT_FS_CREATE_ONLY ( yes | no ): set to yes to force local cache creation
- EXTRAWIFI ( yes | no ): include several drivers for WiFi adapters
- WIREGUARD ( yes | no ): include Wireguard for kernels before it got upstreamed to mainline. Will lose functionality soon.
- AUFS ( yes | no ): include support for AUFS
- SKIP_BOOTSPLASH ( yes | no ): use kernel bootsplash. Disable in case of troubles
- CONSOLE_AUTOLOGIN ( yes | no ): automatically login as root for local consoles. Disable if your security threat model requires.
- EXT (
fake-vcgencmd
): execute extension during the build -fake-vcgencmd
: include fake vcgencmd to monitor and control boards from Android - INCLUDE_HOME_DIR ( yes | no ): include directories created inside /home in final image.
