  "schema": "armbian/board-performance/v1",
  "source": "https://github.com/armbian/autotests",
  "run_url_template": "https://github.com/armbian/autotests/actions/runs/{run_id}",
  "generated": "2026-10-06T15:03:23Z",
  "boards_total": 64,
  "boards_skipped_no_passing_run": [
    "khadas-vim1s",
    "nanopi-r2s"
  "boards_skipped_no_measurements": [],
  "boards": [
      "board_slug": "arduino-uno-q",
      "device": "Arduino UNO Q 01",
      "last_good_test": "2026-10-06T13:31:41Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/37469960611",
      "image_version": "26.11.0-trunk.73",
      "kernel": "7.2.3-edge-qrb2210",
      "cpu": {
        "max_mhz": 2016,
        "aes_MBs": 931,
        "temp_C": 44.0,
        "governor": "schedutil",
        "min_mhz": 300,
        "peak_mhz": 2016,
        "tested": "2026-10-06T13:31:41Z",
        "run_id": "37469960611"
      "memory": {
        "copy_MBs": 5100,
      "storage": {
        "read_MBs": 258,
        "write_MBs": 184,
      "network": {
        "interfaces": [
            "interface": "usb0",
            "wireless": false
            "interface": "wlan0",
            "type": "IEEE 802.11ac (Wi-Fi 5)",
            "up_mbits": 15,
            "down_mbits": 22,
            "wifi_chip": "Qualcomm WCN3990",
            "channel_mhz": 5240,
            "channel_width_mhz": 80,
            "wireless": true
      "summary": {
        "cpu_mhz": 2016,
        "cpu_aes_MBs": 931,
        "ethernet_mbits": 0,
        "ethernet_interfaces": 1,
        "wifi_mbits": 22,
      "board_slug": "bananapicm4io",
      "device": "Banana Pi CM4IO 01",
      "last_good_test": "2026-10-06T13:39:37Z",
      "image_version": "26.8.1",
      "kernel": "7.2.9-edge-meson64",
      "cpu": {
        "max_mhz": 2016,
        "aes_MBs": 1365,
        "temp_C": 65.6,
        "governor": "performance",
        "min_mhz": 1000,
        "peak_mhz": 2400,
        "tested": "2026-10-06T13:39:37Z",
      "memory": {
        "copy_MBs": 6200,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 8,
      "network": {
        "interfaces": [
            "interface": "end0",
            "type": "1000BASE-T (1GE)",
            "up_mbits": 937,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 43,
            "down_mbits": 28,
            "wifi_chip": "Realtek RTL8822CS",
            "wifi_attach": "SDIO",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 2.0,
        "avg": 4.92,
        "max": 11.2,
        "samples": 830,
        "series": [
          4.14,
          5.92,
          4.43,
          4.82,
          5.13,
          4.23,
          5.59,
          4.35,
          5.03,
          4.66,
          3.99,
          4.42,
          5.11,
          3.48,
          4.7,
          4.4,
          4.88,
          6.3,
          4.84,
          4.86,
          5.17,
          5.24,
          4.95,
          4.86,
          5.22,
          5.0,
          4.16,
          4.72,
          4.12,
          5.46,
          6.1,
          5.42,
          5.25,
          5.27,
          6.32,
          4.94,
          5.46,
          5.4,
          3.62,
          4.68
      "summary": {
        "cpu_mhz": 2016,
        "cpu_aes_MBs": 1365,
        "ethernet_mbits": 941,
        "wifi_mbits": 43,
        "power_min_w": 2.0,
        "power_max_w": 11.2
      "board_slug": "bananapif3",
      "device": "BananaPi BPI-F3 01",
      "last_good_test": "2026-09-23T10:34:48Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/35845171896",
      "image_version": "26.11.0-trunk.56",
      "kernel": "7.2.7-edge-spacemit",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 30,
        "temp_C": 58.0,
        "min_mhz": 614,
        "peak_mhz": 1800,
        "tested": "2026-09-23T10:34:48Z",
        "run_id": "35845171896"
      "memory": {
        "copy_MBs": 3400,
      "storage": {
        "read_MBs": 83,
        "write_MBs": 62,
      "network": {
        "interfaces": [
            "interface": "eth0",
            "up_mbits": 939,
            "down_mbits": 938,
            "wireless": false
            "type": "IEEE 802.11ax (Wi-Fi 6)",
            "up_mbits": 308,
            "down_mbits": 323,
            "wifi_chip": "Realtek RTL8852BS",
            "wireless": true
            "interface": "wlan1",
            "up_mbits": 274,
            "down_mbits": 253,
            "wifi_chip": "Realtek RTL8822BU",
            "wifi_attach": "USB",
            "wireless": true
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 30,
        "ethernet_mbits": 939,
        "wifi_mbits": 323,
      "board_slug": "bananapim2pro",
      "device": "Banana Pi M2Pro 01",
      "last_good_test": "2026-10-06T13:45:52Z",
      "cpu": {
        "max_mhz": 2100,
        "aes_MBs": 979,
        "temp_C": 53.5,
        "governor": "ondemand",
        "min_mhz": 1000,
        "peak_mhz": 2100,
        "tested": "2026-10-06T13:45:52Z",
      "memory": {
        "copy_MBs": 5300,
      "storage": {
        "read_MBs": 157,
        "write_MBs": 42,
      "network": {
        "interfaces": [
            "up_mbits": 940,
            "down_mbits": 941,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 1.5,
        "avg": 2.91,
        "max": 4.9,
        "samples": 1138,
        "series": [
          2.91,
          3.41,
          3.26,
          3.01,
          3.34,
          3.01,
          2.88,
          2.58,
          2.54,
          3.1,
          3.16,
          2.64,
          2.49,
          2.58,
          2.81,
          2.5,
          2.59,
          3.43,
          3.18,
          2.61,
          3.0,
          3.38,
          3.28,
          3.3,
          2.89,
          2.49,
          2.5,
          2.84,
          2.6,
          2.49,
          2.9,
          3.36,
          2.62,
          3.39,
          3.29,
          3.28,
          2.94,
          2.77,
          2.5,
          2.49
      "summary": {
        "cpu_mhz": 2100,
        "cpu_aes_MBs": 979,
        "power_min_w": 1.5,
        "power_max_w": 4.9
      "board_slug": "bananapim2ultra",
      "device": "Banana Pi M2 Ultra 01",
      "last_good_test": "2026-10-06T13:52:42Z",
      "kernel": "7.2.9-edge-sunxi",
      "cpu": {
        "max_mhz": 1200,
        "aes_MBs": 23,
        "temp_C": 55.4,
        "min_mhz": 720,
        "peak_mhz": 1200,
        "tested": "2026-10-06T13:52:42Z",
      "memory": {
        "copy_MBs": 2100,
      "storage": {
        "read_MBs": 42,
        "write_MBs": 14,
      "network": {
        "interfaces": [
            "up_mbits": 807,
            "down_mbits": 941,
            "wireless": false
            "type": "IEEE 802.11n (Wi-Fi 4)",
            "up_mbits": 24,
            "down_mbits": 22,
            "wifi_chip": "Broadcom BCM43430",
            "channel_mhz": 2437,
            "channel_width_mhz": 20,
            "wireless": true
      "summary": {
        "cpu_mhz": 1200,
        "cpu_aes_MBs": 23,
        "wifi_mbits": 24,
      "board_slug": "bananapim4zero",
      "device": "BananaPi BPI-M4-Zero 01",
      "last_good_test": "2026-10-06T13:34:17Z",
      "kernel": "6.18.55-current-sunxi64",
      "cpu": {
        "max_mhz": 1416,
        "aes_MBs": 660,
        "temp_C": 58.9,
        "min_mhz": 480,
        "peak_mhz": 1416,
        "tested": "2026-10-06T13:34:17Z",
      "memory": {
        "copy_MBs": 3600,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 13,
      "network": {
        "interfaces": [
            "up_mbits": 85,
            "down_mbits": 101,
            "wifi_chip": "Broadcom (brcmfmac)",
            "channel_width_mhz": 40,
            "wireless": true
      "summary": {
        "cpu_mhz": 1416,
        "cpu_aes_MBs": 660,
        "wifi_mbits": 101,
      "board_slug": "bananapim5",
      "device": "Banana Pi M5 01",
      "last_good_test": "2026-10-06T13:59:40Z",
      "cpu": {
        "max_mhz": 2100,
        "aes_MBs": 980,
        "temp_C": 58.8,
        "min_mhz": 1000,
        "peak_mhz": 2100,
        "tested": "2026-10-06T13:59:40Z",
      "memory": {
        "copy_MBs": 5300,
      "storage": {
        "read_MBs": 15,
        "write_MBs": 10,
      "network": {
        "interfaces": [
            "up_mbits": 940,
            "down_mbits": 941,
            "wireless": false
            "interface": "wlx000f13960190",
            "up_mbits": 1,
            "down_mbits": 6,
            "wifi_chip": "Realtek RTL8192CU",
            "wireless": true
      "summary": {
        "cpu_mhz": 2100,
        "cpu_aes_MBs": 980,
      "board_slug": "bananapim7",
      "device": "Banana Pi M7 01",
      "last_good_test": "2026-10-06T13:41:39Z",
      "kernel": "7.2.9-edge-rockchip64",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1250,
        "temp_C": 70.2,
        "min_mhz": 1800,
        "peak_mhz": 2256,
        "tested": "2026-10-06T13:41:39Z",
      "memory": {
        "copy_MBs": 9600,
      "storage": {
        "read_MBs": 1335,
        "write_MBs": 1070,
      "network": {
        "interfaces": [
            "interface": "enP2p33s0",
            "type": "2.5GBASE-T (2.5GE)",
            "up_mbits": 2349,
            "down_mbits": 2308,
            "wireless": false
            "interface": "enP4p65s0",
            "up_mbits": 2353,
            "down_mbits": 2323,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 0.7,
        "avg": 7.32,
        "max": 15.1,
        "samples": 779,
        "series": [
          6.65,
          7.86,
          7.92,
          6.88,
          7.0,
          6.42,
          6.53,
          7.06,
          8.09,
          7.41,
          7.22,
          7.95,
          6.73,
          7.45,
          6.78,
          6.75,
          6.83,
          6.96,
          6.77,
          6.7,
          7.48,
          8.73,
          7.65,
          7.78,
          9.12,
          7.98,
          6.85,
          6.81,
          6.85,
          6.09,
          6.78,
          6.78,
          6.91,
          9.28,
          7.81,
          7.03,
          7.5,
          7.66,
          8.93,
          6.81
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1250,
        "ethernet_mbits": 2353,
        "ethernet_interfaces": 2,
        "power_min_w": 0.7,
        "power_max_w": 15.1
      "board_slug": "bananapir2",
      "device": "Banana Pi R2 01",
      "last_good_test": "2026-10-06T13:44:01Z",
      "kernel": "7.2.9-edge-mt7623",
      "cpu": {
        "max_mhz": 1300,
        "aes_MBs": 25,
        "temp_C": 54.7,
        "min_mhz": 98,
        "peak_mhz": 1300,
        "tested": "2026-10-06T13:44:01Z",
      "memory": {
        "copy_MBs": 1600,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 20,
      "network": {
        "interfaces": [
            "interface": "lan2",
            "up_mbits": 938,
            "down_mbits": 921,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 2.0,
        "avg": 5.24,
        "max": 6.7,
        "samples": 1053,
        "series": [
          4.91,
          5.28,
          5.38,
          5.43,
          5.33,
          5.89,
          5.44,
          5.36,
          5.3,
          4.48,
          5.59,
          5.4,
          4.53,
          5.2,
          4.14,
          5.5,
          5.18,
          5.52,
          5.27,
          5.32,
          4.93,
          5.47,
          5.49,
          5.53,
          5.35,
          5.34,
          4.5,
          5.09,
          4.92,
          5.43,
          5.45,
          5.42,
          5.34,
          5.34,
          5.43,
          5.42,
          5.36,
          5.37,
          4.92,
          5.14
      "summary": {
        "cpu_mhz": 1300,
        "cpu_aes_MBs": 25,
        "ethernet_mbits": 938,
        "power_min_w": 2.0,
        "power_max_w": 6.7
      "board_slug": "bananapir3mini",
      "device": "Banana Pi R3 Mini 01",
      "last_good_test": "2026-10-06T13:25:37Z",
      "image_version": "26.11.0-trunk",
      "kernel": "6.18.52-current-filogic-mt7986",
      "cpu": {
        "aes_MBs": 934,
        "temp_C": 79.3,
        "tested": "2026-10-06T13:25:37Z",
      "memory": {
        "copy_MBs": 3200,
      "storage": {
        "read_MBs": 91,
        "write_MBs": 77,
      "network": {
        "interfaces": [
            "up_mbits": 2354,
            "down_mbits": 2356,
            "wireless": false
            "interface": "eth1",
            "up_mbits": 2352,
            "down_mbits": 2264,
            "wireless": false
            "up_mbits": 6,
            "down_mbits": 20,
            "wifi_chip": "MediaTek (mt798x-wmac)",
            "wireless": true
            "up_mbits": 194,
            "down_mbits": 389,
            "channel_width_mhz": 160,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 3.6,
        "avg": 7.57,
        "max": 12.7,
        "samples": 218,
        "series": [
          7.4,
          7.6,
          8.47,
          8.56,
          8.3,
          7.96,
          7.93,
          7.9,
          4.32,
          3.6,
          3.92,
          5.47,
          6.56,
          7.6,
          7.86,
          7.83,
          7.64,
          7.52,
          7.82,
          7.8,
          7.68,
          7.92,
          7.93,
          7.66,
          7.6,
          8.0,
          7.62,
          7.86,
          8.5,
          8.22,
          7.8,
          7.7,
          7.54,
          7.5,
          7.5,
          7.48,
          8.86,
          11.07,
          8.12,
          7.9
        "tested": "2026-10-06T09:26:22Z",
        "run_id": "37442228204"
      "summary": {
        "cpu_aes_MBs": 934,
        "ethernet_mbits": 2356,
        "wifi_mbits": 389,
        "power_min_w": 3.6,
        "power_max_w": 12.7
      "board_slug": "clearfogpro",
      "device": "Clearfog Pro 01",
      "last_good_test": "2026-10-06T13:36:20Z",
      "kernel": "7.2.9-edge-mvebu",
      "cpu": {
        "aes_MBs": 43,
        "temp_C": 66.5,
        "tested": "2026-10-06T13:36:20Z",
      "memory": {
        "copy_MBs": 3800,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 21,
      "network": {
        "interfaces": [
            "up_mbits": 935,
            "down_mbits": 936,
            "wireless": false
      "summary": {
        "cpu_aes_MBs": 43,
        "ethernet_mbits": 936,
      "board_slug": "cubietruck",
      "device": "Cubietruck 01",
      "last_good_test": "2026-10-06T13:53:29Z",
      "cpu": {
        "max_mhz": 960,
        "aes_MBs": 19,
        "temp_C": 52.4,
        "min_mhz": 528,
        "peak_mhz": 960,
        "tested": "2026-10-06T13:53:29Z",
      "memory": {
        "copy_MBs": 1700,
      "storage": {
        "read_MBs": 21,
        "write_MBs": 16,
      "network": {
        "interfaces": [
            "up_mbits": 699,
            "down_mbits": 881,
            "wireless": false
            "up_mbits": 19,
            "down_mbits": 19,
            "wifi_chip": "Broadcom BCM43362",
            "wireless": true
      "summary": {
        "cpu_mhz": 960,
        "cpu_aes_MBs": 19,
        "ethernet_mbits": 881,
        "wifi_mbits": 19,
      "board_slug": "cubox-i",
      "device": "Cubox i2eX/i4 01",
      "last_good_test": "2026-10-06T14:02:30Z",
      "kernel": "7.1.13-edge-imx6",
      "cpu": {
        "max_mhz": 996,
        "aes_MBs": 26,
        "temp_C": 54.3,
        "min_mhz": 396,
        "peak_mhz": 996,
        "tested": "2026-10-06T14:02:30Z",
      "memory": {
        "copy_MBs": 782,
      "storage": {
        "read_MBs": 20,
        "write_MBs": 19,
      "network": {
        "interfaces": [
            "type": "100BASE-TX (10/100ME)",
            "up_mbits": 94,
            "down_mbits": 94,
            "wireless": false
            "up_mbits": 18,
            "down_mbits": 16,
            "wifi_chip": "Broadcom BCM4330",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.8,
        "avg": 3.03,
        "max": 6.1,
        "samples": 1937,
        "series": [
          3.23,
          2.16,
          3.1,
          3.37,
          3.03,
          3.0,
          2.13,
          2.28,
          3.83,
          2.99,
          3.04,
          3.62,
          3.56,
          2.98,
          2.43,
          3.43,
          3.28,
          2.98,
          2.54,
          2.32,
          2.36,
          2.41,
          3.31,
          2.5,
          3.33,
          3.29,
          3.17,
          3.39,
          3.54,
          3.47,
          3.26,
          2.89,
          2.97,
          2.67,
          3.19,
          3.39,
          3.39,
          3.15,
          3.04,
          3.33
      "summary": {
        "cpu_mhz": 996,
        "cpu_aes_MBs": 26,
        "ethernet_mbits": 94,
        "wifi_mbits": 18,
        "power_min_w": 1.8,
        "power_max_w": 6.1
      "board_slug": "espressobin",
      "device": "Espressobin 01",
      "kernel": "7.1.13-edge-mvebu64",
      "cpu": {
        "max_mhz": 800,
        "aes_MBs": 371,
        "min_mhz": 200,
        "peak_mhz": 800,
      "memory": {
        "copy_MBs": 2000,
      "storage": {
        "read_MBs": 133,
        "write_MBs": 22,
      "network": {
        "interfaces": [
            "interface": "lan0",
            "up_mbits": 929,
            "down_mbits": 739,
            "wireless": false
      "summary": {
        "cpu_mhz": 800,
        "cpu_aes_MBs": 371,
        "ethernet_mbits": 929,
      "board_slug": "helios4",
      "device": "Helios4 01",
      "last_good_test": "2026-10-06T13:44:44Z",
      "cpu": {
        "aes_MBs": 43,
        "temp_C": 56.5,
        "tested": "2026-10-06T13:44:44Z",
      "memory": {
        "copy_MBs": 3800,
      "storage": {
        "read_MBs": 23,
        "write_MBs": 21,
      "network": {
        "interfaces": [
            "interface": "end1",
            "up_mbits": 941,
            "down_mbits": 941,
            "wireless": false
      "summary": {
        "cpu_aes_MBs": 43,
      "board_slug": "inovato-quadra",
      "device": "Inovato Quadra 01",
      "last_good_test": "2026-10-06T13:39:42Z",
      "kernel": "7.2.9-edge-sunxi64",
      "cpu": {
        "max_mhz": 1704,
        "aes_MBs": 794,
        "temp_C": 71.8,
        "min_mhz": 480,
        "peak_mhz": 1704,
        "tested": "2026-10-06T13:39:42Z",
      "memory": {
        "copy_MBs": 2800,
      "storage": {
        "read_MBs": 23,
        "write_MBs": 16,
      "network": {
        "interfaces": [
            "up_mbits": 94,
            "down_mbits": 94,
            "wireless": false
            "up_mbits": 8,
            "down_mbits": 17,
            "wifi_chip": "XRadio XR819",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 2.3,
        "avg": 4.13,
        "max": 6.7,
        "samples": 847,
        "series": [
          3.81,
          4.31,
          4.42,
          4.24,
          4.19,
          3.95,
          4.33,
          4.28,
          4.55,
          4.2,
          3.45,
          3.67,
          4.49,
          4.09,
          4.78,
          3.1,
          4.35,
          4.31,
          4.73,
          3.9,
          4.11,
          4.2,
          3.96,
          4.36,
          4.35,
          3.95,
          3.34,
          3.43,
          4.23,
          4.27,
          5.08,
          4.08,
          4.17,
          4.34,
          4.16,
          4.21,
          4.38,
          4.35,
          3.66,
          3.27
      "summary": {
        "cpu_mhz": 1704,
        "cpu_aes_MBs": 794,
        "wifi_mbits": 17,
        "power_min_w": 2.3,
        "power_max_w": 6.7
      "board_slug": "k3picoitx",
      "device": "SpacemiT K3 Pico-ITX 01",
      "last_good_test": "2026-10-06T13:52:11Z",
      "kernel": "6.18.3-legacy-spacemit-k3",
      "cpu": {
        "max_mhz": 2150,
        "aes_MBs": 778,
        "temp_C": 46.0,
        "min_mhz": 614,
        "peak_mhz": 2150,
        "tested": "2026-10-06T13:52:11Z",
      "memory": {
        "copy_MBs": 4100,
      "storage": {
        "read_MBs": 1518,
        "write_MBs": 1338,
      "network": {
        "interfaces": [
            "up_mbits": 941,
            "down_mbits": 941,
            "wireless": false
            "type": "10GBASE-T (10GE)",
            "up_mbits": 7445,
            "down_mbits": 4638,
            "wireless": false
            "up_mbits": 55,
            "down_mbits": 167,
            "wifi_chip": "Realtek RTL8852BE",
            "wifi_attach": "PCIe",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 13.4,
        "avg": 14.4,
        "max": 22.4,
        "samples": 148,
        "tested": "2026-08-29T19:35:37Z",
        "run_id": "33270498615"
      "summary": {
        "cpu_mhz": 2150,
        "cpu_aes_MBs": 778,
        "ethernet_mbits": 7445,
        "wifi_mbits": 167,
        "power_min_w": 13.4,
        "power_max_w": 22.4
      "board_slug": "khadas-edge2",
      "device": "Khadas Edge2 01",
      "last_good_test": "2026-10-06T13:31:48Z",
      "kernel": "6.18.55-current-rockchip64",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1276,
        "temp_C": 38.8,
        "min_mhz": 1800,
        "peak_mhz": 2256,
        "tested": "2026-10-06T13:31:48Z",
      "memory": {
        "copy_MBs": 15000,
      "storage": {
        "read_MBs": 256,
        "write_MBs": 105,
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1276
      "board_slug": "khadas-vim1",
      "device": "Khadas VIM1 01",
      "last_good_test": "2026-10-06T13:47:30Z",
      "cpu": {
        "max_mhz": 1512,
        "aes_MBs": 658,
        "temp_C": 58.0,
        "min_mhz": 500,
        "peak_mhz": 1512,
        "tested": "2026-10-06T13:47:30Z",
      "memory": {
        "copy_MBs": 3600,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 18,
      "network": {
        "interfaces": [
            "up_mbits": 94,
            "down_mbits": 94,
            "wireless": false
            "up_mbits": 6,
            "down_mbits": 21,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.2,
        "avg": 2.18,
        "max": 3.8,
        "samples": 1216,
        "series": [
          2.11,
          2.07,
          2.21,
          2.32,
          2.44,
          2.05,
          2.53,
          2.23,
          2.33,
          1.97,
          2.05,
          2.33,
          2.24,
          2.36,
          2.15,
          2.27,
          2.27,
          1.83,
          1.8,
          1.86,
          1.95,
          2.07,
          2.08,
          2.43,
          2.35,
          2.3,
          2.17,
          2.25,
          2.06,
          2.53,
          2.51,
          1.85,
          2.08,
          2.13,
          1.92,
          2.34,
          2.37,
          2.36,
          2.07,
          2.05
      "summary": {
        "cpu_mhz": 1512,
        "cpu_aes_MBs": 658,
        "wifi_mbits": 21,
        "power_min_w": 1.2,
        "power_max_w": 3.8
      "board_slug": "khadas-vim2",
      "device": "Khadas VIM2 01",
      "last_good_test": "2026-10-06T13:46:38Z",
      "cpu": {
        "max_mhz": 1512,
        "aes_MBs": 658,
        "temp_C": 64.0,
        "min_mhz": 500,
        "peak_mhz": 1512,
        "tested": "2026-10-06T13:46:38Z",
      "memory": {
        "copy_MBs": 3600,
      "storage": {
        "read_MBs": 143,
        "write_MBs": 37,
      "network": {
        "interfaces": [
            "up_mbits": 939,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 77,
            "down_mbits": 89,
            "wifi_chip": "Broadcom BCM4356",
            "wireless": true
      "summary": {
        "cpu_mhz": 1512,
        "cpu_aes_MBs": 658,
        "wifi_mbits": 89,
      "board_slug": "khadas-vim3",
      "device": "Khadas VIM3 01",
      "last_good_test": "2026-10-06T09:31:22Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/37442228204",
      "cpu": {
        "max_mhz": 1512,
        "aes_MBs": 852,
        "temp_C": 59.7,
        "min_mhz": 1000,
        "peak_mhz": 1512,
        "tested": "2026-10-06T09:31:22Z",
      "memory": {
        "copy_MBs": 3900,
      "storage": {
        "read_MBs": 159,
        "write_MBs": 69,
      "network": {
        "interfaces": [
            "up_mbits": 940,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 43,
            "down_mbits": 42,
            "wireless": true
      "summary": {
        "cpu_mhz": 1512,
        "cpu_aes_MBs": 852,
        "wifi_mbits": 43,
      "board_slug": "khadas-vim4",
      "device": "Khadas VIM4 01",
      "last_good_test": "2026-09-20T16:34:34Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/35522710123",
      "image_version": "26.11.0-trunk.51",
      "kernel": "5.15.137-legacy-meson-s4t7",
      "cpu": {
        "max_mhz": 2208,
        "aes_MBs": 1246,
        "temp_C": 47.4,
        "min_mhz": 500,
        "peak_mhz": 2208,
        "tested": "2026-09-20T16:34:34Z",
        "run_id": "35522710123"
      "memory": {
        "copy_MBs": 6800,
      "storage": {
        "read_MBs": 169,
        "write_MBs": 106,
      "network": {
        "interfaces": [
            "up_mbits": 927,
            "down_mbits": 935,
            "wireless": false
            "up_mbits": 5,
            "down_mbits": 2,
            "wifi_chip": "Broadcom BCM43752",
            "channel_mhz": 2462,
            "wireless": true
            "up_mbits": 77,
            "down_mbits": 3,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 0.6,
        "avg": 3.93,
        "max": 8.4,
        "samples": 336,
        "series": [
          3.2,
          3.85,
          4.13,
          4.23,
          4.0,
          4.31,
          4.14,
          4.14,
          4.2,
          4.04,
          3.9,
          3.86,
          4.1,
          4.08,
          3.38,
          2.85,
          2.74,
          3.68,
          4.25,
          4.27,
          4.16,
          3.5,
          3.47,
          3.75,
          4.59,
          4.41,
          4.1,
          4.94,
          5.27,
          3.8,
          3.73,
          3.88,
          3.91,
          3.47,
          3.6,
          3.65,
          3.51,
          4.26,
          4.0,
          3.63
      "summary": {
        "cpu_mhz": 2208,
        "cpu_aes_MBs": 1246,
        "ethernet_mbits": 935,
        "wifi_mbits": 77,
        "power_min_w": 0.6,
        "power_max_w": 8.4
      "board_slug": "mekotronics-r58hd",
      "device": "Mekotronics R58HD 01",
      "last_good_test": "2026-10-06T13:46:23Z",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1302,
        "temp_C": 48.1,
        "min_mhz": 1800,
        "peak_mhz": 2304,
        "tested": "2026-10-06T13:46:23Z",
      "memory": {
        "copy_MBs": 16000,
      "storage": {
        "read_MBs": 291,
        "write_MBs": 250,
      "network": {
        "interfaces": [
            "interface": "enP3p49s0",
            "up_mbits": 941,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 941,
            "down_mbits": 941,
            "wireless": false
        "tested": "2026-10-06T09:24:31Z",
      "power": {
        "unit": "W",
        "min": 3.6,
        "avg": 5.05,
        "max": 11.9,
        "samples": 1184,
        "series": [
          5.51,
          5.24,
          5.59,
          5.82,
          5.23,
          5.87,
          6.57,
          5.31,
          6.95,
          4.9,
          4.9,
          4.9,
          4.9,
          4.9,
          4.87,
          4.85,
          4.91,
          4.82,
          4.88,
          4.8,
          4.8,
          4.8,
          4.85,
          4.82,
          4.8,
          4.8,
          4.8,
          4.8,
          4.8,
          4.8,
          4.8,
          4.8,
          4.8,
          4.8,
          4.8,
          4.83,
          4.83,
          5.13,
          4.8,
          4.8
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1302,
        "power_min_w": 3.6,
        "power_max_w": 11.9
      "board_slug": "mekotronics-r58s2",
      "device": "Mekotronics R58S2 01",
      "last_good_test": "2026-10-06T13:24:53Z",
      "image_version": "26.11.0-trunk.72",
      "kernel": "6.1.172-vendor-rk35xx",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1280,
        "temp_C": 44.4,
        "min_mhz": 1800,
        "peak_mhz": 2352,
        "tested": "2026-10-06T13:24:53Z",
      "memory": {
        "copy_MBs": 15000,
      "storage": {
        "read_MBs": 273,
        "write_MBs": 226,
      "network": {
        "interfaces": [
            "up_mbits": 941,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 62,
            "down_mbits": 99,
            "wifi_chip": "Broadcom BCM43456",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 0.6,
        "avg": 3.45,
        "max": 10.5,
        "samples": 141,
        "series": [
          2.6,
          2.6,
          2.6,
          3.9,
          3.63,
          3.1,
          2.7,
          2.62,
          2.6,
          2.6,
          2.6,
          3.25,
          3.9,
          0.6,
          2.43,
          2.58,
          2.8,
          3.77,
          4.37,
          4.9,
          3.8,
          3.67,
          3.83,
          4.5,
          9.0,
          7.93,
          2.8,
          3.8,
          3.35,
          3.17,
          3.1,
          3.4,
          3.4,
          3.17,
          2.7,
          3.4,
          3.25,
          3.1,
          3.3,
          3.5
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1280,
        "wifi_mbits": 99,
        "power_min_w": 0.6,
        "power_max_w": 10.5
      "board_slug": "musepipro",
      "last_good_test": "2026-10-06T13:28:45Z",
      "kernel": "6.18.55-current-spacemit",
      "cpu": {
        "max_mhz": 1600,
        "aes_MBs": 27,
        "temp_C": 54.0,
        "min_mhz": 614,
        "peak_mhz": 1600,
        "tested": "2026-10-06T13:28:45Z",
      "memory": {
        "copy_MBs": 3000,
      "storage": {
        "read_MBs": 81,
        "write_MBs": 70,
      "network": {
        "interfaces": [
            "up_mbits": 941,
            "down_mbits": 940,
            "wireless": false
            "up_mbits": 315,
            "down_mbits": 311,
            "wireless": true
            "up_mbits": 271,
            "down_mbits": 251,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 2.8,
        "avg": 5.26,
        "max": 8.3,
        "samples": 323,
        "series": [
          4.7,
          4.98,
          5.29,
          5.18,
          4.9,
          5.13,
          5.16,
          5.21,
          5.04,
          5.01,
          5.01,
          5.1,
          4.76,
          4.99,
          6.65,
          5.3,
          5.38,
          5.3,
          5.2,
          5.08,
          5.25,
          4.58,
          4.8,
          3.3,
          5.94,
          5.4,
          5.19,
          5.05,
          5.88,
          5.95,
          5.29,
          5.05,
          5.24,
          5.61,
          5.89,
          6.6,
          5.36,
          5.58,
          5.6,
          5.4
      "summary": {
        "cpu_mhz": 1600,
        "cpu_aes_MBs": 27,
        "wifi_mbits": 315,
        "power_min_w": 2.8,
        "power_max_w": 8.3
      "board_slug": "nanopi-m5",
      "device": "NanoPi M5 01",
      "last_good_test": "2026-10-06T13:48:58Z",
      "cpu": {
        "max_mhz": 2016,
        "aes_MBs": 1270,
        "temp_C": 45.3,
        "min_mhz": 2016,
        "peak_mhz": 2208,
        "tested": "2026-10-06T13:48:58Z",
      "memory": {
        "copy_MBs": 7900,
      "storage": {
        "read_MBs": 77,
        "write_MBs": 68,
      "network": {
        "interfaces": [
            "up_mbits": 941,
            "down_mbits": 942,
            "wireless": false
            "up_mbits": 48,
            "down_mbits": 55,
            "wireless": true
            "interface": "wlx44334c47dec3",
            "up_mbits": 37,
            "down_mbits": 28,
            "wifi_chip": "Ralink RT2870/RT3070",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 2.4,
        "avg": 5.13,
        "max": 10.0,
        "samples": 1273,
        "series": [
          5.19,
          5.69,
          5.63,
          5.78,
          5.6,
          4.67,
          5.1,
          4.13,
          3.93,
          3.72,
          4.63,
          6.18,
          5.16,
          5.31,
          5.46,
          5.74,
          5.43,
          4.82,
          4.33,
          5.19,
          6.06,
          5.05,
          5.65,
          5.02,
          5.12,
          5.25,
          5.56,
          5.79,
          4.73,
          4.64,
          5.91,
          6.08,
          5.61,
          5.16,
          5.43,
          5.31,
          5.49,
          4.01,
          3.97,
          3.88
      "summary": {
        "cpu_mhz": 2016,
        "cpu_aes_MBs": 1270,
        "ethernet_mbits": 942,
        "wifi_mbits": 55,
        "power_min_w": 2.4,
        "power_max_w": 10.0
      "board_slug": "nanopi-m6",
      "device": "NanoPi M6 01",
      "last_good_test": "2026-10-06T13:46:13Z",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1272,
        "temp_C": 43.5,
        "min_mhz": 1800,
        "peak_mhz": 2256,
        "tested": "2026-10-06T13:46:13Z",
      "memory": {
        "copy_MBs": 13500,
      "storage": {
        "read_MBs": 75,
        "write_MBs": 52,
      "network": {
        "interfaces": [
            "interface": "lan",
            "up_mbits": 941,
            "down_mbits": 941,
            "wireless": false
            "interface": "wlP3p49s0",
            "up_mbits": 4,
            "down_mbits": 30,
            "wifi_chip": "Realtek RTL8822CE",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.0,
        "avg": 3.89,
        "max": 10.2,
        "samples": 1144,
        "series": [
          3.22,
          3.26,
          3.65,
          2.82,
          3.54,
          3.79,
          3.47,
          3.54,
          2.84,
          3.56,
          4.49,
          3.54,
          3.68,
          3.46,
          3.39,
          3.26,
          2.96,
          4.69,
          5.07,
          4.69,
          4.3,
          4.64,
          4.68,
          3.83,
          3.22,
          5.47,
          4.14,
          4.03,
          3.91,
          3.84,
          3.81,
          4.06,
          3.96,
          4.13,
          4.13,
          4.13,
          4.64,
          4.62,
          4.65,
          2.72
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1272,
        "wifi_mbits": 30,
        "power_min_w": 1.0,
        "power_max_w": 10.2
      "board_slug": "nanopi-r6s",
      "device": "NanoPi R6S 01",
      "last_good_test": "2026-10-06T13:37:07Z",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1274,
        "temp_C": 43.5,
        "min_mhz": 1800,
        "peak_mhz": 2352,
        "tested": "2026-10-06T13:37:07Z",
      "memory": {
        "copy_MBs": 15200,
      "storage": {
        "read_MBs": 268,
        "write_MBs": 208,
      "network": {
        "interfaces": [
            "up_mbits": 941,
            "down_mbits": 942,
            "wireless": false
            "interface": "wan",
            "up_mbits": 2344,
            "down_mbits": 2289,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 2.3,
        "avg": 3.96,
        "max": 9.2,
        "samples": 698,
        "series": [
          2.82,
          3.86,
          3.61,
          3.93,
          3.93,
          3.91,
          3.82,
          4.07,
          4.16,
          3.33,
          3.46,
          5.84,
          3.5,
          3.84,
          3.34,
          4.56,
          4.07,
          3.41,
          3.24,
          3.47,
          4.13,
          4.99,
          4.07,
          3.66,
          3.32,
          3.38,
          3.26,
          4.05,
          4.26,
          4.94,
          3.3,
          3.99,
          4.5,
          5.47,
          3.91,
          3.91,
          4.35,
          4.39,
          4.35,
          3.87
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1274,
        "ethernet_mbits": 2344,
        "power_min_w": 2.3,
        "power_max_w": 9.2
      "board_slug": "nanopi-r76s",
      "device": "NanoPi R76S 01",
      "last_good_test": "2026-10-06T13:41:15Z",
      "cpu": {
        "max_mhz": 2016,
        "aes_MBs": 1271,
        "temp_C": 48.1,
        "min_mhz": 2016,
        "peak_mhz": 2208,
        "tested": "2026-10-06T13:41:15Z",
      "memory": {
        "copy_MBs": 7600,
      "storage": {
        "read_MBs": 77,
        "write_MBs": 63,
      "network": {
        "interfaces": [
            "up_mbits": 2345,
            "down_mbits": 2349,
            "wireless": false
            "up_mbits": 2346,
            "down_mbits": 2352,
            "wireless": false
            "up_mbits": 36,
            "down_mbits": 49,
            "wireless": true
            "interface": "wlxe0e1a933de37",
            "up_mbits": 192,
            "down_mbits": 207,
            "wifi_chip": "Realtek RTL8821CU",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 0.6,
        "avg": 4.4,
        "max": 8.8,
        "samples": 762,
        "series": [
          4.32,
          4.05,
          1.93,
          4.74,
          4.67,
          4.95,
          4.37,
          4.73,
          5.05,
          3.44,
          3.31,
          3.55,
          4.18,
          5.08,
          5.51,
          4.95,
          4.9,
          4.77,
          5.16,
          5.01,
          4.6,
          4.93,
          4.41,
          4.2,
          4.83,
          2.82,
          4.23,
          2.29,
          4.96,
          5.88,
          4.75,
          4.73,
          4.21,
          4.59,
          4.92,
          4.63,
          5.02,
          4.67,
          2.8,
          3.73
      "summary": {
        "cpu_mhz": 2016,
        "cpu_aes_MBs": 1271,
        "ethernet_mbits": 2352,
        "wifi_mbits": 49,
        "power_min_w": 0.6,
        "power_max_w": 8.8
      "board_slug": "nanopifire3",
      "device": "NanoPi Fire3 01",
      "last_good_test": "2026-10-06T13:35:20Z",
      "kernel": "7.2.9-edge-s5p6818",
      "cpu": {
        "aes_MBs": 368,
        "temp_C": 68.0,
        "tested": "2026-10-06T13:35:20Z",
      "memory": {
        "copy_MBs": 2000,
      "storage": {
        "read_MBs": 17,
        "write_MBs": 20,
      "network": {
        "interfaces": [
            "up_mbits": 94,
            "down_mbits": 94,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 1.8,
        "avg": 3.02,
        "max": 3.9,
        "samples": 644,
        "series": [
          2.7,
          3.03,
          2.98,
          3.05,
          3.01,
          3.11,
          3.0,
          3.03,
          3.11,
          2.92,
          2.92,
          2.93,
          3.01,
          3.04,
          2.93,
          2.91,
          3.46,
          3.31,
          3.06,
          3.11,
          2.97,
          2.9,
          2.99,
          3.13,
          2.84,
          2.6,
          3.24,
          3.27,
          3.02,
          2.92,
          2.87,
          2.88,
          3.67,
          2.94,
          2.76,
          3.46,
          3.12,
          2.93,
          2.85,
          2.81
      "summary": {
        "cpu_aes_MBs": 368,
        "power_min_w": 1.8,
        "power_max_w": 3.9
      "board_slug": "nanopik2-s905",
      "device": "NanoPi K2 01",
      "last_good_test": "2026-10-06T13:43:31Z",
      "cpu": {
        "max_mhz": 1536,
        "aes_MBs": 51,
        "temp_C": 65.0,
        "min_mhz": 500,
        "peak_mhz": 1536,
        "tested": "2026-10-06T13:43:31Z",
      "memory": {
        "copy_MBs": 3800,
      "storage": {
        "read_MBs": 41,
        "write_MBs": 10,
      "network": {
        "interfaces": [
            "up_mbits": 935,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 14,
            "down_mbits": 19,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.1,
        "avg": 2.54,
        "max": 4.6,
        "samples": 259,
        "tested": "2026-09-16T18:01:12Z",
        "run_id": "35131071598"
      "summary": {
        "cpu_mhz": 1536,
        "cpu_aes_MBs": 51,
        "wifi_mbits": 19,
        "power_min_w": 1.1,
        "power_max_w": 4.6
      "board_slug": "nanopim4v2",
      "device": "NanoPi M4V2 01",
      "last_good_test": "2026-10-06T13:44:46Z",
      "cpu": {
        "max_mhz": 1416,
        "aes_MBs": 1018,
        "temp_C": 48.1,
        "min_mhz": 408,
        "peak_mhz": 1800,
        "tested": "2026-10-06T13:44:46Z",
      "memory": {
        "copy_MBs": 6500,
      "storage": {
        "read_MBs": 62,
        "write_MBs": 51,
      "network": {
        "interfaces": [
            "up_mbits": 941,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 72,
            "down_mbits": 67,
            "wireless": true
            "interface": "wlx803f5d16af63",
            "up_mbits": 60,
            "down_mbits": 167,
            "wifi_chip": "MediaTek MT7610",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 3.0,
        "avg": 6.92,
        "max": 12.5,
        "samples": 1082,
        "series": [
          6.61,
          7.19,
          7.24,
          7.77,
          8.11,
          7.65,
          6.19,
          7.25,
          7.49,
          6.99,
          6.31,
          8.07,
          8.04,
          6.66,
          6.37,
          6.23,
          5.9,
          5.83,
          6.16,
          6.05,
          6.02,
          6.55,
          6.82,
          7.8,
          6.99,
          7.66,
          5.26,
          7.69,
          7.99,
          8.03,
          6.94,
          6.09,
          6.89,
          6.6,
          6.02,
          6.76,
          7.33,
          7.54,
          6.86,
          6.85
      "summary": {
        "cpu_mhz": 1416,
        "cpu_aes_MBs": 1018,
        "wifi_mbits": 72,
        "power_min_w": 3.0,
        "power_max_w": 12.5
      "board_slug": "nanopineo2black",
      "device": "NanoPi Neo 2 Black 01",
      "last_good_test": "2026-10-06T13:41:58Z",
      "cpu": {
        "max_mhz": 1368,
        "aes_MBs": 606,
        "temp_C": 66.1,
        "min_mhz": 480,
        "peak_mhz": 1368,
        "tested": "2026-10-06T13:41:58Z",
      "memory": {
        "copy_MBs": 3400,
      "storage": {
        "read_MBs": 44,
        "write_MBs": 43,
      "network": {
        "interfaces": [
            "up_mbits": 761,
            "down_mbits": 932,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 1.0,
        "avg": 2.74,
        "max": 5.1,
        "samples": 945,
        "series": [
          2.39,
          2.84,
          3.04,
          3.01,
          3.21,
          3.42,
          3.2,
          2.14,
          2.67,
          3.22,
          2.33,
          3.25,
          3.05,
          3.27,
          3.54,
          3.43,
          2.75,
          3.27,
          3.01,
          3.2,
          3.15,
          2.08,
          1.5,
          1.5,
          1.5,
          1.5,
          1.42,
          1.4,
          2.53,
          2.65,
          3.74,
          3.53,
          2.53,
          2.67,
          3.38,
          3.19,
          3.11,
          2.98,
          2.31,
          2.76
      "summary": {
        "cpu_mhz": 1368,
        "cpu_aes_MBs": 606,
        "ethernet_mbits": 932,
        "power_min_w": 1.0,
        "power_max_w": 5.1
      "board_slug": "nanopineo3",
      "device": "NanoPi Neo 3 01",
      "last_good_test": "2026-10-06T13:48:25Z",
      "cpu": {
        "max_mhz": 1296,
        "aes_MBs": 599,
        "temp_C": 79.6,
        "min_mhz": 408,
        "peak_mhz": 1296,
        "tested": "2026-10-06T13:48:25Z",
      "memory": {
        "copy_MBs": 2400,
      "storage": {
        "read_MBs": 62,
        "write_MBs": 53,
      "network": {
        "interfaces": [
            "up_mbits": 905,
            "down_mbits": 939,
            "wireless": false
            "interface": "wlx7cdd905518f9",
            "up_mbits": 31,
            "down_mbits": 24,
            "wifi_chip": "Ralink RT5370",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.7,
        "avg": 4.5,
        "max": 6.1,
        "samples": 1272,
        "series": [
          3.92,
          4.62,
          5.0,
          4.77,
          4.58,
          5.03,
          4.77,
          4.67,
          3.89,
          4.94,
          4.62,
          4.18,
          4.28,
          4.91,
          4.52,
          4.44,
          4.22,
          4.32,
          3.93,
          4.06,
          4.11,
          4.5,
          4.78,
          4.71,
          4.62,
          4.47,
          4.66,
          4.56,
          4.82,
          4.4,
          4.31,
          4.79,
          4.19,
          4.63,
          3.88,
          4.97,
          4.7,
          4.61,
          4.4,
          4.07
      "summary": {
        "cpu_mhz": 1296,
        "cpu_aes_MBs": 599,
        "power_min_w": 1.7,
        "power_max_w": 6.1
      "board_slug": "odroidc2",
      "device": "Odroid C2 01",
      "last_good_test": "2026-10-06T13:40:18Z",
      "cpu": {
        "max_mhz": 1536,
        "aes_MBs": 51,
        "temp_C": 49.0,
        "min_mhz": 500,
        "peak_mhz": 1536,
        "tested": "2026-10-06T13:40:18Z",
      "memory": {
        "copy_MBs": 3500,
      "storage": {
        "read_MBs": 150,
        "write_MBs": 33,
      "network": {
        "interfaces": [
            "up_mbits": 940,
            "down_mbits": 941,
            "wireless": false
      "summary": {
        "cpu_mhz": 1536,
        "cpu_aes_MBs": 51,
      "board_slug": "odroidc4",
      "device": "Odroid C4 01",
      "last_good_test": "2026-10-06T13:42:32Z",
      "cpu": {
        "max_mhz": 2100,
        "aes_MBs": 980,
        "temp_C": 43.2,
        "min_mhz": 1000,
        "peak_mhz": 2100,
        "tested": "2026-10-06T13:42:32Z",
      "memory": {
        "copy_MBs": 5200,
      "storage": {
        "read_MBs": 78,
        "write_MBs": 29,
      "network": {
        "interfaces": [
            "up_mbits": 941,
            "down_mbits": 941,
            "wireless": false
            "interface": "wlx24050fdd332b",
            "up_mbits": 109,
            "down_mbits": 55,
            "wifi_chip": "Ralink RT5572",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 0.9,
        "avg": 3.41,
        "max": 5.1,
        "samples": 769,
        "series": [
          3.19,
          3.9,
          3.48,
          3.44,
          3.52,
          3.62,
          3.56,
          3.5,
          3.38,
          2.36,
          3.74,
          3.55,
          3.43,
          2.39,
          3.45,
          3.65,
          3.38,
          3.14,
          3.37,
          3.93,
          3.31,
          3.57,
          3.59,
          3.62,
          3.58,
          3.68,
          3.35,
          2.63,
          2.92,
          3.65,
          3.84,
          3.54,
          4.11,
          3.52,
          3.52,
          3.61,
          3.57,
          3.53,
          2.52,
          2.85
      "summary": {
        "cpu_mhz": 2100,
        "cpu_aes_MBs": 980,
        "power_min_w": 0.9,
        "power_max_w": 5.1
      "board_slug": "odroidm1",
      "device": "Odroid M1 01",
      "last_good_test": "2026-10-06T13:50:44Z",
      "cpu": {
        "max_mhz": 1992,
        "aes_MBs": 916,
        "temp_C": 36.1,
        "min_mhz": 408,
        "peak_mhz": 1992,
        "tested": "2026-10-06T13:50:44Z",
      "memory": {
        "copy_MBs": 5100,
      "storage": {
        "read_MBs": 1015,
        "write_MBs": 1058,
      "network": {
        "interfaces": [
            "up_mbits": 667,
            "down_mbits": 941,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 1.9,
        "avg": 4.98,
        "max": 10.3,
        "samples": 1054,
        "series": [
          4.87,
          7.57,
          5.29,
          6.61,
          5.25,
          5.01,
          4.69,
          3.97,
          4.61,
          5.53,
          5.16,
          3.97,
          3.94,
          4.4,
          5.09,
          3.98,
          4.25,
          6.09,
          4.61,
          4.27,
          5.22,
          6.13,
          5.68,
          5.55,
          4.85,
          3.94,
          3.96,
          4.69,
          4.5,
          3.94,
          4.43,
          5.34,
          5.05,
          5.48,
          6.92,
          5.82,
          4.68,
          5.48,
          3.98,
          4.25
      "summary": {
        "cpu_mhz": 1992,
        "cpu_aes_MBs": 916,
        "power_min_w": 1.9,
        "power_max_w": 10.3
      "board_slug": "odroidn2",
      "device": "Odroid N2 01",
      "last_good_test": "2026-10-06T13:44:57Z",
      "cpu": {
        "max_mhz": 1992,
        "aes_MBs": 1085,
        "temp_C": 41.5,
        "min_mhz": 1000,
        "peak_mhz": 1992,
        "tested": "2026-10-06T13:44:57Z",
      "memory": {
        "copy_MBs": 4900,
      "storage": {
        "read_MBs": 137,
        "write_MBs": 27,
      "network": {
        "interfaces": [
            "up_mbits": 939,
            "down_mbits": 941,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 1.0,
        "avg": 5.07,
        "max": 11.0,
        "samples": 729,
        "series": [
          5.61,
          5.31,
          5.84,
          6.21,
          4.83,
          5.67,
          5.33,
          5.19,
          4.36,
          3.41,
          5.54,
          5.24,
          4.37,
          5.73,
          3.62,
          5.16,
          7.24,
          5.78,
          4.3,
          4.48,
          5.02,
          5.03,
          5.25,
          5.16,
          4.08,
          4.94,
          4.43,
          4.72,
          6.75,
          7.29,
          4.38,
          4.92,
          4.28,
          4.69,
          5.45,
          5.14,
          5.18,
          4.67,
          2.92,
          5.07
      "summary": {
        "cpu_mhz": 1992,
        "cpu_aes_MBs": 1085,
        "power_min_w": 1.0,
        "power_max_w": 11.0
      "board_slug": "odroidxu4",
      "device": "Odroid XU4 01",
      "last_good_test": "2026-10-02T09:55:52Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/36989343280",
      "image_version": "26.11.0-trunk.66",
      "kernel": "7.2.8-edge-odroidxu4",
      "cpu": {
        "max_mhz": 1400,
        "aes_MBs": 72,
        "temp_C": 61.0,
        "min_mhz": 600,
        "peak_mhz": 2000,
        "tested": "2026-10-02T09:55:52Z",
        "run_id": "36989343280"
      "memory": {
        "copy_MBs": 5100,
      "storage": {
        "read_MBs": 60,
        "write_MBs": 61,
      "network": {
        "interfaces": [
            "up_mbits": 923,
            "down_mbits": 941,
            "wireless": false
      "summary": {
        "cpu_mhz": 1400,
        "cpu_aes_MBs": 72,
      "board_slug": "orangepi3",
      "device": "Orange Pi 3 01",
      "last_good_test": "2026-10-06T13:55:44Z",
      "image_version": "26.11.0-trunk.58",
      "kernel": "7.0.10-edge-sunxi64",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 839,
        "temp_C": 50.1,
        "min_mhz": 480,
        "peak_mhz": 1800,
        "tested": "2026-10-06T13:55:44Z",
      "memory": {
        "copy_MBs": 4600,
      "storage": {
        "read_MBs": 23,
        "write_MBs": 19,
      "network": {
        "interfaces": [
            "up_mbits": 911,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 18,
            "down_mbits": 103,
            "wireless": true
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 839,
        "wifi_mbits": 103,
      "board_slug": "orangepi3-lts",
      "device": "OrangePi 3 LTS 01",
      "last_good_test": "2026-10-05T22:20:26Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/37378191031",
      "cpu": {
        "max_mhz": 1608,
        "aes_MBs": 744,
        "temp_C": 64.6,
        "min_mhz": 480,
        "peak_mhz": 1608,
        "tested": "2026-10-05T22:20:26Z",
        "run_id": "37378191031"
      "memory": {
        "copy_MBs": 4100,
      "storage": {
        "read_MBs": 128,
        "write_MBs": 46,
      "network": {
        "interfaces": [
            "up_mbits": 915,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 138,
            "down_mbits": 132,
            "wifi_chip": "Unisoc UWE5622",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.0,
        "avg": 3.19,
        "max": 4.8,
        "samples": 787,
        "series": [
          3.11,
          3.22,
          3.37,
          3.36,
          3.5,
          3.55,
          3.36,
          3.28,
          1.91,
          3.57,
          3.5,
          2.95,
          3.33,
          2.39,
          3.42,
          3.48,
          3.26,
          3.72,
          3.52,
          3.21,
          3.33,
          3.36,
          3.32,
          2.51,
          3.16,
          2.44,
          3.42,
          3.75,
          3.25,
          2.66,
          3.39,
          3.49,
          2.56,
          3.03,
          3.28,
          3.51,
          3.28,
          3.45,
          2.59,
          2.94
      "summary": {
        "cpu_mhz": 1608,
        "cpu_aes_MBs": 744,
        "wifi_mbits": 138,
        "power_min_w": 1.0,
        "power_max_w": 4.8
      "board_slug": "orangepi5",
      "device": "Orange Pi 5 01",
      "last_good_test": "2026-08-11T14:40:29Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/31500992869",
      "image_version": "26.8.0-trunk.314",
      "kernel": "6.18.43-current-rockchip64",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1257,
        "temp_C": 49.0,
        "min_mhz": 408,
        "peak_mhz": 2400,
        "tested": "2026-08-11T14:40:29Z",
        "run_id": "31500992869"
      "memory": {
        "copy_MBs": 7700,
      "storage": {
        "read_MBs": 63,
        "write_MBs": 55,
      "network": {
        "interfaces": [
            "up_mbits": 941,
            "down_mbits": 942,
            "wireless": false
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1257,
      "board_slug": "orangepi5-plus",
      "device": "Orange Pi 5 Plus 01",
      "last_good_test": "2026-10-06T13:56:28Z",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1259,
        "temp_C": 62.8,
        "min_mhz": 1800,
        "peak_mhz": 2256,
        "tested": "2026-10-06T13:56:28Z",
      "memory": {
        "copy_MBs": 13800,
      "storage": {
        "read_MBs": 62,
        "write_MBs": 54,
      "network": {
        "interfaces": [
            "up_mbits": 2352,
            "down_mbits": 2351,
            "wireless": false
            "up_mbits": 2353,
            "down_mbits": 2315,
            "wireless": false
            "interface": "wlxe0e1a9380c53",
            "up_mbits": 590,
            "down_mbits": 299,
            "wifi_chip": "MediaTek MT7921",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 0.6,
        "avg": 7.38,
        "max": 14.0,
        "samples": 926,
        "series": [
          7.12,
          7.29,
          6.96,
          7.55,
          7.76,
          7.43,
          4.02,
          7.59,
          5.13,
          5.14,
          6.19,
          8.54,
          6.61,
          7.19,
          7.13,
          8.5,
          7.83,
          7.61,
          7.44,
          6.28,
          6.97,
          4.29,
          9.17,
          8.39,
          8.26,
          8.95,
          8.48,
          8.46,
          6.88,
          6.69,
          6.77,
          9.27,
          7.73,
          7.72,
          8.88,
          8.3,
          8.28,
          8.47,
          8.67,
          5.65
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1259,
        "power_min_w": 0.6,
        "power_max_w": 14.0
      "board_slug": "orangepilite2",
      "device": "Orange Pi Lite 2 01",
      "last_good_test": "2026-10-06T09:43:07Z",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 833,
        "temp_C": 73.0,
        "min_mhz": 480,
        "peak_mhz": 1800,
        "tested": "2026-10-06T09:43:07Z",
      "memory": {
        "copy_MBs": 4400,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 21,
      "network": {
        "interfaces": [
            "up_mbits": 6,
            "down_mbits": 3,
            "wifi_chip": "Broadcom BCM43455",
            "wireless": true
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 833,
        "wifi_mbits": 6,
      "board_slug": "orangepioneplus",
      "device": "Orange Pi One+ 01",
      "last_good_test": "2026-10-06T13:52:48Z",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 839,
        "temp_C": 67.5,
        "min_mhz": 480,
        "peak_mhz": 1800,
        "tested": "2026-10-06T13:52:48Z",
      "memory": {
        "copy_MBs": 4600,
      "storage": {
        "read_MBs": 23,
        "write_MBs": 21,
      "network": {
        "interfaces": [
            "up_mbits": 913,
            "down_mbits": 940,
            "wireless": false
            "interface": "wlx00e04c881724",
            "up_mbits": 79,
            "down_mbits": 115,
            "wifi_chip": "Realtek RTL8821AU",
            "wireless": true
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 839,
        "ethernet_mbits": 940,
      "board_slug": "orangepipcplus",
      "device": "Orange Pi PC + 01",
      "last_good_test": "2026-10-01T10:46:10Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/36845139589",
      "image_version": "26.11.0-trunk.65",
      "kernel": "7.2.8-edge-sunxi",
      "cpu": {
        "max_mhz": 1296,
        "aes_MBs": 25,
        "temp_C": 47.9,
        "min_mhz": 480,
        "peak_mhz": 1296,
        "tested": "2026-10-01T10:46:10Z",
        "run_id": "36845139589"
      "memory": {
        "copy_MBs": 2200,
      "storage": {
        "read_MBs": 77,
        "write_MBs": 7,
      "network": {
        "interfaces": [
            "wireless": false
            "up_mbits": 27,
            "down_mbits": 3,
            "wifi_chip": "Realtek RTL8189FS",
            "wireless": true
            "up_mbits": 27,
            "down_mbits": 3,
            "wireless": true
      "summary": {
        "cpu_mhz": 1296,
        "cpu_aes_MBs": 25,
        "wifi_mbits": 27,
      "board_slug": "orangepiprime",
      "device": "Orange Pi Prime 01",
      "last_good_test": "2026-10-06T13:53:25Z",
      "image_version": "26.11.0-trunk.62",
      "cpu": {
        "aes_MBs": 379,
        "temp_C": 44.8,
        "tested": "2026-10-06T13:53:25Z",
      "memory": {
        "copy_MBs": 2100,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 1,
      "network": {
        "interfaces": [
            "up_mbits": 881,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 30,
            "down_mbits": 27,
            "wifi_chip": "Realtek RTL8723BS",
            "wireless": true
      "summary": {
        "cpu_aes_MBs": 379,
        "wifi_mbits": 30,
      "board_slug": "orangepizero2",
      "device": "Orange Pi Zero2 01",
      "last_good_test": "2026-10-06T13:57:53Z",
      "cpu": {
        "max_mhz": 1512,
        "aes_MBs": 705,
        "temp_C": 69.1,
        "min_mhz": 480,
        "peak_mhz": 1512,
        "tested": "2026-10-06T13:57:53Z",
      "memory": {
        "copy_MBs": 3000,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 15,
      "network": {
        "interfaces": [
            "up_mbits": 876,
            "down_mbits": 941,
            "wireless": false
            "interface": "wlx7c023a625db1",
            "up_mbits": 40,
            "down_mbits": 15,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.8,
        "avg": 2.81,
        "max": 4.2,
        "samples": 983,
        "series": [
          2.63,
          2.84,
          2.99,
          2.72,
          2.63,
          3.03,
          2.75,
          2.79,
          2.46,
          2.68,
          2.78,
          2.86,
          2.53,
          3.09,
          2.96,
          2.7,
          3.15,
          2.98,
          3.33,
          2.74,
          2.79,
          2.98,
          2.91,
          2.75,
          2.62,
          2.92,
          2.9,
          2.66,
          2.95,
          2.84,
          3.19,
          2.38,
          2.32,
          2.8,
          2.89,
          2.87,
          2.77,
          2.65,
          2.53,
          3.12
      "summary": {
        "cpu_mhz": 1512,
        "cpu_aes_MBs": 705,
        "wifi_mbits": 40,
        "power_min_w": 1.8,
        "power_max_w": 4.2
      "board_slug": "radxa-cubie-a5e",
      "device": "Cubie A5E 01",
      "last_good_test": "2026-10-06T14:04:00Z",
      "cpu": {
        "aes_MBs": 358,
        "temp_C": 68.7,
        "tested": "2026-10-06T14:04:00Z",
      "memory": {
        "copy_MBs": 2000,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 18,
      "network": {
        "interfaces": [
            "up_mbits": 831,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 940,
            "down_mbits": 940,
            "wireless": false
            "up_mbits": 120,
            "down_mbits": 128,
            "wifi_chip": "AICSemi AIC8800",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 0.7,
        "avg": 4.19,
        "max": 6.6,
        "samples": 2020,
        "series": [
          3.66,
          3.8,
          3.69,
          4.23,
          3.77,
          4.78,
          4.65,
          3.84,
          3.95,
          3.8,
          3.46,
          3.73,
          3.04,
          3.61,
          3.73,
          3.93,
          3.88,
          3.82,
          3.91,
          4.17,
          5.45,
          4.25,
          5.43,
          4.45,
          3.87,
          3.86,
          3.62,
          4.17,
          4.08,
          4.03,
          4.2,
          4.15,
          4.56,
          4.66,
          6.05,
          4.43,
          6.31,
          4.81,
          4.32,
          3.58
      "summary": {
        "cpu_aes_MBs": 358,
        "wifi_mbits": 128,
        "power_min_w": 0.7,
        "power_max_w": 6.6
      "board_slug": "radxa-dragon-q6a",
      "device": "Radxa Dragon Q6A 01",
      "last_good_test": "2026-10-06T10:03:56Z",
      "kernel": "7.2.3-edge-qcs6490",
      "cpu": {
        "max_mhz": 1958,
        "aes_MBs": 1498,
        "temp_C": 44.2,
        "min_mhz": 300,
        "peak_mhz": 2707,
        "tested": "2026-10-06T10:03:56Z",
      "memory": {
        "copy_MBs": 15700,
      "storage": {
        "read_MBs": 1112,
        "write_MBs": 233,
      "network": {
        "interfaces": [
            "interface": "enp1s0",
            "up_mbits": 940,
            "down_mbits": 116,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 0.9,
        "avg": 2.2,
        "max": 8.4,
        "samples": 1371,
        "series": [
          2.3,
          2.39,
          1.77,
          1.9,
          3.14,
          1.96,
          1.79,
          2.05,
          1.87,
          1.89,
          3.25,
          2.27,
          1.97,
          1.79,
          1.75,
          1.94,
          1.83,
          1.74,
          1.9,
          1.88,
          1.74,
          1.83,
          1.83,
          1.77,
          1.71,
          2.34,
          4.13,
          2.72,
          2.11,
          1.91,
          1.86,
          2.41,
          1.84,
          3.13,
          2.21,
          3.8,
          2.99,
          2.78,
          1.86,
          1.7
      "summary": {
        "cpu_mhz": 1958,
        "cpu_aes_MBs": 1498,
        "power_min_w": 0.9,
        "power_max_w": 8.4
      "board_slug": "radxa-zero3",
      "device": "Radxa ZERO 3 01",
      "last_good_test": "2026-10-06T13:45:11Z",
      "image_version": "26.5.1",
      "kernel": "6.18.44-current-rockchip64",
      "cpu": {
        "max_mhz": 1416,
        "aes_MBs": 718,
        "temp_C": 54.4,
        "min_mhz": 408,
        "peak_mhz": 1416,
        "tested": "2026-10-06T13:45:11Z",
      "memory": {
        "copy_MBs": 3900,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 21,
      "network": {
        "interfaces": [
            "up_mbits": 1,
            "down_mbits": 20,
            "wireless": true
      "summary": {
        "cpu_mhz": 1416,
        "cpu_aes_MBs": 718,
        "wifi_mbits": 20,
      "board_slug": "rock-2f",
      "device": "ROCK 2F 01",
      "last_good_test": "2026-09-25T11:26:48Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/36128641860",
      "cpu": {
        "max_mhz": 2016,
        "aes_MBs": 819,
        "temp_C": 47.7,
        "min_mhz": 408,
        "peak_mhz": 2016,
        "tested": "2026-09-25T11:26:48Z",
        "run_id": "36128641860"
      "memory": {
        "copy_MBs": 5900,
      "storage": {
        "read_MBs": 65,
        "write_MBs": 13,
      "network": {
        "interfaces": [
            "up_mbits": 216,
            "down_mbits": 272,
            "wifi_chip": "AICSemi AIC8800D80",
            "wireless": true
      "summary": {
        "cpu_mhz": 2016,
        "cpu_aes_MBs": 819
      "board_slug": "rock-5b",
      "device": "Rock 5B 01",
      "last_good_test": "2026-10-06T14:16:56Z",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1293,
        "temp_C": 56.4,
        "min_mhz": 1800,
        "peak_mhz": 2352,
        "tested": "2026-10-06T14:16:56Z",
      "memory": {
        "copy_MBs": 15600,
      "storage": {
        "read_MBs": 82,
        "write_MBs": 25,
      "network": {
        "interfaces": [
            "up_mbits": 2353,
            "down_mbits": 2354,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 0.8,
        "avg": 4.69,
        "max": 12.9,
        "samples": 1390,
        "series": [
          3.99,
          4.11,
          4.28,
          3.99,
          3.3,
          3.77,
          4.05,
          3.26,
          3.67,
          3.29,
          4.81,
          3.88,
          3.43,
          3.32,
          3.45,
          3.35,
          3.34,
          3.37,
          3.35,
          3.38,
          4.29,
          4.15,
          5.58,
          5.71,
          5.63,
          5.72,
          6.32,
          7.28,
          6.76,
          6.02,
          5.92,
          5.86,
          5.45,
          5.79,
          7.2,
          6.37,
          6.67,
          6.08,
          3.98,
          3.38
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1293,
        "ethernet_mbits": 2354,
        "power_min_w": 0.8,
        "power_max_w": 12.9
      "board_slug": "rock-5b-plus",
      "device": "Rock 5B Plus 01",
      "last_good_test": "2026-10-06T14:02:33Z",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1279,
        "temp_C": 57.3,
        "min_mhz": 1800,
        "peak_mhz": 2304,
        "tested": "2026-10-06T14:02:33Z",
      "memory": {
        "copy_MBs": 13900,
      "storage": {
        "read_MBs": 82,
        "write_MBs": 21,
      "network": {
        "interfaces": [
            "up_mbits": 2349,
            "down_mbits": 2353,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 0.6,
        "avg": 4.83,
        "max": 12.4,
        "samples": 739,
        "series": [
          4.23,
          3.92,
          3.73,
          4.04,
          4.01,
          3.5,
          3.53,
          3.88,
          4.12,
          4.16,
          3.13,
          4.37,
          3.36,
          3.14,
          4.24,
          5.83,
          3.64,
          3.53,
          4.29,
          4.15,
          4.38,
          3.71,
          3.71,
          3.67,
          5.49,
          5.19,
          7.56,
          6.66,
          6.67,
          6.63,
          6.51,
          5.16,
          4.22,
          6.43,
          8.26,
          6.84,
          6.81,
          6.77,
          6.38,
          3.67
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1279,
        "power_min_w": 0.6,
        "power_max_w": 12.4
      "board_slug": "rock-5t",
      "device": "Rock 5T 01",
      "last_good_test": "2026-10-06T09:54:35Z",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 1252,
        "temp_C": 57.3,
        "min_mhz": 408,
        "peak_mhz": 2400,
        "tested": "2026-10-06T09:54:35Z",
      "memory": {
        "copy_MBs": 10000,
      "storage": {
        "read_MBs": 77,
        "write_MBs": 51,
      "network": {
        "interfaces": [
            "up_mbits": 2349,
            "down_mbits": 2328,
            "wireless": false
            "up_mbits": 2353,
            "down_mbits": 2354,
            "wireless": false
            "interface": "wlP2p33s0",
            "up_mbits": 114,
            "down_mbits": 93,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.8,
        "avg": 7.94,
        "max": 15.0,
        "samples": 559,
        "series": [
          8.61,
          8.36,
          8.94,
          8.91,
          5.81,
          5.78,
          8.96,
          6.14,
          8.19,
          3.27,
          8.44,
          10.64,
          8.44,
          8.86,
          8.57,
          8.66,
          8.29,
          8.46,
          8.29,
          8.76,
          7.59,
          6.91,
          5.79,
          5.39,
          8.52,
          10.48,
          8.37,
          8.79,
          8.81,
          7.85,
          8.97,
          8.26,
          8.35,
          8.49,
          8.35,
          8.83,
          8.3,
          4.46,
          6.77,
          7.84
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 1252,
        "wifi_mbits": 114,
        "power_min_w": 1.8,
        "power_max_w": 15.0
      "board_slug": "rockpi-e",
      "device": "Rockpi E 01",
      "last_good_test": "2026-10-06T14:08:10Z",
      "cpu": {
        "max_mhz": 1296,
        "aes_MBs": 600,
        "temp_C": 63.3,
        "min_mhz": 408,
        "peak_mhz": 1296,
        "tested": "2026-10-06T14:08:10Z",
      "memory": {
        "copy_MBs": 3300,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 21,
      "network": {
        "interfaces": [
            "up_mbits": 940,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 94,
            "down_mbits": 94,
            "wireless": false
            "interface": "wlx7ca7b020e87c",
            "up_mbits": 127,
            "down_mbits": 188,
            "wireless": true
      "summary": {
        "cpu_mhz": 1296,
        "cpu_aes_MBs": 600,
      "board_slug": "rockpi-s",
      "device": "Rockpi S 01",
      "last_good_test": "2026-10-05T22:37:55Z",
      "cpu": {
        "max_mhz": 1008,
        "aes_MBs": 219,
        "temp_C": 51.2,
        "min_mhz": 408,
        "peak_mhz": 1008,
        "tested": "2026-10-05T22:37:55Z",
      "memory": {
        "copy_MBs": 1300,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 21,
      "network": {
        "interfaces": [
            "up_mbits": 94,
            "down_mbits": 94,
            "wireless": false
            "up_mbits": 6,
            "down_mbits": 6,
            "wifi_chip": "Realtek RTL8723DS",
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.0,
        "avg": 1.46,
        "max": 2.8,
        "samples": 1361,
        "series": [
          1.31,
          1.28,
          1.59,
          1.45,
          1.42,
          1.41,
          1.3,
          1.65,
          1.46,
          1.4,
          1.38,
          1.4,
          1.58,
          1.42,
          1.49,
          1.36,
          1.63,
          1.44,
          1.34,
          1.46,
          1.54,
          1.32,
          1.64,
          1.44,
          1.4,
          1.42,
          1.4,
          1.49,
          1.52,
          1.49,
          1.29,
          1.69,
          1.44,
          1.41,
          1.65,
          1.44,
          1.45,
          1.41,
          1.35,
          1.61
      "summary": {
        "cpu_mhz": 1008,
        "cpu_aes_MBs": 219,
        "wifi_mbits": 6,
        "power_min_w": 1.0,
        "power_max_w": 2.8
      "board_slug": "rockpro64",
      "device": "RockPro 64 01",
      "last_good_test": "2026-10-06T14:10:40Z",
      "cpu": {
        "max_mhz": 1416,
        "aes_MBs": 1021,
        "temp_C": 51.1,
        "min_mhz": 408,
        "peak_mhz": 1800,
        "tested": "2026-10-06T14:10:40Z",
      "memory": {
        "copy_MBs": 6600,
      "storage": {
        "read_MBs": 118,
        "write_MBs": 64,
      "network": {
        "interfaces": [
            "up_mbits": 941,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 94,
            "down_mbits": 104,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 3.0,
        "avg": 4.7,
        "max": 9.3,
        "samples": 1189,
        "series": [
          4.67,
          4.69,
          5.14,
          4.49,
          4.63,
          5.09,
          4.23,
          4.98,
          4.79,
          5.04,
          5.1,
          5.1,
          5.1,
          5.1,
          4.41,
          4.52,
          4.6,
          5.27,
          4.4,
          4.71,
          4.53,
          5.72,
          5.05,
          5.14,
          5.2,
          5.2,
          5.2,
          5.2,
          4.92,
          4.3,
          4.0,
          4.15,
          4.96,
          3.56,
          4.29,
          3.7,
          4.11,
          4.25,
          4.15,
          4.29
      "summary": {
        "cpu_mhz": 1416,
        "cpu_aes_MBs": 1021,
        "wifi_mbits": 104,
        "power_min_w": 3.0,
        "power_max_w": 9.3
      "board_slug": "rpi4b",
      "device": "Raspberry Pi 3B",
      "last_good_test": "2026-10-06T14:08:51Z",
      "kernel": "7.2.9-edge-bcm2711",
      "cpu": {
        "max_mhz": 1200,
        "aes_MBs": 24,
        "temp_C": 56.4,
        "min_mhz": 600,
        "peak_mhz": 1200,
        "tested": "2026-10-06T14:08:51Z",
      "memory": {
        "copy_MBs": 1400,
      "storage": {
        "read_MBs": 22,
        "write_MBs": 20,
      "network": {
        "interfaces": [
            "interface": "enxb827eb253a53",
            "up_mbits": 94,
            "down_mbits": 94,
            "wireless": false
            "up_mbits": 15,
            "down_mbits": 29,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 3.2,
        "avg": 6.37,
        "max": 10.6,
        "samples": 657,
        "series": [
          6.01,
          5.69,
          5.88,
          7.62,
          8.05,
          5.81,
          6.56,
          6.97,
          4.44,
          4.98,
          6.62,
          4.88,
          6.24,
          5.74,
          6.04,
          7.96,
          6.51,
          5.98,
          6.91,
          5.91,
          5.76,
          7.92,
          6.54,
          6.55,
          6.12,
          5.65,
          5.24,
          7.27,
          7.51,
          6.33,
          6.65,
          5.78,
          6.31,
          5.93,
          6.3,
          8.91,
          6.26,
          6.98,
          6.3,
          5.51
        "tested": "2026-10-06T13:54:58Z",
      "summary": {
        "cpu_mhz": 1200,
        "cpu_aes_MBs": 24,
        "wifi_mbits": 29,
        "power_min_w": 3.2,
        "power_max_w": 10.6
      "board_slug": "tinkerboard",
      "device": "Tinker Board 01",
      "last_good_test": "2026-10-06T14:02:28Z",
      "kernel": "7.3.0-rc6-edge-rockchip",
      "cpu": {
        "max_mhz": 1800,
        "aes_MBs": 67,
        "temp_C": 65.0,
        "min_mhz": 600,
        "peak_mhz": 1800,
        "tested": "2026-10-06T14:02:28Z",
      "memory": {
        "copy_MBs": 3300,
      "storage": {
        "read_MBs": 63,
        "write_MBs": 13,
      "network": {
        "interfaces": [
            "up_mbits": 940,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 25,
            "down_mbits": 24,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.3,
        "avg": 3.84,
        "max": 7.9,
        "samples": 794,
        "series": [
          3.53,
          3.71,
          4.2,
          3.75,
          4.53,
          3.61,
          4.63,
          4.02,
          2.88,
          3.67,
          4.85,
          3.22,
          3.87,
          2.94,
          3.39,
          4.4,
          5.49,
          3.5,
          3.1,
          2.93,
          2.74,
          4.2,
          3.86,
          3.8,
          3.91,
          4.29,
          4.41,
          3.33,
          3.65,
          3.01,
          4.51,
          4.12,
          4.57,
          4.18,
          3.89,
          4.22,
          4.28,
          4.01,
          3.06,
          3.4
      "summary": {
        "cpu_mhz": 1800,
        "cpu_aes_MBs": 67,
        "wifi_mbits": 25,
        "power_min_w": 1.3,
        "power_max_w": 7.9
      "board_slug": "udoo",
      "device": "Udoo 01",
      "last_good_test": "2026-10-05T18:15:36Z",
      "run_url": "https://github.com/armbian/autotests/actions/runs/37343138770",
      "cpu": {
        "max_mhz": 996,
        "aes_MBs": 26,
        "temp_C": 54.9,
        "min_mhz": 396,
        "peak_mhz": 996,
        "tested": "2026-10-05T18:15:36Z",
        "run_id": "37343138770"
      "memory": {
        "copy_MBs": 756,
      "storage": {
        "read_MBs": 20,
        "write_MBs": 13,
      "network": {
        "interfaces": [
            "up_mbits": 400,
            "down_mbits": 235,
            "wireless": false
            "interface": "wlx7cdd903aa418",
            "up_mbits": 33,
            "down_mbits": 9,
            "channel_mhz": 2412,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 1.3,
        "avg": 5.53,
        "max": 8.5,
        "samples": 2467,
        "series": [
          6.09,
          6.1,
          5.94,
          6.13,
          5.69,
          6.05,
          5.93,
          6.25,
          5.73,
          5.07,
          5.02,
          5.02,
          5.0,
          5.04,
          5.03,
          5.02,
          5.0,
          5.98,
          6.14,
          6.03,
          5.72,
          5.76,
          6.13,
          5.7,
          6.05,
          5.41,
          4.99,
          5.02,
          5.01,
          5.02,
          4.99,
          5.0,
          5.02,
          5.03,
          5.03,
          5.13,
          6.16,
          5.97,
          6.22,
          5.55
      "summary": {
        "cpu_mhz": 996,
        "cpu_aes_MBs": 26,
        "ethernet_mbits": 400,
        "power_min_w": 1.3,
        "power_max_w": 8.5
      "board_slug": "uefi-arm64",
      "device": "UEFI arm64 01",
      "last_good_test": "2026-10-06T14:07:27Z",
      "kernel": "7.2.9-edge-arm64",
      "cpu": {
        "max_mhz": 2600,
        "aes_MBs": 1402,
        "temp_C": 47.0,
        "min_mhz": 800,
        "peak_mhz": 2600,
        "tested": "2026-10-06T14:07:27Z",
      "memory": {
        "copy_MBs": 13000,
      "storage": {
        "read_MBs": 2099,
        "write_MBs": 1576,
      "network": {
        "interfaces": [
            "up_mbits": 7851,
            "down_mbits": 2638,
            "wireless": false
            "interface": "enp49s0",
            "up_mbits": 6834,
            "down_mbits": 9242,
            "wireless": false
            "interface": "wlp97s0",
            "up_mbits": 91,
            "down_mbits": 60,
            "wireless": true
      "summary": {
        "cpu_mhz": 2600,
        "cpu_aes_MBs": 1402,
        "ethernet_mbits": 9242,
        "wifi_mbits": 91,
      "board_slug": "uefi-x86",
      "device": "UEFI x86 01",
      "last_good_test": "2026-10-06T14:18:50Z",
      "kernel": "7.2.9-edge-x86",
      "cpu": {
        "max_mhz": 1920,
        "aes_MBs": 237,
        "temp_C": 66.0,
        "min_mhz": 480,
        "peak_mhz": 1919,
        "tested": "2026-10-06T14:18:50Z",
        "run_id": "37469960611",
        "dvfs_tested": "2026-06-26T06:30:52Z",
        "dvfs_run_id": "28219975764"
      "memory": {
        "copy_MBs": 5200,
      "storage": {
        "read_MBs": 99,
        "write_MBs": 19,
      "network": {
        "interfaces": [
            "up_mbits": 893,
            "down_mbits": 941,
            "wireless": false
            "up_mbits": 36,
            "down_mbits": 32,
            "wireless": true
      "power": {
        "unit": "W",
        "min": 2.3,
        "avg": 3.84,
        "max": 7.9,
        "samples": 1538,
        "series": [
          3.36,
          3.95,
          4.02,
          3.95,
          3.07,
          2.88,
          2.74,
          2.71,
          2.77,
          2.85,
          2.91,
          4.44,
          3.97,
          4.01,
          4.22,
          4.04,
          4.01,
          4.92,
          4.07,
          4.93,
          4.2,
          4.48,
          4.39,
          3.45,
          3.62,
          3.68,
          3.94,
          4.0,
          3.95,
          5.05,
          4.68,
          3.88,
          3.59,
          3.38,
          3.68,
          3.8,
          3.85,
          4.12,
          3.57,
          4.56
      "summary": {
        "cpu_mhz": 1920,
        "cpu_aes_MBs": 237,
        "wifi_mbits": 36,
        "power_min_w": 2.3,
        "power_max_w": 7.9
      "board_slug": "zeropi",
      "device": "ZeroPi 01",
      "last_good_test": "2026-10-06T14:09:22Z",
      "cpu": {
        "max_mhz": 1296,
        "aes_MBs": 25,
        "temp_C": 48.8,
        "min_mhz": 480,
        "peak_mhz": 1296,
        "tested": "2026-10-06T14:09:22Z",
      "memory": {
        "copy_MBs": 1500,
      "storage": {
        "read_MBs": 23,
        "write_MBs": 21,
      "network": {
        "interfaces": [
            "up_mbits": 638,
            "down_mbits": 938,
            "wireless": false
      "power": {
        "unit": "W",
        "min": 1.2,
        "avg": 2.14,
        "max": 3.4,
        "samples": 1062,
        "series": [
          1.95,
          1.99,
          2.15,
          2.09,
          2.08,
          2.09,
          1.93,
          2.59,
          2.14,
          2.13,
          1.92,
          2.19,
          2.31,
          2.13,
          2.0,
          2.02,
          2.27,
          2.04,
          2.32,
          2.15,
          2.14,
          2.06,
          2.1,
          2.11,
          2.11,
          2.14,
          2.12,
          2.17,
          2.41,
          2.08,
          2.41,
          2.2,
          2.42,
          2.15,
          2.21,
          2.11,
          2.1,
          2.1,
          1.94,
          2.05
      "summary": {
        "cpu_mhz": 1296,
        "cpu_aes_MBs": 25,
        "power_min_w": 1.2,
        "power_max_w": 3.4
